[ROM-JB] CodenameSammy 1.2.1 +++TouchWiz+++ Google Speed+Samsung Candy
  • 53 Antworten
Me-Virus
Me-Virus
[ROM] CodenameSammy 4.2 & 1.5.1 +++TouchWiz+++ Google Speed+Samsung Candy
Intentions:
Our goal is to enrich Googles Jelly Bean experience with cherry picks from Samsungs successful TouchWiz Nature UX environment. It is not a ported TouchWiz ROM, it is based on the very stable and customizable CodenameAndroid ROM.
We decided to include some apps, which were ported by us and other xda-members and some apps from google play to get many Samsung features. We think it is useful and completes the Android experience, but some of you might think it’s ‘Bloat’. So we decided to put many apps in data-partition. That way they can be updated through Google Play or uninstalled like regular apps.
Features &Infos:
- All Codename Android 3.6.6 Features (see original thread)
- Samsung TouchWizUX
TouchWizUX Launcher Features ported from Galaxy S3 by Froilson, we adopted it for Nexus 7)
- 4×4 Home Screen Apps-Grid
- Up to 7 Home Screens
- 4 apps in dock bar + menu
- Page indicator for quick navigation (Home, Menu & Widgets)
- 5×4 Drawer Apps-Grid
- 3×2 Widgets Preview
- Folders in App Drawer!
- Drawer View Types: Customizable grid, Alphabetical grid, Listview
- Hide applications
- Share Apps
- Very smooth AND responsive performance (like on S3 and Galaxy Note2)
Included Apps and Media
- Samsung S3 Accuweather Widget
- Samsung Task Manager
- Samsung Memo App
- Samsung Yahoo News Widget
- Samsung Wallpapers modded with HD Pictures from Galaxy Note 10.1
- Samsung Paper Artist from Galaxy Note 2
- Samsung ChatON
- Samsung TecTile (NFC)
- Samsung Clock
- Samsung S3 Notification Sounds
- Samsung S3 Alarms
- Samsung S3 System Sounds
- Samsung App Icons
- Many Google Apps preinstalled
- Flipboard
- FlashPlayer
- Dice Player
- Super Video (Pop up Play)
- Playboard
- Astro FileManager
- Sony Walkman
Changelog CNS
1.1
- included app icons
- added touchwiz missing apps & widgets
- bug fixes
4.2.1
- Android 4.2.1 base
- deodexed & zipaligned apks
- SuperSU 0.98 ROOT
- busybox & init.d support
- customized build.props
- quick settings mod & multi reboot option
- APPS/ADDONS:
- Google Apps
- Nexus 4 Launcher & wallpapers
- TouchWiz Launcher & widgets
- Trickster MOD
- Solid Explorer beta
- WhatsApp messenger for free*
- LockScreen Policy
4.2
- Android 4.2 Jelly bean
- Rooted
- Odexed
- TouchWiz Launcher and some Widgets
- light TouchWiz Theme (Only Icons, no SystemFrameWork themes)
- Touchwiz Ringtones and Alarms added
- Everything else is stock!
1.5.1
- fixed playstore errors
- lcd density reverted back to stock 320dpi
- added cm 10 file manager
- added google apps (drive,currents,google+)
- added modded google calendar from 1.4.0
- added emoji 4.2 keyboard
1.5.0
- updated rombase (included yesterdays commits from source)
- included 4.2 apps (camera, emoticon keyboard, gmail etc.)
- various tweaks with optimized performance
1.4.1
- fixed FaceUnlock
1.4
- updated to android 4.1.2 (cna 3.8)
- updated gapps and play store apps
- added latest swype
- added brand new and powerful LG Notetaking app ported by evilisto
- gmail 4.2 by androidpolice
- new google calendar modded by shaftenberg: adds titles to monthly preview
- added TricksterMod to control your kernel settings (display colors, cpu ) big thanks to bigeyes0x0
- latest franco kernel and kernel updater app
- improved dialer theme
- improved framework theme
- quicker homescreen transitions
- quicker folder animations
Installation:
1. Flash via Recovery or ROM Manager. It will reboot automatically. You don't have to flash GAPPS.
Wiping is only needed if you should encounter unexpected problems.
Known Bugs:
- Touchwiz Launcher Landscape mode: doesn’t work properly. Please use Smart Rotator to disable Rotation for touchWiz App only. 1. Open Smart Rotator 2. Select TouchWiz home and set ‘Auto for all’. 3. Select ‘TouchWiz home’ once again and set ‘Portrait’. 4. Now exit the app and make sure Rotation is locked (check symbol in notification drawer
- Weird Shadows: remove the apps with the broken shadow from the home screen. Adding them the next time everything will look fine
Download Version 1.5.1
http://samsung-galaxy-blog.de/downloads/CodeNameSammy/CodeNameSammy-1.5.1-maguro.zip
Download Light Android Version 1.1
http://samsung-galaxy-blog.de/downloads/CodeNameSammy/CNS-light-1.1.zip
Reaktionen: Emsholgi, morpheus620, reflex und 2 andere
Jo, das hatte ich jetzt auch mal für fünf Minuten drauf. Damit bekommt man wirklich ein S3 Feeling!
Alles funzte und sah gut aus. Leider laggte es manchmal ein wenig beim Wechsel zwischen den Homescreens (aber wirklich minimal).
Für Samsung Fanboys wirklich schönes ROM! Aber, hey, wir haben ein Nexus! :D
Trotzdem cool, dass es machbar ist!
(und ja, das ROM ist wirklich fast 500MB groß!)
Reaktionen: Melon
Werd sie mir mal anschauen :-D hoffe sie wird auch regelmäßig aktualisiert, wie codename android, sonst bringt sie mir nichts :D
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
Also bei mir laggt nichts beim Screenwechsel evtl. viel im Hintergrund am laufen?
Was die aktualität angeht, werde ich versuchen sie so frisch wie möglich zu halten, da mir die ROM selber sehr gut gefällt.
Das einzige, was hier vom S3 ist, sind doch letztlich die angefügten Apps oder? Das Design sieht ja bis auf den launcher "normal" aus, oder sehe ich das falsch?
Echt klasse rom muss ich sagen...
aber war das bei euch auch so als ihr die geflasht habt im cwm das die rom einfach automatisch rebootet hat??
normal rebootet man ja manuell.
Jop, hat auch ins Recovery zurück gebootet.
@ Lokisto:
Ist nicht jede ROM eigentlich ne Abwandlung vom eigentlichen ROM des Entwickler-Teams? Was unterscheidet denn die etlichen CM oder AOKP - ROM's voneinander? Die meisten sind auch nur gethemed und nutzen dann entweder den Nova oder Apex Launcher, hier wird eben der TouchWiz genommen und versucht alles auf S3-look/feeling zu trimmen, was ja auch soweit ganz gut gelungen ist, wie ich finde.
Ja finde auch das es sehr gut gemacht ist...finde das dieses Rom und miui mal ne gute Abwechslung ist vom ganzen holo look.
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
Reaktionen: Me-Virus
Die Sache mit dem Holo-Look war ja meine Frage.
Zum Beispiel die Dialogfenster (Power Menu beispielsweise) sind ja im Holo-Design grau. Bei Touchwiz sind diese, soweit ich mich erinnern kann bläulich (?).
Ich Habe mich nicht beschwert; wollte lediglich wissen, ob das restliche UI im Holo oder Touchwiz look gehalten wurde ;)
Allso unter Einstellung - designs ist schon ein Galaxy theme vorinstalliert.
Damit hasste auch die Fenster so bleulich.
Habe die ROM jetzt auch mal getestet.
Auch mit dem Galaxy Thema habe ich Holo-Dialogfenster.
Ansonsten sind die angefügten Apps ganz nett und auch die Idee, diese in der data partition unterzubringen ist super.
Bleibe aber vorerst bei MIUI.
Ist ja auch die erste Version des. ROM's da wird sicherlich noch bisschen was an Feinschliff folgen. Wirst es sicherlich hier mitbekommen wenn das Theme kompletiert ist ;)
Send from Galaxy Nexus
Reaktionen: Lokisto und Melon
Denke ich auch. Solange werde ich das Thema dann mal beobachten ;)
V 1.4.2 Online
500MB ! groß
Download: Dev-Host - CNS 1.4.2 Maguro.zip - The Ultimate Free File Hosting / File Sharing Service
Changelog CNS 1.4
XDA Thread: http://forum.xda-developers.com/showthread.php?t=1920946
Startbeitrag wurde auf den neusten Stand gebracht.
Reaktionen: reflex
Ich muss sagen, dass ich positiv überrascht bin von der Rom! Ich bin von PA 2.53 mal auf diese Rom gestoßen und sie sagt mir optisch sehr zu. Leider fehlen mir einige Features von ParanoidAndroid und deswegen werde ich wohl wieder zu PA wechseln, sobald sie komplett auf AOSP umgestiegen sind...
Dennoch ist das Testen dieser Rom empfehlenswert!!
Ich kann sie nicht Laden.
Gibt inzwischen auch schon die 1.5.0 und diese kann ich nicht Laden.
Sie haben keine Berechtigung, um auf diese Datei zuzugreifen!
das kann ich bestätigen... ich kann sie auch nicht laden :(
Hab den aktuellen downloadlink und den changelog der 1.5.0er hinzugefügt, sollte also möglich sein die (fast 500MB kleine) ROM zu laden ;)
Bojesse
rene3006
MoRtAl
MicBec
