[ROM][JB/4.2.2] Vanilla Rootbox UNOFFICIAL (AOSP/CM10.1/AOKP/PA/RB)[29/03]
  • 73 Antworten
colanderbrain
colanderbrain
Hier ist ein Port der beliebten Rootbox Rom mit regelmaessigen Updates fuer unser geliebtes O3D. :smile:
picture.php
Features
Based on JB 4.2.2 – Built from RootBox Sources
  • Per App DPI
  • Per App Tablet UI
  • Per App Language
  • OTA Updates – Goo Manager
  • Camera: Save to external memory
  • Phone: Advance Phone Settings (Vibrate on Answer, Every 45 Seconds, On Hangup and On Call Waiting)
  • Phone: Noise Suppression
  • MMS: Message rate alerts (Modify SMS message limit for alert)
  • MMS: Fully Customizable MMS Theme
  • MMS: Soft Keyboard Type (Emoji, Enter to Send, Enter for a New Line)
  • MMS: Emoji Support
  • MMS: Read, Delete, Reply and Call options in StatusBar for messages
  • Home button call answer (Accessibility Option)
  • Variable size pattern lockscreen
  • Clock: Increasing Alarm
  • Clock: Flip/Shake – Snooze or Dismiss
  • Clock: Disable Alarm Icon on Statusbar
RootBox Settings
  • Pie (Paranoid Android)
  • Breathing effect for missed Calls and SMS
  • LCD Density Changer
  • Low Battery Warning (Pop-up & Sound, Pop-up only, Sound only, Off)
  • Option to control cursor in text fields using volume keys
  • Disable Fullscreen Keyboard (Landscape mode)
  • Expanded Desktop
  • Hold Back to Kill
  • CRT Animation (Screen On/Screen Off)
  • Lockscreen See Through
  • Lockscreen Shortcuts (Paranoid)
  • Lockscreen Targets (CM)
  • Screen Security Features (Unlock options: Quick Unlock, Delay Screen Lock, Menu Unlock, Home Unlock)
  • cLock (Chronus)
  • Display Connected WiFi Network beside Carrier Label
  • Notification Drawer Shortcuts
  • Notifications Behaviour (Always Expand, Never Expand, Normal, Old Style)
  • Option to disable sound when adjusting volume
  • Launch Music app on Headset connection
  • Swap Volume Buttons on Rotation
  • Hardware Keys Remapping
  • Lockscreen Hardware Keys Remapping
AOKP Features
General UI
  • Custom Carrier Label
  • Custom Bootanimation
  • Custom Notification Background
  • Notification Count
  • Vibrate on expand
  • Statusbar slider (brightness)
  • StatusBar and NavBar transparency
  • StatusBar Toggle
  • Kill-All-Button in Recents
  • Recents RAM Bar
  • UI Mode (Phone, Phablet, Tablet)
  • Allow 180 degree rotation
  • IME Switcher
  • Wake up on charger
Lockscreen
  • Custom Lockscreen Wallpaper
  • Custom Lockscreen Text Color
  • Lockscreen Battery Percentage
  • Volume Wake
  • Volume Music Controls
  • Hide initial page hints
  • Minimize lockscreen challenge
  • Enable Long Press Unlock (Minimized lockscreen challenged)
  • Use widget carousel
  • Lockscreen rotation
  • Allow all wigets on lockscreen
  • Allo unlimited widgets
Power Menu
  • Screenshot
  • Airplane Toggle
  • Navigation Bar Toggle
  • Torch Toggle
Navigation Bar
  • Button Quantity
  • Custom NavBar Color
  • Custom NavBar buttons Color
  • Custom NavBar buttons Glow Color
  • Navigation Ring Targets (1-5 targets)
  • Menu arrow keys
  • Custom Height
  • Custom width
  • NavBar Button Transparency
  • NavBar Hide Feature
Battery
  • Battery Icon Style (Icon only, Text only, Icon+Text, Icon+Centered Text, CircleMOD, Hide)
  • Battery Bar (Location, Style, Color and Thickness)
Clock
  • Clock Style (Right, Center, Hide)
  • Custom AM/PM Style
  • Custom Day of the Week
  • Notification Clock (Short and Longpress actions)
  • Notificaiton Date (Short and Longpress actions)
  • Clock Color
Statusbar Toggles
  • Custom Toggles (Auto-Rotate, BT, GPS, WIFI, Airplane Mode, Vibrate, Silent, SYNC, DATA, 2G, Tether, USB Tether, Torch, NFC, Quiet Hours, Power Menu, Profiles, RootBox, Quick Record)
  • Tiles or Traditional Style
  • Toggles per row (3, 4, 5)
  • Favourite Contact
  • Toggle Style (Text or Icons)
  • Fast Toggle (Right or Left side)
Signal
  • Signal-WiFi Text Style (Bars, Text, dBm)
  • Signal-WiFi Color
  • Alternate GB Style Signal
  • Hide Signal Bars
LED (Compatible devices)
  • Custom LED per app
  • LED while charging
  • LED blinking speed
Sound
  • Volume Panel
  • Less Frequent Notification
  • Headphones Plugin Action
  • A2DP Connection Action
  • Phone Call Silence (Flip Phone to Silence Calls)
  • Face Down Actions (Vibrate or Silent Mode)
Vibrations
  • Create Own Custom Vibrations
Bugs:
kein Bluetooth
kein Tethering
kein aufnehmen von Videos
kein 3D
Screenshots:
Quelle: VfBStuttgart Danke:thumbsup:
die ROM gibts hier
Gapps gibts hier
Ich uebernehme keine Haftung fuer eventuelle Schaeden an eurem Telefon, wenn ihr diese Rom verwendet.
Anleitung:
Um diese Rom zu verwenden benoetigt ihr den Bootloader von Wkpark 1.25 und eine funktionierende Recovery, wie cwm 6.0.1.9 ( bei dieser Version funktioniert zb reboot in Recovery problemlos.).
  1. Recovery starten
  2. 3 Wipes machen (System/Factory reset, Cache, Dalvik)
  3. Installiere die Rom per .zip
  4. Installiere Gapps per .zip
  5. System starten
Falls ihr das europaeische Partitionslayout verwendet, dann ersetzt 16 in /system/etc/vold.fstab mit 15 und ersetzt 17 mit 9 in /system/etc/init.d/66swapon
Credits:
Rootbox-Team, Berni987654321, Wkpark, Cyanogenmod-Team, AOKP-Team, PA-Team, AOSP-Community
:thumbsup:Vielen Dank an euch! Ohne eure Arbeit und Hilfe waere dieser Port nicht moeglich gewesen!:thumbsup:
Der ursprüngliche Beitrag von 16:12 Uhr wurde um 16:48 Uhr ergänzt:
reserviert
Reaktionen: Driv3r und VfBStuttgart27
Also endlich öffentlich:thumbsup:
Klasse Arbeit - läuft sauschnell und stabil:thumbsup:
Reaktionen: colanderbrain
Schön ,aber ohne 3D für mich keine Option.
JH
Du kannst sie ja mit ICS Dual Booten:laugh:
Reaktionen: joe-hase und colanderbrain
Wie geht das, hab schon davon gehört aber keine Ahnung ....
JH:blushing:
So lange Lg den Source Code von den 3D Treibern nicht veroeffentlicht wird keine cm basierte Rom 3D haben.
Wie VfBStuttgart schon schreibt, kannst du dualbooten.:)
Der ursprüngliche Beitrag von 17:41 Uhr wurde um 17:42 Uhr ergänzt:
Hier ist eine Anleitung dazu..:smile:
JH:blushing:
Einfach ist es aber nicht:laugh:
Les das und das:)
Der ursprüngliche Beitrag von 17:43 Uhr wurde um 17:44 Uhr ergänzt:
Leider:thumbdn:
Ich glaube das übersteigt meine Fähigkeiten...aber trotzdem danke für die Info.
Hat das schon einer probiert?
JH
Ja ich boote die neue Darkroom V3 und Rootbox :)
Ja, bei colanderbrain hat's geklappt, bei mir ist die 2. ROM saulahm, ich teste es nachher mit einer anderen SD:)
500. Beitrag:laugh:
Ich bin jetzt "Android Experte":lol:
Hab auch mal die Rom geflashed. Find ich soweit auch ganz gut,nur die Rom frisst doch schon nen gutes Stück mehr RAM als CM10 :|
mfg
Ich weiss nicht wie weit cm10 jetzt ist, aber bei mir sind immer so zw. 190 und 210 mb frei. Das war im Februar bei cm10 weniger, aber es ist viel Zeit vergangen seit dem.:)
Mir ist auch aufgefallen, dass der Rambalken bei dem Fenster, wo alle geoeffneten Programme sind (swipe rauf), nicht stimmt, sondern nur das was unter apps steht.
Schon spaet, sorry :laugh:
ich habe mir heute rootbox rein geflacht aber leuft nur logo weiter nichts??????Kann mir jemand HELFEN?Danke im voraus.(bin unerfahren)
Wie hast du es denn geflasht?
Welche ROM hattest du vorher?
Welchen Bootloader hast du?
ich habe nach anleitung geflacht,omap4boot-for_optimus-v1.25a,RootBox-JB-p920-Nightly-20130329,gapps-jb-20130301-signed
https://www.android-hilfe.de/forum/...10-ics-custom-roms-fuer-anfaenger.377291.html
Der ursprüngliche Beitrag von 15:43 Uhr wurde um 15:57 Uhr ergänzt:
Ich habe mir heute erst Handy gerootet seit dem CWM installiert,botloader v1.25a,dann geflacht.
Der ursprüngliche Beitrag von 15:57 Uhr wurde um 16:24 Uhr ergänzt:
HILFEEEEEEEE????????????????:confused:mein handy zeigt mir nur logo
Und wenn du immer wieder flaSHst, dann kommt er immer wieder nur bis zum Logo? Gleiches Ergebnis bei Pacman?
ja ich habe noch paar mal von vorne gemacht soger jelly bean ausprobiert öogo zeichen dreit sich aber kommt nicht weiter(CyanogenMod) steht drauf.
Der ursprüngliche Beitrag von 18:03 Uhr wurde um 18:13 Uhr ergänzt:
oder sollte so sein ich brauche nur geduld?
Der ursprüngliche Beitrag von 18:13 Uhr wurde um 18:31 Uhr ergänzt:
Hilfe bitte
Der ursprüngliche Beitrag von 18:31 Uhr wurde um 18:34 Uhr ergänzt:
wenn keiner weist wie komm ich nur zurück zum meinem 2.3.5
Wipes hast du gemacht, ja?
ich habe mitpacemon ausprobiert leuft laut loading weiter wie gewohnt nix
Wipes?
Der ursprüngliche Beitrag von 19:42 Uhr wurde um 19:47 Uhr ergänzt:
ich habe vorher v21e gehabt falls das hilft
zheka777 schrieb:
"wipe data/factory reset"
Wenn du das gemacht hast, kannst du noch unter "advanced" "wipe dalvik cache" versuchen.:)
Q
palma
palma
  • AlfredENeumann
AlfredENeumann
I
wholefish
