[ROM-JB] AndroidME Kang Projekt | v1.3.1 | CM10 Quellen
  • 53 Antworten
PL50
PL50
Dauer-User
1.191
Beitrag befindet sich im Aufbau!!
  • Built from CM10 latest source
  • Android 4.1.1
  • Unsecure boot.img
  • Superuser (ROOT)
  • Deodexed
  • Performance Tweaks
  • Advanced Power Menu
  • T9 Dialler
  • Stock JellyBean Boot animation
  • Custom AndroidME Blue LED pulse
  • Faster LED Pulse for notifications
  • Google Apps pre-installed
  • Fully working Google Now
  1. Boot into recovery
  2. Backup
  3. Wipe Data, Cache & Dalvik Cache
  4. Flash ROM
  5. Boot Phone and setup
Download Version 1.3.1
Einfach über 1.3.0 Flashen!! Fixt die Kamera
Download Version 1.3.0
Hier geht es zum Beitrag auf XDA
Code:
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME CM10 v1.3.1[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]30 July 2012[/I]
[/CENTER]
[LIST]
[*]Fixes camera
[/LIST]
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME CM10 v1.3.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[/CENTER]
[LIST]
[*][B][I]Compiled latest CM10 source[/I][/B]
    [COLOR="RoyalBlue"][B]>> Now includes...[/B][/COLOR]
[COLOR="SeaGreen"][*]Lockscreen toggle options
Theme chooser built into the settings menu
Different profile settings
All the latest CM10 merges[/COLOR]
[*]Updated to latest Google apps
[*]Made base Adfree
[*]Changed Superuser to SuperSU
[*]Fixed updater-script issues
[*]Fixed ROOT issues with busybox
[/LIST]
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME CM10 v1.2.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]25 July 2012[/I]
[/CENTER]
[LIST]
[*]Update SU Binary
[*]Update Google+
[*]Fixed Camera getting stuck on preview
[*]Change name to AndroidME CM10 not AOKP to avoid confusion
[*]Fixed the welcome screen saying "Mother" to "Emergency Dial" for all languages
[*]Fixed FC when selecting "Manage Location Settings" in Google Now
[/LIST]
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME CM10 v1.1.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]24 July 2012[/I]
[I][COLOR="Red"][B]**MUST Full wipe**[/B][/COLOR][/I]
[/CENTER]
[LIST]
[*]Fixed FC on Google Now
[/list]
[CENTER]
[B][SIZE="4"][COLOR="Red"]AndroidME AOKP CM10 v1.0[/COLOR][COLOR="Red"][/COLOR][/SIZE][/B]
[I][B]Release Date:[/B]23 Juli 2012[/I]
[/CENTER]
[LIST]
[*]Initial Release
[/list]
Reaktionen: Dirk64
Was ist da anders als bei der 1.4 von androidme?
Also der Entwickler möchte mit der normalen AndroidME Version mehr bei dem Standard Aussehen und Funktionen bleiben.
Bei dieser ROM werden die Funktionen von CM 10 mit eingearbeitet und hat somit mehr extra Funktionen :)
und warum kang project wenn es nur cm10 features sind?
Version 1 ist Online, bitte den Kamera Fix beachten!
Das mit dem Namen ist wohl da es ein mix aus CM10 ist mit ein paar teilen von AOKP.
Version 1.1.0 ist online!
Hab die 1.1 schon ne gute Stunde drauf. Läuft genauso rund wie die ME
[ROM] [AndroidMe/AMKP/CM10 1.1.0][4.1.1][TrinityAlpha31]@gnex-leider geil!
Nutze die ROM auch seit 1.1.0 und muss sagen es ist die perfekte Mischung.
Hat dank CM 10 erstmal alles was ich brauche: Toggles, Profile, Batterie Mod usw
Dazu noch die Vorzüge vom normalen AndroidME - was will man mehr :)
Reaktionen: KingChaos und Bennni.
Bei mir läuft sie mit 600 mhz extrem flüssig!!!
keine ruckler.... mal schauen wie es mit der akkulaufzeit aussieht...
ach ja ich habe natürlich den trinity kernel.
Hey..
wollte eigentl. bei Stock 4.1.1 bleiben weils sehr gut läuft.. jedoch werde ich bei dieser Version sehr schwach ;)
Wenn ich das richtig verstanden habe (bei xda gelesen) funktioniert die kamera ohne einen fix nicht? Ist dem so?
Danke schonmal im Voraus für die Antwort
"Fully working Google Now" !?
dome988 schrieb:
Hey..
Funktioniert ohne das ich eiben fix geflasht hab! Außer natürlich die gapps in der Anleitung...
Weiß jemand ob ich ohne Fullwipe von AndroidME 1.3 diese Version flashen kann?
Ja in der Version 1.0.0 war ein Fehler bei Google Now drinnen und der wurde gefixt.
Ach Jung steht doch alles im changelog, NEIN nur MIT Full Wipe :rolleyes2:
Ich habe Probleme mit dem Lock screen.
Wenn ich entsperren mit Finger bewegen mache, kann ich nicht entsperren wenn ich mit dem Finger nach rechts wische, um auf das schloss zu kommen. Die anderen beiden Symbole funktionieren aber.
Bei entschlüsseln mit Pin Eingabe funktioniert die Option "Quick unlock" nicht, dh man muss trotz richtigen Pin noch OK drücken (was jetzt nicht wirklich schlimm ist)
Hat das jemand auch schon festgestellt?
Grüße
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
@gknnn:
Kannst du aus dem AMKP in der Überschrift ein AOKP machen? Ist nur ne Kleinigkeit, aber irgendwie fällt mir das immer ins Auge und dann frage ich mich für eine Sekunde: Was ist AMKP? :D
MoRtAl
Pierro
Pierro
Pierro
rl2664
