joker.20
SO es gibt was schönes neues, hab ich seit paar Tagen drauf.
Hab den bei Rootzwiki gefunden.
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem "Samsung Galaxy Nexus". Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Ersteller und damit alle Credits gehen an travp624
http://rootzwiki.com/topic/18297-black-ice-maguro-kangorade-3333-4-20/
This is my daily driver right here mostly built for me but since I built it from AOKP's beautiful source. I figured I would share with everyone! Its Aokp in everyway and at no time will I try to take credit for their beautiful source. I only sync'd it modified it to my liking and themed the hell outta it!
And it now is my pleasure to announce a joining of Mastur Mods and StyGian Studios so in the spirit of that. Mastur Mods and StyGian Studios gives you!!!
Black ICE
features copy and pasted from AOKP thread
This is full AOKP as its built from teamkangs source slightly and only slightly modified by me!
Change LogsInstead of builds like AOKP we will go with Kangs and match the no. to AOKP builds
Downloads
Quote
I Recommend a Wipe with Kang 23.23 but if you choose not that is on you!
md5=34d8d2ac8d3ea7eaefab5b5be4e26e0f
Install Instruction
I will always recommend a data wipe and very important make a nandroid always!!
If you choose not to use my Gapps you or follow instructions then you will need to ask yourself why isn't this or that working right!
1. Make sure your using latest cwm
2. These must be followed exactly
2. Download all 3 and place on phone
3. I recommend wiping data/factory reset (especially if on another rom)
4. Flash Rom
5. Flash Black_ICE_stock-Gapps zip
6. Reboot go thru setup sign in to google account!
7. Get thru setup. (If you wanna let market restore your apps wait but try not to open market LOL)
7a. If you opened market before rebooting go into settings>apps>all apps and uninstall market updates!
8. Reboot back into cwr and flash Black_ICE-gapps zip
(history of why the two gapps packages if you followed my inverted apps thread at all you would know that a fresh install of inverted apps just is a no go. The edited manifest just don't take. But thru alot of trial and error I figured out a hack around it and so the need for the stock gapps comes from that.)
Upating instructions if already on Black ICE
1. Flash Rom update
2. Flash Black_ICE-gapps only
3. (Optional) if you wanna wipe cache and wipe data-dalvik
4. Reboot
Quote
Preparation for the UPCOMING Kang 23.2 App needed after hiding the navbar (if you don't know what I'm talking about then this ain't for you and you will need to read up and make sure you know what your doing). I highly recommend LMT you can get it here There are others as well but can't remember there names.
Now the Credit
Usual disclaimers all apply here!
Black ICE
- built from AOKPsource (source)
- power menu (source)
- ICS style toggles
- superuser & busybox built from source, included
- deodexed & unsecure boot.img (for adb remount)
- Facebook contact sync
- Black ICE Control application lets you take control of your ROM. Customize it how you want it. (Full credit to Roman for making this. I only themed it (no more unicorns))
- Navigation Bar options & layouts (search bar layout, menu visibility options,etc) -- long press search button enabled
- IME Switcher toggle (show/hide notification when you type)
- Customize your carrier label
- Override lockscreen timeout (ie, use Android's timeout when turning the phone off, so it won't lock itself)
- LED pulse timing options
- Statusbar toggle options
- much much more in there
- battery mods built in (including circle mod)
- Unique Power Saver functionality
- Turn data off while your screen is off
- manually sync at a time interval for all your accounts (Gmail, etc)
- Check out all the options in ROM Control
- add cm filemanager
- add dspmanager
- removed status bar notification icons dimming effect (me)
- Kang 23
- sync'd updates from aokp source (thanks teamkang)
- replaced launcher2 with trebuchet (thanks cyangenmod)
- centered lockscreen clock (me)
- added cm9 Messaging instead of stock
- new 1-100% battery icons (mastur mods)
- new charging animation (mastur mods)
- Kang 23.1
- merged up AOKP source
- special init.d scripts provided by DroidTh3ory which gives extra special smooth butter to Black ICE
- Lockscreen wallpaper chooser in Black ICE control(courtesy of Roman of Course)for all lockscreen types (me)
- Fixed Power Btn Flashlight
- Fixed Alternate Toggle on/off btn size
- Fixed lockscreen clock and text now Center (All Lockscreen types)
- Other small fixes I don't remember
- Kang 23.23
- merged up AOKP source sorta LOL
- fixed custom targets on lockscreen (thanks roman)
- fixed DSPManager (my stupid ass used gingerbread version, Now ICS version)
- added Hide Navbar to power menu. (Use with caution)(Zaphod-Beeble's code implented by me into Black ICE)
- fixes to lockscreen wallpaper (credit roman)
- fixed up stock status bar images (Mastur Mynd)
- MasturModsSettings now baked in (app and source from Mastur Mynd baked in by me)
- Others I forgot already
- Kangorade 24.1
- merged up AOKP 24 (#teamkang)
- fixed up Navbar hide its instant now (thanks to Zaphod-Beeblebrox)
- lots of bug fixes! (me and #teamkang)
- others !
Downloads
Quote
- Rom Download
- Black_ICE-MaguroKangorade24.1-02202012.zip
- Kangorade 24.1 Mirror
- AOKP modified Gapps
- Black ICE Gapps *update 2-20 (new youtube)
- Black_ICE-gapps-02202012-signed.zip
- Black ICE gapps 2-20 Mirror
Install Instruction
4. Flash Rom
1. Flash Rom update
4. Reboot
Quote
Now the Credit
- The entire team at teamkang without them the gnex plus many more devices wouldn't be so buttery smooth!
- The entire team at cyangenmod awesome source
- Mastur Mynd for being awesome and for asking me to join mastur mods
- DroidTh3ory for his decision to help somewhat!
- Google of course
- Everyone in the community who helps in the spirit of open source
- And anyone I forgot to mention or include
