[ROM-ICS] MoDaCo ICS Custom ROM
  • 136 Antworten
Alex.Sikes
Alex.Sikes
Dauer-User
686
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem "Samsung Galaxy Nexus". Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
MoDaCo Custom ROM
(Update vom 04.04.2012)
Voraussetzung
- Device muss gerootet sein HowTo
- ClockworkMod Recovery muß installiert sein HowTo
MoDaCo Custom ROM
Code:
[FONT="Arial"][SIZE="3"][B]Features[/B][/SIZE]
- Rebuilt, compressed and optimised with the MCR build system
- Based on the 4.0.4 / IMM30B CDMA leak with IMM76D merges, modified where appropriate for GSM compatability using our own compatability layers
- Stock Kernel and franco.Kernel options - with Franco's kind permissions, the -kitchen contains his milestone releases
- Added initial support for contact sync via the Facebook app. Further enhancements to follow, but basically functionality should now be working
- EFS auto-backup script
- 'TweakDeck', Galaxy Nexus optimised Tweetdeck
- Auto backlight settings from 4.0.3 (much improved!)
- All Google components are running the latest
- Superuser application and su binary from ChainsDD for SAFE root functionality
- Alternative SuperSU from Chainfire in the ktichen
- SQLite performance patch
- Not odexed
- Insecure boot image
- Launcher with rotate support
- Nova Launcher as default launcher (courtesy of teslacoil software)
- Apex Launcher a secondary option (I now use this because of it's vertical scroll support)
- Tesla LED (courtesy of teslacoil software)
- Alternative appstores (Amazon, GetJar patched for maximum compatability and SlideMe Market)
- Faster rotation
- Trackball Alert Pro compatibility
- Alernative UI options (clickable when hidden menu keys with alternate locations, search button)
- Percentage battery mod (circle and normal) included - now independent of the custom UI buttons option
- Our own 'OdexMe' on-demand odex application
- Enhanced Power Menu by djmcnz (updated for Ir13)
- Development Tools
- ClockworkMod ROM Manager
- Disabled menu key unlock
- init.d support on boot
- Customised keyboard (enhanced prediction options, see advanced settings)
- Offline Gallery (no picasa or Google+ sync, allows Google Plus to be uninstalled / frozen)
- Titanium Backup
- avast! Mobile Security baked in
- CyanogenMod APN list
- CyangoenMod Dialer
- 4.0.2 build fingerprint
- Disable camera shutter sound
- MMS compatability patch
- XXKK6 baseband
- XXKL1 baseband
- Much much much more![/FONT]
| Dev: Paul O'Brien | Homepage | Download: MoDaCo IR13 | Online-Kitchen |
HINWEIS: Die Funktion der Online Kitchen ist nur mit einem Premium-Account auf MoDaCo möglich. Gegen eine
Jahresgebühr kann man sich einen Premium-Account auf MoDaCo bestellen. Weitere Informationen dazu findet Ihr dort.
Code:
[FONT=Arial][SIZE=3][B]Changelog[/B][/SIZE]
[SIZE="1"][COLOR="Red"]Letzte Einträge vom 05.04.2012 11:35 Uhr[/COLOR][/SIZE]
[B]MoDaCo Custom ROM v.IR13[/B]
- Merge with production 4.0.4 for both GSM and CDMA releases (phase 1, further changes to follow) including updated radio in kitchen
- Updates to all outdated components..
[B]MoDaCo Custom ROM pre v.IR13[/B]
[U][I]13.03.2012[/I][/U]
- Updates to Amazon Appstore, Apex Launcher, Nova Launcher, SuperSU and Titanium Backup
[B]MoDaCo Custom ROM v.IR12[/B]
- Transition out of Beta release (beta and main topics will merge)
- Updated all outdated apps / components in the build
- Added Apex Launcher as a kitchen option
- Added franco.Kernel milestone 1 as a kitchen option
- Added SuperSU as a kitchen option
- Added 3 MoDaCo wallpapers on sdcard
- Minor install script tweak
[B]MoDaCo Custom ROM v.IR11 Beta[/B]
[U][I]21.02.2012 pre-Beta 3[/I][/U]
- Updated to fix very rare SystemUI crashes
- Updated various app components (Google Plus, Maps, Nova Launcher)
[U][I]16.02.2012 pre-Beta 3[/I][/U]
- Resolved MHL connectivity reboot issue.
[U][I]15.02.2012 pre-Beta 3[/I][/U]
- Added alternate messaging app to the kitchen (use if you are having issues sending MMS).
- Widgetsoid icon in status bar is now hidden
- Custom button images can now be pulled in on bootup - simply replicate the SystemUI directory structure (e.g. res/drawable-xhdpi/) under /system/mods/buttons and include the files you want replaced.
- Launcher with no rotate resigned (user problem report)
[U][I]14.02.2012 pre-Beta 2[/I][/U]
- CM Contacts / Dialer now available in the kitchen
- On-boot signature update mechanism and other changes to facilitate the above!
- WiFi signal strength update for CDMA version
- Added 4.0.2 build fingerprint options (ensure you select the correct version - GSM / CDMA)
- Fix for intermittent SystemUI crash
[U][I]10.02.2012 pre-Beta 2[/I][/U]
- Updated Nova Launcher
[U][I]09.02.2012 pre-Beta 2[/I][/U]
- Added circular and stock style battery percentage mods
- Added 'offline gallery' option
- Removed rotation from the lockscreen (by popular request!)
- Even faster rotation
- Added optional stock Launcher with rotation support
[U][I]08.02.2012[/I][/U]
- Resolved Chrome crash issue (moved to /data/)
- BETA 1 CUT POINT
- Added Google Chrome Beta
- Added Enhanced Power Menu!
- Added Trackball Alert support.
- Framework changes in preperation for enhanced power menu.
- Added Facebook sync support to the kitchen
- Signal indicator fix!
- WiFi weak signal fix
- Tether fix for GSM build
- Fix for CDMA build
[U][I]7 Feb 17:30[/I][/U]
- Disabled menu key in lock screen
- Enabled rotation on lock screen
- Enable rotation to all angles (including upside down)
- framework-res prep for battery customisations
- Restored HSPA differentiation in status bar
- The full complement of button tweaks is now online!
- Added the first custom UI tweak - my preferred option - search button and hidden menu buttons. More to follow.
[U][I]7 Feb 14:00[/I][/U]
- Initial Release
[B]MoDaCo Custom ROM v.IR10[/B]
- Ir10 released and prebakes online!
[B]MoDaCo Custom ROM v.IR10-dev[/B]
[I][U]17.01.2012[/U][/I]
- Version bumped to Ir10 on device and Ir10-dev on kitchen in preperation for Ir10 release
- Kitchen defaults tweaked in preperation for Ir10 release
- Added alternative appstores (Amazon, GetJar, SlideMe)
- Updated TweakDeck
[B]MoDaCo Custom ROM v.IR9[/B]
- Nova Launcher is now included in the kitchen (by kind permission of TeslaCoil software) - this will be the default launcher for Ir10
- TeslaLED flashlight / torch is now included in the kitchen (by kind permission of TeslaCoil software)
[I][U]16.01.2012[/U][/I]
- Kitchen: fixes for the battery percentage options
- Kitchen: renamed the incorrectly identified kernel options
- Kitchen: updated the TweakDeck version
- Kitchen: removed Trebuchet pending further changes required for 4.0.2 support
[I][U]13.01.2012[/U][/I]
- Ir9 release!
- Added exclusive XXKL1 radio.
- Added CyanogenMod 'Trebuchet' launcher to the kitchen (user request) (Ir9-dev)
- The battery percentage mods are now independent of the UI tweaks! (Ir9-dev)
- Added 'OdexMe' (a MCR exclusive application by Paul O'Brien) for on-demand odexing (Ir9-dev)
- Resolved issue with UI choice options in the kitchen (Ir9-dev)
[I][U]09.01.2012[/U][/I]
- MoDaCo Custom Kernel r8 (all versions)
- Kitchen fixes
- Based on an unreleased Samsung leak
- Google Plus changes to resolve clean boot issues (if you get a G+ crash on install, visit Market to install the latest update)
- Widgetsoid tweak - If you use Widgetsoid to have a toggle bar, this ROM won't show the icon! It will also improve the anchoring of the toggles to the top of the notification bar
- Abstracted 4.0.3 kernel compatability layer
- Changes to help fix camera issues with 4.0.3 compatability layer
- Kernel and various changes to noticeable improve battery life
[B]MoDaCo Custom ROM v.IR8[/B]
[I][U]23.12.2011[/U][/I]
- Version bumped to Ir8 ready for general release
- Updated all Google components
- Added Titanium Backup to kitchen (user request)
- Added avast! Mobile Security to kitchen (user request)
- Added percentage battery mod (circle) by hooolm (updated to Ir8 compatability) to the kitchen
- Added percentage battery mod (stock style) by hooolm (updated to Ir8 compatability) to the kitchen
[I][U]22.12.2011[/U][/I]
- Fixed Trackball Alert support
- Added enhanced power menu by djmcmz (patched for Ir8)
- Added enhanced launcher by djmcnz
- Re-added rotation speed enhancement
[I][U]21.12.2011[/U][/I]
- Major update to ICL53F (4.0.2) release
- Android 4.0.3 compatability package
- this ROM supports 4.0.3 kernels
- MoDaCo Custom Kernel (MCK) r7, 2.0.3 source based kernel with CIFS added, regular, OCUV and UV only versions included.
- Auto backlight levels updated to 4.0.3 settings (much, much improved!)
- Other minor tweaks and improvements
[B]MoDaCo Custom ROM v.pre-IR7[/B]
[I][U]16.12.2011[/U][/I]
- Minor bug fixes
- Google app updates (Music, Vending, Plus, Maps)
[I][U]15.12.2011[/U][/I]
- XWKK9 merge (exclusive leak at MoDaCo, thanks secany!)
[B]MoDaCo Custom ROM v.pre-IR6[/B]
- Ir6 commited to prebakes
- Minor kitchen default option changes
[I][U]14.12.2011[/U][/I]
- Updated MoDaCo Custom Kernel (MCK) to r5 (standard and oc/uv), removed USB OTG wakelock.
- Added baseband UGKK7 option
[I][U]13.12.2011[/U][/I]
- Added EFS auto-backup script
- Replaced 'patched TweetDeck with 'TweakDeck'
[I][U]07.12.2011[/U][/I]
- Added MCK r4 with coolbho3000's OC/UV changes
- Added 2 step auto-backlight patch
[B]MoDaCo Custom ROM v.IR5[/B]
- Updated MoDaCo Custom Kernel (latest source including volume fix, patched to 3.0.9)
- Fixed backlight patch
- Added XXKK6 radio option (thanks imth!)
- Added Trackball Alert Free edition
[B]MoDaCo Custom ROM v.IR4[/B]
- Merged in ITL41F update
- Optional Offline Gallery (no picasa or Google+ sync, allows Google Plus to be uninstalled / frozen)
[B]MoDaCo Custom ROM v.IR3[/B]
- New stock kernel with volume bug fix
- Launcher with landscape support
[B]MoDaCo Custom ROM v.IR2[/B]
- Added new MoDaCo Custom Kernel (r3) with screen improvements!
- Added customised stock keyboard, it now support enhanced word prediction (see advanced settings)
- Added init.d support to boot image
[B]MoDaCo Custom ROM v.IR1[/B]
- Initial Release
- Added option to disable camera shutter sound
[/FONT]
Alex.S
Reaktionen: Babbaaa, DopeyDevil, galaxyS-rookie und 6 andere
Argh ich wollte doch auf Stock bleiben :)
Das ist der Hammer, das Ding ist ne Woche draußen und schon gibts das erste Rom.
Ich freu mich so wenn meins endlich kommt. Aber mal zu meiner Frage, kann vlt. mal jemand die
Feature Liste auf Deutsch übersetzen, ich bin zwar des Englischen mächtig aber das ein oder andere
verstehe ich in der Liste dann doch nicht. Und ich denke das geht nicht nur mir so.
Also sollte Google bis nächsten Freitag kein OTA Update raus hauen verwerf ich meine Vorsätze und geh eben wieder auf Custom Roms :)
im moment gibt es den volume fix nur im stock kernel.
paul meint, es gibt keinen source, um es in seinen einzubinden
da ist er wieder der suchen button. hmmm :)
Hat denn schon jemand von den Glücklichen die Rom ausprobiert?
sobald meins eintrifft, kommt dass ding drauf.
leider mit dem stock kernel.
paul wird hoffentlich versuchen, den volume fix in seinen eigenen zu integrieren
In der IR4 ist er doch schon drin! Dürfte heute oder morgen online gehen!
oder ihr werded premium user. die 9 pfund im jahr sind es mir wert paul zu unterstuetzen auf den man sich immer verlassen kann.
IR4 enthält nicht pauls custom kernel, hat er gestern im thread auf meine anfrage besttätigt.
ich werde die 9 pfund auch ausgeben, aber erst wenn das phone da ist
Ich versuiche jetzt schon das vierte Mal, mir das aktuelle MoDaCo ir4 ROM zu flashen und lande leider immer wieder aufs neue in einem Bootloop (das Bootlogo ist zwar schön, wird aber doch irgendwann langweilig).
Restore des Nandroid Backups klappt problemlos (puh), aber das Flashen will nicht.
Ich weiß leider nicht, wo mein Fehler liegen könnte. Hier die Schritte:
Root über Superboot, aktuellstes CWM.
  • ROM über die Kitchen gebacken
  • CWM - Install ROM from SD
  • Installation läuft offenbar fehlerfrei, zumindest kommt kein Fehler
  • Reboot - Bootloop
Sooo viel kann man doch nicht falschmachen, oder?
Ich habe schon signed und unsigned probiert, vorher nen Wipe gemacht, nichts ...
Hat irgendjemand eine Idee oder einen Tipp?
Danke!
EDIT: So, jetzt vorher mal Mikes Super Wipe Scrpt durchgeführt und siehe da, danach klappts auch mit dem MoDaCo.
hat jemand schon die ir4 drauf?
Hab sie den halben Tag am laufen und ist bisher sehr gut. Allerdings merk ich nichts vom backlight fix obwohl in der kitchen ausgewählt...
Sent from Galaxy Nexus
Hallo leute,
mein Nexus hab ich gerade einen neuen ROM raufgemacht von MoDaCo
und der bootet immernoch. Was sollte ich jetzt machen?
Der Bootvorgang hat bei mir auch (verdammt) lange gedauert.
Aber jetzt läuft bei mir alles einwandfrei (ebenfalls Rom aus der Kitchen)
Kannst du mir sagen welche Vorteile MoDaCo für dich persönlich hat? Also im Vergleich zur Stock?
Hat die rom, die Paul kostenlos anbietet den Suchbutton? Weil der gefällt mir nicht.
Schonmal danke.
Wie lange ist (verdammt) lange?... Bin mir langsam auch nicht mehr sicher, ob ich einen bootloop habe oder er noch beim aufwärmen ist...
MoRtAl
Pierro
Pierro
Pierro
Buuud
