ThiaiZO3D Gingerbread ROM
  • 203 Antworten
Kyomo
Dauer-User
182
ThiaiZ schrieb:
Welcome to ThiaiZ O3D V2.8 GB
I saw that a lot of people out there would like a stock,stable,fast and rooted ROM, so i decided to make one on my own, keeping it as much as stock as possible.This is my first O3D ROM (promised to myself that i would just start developing after GB update, but its comming very soon so it's time) . I'm coming from HTC Desire and Samsung Galaxy S2 where I have always developed my own ROMs.Be patient and I do really want to help this community to grow and find the best for this incredible peace of engineering called LG Optimus 3D.Suggestions are always welcome.
Please don't send me PM asking me how to flash the ROM,baseband,kernel or whatever isn't related to development or ideas, I am not gonna answer. Post the questions in the ROM's thread instead.
Here is how it looks:
Features:V2.8 GB
-Base: V21e.NEW
-Kernel:ThiaiZ Custom Kernel V0.6
-Everything from LG is still there. (No Gulliver's book)
-Odexed.NEW
-Many .apks were deodexed re-engineered and odexed back. The boost in memory management and performance is incredible.NEW
-LG 3D Max + LG O3D stock launcher.
-LG Prada IME.
-LG Spectrum in touch widget.
-LG Spectrum Desk clock.
-LG Spectrum Digital clock widget.
-Google Play store Legacy.NEW
-New Ringtones,Message tones and Alarm tones.
-WIFI Killer +App timer Pro(NEW) + FM Radio +Onlive + Root browser (Just free apps on my ROM)
-Changed Bootanimation.
-Original 3D games (Nova,Golf2,Asphalt6) are patched to be installed on SDCARD.
-My Gingerbread theme in it.
-New wallpapers.
-Sony Bravia Engine.
-Sony XPLOD Engine.
-HTC Beats.
-ThiaiZ Smoothness tweak V0.3 (Working together with LG 3D max launcher, making it very smooth).
-Increased I/O reading speed with performance pack from O2X.
-Removed software (CPU) rendering - full PowerVR SGX 540 (GPU) rendering.
-SIP over 3G.
-Init.d new tweaks (zipalign on boot,RAM management,SDbooster=128kb).
ThiaiZ V0.6 Kernel:
-ThiaiZ Kernels are a mix of stock LG O3D zImage compiled together with a also stock LG O3D Ramdisk(but in the Ramdisk I have added a lot of tweaks)
-ROM V2.8 itself comes with Kernel V0.6 NOOC
-Init.d scripts reading ability.
-Overclock Module Support (Credits to tekhuna)
-Ext 4 ability.
-Unsecured Kernel.
-CIFS,TUN Modules (Credits trax11 + Acura Team)
-more to come
V0.6 Kernel package link: Extract the .zip file and you gonna finde 4 different version, just flash the one you want.
https://hotfile.com/dl/165734820/5b6b69e/V0.6package.zip.html
Known bugs:
-You tell me please .
How you Install it:
YOU MUST INSTALL "v21e GB BASEBAND" OR "v21e.KDZ" BEFORE YOU FLASH THE ROM.FLASHING A .KDZ FILE IS EASIER IMO:
http://forum.xda-developers.com/showthread.php?t=1287236
http://forum.xda-developers.com/showpost.php?p=17177547&postcount=2
V2.8 link:
https://hotfile.com/dl/164047911/e2cc341/ThiaiZO3DV2.8BetaGB.zip.html
-Download and copy the .ZIP file onto your SD or Phone.
-Restart device in CWM (Vol down + 3D + power)
-Backup your old Rom
-Wipe data + cache (All your data will be gone)
-Choose "Install Zip from SD card"
-Browse the .ZIP file and install it.(takes 3 minutes)
-Boot device and ENJOY.
-If you are planing to use LG 3D MAX launcher, flash the update found under attached files. It contains: Themes,SNS widget and Data traffic widget.
ThiaiZO3D Kernels for GINGER BREAD only:
"KERNEL PACKAGE: EXTRACT IT AND FIND DIFFERENT KERNELS INSIDE"
-V0.5 https://hotfile.com/dl/151800032/d08a4d4/V0.5.zip.html
-V0.4 http://hotfile.com/dl/141095076/01b8611/V0.4.zip.html
-V0.3 http://forum.xda-developers.com/showthread.php?p=21097245&posted=1#post21097245
http://hotfile.com/dl/140296857/1bb19b3/V0.3.zip.html
-V0.2 http://hotfile.com/dl/137278560/7eb286e/ThiaiZV0.2OC1100.zip.html
-V0.1 OLDER Kernel package :
http://www.multiupload.com/2AJDK75KEL
THANX:
-aljahwari: For RTL Support http://www.adslgate.com/dsl/
-My mates: Gerrett "Road Runner" and Claudio67 for boot.img compiling.
-Ricardo Cerqueira - For "boot.img how to" and opening up possibilities to O3D
-Tekahuna - for OC modules http://forum.xda-developers.com/showthread.php?t=1355474
-ACURA Team.http://www.htcspain.com/roms-384/acurateam-rom-v1-base-10e-beta-kernel-10-09-2011-a-50087/
-Zeppelinrox for V6 SuperCharger! The ONLY Android MEMORY FIXER! 3G & KAK! http://forum.xda-developers.com/showthread.php?t=991276
-Ipy (Smoothness tweak) I re-made it to our O3D
-Trax11 http://forum.xda-developers.com/archive/index.php/t-1409455.html
-Titan kernel http://forum.xda-developers.com/showthread.php?t=1547319&page=14
-http://uot.dakra.lt/kitchen/ .Donate to them if you think the kitchen works good.
If you think this ROM is good, buy those people under thanx or myself a beer
Quelle: [ROM][27/03/12] ThiaiZO3D V2.7 GB-Stock,Stable and fast - xda-developers
Großes Lob und Dankeschön an ThiaiZ.
Update: 08. August 2012
Reaktionen: Freeman2000yes
beste rom überhaupt. sehr geringer akku verbrauch und super performance.
Merkt man einen unterschied zur stock v21a in sachen performance?
Ja, flash dir am besten den 1100er Kernel hinterher, dann ist es OC und supercharged. Da kommt kein Stock mit.
Wenn ich mal etwas zeit hab probier ich das mal aus
So habe ichs auch gemacht, der OC1188 Kernel brachte mein Optimus3D erst zum freeze und dann wieder in den Bootloop....aber die genannte Kombination ist einfach ein Traum, warum ists nicht out of the box so genial?
Besonders mit dem Go Launcher ist alles sehr sehr smooth!
Hört sich ja nicht so positiv an :)
Mal eine Frage,
in dieser Rom soll doch das Uhren-Wetterwidget des Optimus speed enthalten sein.Ist es möglich diese ohne die ganzen Rom zu installieren zum laufen zu bringen?Eventuell gibt es jemanden der nur dieses Widget zum download zur verfügung stellt, inkl. anweisung zur installation?Das wär echt supi
Danke schonmal
Habe installiert, erkennt aber meine simkarte nicht.
dann hast du wohl noch kein GB kernel
Wohl eher das falsche Baseband.
Doch doch, einfach den OC1100 Kernel nehmen, oder den enthaltenen Kernel einfach drauf lassen ;)
Aber vllt. haben andere mit dem OC1188 Kernel andere Erfahrungen gemacht, sollte ja eigentlich so gut wie identisch sein...
Habe es in den Beitrag editiert.
Keine Sorge Hundekopf, der OC1188er Kernel ist für manche Geräte zu viel des Guten. Der 1100er sollte stabil laufen, mir ist noch kein Fall von Instabilität bekannt.
Wie mache ich das mit GB kernel ?
Wie gesagt ist es jetzt unten im Eingangsbeitrag editiert. Im Forum gibt es inzwischen unzählige Threads mit einer Anweisung wie man die originale .kdz flasht. Wenn du kein Branding hast, kannst du es auch einfach "normal" über die PC Software updaten.
hast du dazu eventuell eine Anleitung?
Zur ROM oder nur Kernel?
Die Kernelzip (nicht die Zip der ROM!) aus dem Erstbeitrag muss man erst einmal entpacken, in ihr enthalten sind weitere ZIPs, welche für die verschiedenen Taktungen stehen. Die Zip der Wahl (meine Empfehlung: OC1100) muss zusammen mit der ROM auf die SD und dann über "install ZIP from SD" in der CWM Recovery geflasht werden. Erst die ROM, dann den Kernel flashen.
Ist die ROM bereits installiert, kann der Kernel auch nachträglich geflasht werden. Vorher am besten ein Nandroid Backup erstellen (sicher ist sicher!) und flashen. Daten gehen dabei nicht verloren.
Ob der Kernel auch mit anderen ROMs oder Stock funktioniert weiß ich nicht.
Reaktionen: narrischer und Devox
danke kyomo genau das wollte ich wissen :)
Guten Morgen
Ich hab das Rom auch drauf, und ich muss sagen es läuft stabil und schnell. Nur mein Akku ist verflucht schnell leer. Über Nacht hat er 40% Leistung verloren. Weiss aber nicht woran das liegt. Hat jemand ne Idee??
Gruss
Sash
Sash1405 schrieb:
Guten Morgen
Gruss
Sash
Hast du daran gedacht die Batterie neu zu kalibrieren? Am einfachsten mit der App Battery Calibration zu bewerkstelligen.
I
wholefish
VfBStuttgart27
VfBStuttgart27
joker.20
  • joker.20
schnibbel001
