molesarecoming
Google Translate
Screenshot 1: SystemUI.apk (Status/Navbar) in PhoneUI, Launcher in PhoneUI, both 320 DPI
Screenshot 2: SystemUI.apk in TabletUI at 220 DPI, Launcher in PhoneUI at 320 DPI
Screenshot 3: SystemUI.apk in PhoneUI, Settings.apk is being projected into TabletUI at 245 DPI
Find any combination you like, scale and project apps, widgets and system components!
JELLYBEAN 1.6 PRE-PRE-PRE-PRE-ALPHA-EARLYBIRD, for alpha testers and experienced users only
ICE CREAM SANDWICH 1.5 STABLE
To be honest, this is not tablet mode at all, it has nothing to do with silly build.prop hacks. This is the first and only Android rom to feature true Hybrid mode. This rom lets you scale and project every app, every widget, even systemcomponents individually. For every component that you like chose a mode (TabletUI, Phablet-Nexus7UI, TabletUI) and a size. You are 100% independend of the system DPI which runs nicely in whatever value it has been assigned to. You do not need to boot your phone into a certain DPI, for most of the changes you make you won't need to reboot aswell, you will not suffer from the myriads of troubles you normally get under build.prop tablet mode, market, phone, etc. will all work, apps won't shrink on you unless you shrink them yourself. This is an ongoing developer project to make way for a modification that will entirely transform your device, but retain the aesthetics and the experience of your phone.
Notice: If you want to see this rom in action choose the ICS version. JB is being worked on, it has the basic functionality but you won't get the panel to control it and you wont get the extras yet. If you want to be on the bleeding edge flash the JB version and control your apps by editing /system/pad.prop. Expect updates soon.
Donations to molesarecoming
to D4rKn3sSyS
to Cyanogenmod
to D4rKn3sSyS
to Cyanogenmod
- CWM: Wipe Cache / Factory Reset IF you come from another rom than JB 4.1 STOCK OTA/IO-Preview
- CWM: Install Zip File: (ROM) https://rapidshare.com/files/3026254380/paranoidandroid_jb_16.zip (includes GApps!)
- CWM: Wipe Cache Partition
- CWM: Advanced/Wipe Dalvik Cache
- Reboot
- CWM: Wipe Cache / Factory Reset IF you come from another rom than CM9 or PA
- CWM: Mount & Storage\Format /System
- CWM: Install Zip File: (ROM) /drcmda/maguro/
- CWM: Install Zip File: (GAPPS) /drcmda/common/
- Reboot and edit your Apps Dpi & Layout under Settings/Paranoid Settings
- Our webpage: ParanoidAndroid » The best of both worlds
- You want to port PA? Take a look here: [PARANOIDANDROID 1.5>] [CM9HYBRID] Developers only: Porting, Support and Maintanance - xda-developers
- Themes and other goodies you can find here: [PARANOIDANDROID STUFF] - Walls, Themes, Guides and..... - xda-developers
- Go to Settings, System, Font size, set it to NORMAL
- Check "Auto Hide" in Settings, System, Statusbar, to finally get Fullscreen
- Trebuchet Settings: margins:SMALL, show permanent searchbar:YES, Grid: 4x4, resize all widgets:YES, Wallpaper scrolling: OFF
- If you have an issue and you want to call our attention, here's what you do:
- 1. Try everything you can, find solutions for yourself. Wipe caches, revert all your settings you have made, go back to your stock Kernel, factory reset if you have to or reflash the rom. Assume that the issue is on your side and try your best to isolate it.
- 2. Search this thread and Cyanogenmods aswell (its our base) for possible reoccurences of your issue and hopefully solutions that may have come up.
- 3. If you think the issue is important enough that we should cease our work and look into it, post your issue, BUT ...
- ... stay friendly, do not demand anything, do not threaten
- ... explain your issue as precise as you can, name the exact apps and conditions that cause trouble, help us to replicate the issue right away. If we can't there's no way we can fix it and your post will simply clutter the thread
- ... collect evidence, keep in mind this is a developer thread so even if you are not one, do us the favor and research how to record logcat. logcat is the single most important help you can give us to resolve your issue.
- Tina: Home
- Cyanogenmod Team
- Franko, for his Kernel
