[Rom's][Kernel's][References] The Promethius Project by samno [always up2date]
  • 69 Antworten
Kyomo
Dauer-User
182
samno schrieb:
Ok guys so this is it, the final gingerbread rom from me(hopefully :D). It's been good but I can't really do much more on this rom wise & with the ICS update coming soon(hopefully:rolleyes:) it dos'nt make sense to do another version.So on to the goodies :D & please please,please take one minute to read all of the the post's below it will help you an awful lot on your way to Optimus Goodnus;)
ROM Features List Version 1.5
-Android 2.3.5 21E Italy/20F UAE/20F SU760 Bases
-Deodexed & Zipaligned
-IO Tweaks
-Fully Optimised Ext 4 Mounts
-Beats & Xloud Audio Mods
-Scrolling Mods
-Stock Theming Lightly Modified (Including Optional % Mod)
-Fixed Battery Stats
-Bravia Engine Image Mods
-Modified Font Package Also Including ICS/JellyBean & Ubuntu Font's
-Epic Apn List
-Modified TI Camera Props & Media Profiles For Better Looking Pictures
-Epic Build Prop Tweaks Including GPU UI Rendering & Much More
-Ad Blocking Built In No Software Needed
-ICS Keyboard
-Includes Overclock Modules & Loaded At Boot Time
-Latest 3D Game Converter
-99% Of All Stock Apps & Widgets That Came With The Version I Got
-LaucherPro Launcher (If You Require LG Launcher See The Extra's Section)
-ScriptManager Included
-Quick Boot Included
-LG FM Radio App Included(Not In SU760 Because Of FC's)
-Removed Annoying Slow Blur From Power Screen
-Disabled Scrolling Cache
-RTL Support (20F Bases Only)
-Includes SuperStock Kernel (Just Flash Promethius Kernel For Extra Features)
-Personalisable Scripts For Appless Modding
Installing The Rom
-****YOU MUST USE NON-TOUCH RECOVERY!!****
-Download & Copy The .ZIP File Into Your SD.
-Restart The Device In CWM Either Through RomManager Or Power On + Down Volume Key.
-Backup Your Old Rom Just In Case(Recommended).
-At This Stage You Can Wipe Data & The Cache's If You Want For Non-Wipe Version Or Continue To Next Step For Wipe Version.
-Then Choose Install Zip from SD Card, Either Internal Or External. Wherever You Save It.
-Select The .ZIP File & Install It.
-The Script Will Then Do Everything Else You Require Be It Formating & Stuff.
-Reboot Your Phone & You Should Be good To Go.;)
-Just Give A Few Minutes As First Boot May Take Longer Than Usual.
-After First Boot & Set-up You Can Then Boot Back Into Recovery To Flash A Kernel.
If you have any problems please download & use the full wipe version of the rom before flashing again, some people may be fine without wiping depending on what rom you have come from but it is best to use the full wipe version of the rom. Oh & did i mention YOU MUST USE NON-TOUCH VERSION OF CWM RECOVERY!! & YOU MUST HAVE BOOTED INTO ANDROID BEFORE ATTEMPTING TO FLASH ANOTHER KERNEL. Otherwise it may not boot and/or you may get wifi and bluetooth errors.
Notices & Information
For Overclocking You Must Flash The Promethius Kernel In The 2# Post, See That Post For More Details On The Kernel.
NOTE: You MUST have the latest gingerbread baseband already im using V20F but 20G, 21E & 20P & maybe 20C will work aswell anything else will NOT work so update your baseband or you wont ever be able to use the latest release.
Something Wrong?
Did you follow the instructions above properly? If you find a bug or there is something you would like me to add please tell me what it is and i will do my best to remedy/add/modify it upon popular request or if its possible. If you do have problems please state you baseband version, which rom you are using and which kernel. I cannot help without these details.
Latest ROM Download's
Promethius V1.5 21E:http://d-h.st/2Lj
Promethius V1.5 21E(Non-Wipe):http://d-h.st/Ici
Promethius V1.5 20F:http://d-h.st/08R
Promethius V1.5 20F(Non-Wipe):http://d-h.st/2Wt
Promethius V1.5 SU760:http://d-h.st/76C
Promethius V1.5 SU760(Non-Wipe):http://d-h.st/D4B
Previous Versions
Promethius V1.0: https://hotfile.com/dl/155181764/3afc4f9/Promethius_ROM_V1.0.zip.html
Promethius V1.1 21E: https://hotfile.com/dl/155509867/e77ee52/Promethius_ROM_V1.1.zip.html
Promethius V1.1 20F: https://hotfile.com/dl/155509590/f8e817a/Promethius_ROM_V1.1_20F.zip.html
Promethius V1.2 21E: https://hotfile.com/dl/155807296/50dacdf/Promethius_ROM_V1.2.zip.html
Promethius V1.2 20F: https://hotfile.com/dl/155807267/140a1ec/Promethius_ROM_V1.2_20F.zip.html
Promethius V1.3 21E: https://hotfile.com/dl/156076444/0994a28/Promethius_ROM_V1.3.zip.html
Promethius V1.3 20F: https://hotfile.com/dl/156076327/d18c385/Promethius_ROM_V1.3_20F.zip.html
Promethius V1.4 21E: https://hotfile.com/dl/156990867/4ad22c1/Promethius_ROM_V1.4.zip.html
Promethius V1.4 20F: https://hotfile.com/dl/156985063/0dcafc0/Promethius_ROM_V1.4_20F.zip.html
Credits & Other Stuff
If you want to theme something i suggest you use this http://uot.dakra.lt/kitchen/ Its really simple to use and quick too.
Please give feedback as it will improve the rom for everyone. Oh and thanks for the inspiration meemo, thiaiz, Fab , Acura, RC and the rest of us original O3D crew, XDA, the community & thanks to my tester's too, you know who you are. BTW remind me if i need to credit someone or if I have forgot something im really sorry please mention it to me.
Extra's
This is the Extra's section, here you'll find some useful flash zips for my Rom for you to enjoy. I have also attached the latest LG stock kernel's too for those that would prefer them at the bottom of this post.
3D Max Home Flash Package With Weather & Prada SNS: https://hotfile.com/dl/156076865/d613feb/3DMaxHome.zip.html
Stock LG Home Flash Package: https://hotfile.com/dl/155497520/22a66a7/Stock_LGHome.zip.html
Stock LG Keyboard: https://hotfile.com/dl/155513605/ae76c54/Stock_LG_Keyboard.zip.html
21E Battery % Framework: https://hotfile.com/dl/156077330/ca6cee5/21E.zip.html
20F Battery % Framework: https://hotfile.com/dl/156077274/47370c4/20F.zip.html
SU760 Battery % Framework:
If you flash the 3D Max Package please clear Weather data in Setting's to prevent force closes and other issues.
Thank You Very Much & I Hope To Be Back Soon Bigger & Better than Before ;)
Quelle: [Rom's][Kernel's][References] The Promethius Project [Version 1.3][16/05/2012] - xda-developers
Letztes Update: 5.7.2012
Kernel kommt hier:
samno schrieb:
The Promethius Kernel Version 1.5
Here it is guys, the last kernel for a while. Added & fixed quite a bit under the hood hopefully stable & quick for you whilst giving decent battery performance.
Kernel Features
-Over Clocked CPU To 1.32 Ghz Upto* 1.4 With Moduler Over Clock
-Include's Under Volted 1.2 Ghz OPP Set At Boot
-Over Clock Modules Loaded On Boot Time
-Over Clocked RAM To Maximum 466Mhz
-Lowest Under Volt Possible
-Init.d Support
-Carrier IQ Disabled
-Minimum Frequency 300Mhz
-Modified VM Read Aheads
-Custom Promethius RamDisk Based On 21E
-App Cpu Usage Tweak
-Screen Off Frequency Automatically Set To Lowest Frequency
-*Ghost Call Patch To Help Reduce Them
-*Built With Latest 21E Source (Version 1.3 Onwards Only)
-Plus Many More To List See Changelog's For More
Installing The Kernel
-Make Sure You Have CWM
-Copy The Zip To Your SD
-Select Install Zip From Internal/External SD (Wherever You Put It)
-Select The Kernel File
-BOOM You should Be Good To Go, Just Restart.
NOTE: You May Clear Cache & Davlik Cache If You Have Problems But Ive Never Done So.
NOTE: **Ghost Call Patch Applies Only To Versions Below 1.3 As Versions 1.3 And Above Are/Will Be Based On 21E Kernel Source So They Should Not Have Ghost Call Issues, I'm Not Guaranteeing Anything Though.
NOTE:*I Cannot Guarantee You Can Over Clock Higher Than, This Will Be Phone Dependent But I Have Set Realistic Over Clock Frequencies In The Kernel Already Which Should Be Safe.
IMPORTANT: You MUST Be Using Either 21E, 20F,20G Or 20P & Maybe 20C Baseband's For Kernel Versions 1.3 & Higher.
Kernel Source
My Git Complying With GPL & XDA Rules: https://github.com/samno1607
Also See Me Adding My Latest Tweaks Or Compile You Could Compile It Yourself Before Release. Any Tips & Tricks Are Welcome.
Kernel Download's
See The Bottom Of This Post! But If You Require LG's Stock Kernels See The 1# Post.
Please Flash Promethius+ For 21E Base Or If Your Using A Rom With Kernel Version With A "+" At The End.
Please Flash Promethius For 20F Base Or Or If Your Using A Rom With Kernel Version Without A "+" At The End.
Vielen Dank an samno für diese gute Arbeit!
Leider sind derzeit keine direkten Links von ihm gegeben.
Downloadbar ist der Kernel auf der Quelle: xda-developers - View Single Post - [Rom's][Kernel's][References] The Promethius Project [Version 1.3][16/05/2012]
Changelog
Achtung: Diese ROM kann euch NICHT das Baseband der 21e aufspielen. Stellt bitte sicher, dass ihr diese Version vorher geflasht habt. Danach dann darauf achten, dass es der + Kernel sein MUSS (Beachtet das "+"!)
Reaktionen: schirnerj
Habe das jetzt mal alles getestet in der neuesten Version und es läuft wirklich hervorragend :)
wenn ich das kernel installieren 1.3 habe kein Signal hat jemand auch das problem
gruss
gruss
Welchen Kernel hast du geflasht?
Auf Basis welchen ROMS hast du das Custom ROM installiert, sprich welches ROM hattes du vorher drauf?
Auf 21e musst du den v1.3+ Kernel flashen.
Jetz habe ich das 3D max Rom von Accura das ist BB, 21E, das komisch ist das selbst mit die neu Accura Kernel nicht mit jeder nett habe
Ich versuche diesen Satz mal zu interpretieren und er könnte bedeuten, dass du auch mit der Acura Rom kein Netz hast?
Das Baseband bekommst du nicht per ROM, sondern nur über das Flashen der firmware oder des Basebands selbst.
Also:
-21e flashen (z.B. mit der .kdz Datei oder vielleicht auch am einfachsten über das LG Update Tool)
- diese ROM flashen für 21E
- diesen Kernel flashen V1.3+
Also mit Accura 3D Rom u. D bestia Kernel hab Netz, mit Titan Kernel 6r genauso ausser mit accura Kernel v5 und das ihr nicht
Wenn ich das richtig sehe hast du also Netz mit den Kernels, die auf einer Source unter 21e basieren. Das ist nicht verwunderlich, schau dir nochmal meinen letzten Beitrag an.
Du musst dir die V21e Firmware nochmal rüberflashen um das Baseband zu erhalten. Eine ROM, die auf V21e basiert bringt dir NICHT das erforerliche Baseband für die neuen Kernels.
Erst mal danke
Welche Anleitung ist die beste zu nehmen um das 21E drauf zu machen
Ach Gottchen - das is echt mühsam mit dem Zeuch.
Mittlerweile geht mir das 3D schon am Senkel. Ich glaube, ich wechsel mal zu Samsung. Nischenhandys sind einfach unglaublich unterpriviligiert, was gute Customs angeht. Und gibts dann mal welche, is es schon mühsam, die richtige zu finden und die draufzubekommen.
:unsure:
Reaktionen: sarfann
cobra111 schrieb:
Erst mal danke
Wenn du ein ungebrandetes Handy hast, dann sollte die V21E durch ein völlig normales LG Firmware Update aufgespielt werden.
Falls nicht ist das hier der manuelle Weg:
csmg.lgmobile.com/swdata/WEBSW/LGP920/ADEUML/V21e_00/V21E_00.kdz
[DEV] KDZ Firmware Update Fix - xda-developers
◘►◘►[FLASH + ROMS][v20B.KDZ] KDZ Files on WINDOWS 7 (64) & XP + Download◄◘◄◘ - xda-developers
@narrischer: Worauf genau beziehst du dich? Die Custom ROM ist doch ganz einfach zu flashen. Und V21e bekommt man normal über das Firmware Update am PC, das macht jeder Hersteller so.
Weiß ja nicht, ob es überhaupt irgendjemand außer mir nutzt, aber es gibt eine neue Version! :) (Kernel + ROM)
Das ROM nutze ich nicht, aber den Kernel :winki:
Läuft prinzipiell gut, aber ich habe den Eindruck, als ob die CPU mit dem 1.3+ Kernel etwas lang braucht, bis sie bei rechenintensiven Apps (z. B. beim Schachprogramm Droidfish) auf "Touren kommt" (andere Versionen (also auch die aktuelle) habe ich noch nicht probiert)
Ist das möglicherweise eine Folge von "-App Cpu Usage Tweak"?
Nutzt du SetCPU? Und hotplug? Ich habe gelesen, dass es Ansprechprobleme geben könnte, wenn die minimale Frequenz auf unter 300MHz steht. Er arbeitet schon dran. Ich habe die Minimale auf 300MHz stehen und nichts Negatives bemerkt :) Den neuen Kernel kannst du dir ja dennoch schonmal flashen.
Gesendet von meinem LG-P920 mit Tapatalk 2
Reaktionen: hellion
CPU Master free 2.5 mit Hotplug
Hmm, seitdem ich mit den Einstellungen in CPU Master ein wenig gespielt habe, scheint es auch mit 196 MHz Minimum deutlich schneller anzusprechen als vorher! :confused2: Aber du hast recht, das verzögerte Ansprechverhalten ist mir mit 196 zuerst aufgefallen...
Naja, bei meinem LG wundert mich schon lange nix mehr, seitdem ich festgestellt habe, dass sich alle 1-3 Tage einer der CPU-Kerne verabschiedet (unabhängig vom verwendeten ROM/Kernel) und sich nur noch mit einem Reboot wiederbeleben lässt...
Ich hab noch nach wie vor den Thiaiz2.7.1 Rom drauf und in Verbindung mit dem Promethius Kernel V 1.1 ist es die absolute Dreamfusion. Alles funzt absolut perfekt und in Sachen akku ist es das Beste was ich bisher ausprobiert hab, zumindest mit den 1200 Mhz. Ab V1.3 geht es mit dem alten Baseband nicht mehr , aber wozu Updaten, wenn alles super läuft , ich nutze setcpu und mit den 196 Mhz , hab ich keine Probleme, den 1.2 Kernel will ich gar nicht erst ausprobieren , meinermeinung nach bringt dieses ganze Undervolten nicht viel und es gibt auch mal probleme, versucht doch mal die alte V1.1 , wer Probleme hat.
Mfg
Man könnte aber erwähnen, dass der Ghostcall erst mit dem neuen V21e Baseband behoben ist :) Ansonsten war diese Combo wirklich gut, wie alles von ThaiZ. Samnos ROM ist aber mMn nicht wirklich inferior.
ich habe mir jetzt den 1.4+-Kernel geflasht und in Verbindung mit meinem Stock-ROM (V21e) läuft er wirklich gut. Als Minimum sind jetzt sogar 150 MHz möglich; und sogar damit ist das langsame Ansprechen der CPU kein Thema mehr! (evtl. war das nur ein vorübergehendes Phänomen bei meinem O3D)
Bin sehr zufrieden!
I
colanderbrain
colanderbrain
  • PyromanicZ
PyromanicZ
O
Gagac
Gagac
