[ROM-ICS] Android Revolution HD
  • 67 Antworten
escrivel
escrivel
Dauer-User
354
Rom: [ROM] Android Revolution HD™ 1.2.3 | High Quality & Performance | ICS | Legendary - xda-developers
System details:
Android 4.0.1 (Ice Cream Sandwich) - official Samsung Galaxy Nexus GSM firmware ITL41F
Android 4.0.0 (Ice Cream Sandwich) - official Samsung Galaxy Nexus LTE firmware IFL10C
This is improved version of stock ROM - no visual changes!
Very fast, clean & stable!
Multi-language (WWE)
Full Arabic and Hebrew languages support! (ICS feature)
Included kernel details:
New kernel: 3.0.9-mck-r3+
Many CPU governors (Interactive, Ondemand, Performance, Conservative, UserSpace)
NOOP as default scheduler
USB drive / keyboard / mouse support
CIFS support
Screen improvements
Purely config tweaks
You can find custom kernels here
Kernel source (paulobrien)
ROM details:
Fully optimized and tweaked
ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
Unsecured boot.img
Newest BusyBox
RAM optimizations
Speed optimizations
SD Card speed tweak
Data, cache and system partitions mounting tweaks
Battery auto-calibration script (Thanks to seo)
Bloatware applications removed
All system applications updated to latest available
Zipaligned (Improved RAM management)
Zipalign on boot (for user applications on data partition)
Fully de-odexed
init.d scripts (BusyBox run-parts) support
Signatures hack
Excellent battery life!
Device partitions mounted & formatted as fast EXT4 with many optimizations and EXT4 alignment
You can replace Samsung boot animation with any custom one (or use ICS default)
Support almost 24h a day
...and many more!
You need:
Samsung Galaxy Nexus GSM or LTE rooted with [MOD] Superboot - rooting the Galaxy Nexus
ClockworkMod Recovery
Android Revolution HD 1.3.1
--- release date: 6 December 2011 ---
Improved 3D performance
Google Music updated to latest 4.0.9
Some fixes to updater-script
Fixed ROM name in "About phone"
Other minor changes and fixes
- No need to use Super Wipe if you have 1.3.x already!
Grüße,
im thread ist jedenfalls zu lesen, dass der "Entwickler" "mike1986." das telefon nichteinmal hat.
von daher vertraue ich erstmal auf MoDaCo
Nun die Revolution ROM´s werden im Desire HD Bereich sehr gut angenommen.
Hab mir die Rom jetzt mal drauf gemacht läuft bis jetzt einwandfrei.
hat es auch den Backlight fix? Mein GN ist so extrem dunkel...
Nein, für das zu dunkle Display gibt es auch bei diesem Rom keine Verbesserung.
Schade. Naja hab jetzt 50% Displayhelligkeit standardmäßig festgelegt. Das passt soweit ganz gut.
Da sich der Thread vor allem auf XDA großer Beliebtheit erfreut, habe ich den 1. Post mal etwas überarbeitet.
Kann mir mal einer verraten wie ich den USB-Massenspeicher verwende, der ja in diesem ROM integriert sein soll....?????
Wo steht, dass das funktionieren soll?
Sorry wenn ich das falsch verstanden habe. Dachte mit USB drive wäre der Massenspeicher gemeint.
Damit ist USB-OTG gemeint, muss mir noch so blöden Adapter besorgen um das mal zu testen.
Irgendwie ging das an mir vorbei, ich dachte bis heute immer das das auch mit der Stock geht?
HI
Ist der Volumen Bug noch in der ROM drin??
in der offiziellen Version ITL41F ist der Bug gefixt. Da dieses ROM auf eben dieser Version basiert, sollte also auch hier der Bug nicht mehr auftreten.
Viele Grüße
Handymeister
weil bei mir ist er noch komisch warum??
Was steht denn bei Dir für eine Build unter Telefoninfo?
itl41f
ist bei der [ROM] Original Stock Rom (ITL41F) rooted, busybox &. deodexed auch der Bug raus
Dann sollte nach allgemeiner Meinung der Bug auch raus sein! Jedenfalls bist Du, was ich bisher gelesen habe, der erste mit der Version der den Bug noch hat.
MoRtAl
Pierro
Pierro
Pierro
rl2664
