[ROM-JB] NexusHD v4.3 - JRO03L - 30.08.12
  • 33 Antworten
wwallace1979
wwallace1979
Enthusiast
995
Habe dieses Rom bei XDA-gefunden, sieht optisch sehr interessant aus. Beachtet: Ich bin nicht der Entwicklerder Rom und habe mit dem Rom insofern nicht zu tun.
Hier der Link zum orginal Beitrag auf XDA: [ROM][4.1.1 AOSP] NexusHD v4.4 - JRO03L - 01.09.12 | POWER IN YOUR HANDS! | - xda-developers
Schlechte News:
Am 04.09. schrieb der Entwickler ste9326 folgendes auf XDA:
Guys,
I'm here with a bad news:
i'll have to stop posting this rom(and mod locking the 3ad)because my ROM does not comply with the GPL,and this is needed to not go against the rules here on XDA.
Thank all for your comments, assistance e and support given.
PS:The material of this rom it will be used for a theme in future
Based on build 4.1.1 Jellybean JRO03L By Team Bamf
Rooted
Superuser
Themed!
Amazing speed and smoother
BAMF Setting
Theme Chooser
Changelog v4.4
Updated to Bamf 2.3.1
Included Nexus Louder+Dsp manager
Added Solid File Manager
Added Volume Wake
Fix rom updater scripts
New Kernel experiment: Trinity#35+Lean Ram Disck
For kernel remember to go to Bamf setting>>set min cpu frequencies to 691Mhz
Changelog v4.3
Added Navbar Option and more small changes by Team Bamf
Fix Softkey for integrate with new option
Fix Dialer Background(courtesy of Vicino)
Added new Franco Kernel r246 GPU 384Mhz
Added new battery % for more customization
Set wifi.scan to 180 for more battery life
Changelog v4.1
New Bootsound
new icon for power menù
New icon for audio
New Easter Egg
Optional radio XXLF1
Reduced scan wifi and set to 150,for better battery life
Insert stock Clock widget ICS/JB + digital clock widget
New lockscreen
New Franco kernel Melistone 5
Changelog V4
New base 4.1.1 JB JRO03L
New dock
New softkey (made more elegant)
Included Reflect softkey
Included in the rom other three variants of the battery%
New Background System Fixed to avoid lines screen (Thanks to HaSKDX)
New icon for the "wallpaper"
New bootanimation!
New background for "Phone"
Themed completely!(thanks to Vicino!)
Removed theme to Gmail and Calendar
New icons for the Power Menu
Lighten the system further
Included new notifications
Deleted many unnecessary system app
Deleted many unnecessary apps in gapps
New Franco Kernel r241 384 GPU
Removed Glow softkey to make it customizable thanks to "bamf setting"
New icons for "Setting"
Removed Powercontrol
Much more i don't remember
Changelog V3:
Added battery% in the status bar
Themed MMS apk (dark-blue color)
New emoticons MMS.apk
Added emoji for greater customization when writing (to enable from messages >> settings)
Adding the possibility to have the original timestamps, full timestapms, Gestures, and patterns for vibration
Icon flashing messages received (from blue to white)
Themed Calendar (dark-blue color)
Added new effects to glow at the touch softkeys to make the whole theme
Themed Gmail (dark-blue color)
Themed Contact (dark-blue color) with new icon and new default images
Sub-system further aleggerito
Added to default Franco Kernel R230 GPU 384Mhz
Changelog V2:
Modified the stock launcher to get the drawer icon in theme
Fixed the "Multi-Reboot-Power menu"
Added the "volume skip" while listening music and screen is off
Removed some system app to be as light as possible
Added "Lock button in status bar"
Changed the lockscreen to make it as theme
Added on Franco Kernel R221 default: Fluidity and reactivity increased significantly
Changelog V1:
Removed some useless app to lighten up the system;
Removed some ringtones / notifications to lighten the system;
Added two notification sounds;
Adding the Power Control app for the notification bar of the toggle can be customized for a more rapid and simple rom operations simpler (just go to turn on the app itself and on "Notification Widgets" plug on the mustache, the app allows also include customizable widgets);
MOD Setting;
MOD Dialer;
MOD softkeys, with the addition of a small gem (hope you like);
Battery stock;
Added the "Power Menu" with various restart options;
Easter egg: for those who still do not know, try to plug many times about "Version of Android" in settings
Reboot to recovery
1. Wipe data
2. Wipe cache
3. Advanced>>Wipe dalvick cache
4. Install zip from sd card>>Choose zip>>NexusHD
5. Enjoy
NexusHD ROM v4.4
Dev-Host - NexusHD_v4.4_Maguro_JRO03L.zip - The Ultimate Free File Hosting / File Sharing Service
NexusHD Gapps 08.31.12
Dev-Host - NexusHD_Gapps_08.31.2012.zip - The Ultimate Free File Hosting / File Sharing Service
NexusHD Fix Videorecorder >>flash after install Gapps<<
Dev-Host - NexusHD_Fix_ Videorecorder.zip - The Ultimate Free File Hosting / File Sharing Service
RADIO XXLF1
Dev-Host - CWM_xxlf1_Radio_Galaxy Nexus.zip - The Ultimate Free File Hosting / File Sharing Service
NexusHD WALLPAPER
Dev-Host - NexusHD Wallpaper.rar - The Ultimate Free File Hosting / File Sharing Service
Hört sich ja sehr gut an.jemand schon ausprobiert?
Hab sie ca seit ner Stunde drauf. Design ist unschlagbar, selten sowas gutes gesehen. Läuft absolut flüssig & gibt rein gar nichts zu bemängeln. Bleibt vorerst drauf.
Beachtet:
Am 01.09.2012 ist die neue Version V4.4 erschienen.
Download, Channellog etc ist bereits im Eröffnungsbeitrag eingearbeitet
Reaktionen: motoroller
Link zum Original- (XD.) Thread ?
Hab die Rom seit heute morgen auch am laufen,sieht sehr sehr gut aus und der speed ist auch klasse.werde auf jeden Fall erstmal weiter testen.
wwallace1979 schrieb:
Da es ja auch hier im Forum Menschen geben soll die zu faul, zu bequem oder für alles Ihren Lakaien haben müssen :flapper:
Nee, nee, nu mach mal halblang! Der Link gehört einfach ins OP !!
Hatte sie auch mal kurz drauf...fand es optisch nicht so ansprechend, wirkte wie ein original ROM von Sony oder so....
Hatte es gerade drauf und fand es optisch als auch von den Funktionen super. Einzig eine profilfunktion hat mir gefehlt. Gibt es eine Möglichkeit nur an das theme zu kommen?
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
In den OP gehören für mich Menschen die krank sind bzw
die nur Fordern und zu Faul sind mal selber Google zu benutzen :tongue:
Für mich ist das hier ein Hobby und kein Beruf. In dem Sinne genießt das sonnige Wochenende :cool2:
und zurück zum Thema
PS der Hinweis zum Querverweis bei XDA ist auch im Eröffnungsbeitrag hinterlegt
Kann jemanden bestätigen, dass der playstore nicht ganz so flüssig läuft? Hängt irgendwie ein wenig nach bei mir.
Bei mir läuft der play store wie er soll.
OP (original post) ist übrigens das, was du hier Eröffnungsbeitrag nennst.
Bei den im Übrigen von dir geäußerten Frechheiten hättest du besser die Finger von einer Threaderöffnung gelassen. :D
Reaktionen: Cornmat
Kann jemand bestätigen,dass der download von Version 4.4 immer bei ca 57mb abbricht?
Also ich habe heute morgen heruntergeladen (allerdings noch nicht geflasht). Da funktionierte der Download der v4.4 einwandfrei:thumbup:
Wäre nett, wenn jemand ein paar Screenshots hochladen könnte :)
?????? :confused: Was denkst Du, was die Bilder im OP sind???
Kann tinypic irgendwie nicht erreichen.. sind sie bei dir eventl. noch im cache?
Edit: Ok, hat sich erledigt.. jetzt geht es wieder..
Moin
Ich hab mir auch grad mal die Rom druf gehauen.Das Bild ist ja sowas von scharf mir taten gleich die Augen weh.:)
Bis jetzt läuft alles super,die bleibt auch erst mal druf.
