[ROM] JBSourceryV5.4-GSM Encore FINAL RELEASE
  • 447 Antworten
thunder-md
thunder-md
Aktuell: JBSourcery V5.4-GSM Encore FINAL RELEASE
Laut Eagel1967 ist dies leider die letzte Version von JBSourcery, es sollen nur noch eventuelle Fehler beseitigt werden:
Thanks for the great times!
Please assist others with problems.
Please post issues with tool mods or apps in tools we will fix those.
Sourcery code is complete and wont be changed any further.
Original XDA Thread
Download JBSourceryV5.4-GSM Encore FINAL RELEASE
GPS-Fix Europa von Dirk64 :thumbup:
Gapps--WHITE MAGIC--basic gapps not black magic enabled. These will update in market! (this has not changed from 5.3)
Download White Magic Gapps for 5.4 Encore
Gapps--BLACK MAGIC--Gapps that are Black Magic enabled-Preferred Gapps for Verison 5.4 Encore These are modified Gapps and will not all update through market. But are white until you turn on Black Magic.
Download Black Magic Gapps for 5.4 Encore
Please follow these instructions
  1. Download Rom and Gapps to your Phone’s Storage drive and boot into recovery
  2. Clear davlik cache
  3. Wipe data/cache
  4. Install your Chosen Team Sourcery Rom
  5. Install Gapps
  6. Boot into Rom
  7. Sign in and wait for all market apps to Restore
  8. After market apps have restored Reboot again
  9. Make a backup
  10. Enjoy
Mitglieder bei Team Sourcery:
Eagle1967
DeVortEx
Chizzele
T-dev
Alastrionia
JohnnyB15613
atreyu381
Bigralphn
Kontakt zum Team Sourcery
E-Mail: icsourcery@gmail.com
Twitter: @icsourcery
IRC: #sourcery
Web: teamsourcery.com
Screenshots
Einstellungen:
JBSourcery Tools:
Features in JBSourcery:
FIXED in ENCORE Version (This is the final Version of Sourcery)
  • fixed white on white in mms and people with white magic
  • improvements to status bar text sizing
  • black magic (Slim TRDS) updated to version 2
  • switched to koush super user(Jboyer wanted it i guess)
  • added option for lock screen circle flashlight setting in lockscreen
  • reverted dpi to old way-this fixes some apps being oversized cutting off options and such.
  • more blue tooth adjusments
  • various other fixes.
JBSourcery 5.3 Change Log
  • Pie redone
  • Magic Shortcuts(aokp ribbon) change font and image size in status bar
    (cm clock is pushed up-couldnt fix sorry)-feature worth the couple bad things it caused.
  • dpi changing switched to pa method , Appears to be working fine
    (although some dev report problems i havent seen them think maybe with different devices)
  • Tools redone -system ui restart slower but more stable. Still need a reboot occasionally but more rare.
  • keyboard adjustments in magic ui section
  • Black Magic--(Slims inverted instant theming)
  • more toggles than you can shake a stick at (40)
  • Cm power widget option added.(works great to set just the audio playing features above the toggles)
  • Auto hide of status bar
  • redone expanded desktop(must set in power menu before the toggle works)
  • many memory leak fixes
  • source updated to 4.2.2_r1.2
  • blue tooth fixes again (yeah right) i already see s4 complaints of bluetooth with the 4.2.2 on it )
  • univerted mms and contacts stock(people app is white on white without black magic-Couldnt fix it)
  • MMS is whit eon whit also in messaging but you can change this in the theming section.
  • Camera-added ability to trigger shutter by voice, timer setting and a few other additions/fixes.
  • New Kernel by Buck- We have found Lean runs very well with the rom also if you prefer.
  • Permission manager-look in settings toward bottom- change permissions on any app-(be careful)
  • black list now back in phone app
  • many speed and memory enhancements.
JBSourcery 5.2 Change Log
  • NavBar, NavRing,Toggle’s redone
    –Note some funtions in these areas reverted due to rebuild
  • New Kernel-Faster, closing apps fixed
  • Tons of fixes from aokp,slimrom,xyaosp,Google alternate signal layout
  • updated the sourcery dashclock with latest source
  • Sourcery tools update-faster, large data usage decrease.
  • contacts change color of numbers/symbols
  • New theming in tools for contacts
  • removed trickstermod-gnexuspart/performace apps added
  • BlackList in phone app
  • ability to dismiss missed calls
  • mms-fixed unreadable text
  • Bean picker more integrated into the rom for easier use
    –for those that like Johnny’s great tool here
  • MagicClock redone and working again
  • wifi-allow change country codes,adhoc(ibbs),frequency selection
  • Tons and tons of patching, performance enhancements, bug fixes.
Version 5.2 has been reworked and rebuilt and we feel you will see the difference!
JBSourcery 5.1 Change Log
  • Apollo Music App removed
  • Pie improvements
  • DashClock-Sourcerized
  • DashClock-tools extension
  • LTE connection reporting improvements.
  • fixed fc in security settings
  • New kernel-Based off BuckMarble Source
  • all Binaries updated
  • wake lock issues fixed
  • PGM Support
  • App updates
  • New gapps at release site
  • Hopefully(fixed reboots )
  • changes to allow koushes superuser to work-MarcLandis
  • DeskClock improvements
  • Blue tooth improvements(???) heard this one before
  • Stability improvements and memory usage improvements
Note:
Browser reverted to stock browser for this release.
MMS-theming options are removed.
We will get you an alternative but due to requests from our themers to offer you what they mean too this has been removed.
You may pull the one from inverted gapps if you wish.
DO NOT PULL FROM 5.0 THAT ONE WAS BAD!!!
JBSourcery 5.0 Change Log
  • Based on Android 4.2.2
  • New toggles -quick record ability for left -right quick pulldown and pull down toggles when no notifications
  • CRT on/off aniomation control
  • Camera-added software HDR –swipe to gallery (aosp does not have photosphere)
  • phone-flip to dismiss or silent
  • increasing alarm clock volumes-
  • NavBar Hide — improvements
  • Contacts-add call statistics improvements-
  • Changed navbar and status bar transparency and color
  • security settings redone with addition slide lock before secure lock-
  • Back light curve adjustments
  • Pie controls
  • 4.2.2 Kernal based off Buck Marbles work
  • Tons of fixes from android github
  • speed tweaks
  • memory leak fixes
Tools additions
  • search light-animated pulldowns.
  • DashClock Widget included thanks to Roman Nurik
  • Notification Widget-Lior Tamam
  • SuperSU updated to 1.10 - ChainFire
Reaktionen: Radagast, tabaluga1981, qu4nd und 2 andere
Yes, endlich hat es jemand vorgestellt! Habe es gestern schon verlinkt...würde aber gelöscht. Läuft absolut flüssig, stabil und die einstellmöglichkeiten sind der knaller! Auch die Möglichkeit aus der rom heraus Kernel, themes, apps die. Zu flashen finde ich klasse! Einen Mangel gibt es aber, und der ist schon wichtig...momentan kein gps verfügbar. Soll aber wohl bald behoben werden...Und dank der integrierten Updates....
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
GPS geht bei mir, ich hab aber sofort ein Update bekommen und auch die gps.conf geändert. Die ROM gehört auf jeden Fall angepinnt, mit diesen Einstellungsmöglichkeiten ist sie einmalig. Man muss fast nichts mehr selbst machen, es gibt zig Veränderungen die man zur Auswahl hat. Bleibt drauf als Daily, mal sehen ob's relevante Schwächen gibt.
Sent from GNex...
Nach Update auf 1.3 funktioniert jetzt wirklich alles!
Klasse ROM!
Jetzt kann mich nur noch das ras ROM zum Wechsel bringen ;)
Aber sie ist nicht multilingual, oder? Oder findet sich der Hinweis ohnehin irgendwo ...
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
Mit der app morelocale ist die Sprache kein Thema!
Der 35er 307 trinity Kernel läuft übrigens hervorragend mit der ROM!
Kann wirklich behaupten das es die momentan wohl beste ROM auf den Markt ist. Die lässt wirklich keine Wünsche offen!
Einfach die beta2 flashen, einrichten, ota Update auf 1.3 machen und trinity flashen! Die einstellmöglichkeiten sind einfach der Knüller... alleine ca. 50 verschieden nav bars, toogles usw.
Reaktionen: kosmogon
Wieso nicht multilingual? Hab ich was anderes drauf? Ich hab die Public beta 2 und meine Einstellung ist deutsch (Na ja, nicht alles). Was in der Beschreibung steht, stimmt...GSMUsers, you've never seen a ROM like this.
Sent from GNex...
Die Beta 2 ist Multi! Aber installiere dir trotzdem die morelocale app..dann ist alles auf deutsch!
Klasse ROM!
Ich hab das fix aus der ROM, nach Ca.3sec. Funktioniert's...
[/SIZE]
Der steht auf North-America aber wenn's bei Dir geht, auch gut. Bei mir war der Fix eher schlecht.
Hier nochmal als zip:
http://db.tt/gXFmp9al
Sent from GNex...
Reaktionen: westwood
Hm, das versteh ich dann aber nicht....wo sehe ich denn auf was es steht?!
Also unter gebietsschema habe ich de.stehen...
Allerdings gab ich festgestellt das mein Standort nur auf 2200m festgestellt werden kann (ohne GPS)
Schau mal in die gps.conf
EDIT: Bei mir schwankt der Fix um 10-15 Meter.
Sent from GNex...
Beste Rom zZ :love: . Hatte die erste Version installiert, wo leider GPS nicht funktionierte. Installiere gerade die Beta 2... mal schauen obs jetzt funktioniert
Akkulaufzeit Top
(Bei CM10 Roms hatte ich eine Laufzeit von knappen 6-7 Std ^^ :thumbdn: )
och man :(
habe gerade die neue Liquid Rom geflasht und jetzt ist schon wieder eine neue da^^
Lohnt es sich die zu Flashen?
Solltest Sie auf jeden Fall mal antesten. Noch nie so viele Einstellungsmöglichkeiten gesehen
GPS funktioniert jetzt auch:thumbup:
Ich nehm alles zurück! Hatte leider den Factory Reset vergessen -.-
Jetzt läuft sie echt super! Hut ab!
Klar sieht man die vorher...
Huuuch! Natürlich habt Ihr mich neugierig gemacht - und natürlich musste ich das Rom flashen und ich muss sagen: Hut ab! Meinen "Vorschreibern" muss ich recht geben: So viele Einstellungsoptionen hatte ich überhaupt noch nie - und das bereits in diesem Stadium, wo etwa CM10 noch dreimal am Tag "stirbt" und die Batterie raus muss! Bislang hab' ich mich nur mit den unzähligen Optionen gespielt; man sieht alles vorweg und Deutsch ist auch an Bord. Wenn jetzt auch noch die Stabilität da ist, dann "Forza JBSourcery"! Ich bleibe einmal ein paar Tage und beobachte die Ausdauer mit Trinity an Bord ...
ROM rennt sehr gut, würd ich sogar schon in den RC-Status heben, weil ne beta hat ja noch kleinere Bugs und ich hab bisher nicht den Hauch eines Fehlers gehabt oder gefunden. Echt super! Und dann auch noch updatebar per OTA, der Hammer überhaupt :D Beste JB-ROM die bisher vefügbar ist.
MoRtAl
Pierro
Pierro
Pierro
rl2664
