[ROM-ICS] Manhattan IC120 (v 1.2.0 / 22.02.12)
  • 36 Antworten
scimitar
Stamm-User
192
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem "Samsung Galaxy Nexus". Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Ersteller und damit alle Credits gehen an gnufabio
[ROM] [AOSP 4.0.3] Manhatten IC101 - XDA Forum
Download:
Version IC120:
Download Manhattan IC120
Gapps
: IML74K-010112.zip
Mirror Downlod:
-World-of-Nexus-
Features:
  • Fast and stable
  • Trebuchet instead of the Classic Launcher2
  • Built-in audio enhancement
  • Lot of tweaks, this rom is completely customizable.
  • Facebook sync enabled
  • Battery percentage in the lockscreen
  • Super slim
  • Led settings
  • Notification widget
License:
Manhattan distributed under Creative Commons 3 BY-NC-ND license. If you want to use a part of my work, please send me a PM and ask for permissions. I may make it open source when I'm able to upload the sources.
More details on the license:
Credits:
  • Google for ICS AOSP
  • CyanogenMod team for their awesome work
  • bigxie for his support
  • Andrew2511 for his help
  • Romanbb for the facebook sync and some codes
  • Goo-inside.me team for the hosting!
  • Imoseyon for the kernel
Reaktionen: Falsche Uhrzeit und wemsinho
Changelog:
Version IC120:
  • Updated Trebuchet, fixed the laggy app-drawer.
  • Moved battery icons from framework to systemui for a lighter system.
  • Fixed MMS app not sending SMS with more than 360 chars.
  • Updated kernel to latest 2.2.0.
  • Hopefully fixed the keyboard lag.
  • Some other bugfixes.
Version IC112 (1.1.2) | OTA:
  • Updated kernel to 1.8.0
  • Added Adb over network to Developer Settings. Thanks CM team.
  • Added the possibility to hide battery icon to ManhattanSettings.
Version IC111 (1.1.1):
  • Fixed problems with Manhattan Settings
  • Improved speed of the navigation bar buttons (thanks bigxie)
Version IC110 (1.1.0):
  • Updated kernel to latest Leankernel 1.7.3 (thanks Imoseyon as always)
  • Added three new battery icons (thanks Andrew2511 and Circlemod team)
  • Added longpress action to the search button (now it will open the Voice Search)
  • Updated Trebuchet with new options and transitions
  • Removed gmail bugreport
  • Added flash button to the notification widget (it's still in a initial stage, it will open TeslaLED app)
  • Enabled OTA app from ManhattanSettings (download it from Android Market)
Version IC102 (1.0.2):
  • Added the new "Battery bar" option
  • Added an option to take photos throught the volume keys too (enable it from ManhattanSettings → System)
  • Improved central and left clocks, now they animate when a notification appears.
  • Fixed bugs with root-applications.
  • Updated Trebuchet with latest bugfixes.
  • Other fixes/improvements I don't remember (lol)
Update IC101 (1.0.1)
  • Fixed the centered-clock's bug.
  • Added an option to put the clock to left in the statusbar.
  • Now you can set the color of the clock from Manhattan Settings.
  • Fixed wrong strings in ManhattanSettings.
  • Added a new battery icon style (Black and white)
  • Added an option to always show the Menu button.
  • Removed the confirmation dialog for the reboot.
IC100 (1.0):
This is a Major update. A wipe is suggested.
System:
  • Added Manhattan Settings, a nice app to controll the system.
  • Updated Trebuchet: latest fixes, added effects and transitions.
  • Super speed up: super fast system.
  • Using imo kernel instead of stock (thanks imoseyon)
  • Added Performance settings to Manhattan Settings
  • Added a toggle in Manhattan Settings for the 180° rotation.
  • Added an option to Manhattan Settings to controll the rotation delay.
UI:
  • Added battery percentage in the statusbar (in the expanded statusbar, toggleable from ManhattanSettings)
  • Added different battery icons (you can switch to them from Manhattan Settings)
  • Added an option to change the opacity of the statusbar.
  • Statusbar's clock options: Central/Right/Hidden, AM/PM settings, 24H toggle.
  • Hardware-accelerated statusbar by default, you can revert this change from ManhattanSettings.
  • Added an option to change the statubar navigation buttons color.
Other:
  • Now you can set the default color for led's notifications from Manhattan Settings.
  • Now you can disable the hardware volume keys from Manhattan Settings.
  • Improved Launcher's performances.
  • Other minor bugfixes.
Special Thanks for this version:
  • CyanogenMod team for Trebuchet and the T9 Dialer.
  • Romanbb for the color picker.
  • imoseyon for the kernel.
  • Xoomdev for his work, I take suggestions from his mods.
  • Andrew2511 for translations.
  • Jrummy for the performance settings
Danke für den Thread!
Ich hätte ja gedacht er nennt sein ROM Shotgun oder so - nach Revolver für das Transformer ;)
Gesendet von meinem Galaxy Nexus mit Tapatalk
schaut gut aus, werde es mal testen.
Läuft super. Konnte bisher noch keine Bugs feststellen. Selbst mit Stock Kernel top Akkulaufzeit. NFC funktioniert voll.
hoffe er bringt auch hier wie beim revolver seine OTA app :)
Siehe vorletzter Screenshot "Manhattan Settings" - ist das keine App?
jain, mit Revolver Parts (Market) hat er fürs Transformer eine OTA app, die halt bequem Updates meldet
(er baut gerne und öfter mal so kleine patch-updates wie auch aktuell zu sehen mit 1.0.1)
Davon abgesehen hat er dort auch ausgewählte themes/kernels usw. die immer aktuell gehalten werden
Aber vielleicht baut er das alles auch einfach im die Manhattan settings, anstatt eine zweite app ;)
Das wäre super. Hab in letzter Zeit sogut wie alle Roms getestet. Ich muss sagen das die Manhattan am besten läuft. Vorallem hält der Akku im Gegensatz zu AOKP mindestens 10h länger. Ich komme so auf 36 stunden!
Eine solche Update App wäre super!
ich hab mir die Custom Rom installiert, gefällt mir so ganz gut. Aber die Benachrichtigungs LED funktioniert nicht. Ist alles auf Standard, bis auf das ich die Farbe eingestellt habe, auf Rot.
Nun leuchtet die LED bei einer WhatsApp Nachricht Weiß und bei einen verpassten Anruf, SMS, leuchtet sie gar nicht. Eigentlich kann man nicht viel falsch machen oder?
Sei einem Tag teste ich jetzt dieses Rom und bin sehr zufrieden.
Es ist schlank,schnell,stabil,gut konfigurierbar,stellt mehr freien Speicher zu Verfügung(im Vergleich zum AOKP).
Am besten finde ich,dass Updates per OTA zur Verfügung gestellt werden.
Das letzte Update/Version war nur ca.11MB groß,ruckzuck aufgespielt und ohne Gefummel oder viel Traffic, stand das neue System.
St0neC0ld schrieb:
komisch, das Problem hatte ich bis jetzt noch gar nicht. Also bei What´s App leuchtet die LED in der von mir gewählten Farbe und auch bei Mails oder SMS oder Kalender Alarmen etc....werde es aber mal beobachten.
Habe nun seit zwei Tagen die Manhatten Rom drauf, läuft soweit auch sehr gut.
Nun habe ich aber das Problem, dass mein Nexus öfters im Standby die Verbindung zum Mobilfunknetz verliert. Es hilft dann nur noch Flugmodus an/aus.
Hoffe, dass mir jemand helfen kann. ;)
hab heut auf v 1.1.2 nachgezogen und das mit der LED funktioniert weiterhin nicht ordentlich bei mir, sehr merkwürdig
die farbe kann ich einstellen und bei einen whatsapp nachricht blinkt die LED, aber z.B. bei einen verpassten anruf nicht (mehr hab ich noch nicht getestet)
klar ist lightflow eine einfache lösung, aber warum eine extra app wenn das rom eine solche funktion hat :unsure:
derzeit bin ich wieder beim Apex ROM, daher kann ich es nicht testen. Meine mich aber erinnern zu können, dass die LED auch bei verpassten Anrufen geblinkt hätte.
Wenn ich wieder zu Manhattan zurück kehren sollte, werde ich auch jeden Fall nochmal drauf achten.
Was ist denn bei SMS oder Mail´s blinkt da was?
Der Vorteil von Lightflow ist halt, wie ich finde, dass man die Farben doch sehr viel freier definieren kann, allerdings sind nur in der Bezahlversion auch Apps, wie What´s App, FB und so drin, meine ich zumindest gesehen zu haben
Und ich bin von Apex auf die Rom wieder zurück :D
hab erstmal wieder lightflow drauf, mal abwarten und nochma testen wenn es eine neues update gibt, vllt funzt es dann.
Neue Version 1.2.0 ist online!
Im XDA Forum wird von einem Kamera Bug berichtet.
Habe es todesmutig trotzdem geflasht und bisher keine Probleme mit der Cam.
Einfach über die aktuelle Version, ohne Wipe von Cache oder Dalvik Cache, anschließend noch die GApps geflasht und das wars.
Allerdings habe ich ein anderes Problem, zur Zeit scheint meine Internet Verbindung immer mal wieder abzubrechen, allerdings wird angezeigt ich hätte weiterhin Empfang. Werde das mal beobachten.
Oh und zu dem LED Problem, konnte ich jetzt nicht so fest stellen, habe es aber bisher nur bei SMS und Mails überprüfen können, What's app funktioniert ja sowieso :)
Sent from my Galaxy Nexus
Moin, das lag bei mir am baseband. Ein Update auf's aktuelle hat mir einen absolut guten Empfang ohne irgendwelche Störungen beschert.
Grüße, Tobi
MoRtAl
Pierro
Pierro
Pierro
rl2664
