morpheus620
Android-Guru
- 2.716
EdleRatte schrieb:Die List View Animationen sind auch geil![]()
Ist aber geklaut von MoKee OS
Originally Posted by kufikugel
the menu button at all is completly depreciated and will be removed from google completly. That google left it dynamically is just because of the fact that some apps still not changed to Holo style.
Holo guidelines clearly say use the action bar for the menu. If an app does this it makes absolutly no sense to have a menu button due that the menu button is on the bottom (navbar)....and the action bar on the top where the menu opens even if you push the menu button on navbar pie or whatever.
Other then that you still have the possibility to show the menu button permanently
morpheus620 schrieb:Ist aber geklaut von MoKee OS![]()
amo66 schrieb:Ich brauche ihn nicht, wenn die einen den brauchen um glücklich zu werden, sollen sie sich ne andere Rom suchen.
