[ROM] [JB 4.3.1 JLS36I] TREX v52 Final JOREX|HALO|PIE|Team T-REX
  • 12.636 Antworten
Welcher Mpokang v10 Kernel läuft bei euch ??
  • Umfrageteilnehmer
    18
  • Umfrage geschlossen .
T-REX600
Gast
- Android 4.3.1 (JLS36I) -
- Mpokang v10 CM Kernel -
- Halo -
- Pie -
- AOKP Ribbons -
- Android 4.4 Kitkat Launcher -
- Comprehensive speed enhancements, including Linaro -O3 and processor-specific optimizations -
- Option to hide lockscreen -
- Carousel lockscreen -
- Customizable lockscreen buttons and sliders -
- Chronus clock widget -
- Customizable hardware and software keys -
- Transparent navbar and status bar -
- Customizable navbar ring -
- Navbar arrow keys -
- Navigation bar widgets -
- Customizable power menu -
- Notification power widget -
- Notification brightness adjustment -
- Customizable quicksettings panel -
- Statusbar mods including center clock and color -
- LCD Density -
- Theme engine -
- Quiet hours -
- Volume rocker music controls -
- Full Rotation -
- Customizable battery and notification light -
- More that haven't even been mentioned, and more to come! -
- Ram Tweaks Optimierung Get more RAM and faster responses by disabling verify-bytecode! -
- Sound (NexusLouder) -
- Grafik Engine (BRAVIA Engine 3 with X-Reality Engine) -
- System Animation flyflip -
- Dialoge Transparent -
- mehr Benachrichtigungstöne -
- geänderter Lockscreen Style -
- Lockscreen Ton geändert
- ES Datei Explorer app -
- Apex Launcher app -
- Trickster Mod app -
- TitaniumBackup app -
- Sony Musikplayer app -
- Auto Memory Manager app -
v52 Final
JOREX
TREX-JB 4.3.1-JLS36I Build 20.10.2013 (v46)
● update Init.d & Build.prop Tweaks
● added Trebuchet
● Android 4.4 Kitkat Launcher (GoogleHome)
● Android 4.4 Kitkat Google Search (Velvet)
v52 Final JOREX benötigt gapps vom 07.11.2013 !!!
Fullwipe notwendig
"Zugangspunkte (APNs)" Nach einen Fullwipe besteht keine Mobile Datenverbindung, ihr müßt dann eure APN in Einstellungen / Mehr / Mobilfunknetze / Zugangspunkte (APNs) eintragen !
APNs der Provider siehe hier
Android APN-Einstellungen: T-Mobile, Vodafone, E-Plus, o2, usw.
- ROM und Gapps herunterladen und auf interne SD-Karte speichern
- Ins Recovery-Menü booten
- Ein Nandroid-Backup erstellen (empfohlen)
- Full-Wipe durchführen: wipe cache/ wipe dalvik cache / Factory-Reset und Format System (wenn Ihr von einen anderen Rom kommt), bei ein update: Wipe Cache/Dalvik Cache und Format System
- ROM installieren (select ZIP from SD)
- Gapps installieren (select ZIP from SD)
- Neu starten​
**** Der erste Neustart: geht schnell eine Rauchen oder Kaffee trinken! :D:D:D ****​
Rom: Download
(Stable Rom Versionen)
Experimental Rom: Download
(Vorversionen zum offiziellen Stable Rom)
Gapps: Download
(Google apps mit Walkman Player oder GoogleMusic , Nexus Louder, Titanium Backup, BRAVIA Engine 3 with X-Reality Engine und GPS Fix )
Kernel Mpokang v10 SuperRam: Download
Kernel Fancy 4.3 pre 44-3 big: Download
Kernel Fancy 4.3 r42 big: Download
funktioniert mit TREX ROM ab Build Datum 22.10.2013 !!
Recovery:
CWM Recovery
cwm-recovery-clockwork-touch-6.0.4.4.b41579-maguro.zip
TWRP Recovery
TWRP-2.6.3.0-Recovery-for-MAGURO
Theme für TWRP Recovery
(Danke quand443 fürs TREX Theme)
[THEME] TWRP-Themes by quand443
file.html
file.html
T-REX600
(Rom)
Jori66
(Kernel, Design & Rom)
klimo
(Design & Tester)
Dirk64
(Design: Animationen, Tools, GPS-Fix)​
CarbonDev | mpokwsths | Sony | NexusLouder | Slim Roms
Reaktionen: Riefi, Soldat0815, Pubhero und 68 andere
Danke, dann habe ich ja was zum Testen :D
Wetter ist sowieso Scheiße :D
Emsholgi
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
@Emsholgi: Kannst du dann über die Rom berichten? Ich würd gern wissen ob die Stable ist, will demnächst auch auf 4.2 umsteigen aber hab bisher nur eher negatives von den anderen 4.2 Roms gelesen :D
Jo mach ich :cool:
Lade grade, schmeiße die drauf und dann etwas später kann ich meine ersten Eindrücke posten :D
Was ist denn das für eine Musik Player App auf dem Screenshot?
Aus dem Hause Sony:D:D ( Walkman )
2 kaffe und 2 kippen gewartet ^^ blidschirm nun schwarz und ende ^^ ich denke mal das soll so nicht sein ^^
ok berichtige ^^ nun wieder bootscreen der auch wenn ich ihn nicht zu lange sehen will gut ist ^^
Sind auch notifications button enthalten?
So wie die im Bild.
Ich kann die Rom zwar auswählen, aber dann bekomme ich ein Error ( Status 7 ) und die Installation bricht ab :confused:
Ist die Rom komplett?
Hat CWM die Rom nicht erkannt?
So wie die im Bild.
ganz oben rechts mal drücken dann kommen se raus
Die meine ich nicht.
Wie die in dem Bild das ich angehangen habe.
Moin,
dann scheinst du die ja installiert zu haben oder?
Hattest du Probleme dabei?
Meine Installation bricht immer ab!
Emsholgi
Puuuh dauert der erste Start aber schon recht lange... und heiß wird mein Nexus auch ziemlich.... ist irgendjemand schon weiter als Bootscreen?
Der ursprüngliche Beitrag von 16:03 Uhr wurde um 16:05 Uhr ergänzt:
Zitiere mich mal selbst... also jetzt das dritte mal bis zum startbildschirm gekommen und zack neustart... ich glaub da läuft was schief...:ohmy:
bei mir gings mit fullwipe.
dann nur die rom und neustart.
wenn es dann da ist wieder ins recovery und dann die gapps. jezt läufts mal.
und meins wurde auch recht heiss und schaffte den boot ned davor so ging es dann
Reaktionen: elenco
Ich schmeiße jetzt mal CWM Touch runter und versuche es nochmal. Den Fehler mit der Speicherkarte kann ich durch den RootExplorer beheben.
Schaun wir mal :D
ich hab das twrp
So wie die im Bild.
Nein so nicht gibt aber schöne apps in PlayStore !!!
jans schrieb:
Moin,
woher hast du das und muss ich da was beachten?
Wenn es damit geht :D
Emsholgi
Sind bei der fehler suche !!!!
Hat geklappt danke :razz: jetzt mal fleißig testen :thumbup:
