[ROM] AOKP Nexus 10 Task650 & Ktoonsez (23.04.2013)
  • 25 Antworten
hanspampel
hanspampel
Ehrenmitglied
9.863
Und hier passend zum Manta Kernel noch das entsprechende ROM auf AOKP Basis. Erstellt hat es der Dev Task650. Ich kenne ihn noch zu GTab 10.1 Zeiten. Dort fanden seine ROMs im regen Anklang. Leider kam ich nie in den Genuss da er nur für WiFi-only Tabs bastelte. Nun ists zwar auch so, aber ich kanns dann endlich mal flashen. Muss nur noch mein Tab kommen.:drool:
Ktoonsez & I wanted to bring you guys some AOKP releases to the Nexus 10.​
A Big Thanks Goes to the AOKP Team & CyanogenMod Team. Without their source this wouldn't be possible. Go thank them, tweet them, and donate to them. Also a HUGE thanks to mrgoat for the hosting!!!​
If you have any problems after flashing this ROM read the line below...
Preemptive Task650 answer - "Full wipe and reflash, now F*ck off" *jthatch12*​
Changelog
AOKP Jellybean 23.4.2013
Updated Kernel
Updated to latest Nova Launcher
Gapps package updated to latest everything (Make sure to download it!)
RAM Bar View optimizations
Added AOKP Ribbons (ROM Control/Ribbons)
Lockscreen Targets Speed Optimizations
cLock Updates
Added Block Private Numbers To Blacklist Options
Toggles are in alphabetical order now
Fixed recents minimization animation
Fixed Potential FC on Hiding NavBar
Animate Transparency changes. (Instead of the white block in the status bar when switching between apps, it now look like a fade transition.)
SystemUI: fix memory leaks
Fixed Signal toggle layout
Made the HSPA+ drawables more consistent with the HSPA drawables
Fixed Screen Sizing for TabUI when HiddenNav Enabled
Added Transparency for TabletUI
Added Blacklist Options (Phone/Settings)
Brought Swagger toggle back
Added LongClick to FastCharge Toggle
Added Trickster Mod to Settings (This replaces Performance Control)
Fixed cursor leak in Email
Don't clear wallpaper when SystemUI disconnects
Fixed apps from crashing
Fixed cLock
Allow enabling WebSockets from Labs Preferences in Broswer (HTML5)
Lockscreen: adjust layout of GlowPad
Fixed NavRing Icon size
Fixed potential deadlock between LockScreen and WindowManagerService
Updated Vibration Patterns
Fixed a cursor leak
Fixed a race condition in backlight adjustment
I'm sure there's more I'm missing....
Ältere Changelogs
AOKP Jellybean 1.4.2013
Updated Kernel
Added Statusbar/Navbar transparency Added option to hide AlarmClock Icon in StatusBar
Added option to allow users to disable safe headset volume warning
Added option to hide Adb notification icon
Added optimized browser interface for tablets
Added option to hide Adb Notification icon
Fixed IME overlapping fields while typing in certain situations
Fixed JPEG file indexing
Added code to fix possible memory leaks by ensuring stream closures
Probably more that I've missed. Just check out AOKP Gerrit if you want to know more.[/B]
AOKP Jellybean 12.14.2012
Updated Kernel (Linux 3.4.23 and other updates)
Youtube App works now (Thanks to the update ;) )
Allow transfer all files via Bluetooth (The craiggomez for pointing me in the direction)
Favorite Contact added to Quicksettings
VeNum optimizations to libpng to improve PNG decode time
Fixed App & Widget Pickers.
Added IME Toggler Updated AOKP Clock Widget
Probably more. No time right now. ;)
AOKP Jellybean 12.4.2012
Updated binaries & other proprietaries
Updated Kernel to 3.4.21 along with other updates
More Rom Control Option (Nav Bar Toggle, Nav Bar Widgets, ect... Just llok around a little. ;) )
WiFi Icon now Shows in the Quick Settings
NFC Toggle Fixed (No more Force Close)
LED Options are back
Allows for Overclocking now (Unnecessary now but oh well. ;) )
Nav Bar Updates
Link Volume States Added
NFC Polling Options Added
Probably more
YouTube app is still not working (Working on it now. It'll be fixed in the next release. :D )
AOKP Jellybean 11.27.2012
Added Selectable tiles (Look in ROM Control/Statusbar Toggles. Enable/Disable tiles, Toggle Order, and Toggles per row options.)
OTG Support
Added Notification sound-to-vibration conversion toggle (Look in Settings/Sound for the toggle)
More Lockscreen Options (Lockscreen Text Color, Battery Percentage, ect...
Update kernel to Linux 3.4.11
Nav Bar button Actions/Longpress Actions work correctly. (Still working on the portrait quirks and Ring Targets.)
Implemented out OTA System now. (You have to update to this release first. Then you will be able to use it.)
There's probably more. But I'm tired and going to sleep for the night and don't care. ;)
AOKP Jellybean 11.25.2012
Initial Release
Downloads
Task & Ktoonsez AOKP
NEW!!!
AOKP Jellybean Build 23.04.2013
Download HERE
Mirror
Download HERE
Gapps
Kernels
_______________________________________________________________________________________________[/COLOR]
[/COLOR]
These guys spend countless of hours doing this for next to nothing. Posts, views, and donations encourage them, and everyone else who helps out.
Donate to Romanb here
Donate to Whitehawkx here
Donate to Zaphod-Beeble here
Donate to ProTekk here
Donate to Sethyx here
Donate to Cyanogen here
Check out the ROM source ( https://github.com/AOKP ) on github. Open source, in the spirit of community kangage.
Quelle
Kann man über dieses ROM bei HDMI-Betrieb das Display abschalten?
Kann ich dir leider nicht beantworten. Warte noch auf mein N10.
Hallo, kann jemand Erfahrungen über diese ROM berichten?
Ich würde gerne erst lesen und dann flashen ;-))
Im Augenblick kann ich die Vorteile nicht so richtig erkennen
bzw. abschätzen. Pluspunkt wäre, muss ich aber noch selber testen,
das man via autopatcher openpdroid patchen kann (?).
hi watcherlein
ich habe in den letztem tagen 5 oder 6 verschiedene roms getestet. dieses gefällt mir mit abstand am besten.
hi
hab zurzeit die official aopk drauf..
gibts eine möglichkeite ohne meine apps/einstellungen zu verlieren, auf diese rom umzusteigen?
Reaktionen: SpeedyRS2
hi
du kannst deine apps und einstellungen mit titanium backup sichern, bevor du umsteigst. trotzdem würde ich im recovery das komplette image sichern, bevor du umsteigst.
wenn du dann das neue rom aufspielst, dann kannst du es ja erstmal ohne fullwipe versuchen. nur cache und dalvik cache wipen, dann rom und gapps installieren. dann bleiben alle apps und daten erhalten!
So hab mir das ROM gestern auch mal installiert. Zu Anfangs hatte ich erst das PA ROM installiert, aber das habe ich dann nach ner Stunde wegen andauernder Grafik Fehler und schlechter Performance wieder runter geschmissen um mich dann ganz diesem hier zu widmen.
Läuft soweit ganz gut ohne größere Probe. Gott sei dank hat man dem ROM auch die Tablet UI spendiert. Sieht zwar nicht so gut aus wie beim PA, wird aber sicher noch. Hat Task650 ja selber gesagt das es noch nicht optimal ist. Dafür verwöhnt die Tablet UI ein besseres Feeling beim Scrollen der Homescreens. Das N10 ist zwar nicht gerade schwach auf der Brust, aber, wie bei meinem GTab 10.1, bringt auch die alte Tablet UI eine bessere Performance.
Geil finde ich den "Animation Manager". Dort hat man die Auswahl aus zig neuen Animationen. Dabei wird einen neue SystemUI generiert die dann wahlweise per CWM geflasht werden kann.:thumbsup: Sieht mal richtig nice aus.
Beim Kernelvon Ktoonsez ist der Audiofix über HDMI schon implementiert, hier nun auch der Fix des Kernels von Task650. Sol wohl funzen, kanns aber selber nicht testen da ich kein Kabel habe.
*edit*
Servus zusammen,
Ich brauch eure Hilfe, nachdem ich mit dieser Rom, in Verbindung mit dem Ktmanta Kernel eigentlich Mega gute Akku Laufzeiten hatte, (screen on time bis zu 11 Stunden) ist es die letzten beiden Akkuladungen irgendwie schlechter geworden. Ich komme mit Mühe auf 7 Stunden Screen on.
Ebenfalls hab ich einen Akku drain wenn das Gerät zu 100% im deep sleep ist. Heute Nacht habe ich in 8 Stunden 4% verloren, aber trotz Flugmodus und Synchronisation aus.
Sonst lag der drain über Nacht bei höchstens einem Prozentpunkt.
Inzwischen habe ich zwar 3-4 Apps mehr drauf sowie ein case aber ich kann mir nicht vorstellen dass es daran liegt.
Hat jemand einen Lösungsansatz? Vielleicht die Rom wechseln?
Gesendet von meinem Nexus 10 mit Tapatalk 2
@s0'addicted
Das ist denke ich normal ... zumindest bei mir war das so ... nach mehreren LAdezyklen hat sich das wieder eingependelt ...
Kannst auch mal deine Bat Stats wipen nach dem aufladen ... sollte eventuell auch Helfen ...
ALso würde ich erst mal abwarten (ca. ne Woche) danach mal sehen wie sich der Akku verhält ...
Reaktionen: s0'addicted
Mh hab ich auch gedacht aber bin am zweifeln. Ich hab mir zwischenzeitlich die 2 letzten CM10.1 nightlys geflasht und den Stock cm Kernel gelassen, damit hatte ich wirklich kaum Akku drain. Vllt. Probiere ich es bald nochmal mit der AOKP von task650 wenn er ein update raushaut.
Grade hab ich cm 10.1 mit ktmanta Kernel drauf und habe wieder Akku drain im deep sleep :D
Versuch doch mal den Franco-Kernel R7. Den nutze ich derzeit weil ich damit keine Probs habe. Der KTManta zickt auf meinem Tab nur rum. Man kann ihn zwar nicht übertakten, aber dafür läuft es echt wie Butter.
hat wer den aktuellen build drauf ?
und @hans : kann man bei der ROM wie bei PA die NAVBAR färben?
oder aht da sonst jmd ahnung?
Jo die Farben kannste ändern. Sowohl die der Navkeys als auch der schwarze Hintergrund. Würde dir aber raten nicht uzm offiziellen AOKP zu gehen. Die laufen zwar recht gut, aber nicht annähernd so gut wie die PUB Builds mit Linaro Anpassungen.
Und was ist mit dieser Rom? :-D
Könntest du mir mal bitte eine pm mit dem thread schicken den du meinst?
Gesendet von meinem Nexus 10 mit der Android-Hilfe.de App
Ich habe es noch nicht drauf, aber nutze meistens seine Builds.
Klick mich
Mache dann ne Thread dafür auf wenn er soweit ist. Will noch ein paar Sachen einbauen. Deswegen hat er noch keinen Thread.
So Task650 hat dann nun sein AOKP Build auch in die Android 4.2.2 Ebene gehievt. Fullwipe ist Pflicht wer von 4.2.1 kommt.
Wurde mal gern ein testvideo mit den features usw sehen :-$
  • reticulum
Jonas38
  • steiner.seevetal
steiner.seevetal
PPM-Droid
PPM-Droid
PPM-Droid
