[ROM-JB][4.2.1][JOP40D] udK's AOSP R8 | 18.12.12
  • 150 Antworten
Elting
Elting
Ehrenmitglied
5.657
udK's AOSP
Das folgende ROM wurde von dem Dev udK entwickelt. Den Thread zum ROM findet ihr auf XDA!​
Über das ROM
Kernel + boot.img:
•Kernel updated to: 3.0.53 (compiled with Linaro GCC 4.7-2012.10)
•Compressed zImage - LZO
•Color Control (use this app to change values: Trickster Mod)
•FSync Control
•Force AC (fast) charging
•Enabled adb root
•Available I/O Schedulers: Deadline - CFQ - No-op - BFQ v5
•Available CPUFreq govenor: performance - powersave - userspace - ondemand - interactive - conservative - hotplug
•Enabled CIFS support
•Enabled TUN support
System:
•AOSP Jelly Bean 4.2.1 build JOP40D
•Google Apps JOP40C
•rooted
•Dialpad T9
•extra Quick Settings Mod
•Volume rocker wake
•Volume rocker music control
•Gapps removed: Google Current - Google Books - Genie widget - Google Ears - Google Magazines - Google+ - Wallet
•/app and /framework ODEXed
•busybox v1.20.2
•Volume Louder fix
•Enabled support to /etc/init.d support
•AD Block /etc/hosts
•Enabled Adobe FlashPlayer
Quick Settings Mod features:
Thanks to kevdliu - Mod thread -> http://goo.gl/vK32W
•Press to directly toggle Wifi and long press to access Wifi settings menu
•Press to directly toggle Mobile Data and long press to access Mobile Data settings menu
•Press to directly toggle BT and long press to access BT settings menu
•Persistent GPS Tile: Press to toggle GPS and long press to access Location settings menu
•Add Auto Rotation Tile
•Add Volume Tile (Press to display media volume slider and long press to access Volume settings menu)
•Add Screen Off Tile
•Add Ringer Modes Tile
•Add Torch Tile
•Add Wifi AP Tile
•Control Panel application to show/hide Tiles
•Reorder the tiles by enabling them in the order you want them to be placed (first enabled toggle will be placed first etc.)
Release / Changelog
Code:
[B]aktuelles Release R8 (18.12.12)[/B]
18 December 2012 - R8
[+]Kernel updated to 3.0.57
[+]Kernel recompiled with linaro-4.7-2012.11
[+]Updated TalkBack 3.2.1
[+]Updated SuperSU 0.99
[+]Updated Gmail 4.2.1
[+]Updated Google Maps 6.14.2
[+]Updated Google Now 2.2.10.546669
[+]Updated Google Earth 7.0.2.8403
[+]Updated YouTube 4.2.16
[+]Updated Adobe Flash Player 11.1.115.34
[+]Update Google Play Services 2.0.12
[+]Update Google Play Store 3.10.10
[+]Update Google Calendar 201212060
[+]Added "Clear all" button on recent apps
[+]Added long press Back to kill app
[+]Added Quick Message reply
[+]Added Emojis support
[+]Added customizable Navigation bar
[+]Added customizable Lockscreen targets
[+]Added option to control cursor in text fields using volume keys
[+]Enabled Sound Recorder
[+]OTG can mount multiple volumes via mass storage
[+]OTG support NTFS (read only) UMS devices
[-]Removed Launcher landscape mode
[!]Fixed OTG UMS notifications
[!]Fixed OTG UMS infos in Settings -> Storage
[B]Release R7 (28.11.12)[/B]
[+]Updated to Android 4.2.1 (build JOP40D)
[+]Updated to Kernel 3.0.53
[+]Added Volume rocker wake
[+]Added Volume rocker music control
[+]Added Dialpad T9
[+]Fixed CM File Manager
[+]Automount on /storage/usbdisk (OTG connected devices)
[+]Added FSync Control - [URL="http://goo.gl/iyih4"][KERNEL]CM10/CM9/AOKP Kernel v6.2.1 [8/16] - UV/OC/GPU-BLN-Governors - AT&T Galaxy S II Skyrocket Development - RootzWiki[/URL]
[+]Updated Quick Settings
[+]Added Quick Settings Mod app
[+]Force AC (fast) charging - [URL="http://goo.gl/62i7p"][KERNEL PATCH] Force AC (fast) Charging - xda-developers[/URL] (App to control it [URL]http://goo.gl/f7a9K[/URL])
[B]Release R6 (22.11.12)[/B]
[+]Updated Kernel with latest AOSP 4.2 patches
[+]Updated Kernel to v3.0.52
[+]Included trinity's kernel patch for colours
[+]Added support for color control
[+]Added Expanded Desktop mode
[+]Added Lockscreen widgets mod (thx to kevdliu)
[+]Added QuickSettings (thx to kevdliu)
[+]Updated BFQ to v5
[+]Updated Google Play Store 3.10.9
[+]Switched from AOSP Calendar to Google Calendar
[!]Fixed Deep Sleep (no more battery drain)
[!]Fixed Calendar (december month missing in calendar)
[!]Fixed Clock in Daydream FC
[-]Removed Google Ears
[B]Release R5 (17.11.12)[/B]
[+]Upgraded to AOSP Jelly Bean 4.2 (build JOP40C)
[+]Upgraded to Google Apps JOP40C
[+]Updated to Kernel 3.0.51
[+]Added the extended Power menu (reboot, reboot recovery and reboot bootloader)
[+]Added Google keyboard with swipe features
[+]Added Google Camera with Photosphere
[+]Added Apollo music player
[+]Added DSP Manager
[+]Added volume louder fix
[+]Added the ability to recognize HSPA+ signal (H+ icon)
[+]Enabled remote Backup&Restore option
[+]Enabled GTalk with video effects
[+]Enabled Landscape mode
[+]Added rotation lock in Quick Settings
and some more!
Download
  • Hier könnt ihr die aktuelle Version runterladen: AOSP R8 (MD5: d61c534bdc120c0262723d4d20f5f00e)
  • udK's AOSP bei goo.im: Goo.im Downloads - Browsing ROM
  • Das ROM beinhaltet einen OTA-Updater, über welchen ihr die neuesten Releases runterladen könnt!
Installation
Achtung! Ihr benötigt unbedingt jeweils das aktuellste Custom Recovery (CWM oder TWRP):
  • Ladet die aktuelle Zip auf die interne SD-Karte
  • Reboot ins Recovery
  • Erst FullWipe, dann flashen
  • Gapps sind enthalten!
Screens (folgen)
Ich (Elting) bin nicht verantwortlich für die ganze Schose. Ich bin lediglich der Thread-Ersteller!
Reaktionen: heleis, mr.a, Scum und 9 andere
Danke für den Thread! Ist mir bei xda über den Weg gelaufen und sicherlich wert mal gestestet zu werden ;)
Auf jeden Fall! Ich hab's seit R6 drauf und es läuft einfach klasse (allerdings läuft es bei mir mit dem 328er Franco).
Einen Reboot hatte ich in der ganzen Zeit nicht (manche berichten auf XDA davon...).
Edit: und diese erweiterten Toggles sind einfach klasse! Das wäre eigentlich DIE Lösung für CM10.1 & Co.
Wer hatte im aokp thread den link zum hiesigen Rom verlinkt, verwende seitdem die r6 ;-) seit 3 Tagen.
Bis auf den t9 dialpad (ab r7 dabei) und den änderbaren navbar widgets von aokp vermisse ich nichts bei dieser rom.
Einzig und allein die Änderung der Ordner Struktur auf der sd Karte hat mich geärgert..
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
Ja, mit der Ordner Struktur liegt ja an JB 4.2 im allgemeinen....
Ich vermisse auch 'nur' noch die NavBar-Targets aus AOKP. Damit hab ich immer das Handy ausgeschaltet. Das Ausschalten bietet dieses ROM zwar auch, aber nur über die Toggles und das ist etwas umständlich...
Ich werde heute die R7 super-clean flashen (d. h. incl. format /system).
Das neue TWRP sorgt ja nun wenigstens dafür, dass dabei keine neuen /0-Verzeichnisse mehr angehängt werden.
Frage aber:
Wie wird man mit Anstand all die /0-Verzeichnisse nachträglich wieder los, die vorher angelegt wurden und von denen
(im Single-User-Betrieb) jeweils nur das allererste wirklich gebraucht wird.
Löschen geht ja nicht einfach.
Edit:
@Elting
Hast du mal das neue Power Toggle in Erwägung gezogen?
Es deckt bei mir vorerst all die nützlichen Kleinigkeiten ab, die sicher auch bald von den guten Custom Roms
angeboten werden (incl. purer Akku-Prozent-Text in der Statusbar).
Reaktionen: Elting
Ich dachte die werden mit 'format system' gelöscht?! Sollte eigentlich so sein...
Habe ich auch gedacht. :confused:
Geschieht aber nicht. :D
P.S.: Mein letztes Post oben hat eine Edith für dich.
Hmmm... das finde ich aber sehr seltsam, dass die /0/0/0 nach nem format system nicht weg sind...
PowerToggles? Woher bekomme ich die? :)
Edit: ach, das ist ne App, richtisch?
Du sags es. :flapper:
Moin!
Danke, endlich ein Thread vom, wie ich finde, stabilsten Rom derzeit hier :D
Ich habe es auch von Anfang an am Laufen und bin begeistert :D
Eigentlich bin ich ja eher der Themen-Typ, dass heißt ich stelle mir gerne meine bevorzugten Farben zusammen.
AOSP r7 ist zwar nur ein bisschen mehr als Stock, aber ich finde es trotzdem Geil :thumbup:
Die Akkulaufzeit ist spitze und dank Trickster-Mod und OTA-Updater auch schön erweitert!
Ich habe jetzt mal die CPU auf 920 runter getaktet und es läuft trotzdem alles flüssig :D
Die Toogle und Widgets Erweiterungen sind auch genial!
Ich bin mal auf weitere Erfahrungen gespannt.
In der r8 hat sich ja der Kernel geändert, gibt es da schon erste Meinungen?
Also noch mal Dank an @ Elting für den Thread :D
Emsholgi
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
Reaktionen: Elting
Erster Eindruck:
Alles läuft korrekt, schnell und flüssig.
Letztere beide Eigenschaften werden durch den Zen-v8-Kernel noch spürbar gepusht.
Kurz: Tut effektiv und effizient das, was es soll.
Was die /0-Verzeichnisse angeht:
Gute Nachricht: durch TWRP 2.3.2.1 kommen wenigstens keine neuen dazu.
Schlechte Nachrichten: 1. durch format /system werden die Altlasten nicht beseitigt.
2. freie Kapazität in sdcard hat bei mir über 20% abgenommen.
Das letztere kann ich leider nicht genauer angeben, da ich mir die alten Werte nicht genau genug gemerkt habe.
Muss ich beim nächsten Mal rechtzeitig machen.
Frage: Kann es gegen die unnötigen /0-Verzeichnisse vielleicht, helfen, wenn man
(per Flash oder Nandroid) auf ein 4.1-Rom zurückgeht und das 4.2 dann neu mit TWRP 2.3.2.1 aufsetzt?
Wer opfert sich ggf. ?
Sorry, ich gehe nicht mehr zurück auf 4.1.2... :flapper:
Hab jetzt die R7 drauf. Läuft alles wie gewohnt flüssig und gut. Bin allerdings sofort auf den Franco 328 gewechselt.
Hat jemand noch eine Empfehlung bezüglich Kernel?
Franco 328 oder Zen 9?
Ich kann dir keine Empfehlung zwischen den beiden Kernel geben, aber der Franco 328 läuft bei mir ohne Probleme sehr gut.
Reaktionen: Zwirbu
Bin gestern Abend auch gewechselt von CM10 hier auf die R7.
Erster Eindruck ..... gar nicht mal so schlecht ......denke das
werde ich mal ein paar Tage drauf lassen obwohl ich doch jetzt schon ganz
schön das %vor der Accuanzeige vermisse.
Schöne Arbeit und heute schaue ich mal wie sich die Accukurve verhält.
Danke
Mr.a
Apropos Akku...
Hab jetzt über Nacht im Flugmodus ca. 2% verloren. Gestern mit der R6 waren es noch 10%! :)
Wahrscheinlich war beim flashen der R6 irgendwas nicht ganz rund gelaufen...
Moin,
es wurde doch auch mit der neuen Version r7 ein neuer Kernel mit geliefert und der soll angeblich auch die Akkulaufzeit verlängern :D
Ich werde das mal im Auge behalten!
Wäre doch nicht schlecht :)
Emsholgi
Auch von mir was zum Thema Akku:
Ich habe mein Gnex gestern Abend 22.30 Uhr mit 88% einfach aus der Hand gelegt
und heute früh 6.30 mit 85% wieder in die Hand genommen.
Eingeschaltet war das, was zu Hause immer eingeschaltet ist (d.h WLAN, BT, Mobilfunk incl. Data - kein GPS).
Es lebe der Zen v8. :thumbup:
Reaktionen: Emsholgi und Elting
Ich hab mal gerade den Zen v9 drauf gemacht. Mal schauen...
Eigentlich bin ich mit Franco zufrieden, allerdings gefällt mir gerade seine 'Update-Politik' nicht. Die App bietet seit 4.2 gar keine Updates mehr an... immerhin gibt es jetzt flashbare Zips auf der Homepage von Minooch... :blushing:
Reaktionen: Ursus77
schnueppi
schnueppi
schnueppi
MoRtAl
Pierro
Pierro
Pierro
