1907
Ehrenmitglied
- 1.205
Hast du beim hin und her Flaschen zwischen den Roms wipe data/factory reset gemacht, oder nur wipe cache und dalvik cache?
ysoserious schrieb:Kann mal wer bitte ein sreenshot vom tabletUI Hochladen?
Gesendet von meinem Nexus 10 mit der Android-Hilfe.de App
-- Fix CustomToggle Actions as well
-- Ribbon use updated getArray / putArray
-- Make menu item title and help text consistent
-- CustomToggle Improvements
-- Add turn off action to WiFi Tether notification
-- aokpclock: clock hands based on unicorn horns!! and 2 new dials
-- (Updated busybox to latest)
-- (Updated and forked openssl)
-- Avoid NullPointerException
-- FW: Navring ShouldUnlock method
-- RC: Ribbon fix reset method derp
-- Ribbons - Long swipe App window
So who wants to try out the Dark UI? Pre-release build.
Go to Settings, Flip the switch to turn on Dark UI.
Currently it will apply darkness to the following:
- Settings
- Contacts
- MMS
- Calculator
- Phone
- Gallery
Obviously not all apply to this tablet.
AOKP are porting in TRDS from SlimRoms. Details on this HERE.
Give it a shot,
buttered_aokp_manta_2013-05-08.zip
