[ROM][4.0.4][IMM76I] Apex v1.1.2 + Apex v1.1.3beta2
  • 174 Antworten
boshot
boshot
Enthusiast
1.070
[ROM][4.0.4][IMM76I] Apex v1.1.2​
Features:
Built from AOSP source code - 4.0.4 IMM76I base
Stock look and feel with useful mods
Device specific control app (Galaxy Nexus Parts, Crespo Parts, etc) for low level adjustments
Customizeable Lockscreen (2-5 targets, custom targets, custom icons)
Customizeable Notification Pulldown Widgets
Customizeable NavBar w/ tutorial
Customizeable batteries (%, circle, bar, miui bar)
Customizeable Trebuchet Launcher with adjustable homescreen grid size
T9 Predictive (smart) dialer
Built in CPU Perfomance Settings w/ voltage control
Facebook sync enabled
Quick unlock (toggleable, for PIN and Password lockscreens)
3.0.30 Imoseyon leanKernel 3.5.0
Advanced Power Menu w/ reboot and screenshot options
Rooted and busybox preinstalled
All apks deodexed/zipaligned/optimized
Changelog:
Code:
[B][U]Apex 1.1.3beta2 (Download unter Extra/Mods)[/U][/B]
Bluetooth: AVRCP support for many players, MAP support
NEW Option to unlink ringtone & notification volumes (Sound Settings)
NEW Option to customize volume panel: single, expandable, expanded, none (Sound Settings)
NEW Quiet hours feature to set time span where phone doesn't interrupt you (Sound Settings)
NEW Statusbar brightness control: hold finger on statusbar and move to adjust brightness (Misc. Tweaks)
NEW Dialer advanced settings: vibrate on connect/disconnect, 45s, call waiting, option to turn on/off T9, hit name to dial
Fixed 2G/3G toggle
Updated NavBar: code cleanup, added big menu button option, button color option, option to hide navbar via APM
Updated leanKernel to 3.6.0: Linux kernel 3.0.31, gamma control, and more
[B][U]Apex 1.1.2[/U][/B]
- Updated to 4.0.4. IMM76I base
- NEW Kernel built inline with ROM
- Updated notification power widget drawables, fixed torch toggle
- NEW Lockscreen customization - customize up to 4 additional targets (5 total inc. unlock) w/ activities and icons
- Updated T9 dialer - no more slowdowns and crashes
- Updated Trebuchet launcher - more mod options, adjustable homescreen grid size
- Updated Messaging - support for emojis, custom vibration settings, and more
- NEW Quick unlock - enable to skip pressing OK after typing in PIN/Password at lockscreen
- NEW Device Control App - control screen colors, enable presets, and more low level mods
- Updated GAPPS package - using goo.im "official" package, no more update/signature mismatch issues
- NEW Navigation Bar customizations - pick and choose order, number, etc, with tutorial
- Updated leanKernel to 3.5.0 stable
[B][U]Apex 1.1.1 b6[/U][/B]
-3.0.30 leankernel compiled from imoseyon's latest stable source
-Additional stock icons for custom lockscreen, code fixes (credit Danesh M/CM9)
-Quick unlock added in Misc. settings (PIN/password unlock w/o hitting enter)
-Updated icons in the notification pulldown menu (CM)
[U][B]Apex 1.1.0:[/B][/U]
[U][B]Apex 1.0.2:[/B][/U]
Added option to change carrier text in notification pulldown (reboot required)
Added gesture templates in Messaging app
Fixed volume stepping in applications while volume music controls were enabled
Updated kernel to 3.0.18 imoseyon v1.8.0
Diese Dinge bitte beachten:
Anforderungen:
- GSM Galaxy Nexus (GT-i9250)
- Clockwork Recovery
- XXLA2 Radio oder neuer empfohlen für 4.0.4
Anleitung:
Flashbar über CWM recovery, Backup vor flashen empfohlen.
- Wipe dalvik/cache if coming from Apex 1.1.x, full wipe otherwise.
- flash rom
- flash gapps*
- reboot
Download:
Rom:
Goo.im Downloads - Downloading bigxie_maguro_Apex_v1-1-2.zip
Gapps*:
Goo.im Downloads - Downloading gapps-ics-20120429-signed.zip
GMail 4.0.5
https://www.android-hilfe.de/attach...tone-5-beta-build-34-24-04-12-gmail_4.0.5.apk
*die gapps einfach direkt am Anschluss an den Romflash hinterherflashen, ohne reboot, wipe oder sonstiges..
Extras/Mods:
Version 1.1.3beta2
credits an xda
[ROM][4.0.4][IMM76I] Apex v1.1.2: Back with a Vengeance! (5/8/12) - xda-developers
Der Dank gebührt wieder einmal bigxie: xda-developers - View Profile: bigxie
Reaktionen: Luke und MerowingerX
Bei 4.0.3 (IML74K)
-scheint Facebook wieder zu funktionieren (habe nur webseite getestet)
-die Kamera stürzt ab wenn man die Funktionen der Automatischen Gesichtserkennung nutzt
-Widgetsoid hat in der Statusleiste einen weißen Hintergrund (vieleicht hilft eine Neueinrichtung)
-bei den Einstellungen gibt es jetzt auch ein für das Dock
-Die reaktionszeit der Rotation schein etwas geringer zu sein
Das sind Änderungen die mir spontan auf die Schnelle aufgefallen sind.
Reaktionen: he_stheone64
Dann hast Du noch nicht das Power Menu gedrückt... dort kann man jetzt Lautlos, Vibration und Lautsprecher toggeln. Heißt leider für mich auch Tonnen an neuem Code für´s APM...
Reaktionen: escrivel
Bei mir funktioniert die Kamera einwandfrei mit Gesichtserkennung.
Bei der Camcorderfunktion gibts keine Gesichtserkennung mehr..
Warum widgetsoid jetz so nen weißen Hintergrund hat, keine ahnung.
Auch ne Neueinrichtung bringt keine Änderung..
Hoffentlich wird mein genutztes BAT Theme bald auf 4.0.3 geportet, dann sollte es wieder passen..
@he_stheone
Is doch gut, sonst würds dir doch langweilig werden ;)
Wie machst du eigentlich deinen MOD? In den AOSP Sources editieren und dann kompilieren?
Gruß,
Lado
Ich meine die funktion bei dem camcorder wo du große augen und so mache kannst.
Die musik.apk fehlt auch irgendwie
Mal 2 doofe Fragen:
1. Wird die 4.0.3 schon per OTA verteilt
2. Sollte man von der 4.0.2 auf die 4.0.3 flashen...ist ein Wipe zwingend erforderlich?
bulari schrieb:
Mal 2 doofe Fragen:
1. Soweit ich weiß nur für das Nexus S.
2. Du solltest den Cache wipen. Bei Dalvik scheiden sich die Geister ich mache ihn immer. Data Wipe brauchst du aber nicht. Bleibt also alles erhalten!
bulari schrieb:
Mal 2 doofe Fragen:
Wird noch nicht verteilt, die Version gibt es erst als Custom Rom.
Ich denke auch, dass es kein Problem sein dürfte nur den Cache zu leeren. Im endeffekt macht das offizielle Update nichts anderes und da bleiben alle Daten auch erhalten!
Bezogen auf diese ROM solltest du nicht einfach OTA updaten.
Dann sind ja zunächst die ganzen Vorteile Deodexed/Root wieder hin und du bist auf Stock unterwegs!
In dem Fall heißt es Pobacken zusammen kneifen und auf ein angepasstes Update warten! :)
@rookie: Genau, das sollte man noch dazu sagen :) Aber wipen ist nicht notwendig afaik!
4.0.1 -> 4.0.3 sollte auch ohne data wipe klappen, oder?
wird durch das Rom auch ein neues Baseband aufgespielt ?
Thx
Thx
Nein - Update lohnt sich aber vor allem im Hinblick auf Speed, 4.02 war ja leider recht laggy.
Aber nochmal zur Bestätigung von jemand der Ahnung hat he_stheone: Wipe ist nicht notwendig?
Frage selber beantwortet, man sollte viel öfters einen Blick in den #1 Post wagen :p
- Data wipe ist nicht notwendig
ICH EMPFEHLE IHN BEI ERSTINSTALLATION EINES SOLCHEN ROMS TROTZDEM, DA MAN SONST HÖCHSTWAHRSCHEINLICH IN EINEM BOOTLOOP STECKT
BEI EINEM UPDATE INNERHALB DER STOCK ROMS (Z.B. VON 4.0.1 > 4.0.2 ODER 4.0.2 > 4.0.3 ETC, IST ER NICHT NOTWENDIG, DA REICHT CACHE &. DALVIK CACHE WIPE
Wenn Du von einer stock ROM kommst (odexed oder deodexed)
  • System & Cache Wipe, Data NICHT notwendig
Wenn Du von einer Custom ROM kommst wie z.B. Revolution oder Modaco
  • System & Cache & Data Wipe
Reaktionen: hermz und rookie
Bei den GAPPS ist der alte Musikplayer, richtig?
E: Es gibt ja wirklich zahlreiche kleine Verbesserungen. Das Power Menü, der Lockscreen, die Benachrichtigungsleiste, die Haken in den Einstellungen sind jetzt blau...
Ist der Launcher in 4.0.3 auch Landscape geeignet?
