[ROM-JB] AndroidME v1.6 | 4.1.1 Jelly Bean AOSP/JRO03H | Stable | Smooth
  • 168 Antworten
nekbreak
nekbreak
Dauer-User
235
Aktuell ist die Version 1.9
  • JRO03C Google Stock Image Base Fully Optimzed
    CM10 4.1.1 Kernel Compiled with Linaro Toolchain
    Android 4.1.1
    Stock Battery Percent
    Adfree base
    Build.prop mods
    Includes AOSP Compiled apps and libs
    Busybox installed
    Unsecured boot.img
    Custom Blue LED notification light
    Faster blinking LED without the need of an app
    Stock look, clean, simple, stable.
    Advanced Power Menu
    OTA Update function - Thanks to OTA Updater app
    init.d scripts for speed and RAM Optimization
    Google apps included (No need for an extra flash)
    Excellent battery life
    ADB Debugging notification disabled
    Rooted and Latest Superuser added
    Slightly improved Images and Videos
    Tweaks for speed and memory improvements
    Fully de-odexed
    SQLite boost script
    Audio Improvement Patch + Awesome Beats - Thanks to Misledz and ..Awesome..
    4EXT Optimization script
    Multi-language (WWE)
    Fully Zipaligned
    Very Fast & Fluid!
    Friendly, Fast support
    Plus more...
  1. Boot into recovery
  2. Backup
  3. Wipe Data, Cache & Dalvik Cache
  4. Flash ROM
  5. Boot Phone and setup
DONE
If you like my ROM please hit thanks its much appreciated!
Hier kommst du zum Download beim ROM Manager!
Aktuell ist 1.9 im ROM Manager..​
Hier kommst du zum XDA-Beitrag des ROM Entwicklers
Addons
**These current addons will disable animation speed-up for 1.4 >, New mods coming.
>> Recommended Nav Bar Mods - Thanks to Thyrus
**For 1.4 on**
>> Volume wake mod + Extended Power Menu
>> Remove Carrier Label from pull down status bar
>> Add screen lock button to status bar - Vicino MOD
Fehler:
Keine bekannt
Code:
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME v1.6.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]29 July 2012[/I][/CENTER]
[I][COLOR="Red"][B]**Full wipe needed [COLOR="blue"]IF[/COLOR] coming from v1.5.0 or any other ROM**[/COLOR]
 > If coming from v1.4.0 or bellow no wipe is needed.[/B][/I]
[LIST]
[*]Rebuilt base again from Stock Google image 4.1.1
[*]Fixed issues from 1.5.0
[*]Added /data/app function and included Facebook, Twitter and Moved Maps to data.
[*]Played around with colour correction, tell me if you notice a difference!
[*]Kept louder volume notifications from 1.5.0
[*]Basically rebuilt the ROM from ground up
[*]Fixed GPS bug (Locking in under 5 seconds, tested inside)
[*]Added a couple of experimental mods with volume, want to see if its noticed
[*][I][COLOR="RoyalBlue"]This will now STAY as a Stock Google base and I will post AOSP ROMs in the
2nd post of my CM10 thread. This ROM is intended to be stable and fast so
ill keep the AOSP experimental ROMs over on the other thread[/COLOR][/I]
[/LIST]
[B][I]Bugs:[/I][/B]
[LIST]
[*]None
[/LIST]
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME v1.5.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]28 July 2012[/I][/CENTER]
[I][COLOR="Red"][B]**Full wipe needed in any case! Newly compiled AOSP base from Google source code**[/B][/COLOR][/I]
[LIST]
[*]Fully rebuilt base from AOSP Google source
[*]Added T9 Dialler from
[*]Added new Google Apps
[*]Removed "Software Update" from settings menu, as it cant be used anyway.
[*]Notification sounds are now louder thanks to Google source
[*]Battery should also be better
[*]Rebuilt all MODs for new base
[*]ROM is now 35MB slimmer due to new base.
[*]Havent put Awesome Beats back in yet
  >> [COLOR="RoyalBlue"] (I dont think it really improves anything on the new base, will review after i get feedback.)[/COLOR]
[*]This is not now based on OTA updates, this is pure AOSP with Gapps.
[*]New themes coming from our team also!
[/LIST]
[B][I]Bugs:[/I][/B]
[LIST]
[*]T9 Dialler has a vibration issue when pressing numbers, just turn off vibration under Settings>Sounds until i fix it.
[/LIST]
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME v1.4.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]23 July 2012[/I][/CENTER]
[I][COLOR="Red"][B]**No Wipe Needed unless coming from another ROM**[/B][/COLOR][/I]
[LIST]
[*]Added low brightness patch - Thanks Thyrus
[*]Made LED notification light blink faster (Without an extra app)
[*]Made LED light a custom blue colour
[*]Modified framework to make animations and scrolling faster
[*]Few fixes regarding to rare FC's
   [B][I][COLOR="RoyalBlue"]> Side Note[/COLOR][/I][/B]
[*][B]Released AndroidME AOKP CM10 in 3rd post[/B] [B][URL="http://forum.xda-developers.com/showpost.php?p=28795911&postcount=3"]HERE[/URL][/B]
[/LIST]
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME v1.3.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]17 July 2012[/I][/CENTER]
[LIST]
[*]Changed back to stock DPI navbar
       [COLOR="SeaGreen"]>> Includes standard white icons with RH menu button when needed[/COLOR]
[*]Added back awesome-beats mod
[*]ROM is now ad-free
[*]Removed a couple of init.d scripts that were no good
[*]Fixed missing Symlinks in updater-script
[*]Updated Busybox
[*]Cleaned up xbin folder
[*]Fixed /system not being able to mount RW
       [COLOR="SeaGreen"]>> Fixes issues with GetRIL etc...[/COLOR]
[/LIST]
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME v1.2[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][COLOR="Red"][B]**No Wipe Needed**[/B][/COLOR][/I]
[LIST]
[*]Fixed some errors in updater-script
[*]Fixed some errors with android.policy.jar
[*]Changed Navbar to 38dpi with menu button (hidden when not needed)
[*]Recompiled framework-res properly to fix signature issue on boot
[*]Added experimental O/C Daemon system MOD [B](Optional 2nd Post) [/B]
[*][COLOR="SeaGreen"][I]  > Inludes Francos Kernel and the Virtuous O/C App[/I][/COLOR]
[*]Lots of back-end app optimizations and rebuilds
[/LIST]
[B][SIZE="4"][COLOR="Red"]AndroidME v1.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]15 July 2012[/I]
[I][COLOR="Red"][B]**[B]MUST[/B] Full wipe**[/B][/COLOR][/I]
Rennt verdammt schnell...!
Der Akku leider auch...
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
Ja bei der ROM merkt man einen Leistungszuwachs meiner Meinung, deswegen teile ich die ROM mit euch :)
Habe noch Screenshots hinzugefügt das man sieht wie der Batterie % MOD, das Power Menü usw. aussieht.
Werd sie mal testen. Hab 4.1.1 Stock drauf..fullwipe oder reicht cache/dalvik?
[ROM] [JB 4.1] [JRN84D] @gnex-leider geil!
Ja! Full wipe ist immer von Vorteil..
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
Version 1.1 ist Online und im 2. Post befinden sich extra mods wie z.B. Batterie Prozent anzeige.
Also bei mir ist die Akkulaufzeit sehr gut, nutze den Trinity Kernel A28.
die extra mods sind ja super :) der gute alte Thyrus wieder mal lol
Reaktionen: Lion13
Habe es mir grade geflasht, hab aber weder eine Statusbar, noch hab ich eine Navbar
Achtung Bitte 1.1 nur flashen wenn man von 1.0 kommt. Ein update kommt bald anscheinend haben manche Leute ein Problem.
Reaktionen: Eay
Ah, gut zu wissen. Dann flashe ich vorher erstmal die 1.0
Ja,mach das läuft 1A diese Rom.
Habe sie jetzt 2 Tage ordentlich ran genommen und sehr gefordert ;-)
Läuft astrein in allen belangen,bin sehr zufrieden.
Einzigst diese Unsypatische Google Navi Stimme ist unerträglich.
So ein zickige Stimme nö Google bitte ändern ;-)
Ansonsten sehr sehr gute Arbeit.
https://www.android-hilfe.de/members/and_girl-33950.html
Klasse ROM ! ! !
Läuft echt flüssig und bis jetzt hatte ich keine Probleme damit,
weder mit 1.0 noch mit der 1.1...Weiter so :thumbsup:
Finde von den aktuell angebotenen Jelly ROMS läuft die wirklich am besten, der neue Trinity Kernel verrichtet seine Arbeit auch perfekt!
Mit welchem Trinity genau? TNP1420-307-JB-ALPHA31?
ja, der Vorgänger läuft aber auch gut bzw. habe keine Veränderungen festgestellt.
Widgetsoid in die Benachrichtungsleiste gepackt und man hat als was man braucht.
Geht klar. Werds später mal mit der v1.2 versuchen, soll ja bald kommen.
Version 1.2 ist schon fertig und wird gerade hochgeladen ;-) (der xda Seite zu entnehmen)
Changelog hinzugefügt, jetzt heißt es warten bis die ROM online ist :)
Der ursprüngliche Beitrag von 15:44 Uhr wurde um 16:03 Uhr ergänzt:
cdtdroid schrieb:
for f**k sake, dev-host stopped at 86% again! Restarting to rom manager server... Getting new service tomorrow, over it. Sorry guys another 20 mins
:d :d
@gknnn wie ist die Rom im Vergleich zu RasCream+Trinity. Also vom Stable, Smoothnes und Akkulaufzeit?
Gesendet von meinem RasCream Prime mit Tapatalk 2
