[ROM-JB] BAMF Paradigm v2.0 [4.1.1] JRO03H 7/24/2012 *THEME CHOOSER*
  • 36 Antworten
milestone2mod
milestone2mod
Der Originalthread ist hier zu finden: BAMF Paradigm v3.1 [4.2.2] JDQ39 - We're | Galaxy Nexus > XDA
Paradigm represents the culmination of months (years) of work to bring our users the best possible AOSP experience. Using all of our previous experience with a multitude of devices and user interfaces, we aim to bring you something you just can't get anywhere else.
Are you ready for the shift?
When we set out to build this ROM, we wanted to keep the feel as stock as possible while adding as much functionality as possible. The primary concern was always stability and user experience.
Was ihr erwarten könnt:
  • Android 4.2.2 internals
  • Quick, lag-free performance
  • Rock-solid stability
  • Many original features
  • Bug-free (we hope) android experience
  • Outstanding developer support
Innereien
  • AOSP 4.2.2 base
  • 4.2.2 Proprietary blobs
  • Custom busybox built for Team BAMF
  • SuperSU and su binary from Chainfire (for compatibility)
  • Signed with private developer keys for increased security
BAMF Add-Ons
  • Custom boot animation (thanks to gadget! for the logo)
  • T9 dialer courtesy of CyanogenMod with optional settings in dialer
  • BAMF LTE Widget
  • BAMF Torch Widget
  • Configurable Lockscreen with unlimited* shortcuts, and pull down for Torch
  • Completely configurable QuickSettings Tiles replacing stock QuickTiles
  • Copy/Paste from any app
  • BAMF Settings (huge thanks to Stericson for the RootTools SDK which we incorporated for root functionality)
BAMF Settings Features
  • Performance Settings (Based on CyanogenMod CPU Settings)
  • CPU Speeds
  • Governor
  • I/O Scheduler
  • Voltages (where supported)
  • System Settings
  • Ad Blocking
  • Remounting of System Partition
  • Volume Key Track Skip
  • Granular Autobrightness adjustment
  • Full management of system apps (disable/enable/uninstall)
  • Full Management of Notifications including Quiet Hours (courtesy of CM)
Visual Settings
  • Fully configurable Lockscreen with the new QuickLaunch Ribbon
  • Launcher Tweaks
  • Show or hide the dock divider
  • Show or hide search bar
  • Set number of home screens (3,5, or 7)
  • Status Bar Tweaks
  • Normal, Centered, or Hidden Status Bar Clock
  • Clock Text Color
  • Show or Hide Alarm notification
  • Show or Hide Debugging Indicator
  • Battery Skin System (Some sample skins are available in the 2nd post and a tutorial for making your own is available in the "Themes" section)
  • Signal Skin System
  • Fully customizable battery text including size, color, and visibility
  • Customizable carrier banner
  • Select and arrange Quick Settings Tiles
Navbar Settings
  • Fully customizable Navigation Keys
  • Long press IME arrow for IME Switcher
  • Selectable Keyboard arrows in Navigation Bar
  • Soft key reflections on/off
  • Navbar/Statusbar Skin System
  • Set Soft Key color
  • Set Soft Key glow color
Danksagungen
(von Seiten des Entwickler-Teams)
Thanks again to Gadget! for the graphics
CyanogenMod for paving the way
ChainsDD for his work with superuser
Stericson for giving us lazy developers RootTools
wowthatisrandom for the initial battery skins
All of our Beta Testers (even though you made us crazy!)
Most importantly, our users, who waited patiently while we beat our heads against the wall working on this!
Installatiosanleitung
Rom und offizielle Gapps downloaden
Verify MD5 Hashes
Beide dateien auf die SDKarte schieben (am besten in enen gemeinamen Ordner im Stammverzeichnis)
Ins Recoverysystem bootem (Cwm oder Team win Recovery)
Einen factory reset machen und cache wipen
Dalcik xache unter "advanced" wipen
Rom unter "install zip from sdcard" auswählen und installieren
Gapps genauso installieren
Sich freuen!
Changelog
Version 1.0
Initial Release
Version 1.1
First release of Maguro version
Changing softkey background alpha to 0 disables all animations
Soft key reflections toggle
Fixed hotspot quick setting (which should stop random reboots for some)
Fixed launching direct contacts from the lock screen
Please note: Volumes do not appear split under settings temporarily. They are still split for quick settings
Version 1.2
Updated ROM and Kernel to 4.0.4
Normal, Centered, Hidden Clock options
Battery Skin System (Sample skins are in the 2nd post and a tutorial for making your own is available in the "Themes" section)
Full Battery text customization
Persistent search bar option for launcher
Huge changes under the hood in preparation for future mods
Version 1.25
Maintenance Release
Performance Enhancements
Bug Fixes
Version 1.3
Bug Fixes
Addition of Sprint Galaxy Nexus
New Notification Management System
Theme Chooser from CM9 with a custom theme
Much more (changelog to be updated later)
Version 2.0
Everything from before, but with Beans included.
Version 2.1
Fix for BAMFSettings not restoring Kernel Settings
GPS Lock Fix
Fixed launcher FC loop
Fixed SIM unlock reboot
Added LongPress track skip
Increased Speaker volume
Added option to link ringer and notification volumes
Paradigm theme is back - Although not complete
Updated GAPPS
Version 2.2
Based on JRO03L
Lockscreen is back!
Many bug fixes!
DRM and Hulu are fixed =D
Some more I can't remember..
Version 2.3
Custom Navigation Bar!
Updated AdBlocking
Added ability to open alarm clock view Statusbar clock courtesy of 1RoLa
Many small changes and bug fixes
Version 2.3.1
Maintenance Release
Fixed MMS for Toroplus users (Huge thank you to maddoggin and dreamsforgotten for the assistance)
Theme Chooser now correctly applies wallpaper 94% of the time.
Modifications to ThemeEngine framework to allow themeing of Gapps that replace AOSP versions.
Updated Gapps to fix some missing theme elements.
Version 2.3.5
Add copy/paste to messages in Talk
Allow arrow soft keys to repeat when held
Version 2.4
Update to 4.1.2 (JZO54K)
Bug fixes
Version 3.1
Rebased to Android 4.2.2 (JDQ39)
Everything it had before, and then some.​
Downloads:
Auf der Entwicklerseite: [ROM] BAMF Paradigm v3.1 [4.2.2] JDQ39 - Galaxy Nexus - Official BAMF Galaxy Nexus Development - TeamBAMF (nur noch dort)
Reaktionen: mschortie, Radagast und Schoschi
milestone2mod schrieb:
(@mods: Bitte Anpinnen!)
Am besten meldest du den Thread, der Hinweis ist kaum lesbar. ;)
Und gut wäre auch, wenn du den Titel noch an die Konventionen anpassen würdest, also [ROM-JB], damit auch wirklich jeder merkt, welche Version die Basis ist.
Is noch im Aufbau, bleib dran, um mir Bescheid zu sagen.
Reserviert für Add-Ons, Mods etc.
Was ist noch im Aufbau?? Die Rom? O.o
Wahre Fahrer erkennt man daran das die Fliegen an den Seiten Scheiben kleben!!!
Ich hab die Rom seit heute mittag drauf - mittlererweile mit dem Trinity Kernel - und bin echt schwer begeistert.
Hab alle JB - Rom mittlerer Weile durch und kann mit absoluter Sicherheit für mich sagen: Die BAMF JB ist es, wo ich jetzt erst einmal bleiben werde.
Der Theme - Chooser tut seinen Dienst besser als wie bei der 4.0..., denn jetzt kann man das Theme wechseln, ohne, dass man erst einmal das Standardtheme zurück flashen muss.
Die Theme kommen sauber aufs Handy und es gibt keine Klagen. Außer mit den ICS Mixer Themen. Da kann man das Handy nicht mehr via Schloß und Fingerwischen entsperren. Nimmt man ein Muster, dann funktioniert es.
Einstellmöglichkeiten hat man mehr als genug, es bleiben eigentlich kaum Wünsche offen.
Das Ändern der DPI der Navbar ist noch nicht im Rom enthalten, aber hier kann man die 36 DPI nachflashen
Paradigm-36Nav.zip
und hier die 24 DPI
Paradigm-24Nav.zip
oder hier 32 DPI Porträt und 24 Landscape
Jas_Navbar_BAMF.zip
Von Lichti 1901 gibt es noch das Icon, welches erlaubt, die Screenrotation in der Statusleiste an- bzw. abzuschalten
http://dl.dropbox.com/u/45805601/BAMF.4.1.1.V2.0.RotationLock-enabled.zip
Die Einstellungen des Sperrbildschirms sind noch Platzhalter, aber ich denke, es wird nicht lange dauern, bis auch das funktioniert.
Ich hatte bisher mit der Rom keinen Absturz und ich habe schon so einiges mit ihr getestet.
Bei wem Whatsapp nicht funktioniert, einfach die App löschen und neu aus dem Markt installieren, dann haut es hin.
Reaktionen: Schoschi
Der Thread natürlich, die ROM is ja nich von mir. ;-)
Ich schau mal, dass ich dann noch die ganzen Mods etc. verlinke und in den ersten Post einfüge. Ach, und auf Wunsch übersetze ich natürlich die Funktionslisten und nachfolgenden Changelogs noch, is ja schließlich ein deutschsprachiges Forum.
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
Ich probiere das Rom heute nach der arbeit auch mal aus .
Rom läd, da bin ich ja mal gespannt!:)
Klingt sehr, sehr vielversprechend.
Leider habe ich bei diesem ROM das alte CM-Problem: nach der PIN-Eingabe erscheint nochmal die Bootanimation. Kann das jemand bestätigen?
Bin jetzt erstmal wieder auf AndroidME 1.4 zurück.
habe auch das gleiche Problem.
Das wäre wirklich super!:D
Hat vllt jemand einen Mod für die %-Anzeige des Akkustandes??
Gesendet via Tapatalk
Brauchst doch keinen Mod dafür. Es gibt ein paar APKs, mit denen sich Batterie-Themes installieren lassen. Und auch ohne diese kann man die Textanzeige aktivieren.
Schau mal auf der Entwicklerseite, da findest du die für diese ROM spezifischen.
Ich binde sie auch, sobald ich mehr Zeit habe, in den 1.Post ein.
Ja, bei der Pineingabe kommt dann noch mal kurz die Bootanimation.
Ich bin auch wieder zurück auf AndroidME 1.2 Kang CM10, die erscheint mir auch ausgereifter, und außerdem läuft sie flüssiger.
Ich denke, wenn weiterentwickelte 4.1.1 Versionen erscheinen (die BAMF-2.0 ist ja die erste 4.1.1) die eine bessere Akkulaufzeit und tiefergehende Einstellungs-Erweiterungen hat, überleg ich mir, zu wechseln, aber so bleib ich lieber auf AndroidME.
Leider Geht kein Anderer Kernel zum Undervolten. Ich hätte so gerne den Leankernel daraufgemacht.
Kleines Update zum Akku nach der ersten Aufladung mit dem aktuellsten Trinity-Kernel. Interactive @ 307/1036 MHz
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
Franco und trinity gehen zu uv!...
Versteh dein problem nicht...
Hab wieder mal n Mod gebastelt bzw meinen "alten" portiert ;)
- 30 dip Navbar (finde ich die oprimale Größe - nicht zu klein nicht zu groß)
- black/cyan theme
- black cyan Tastatur
Screenshots füge ich bald hier an.
Download:
Lokistos MOD - BAMF
So, Also Trinity und Franco gehen tatsächlich, aber das Handy wird damit tierisch heiß. Außerdem stürzt jedesmal wenn ich telefonieren die Telefon Anwendung ab. Also abwarten und Tee trinken, bin nun wieder auf Android Revolution HD 5.0.0 JRN84D mit Leankernel. Super Laufzeit, keine Bugs ,läuft und läuft und läuft.
Also bei mir klappt franco zwar aber leider ist der Akku extrem schnell leer.
Mit dem Air Kernel erziele ich allerdings normale Standardwerte und er läuft mit der Rom auch ganz gut.
  • Hans3000
swa00
swa00
MoRtAl
Pierro
Pierro
Pierro
