[ROM][ICS][P920][20/01/2013] DARKROOM International V2
  • 3 Antworten
MarcoJoo
MarcoJoo
Seit gestern gibt es die DARKROOM V2 nun auch in Deutsch. Soweit ich was ist das aktuell die Bugfreiste ICS ROM. Leider ist die Installation nach wie vor sehr aufwendig.
Hier alles aus dem XDA-developers Forum:
DARKROOM INTERNATIONAL V2
We bring the expected and longed International V2. Everything made ??from scratch, base cover Xbsall Ics (XDA), with the kernel itself Team, Team spectacular mod and more nice .............
A slow to see the light, but we believe that a rom has gone very, very good. We hope comments and try how it work.
The rom is with right to work at 100%, and that everyone gets what interests you.
Has many settings, besides enhancing the rom tweaks inall aspects. Reading sd, screen sensitivity, 3G and wifi speed, reduced power, zipaling startup, defragmentation, etc .......
Besides Team own kernel with OC Cpu, Cpu UV, Oc ram, GPU OC, improved ram, init.d habiliado from the kernel, etc ....... and much more.
One novelty is to regulate yourselves the CPU voltage from SetCPU for example, we get 1.5 MHz of the CPU Oc. Here, as we know, each O3D is a world, therefore there will be terminals they will support and others do not.
Being able to regulate the voltage to frequency, we can adjust much consumption and regunlando well, we can get reduced consumption. Below we explain how to adjust this.
The Mod, c'mon, awesome job that gives unbeatable elegance to our gadgets, android envy of the world.
ONLY INSTALL IF YOU HAVE ICS ROM ported from the SU760, BY XBSALL
ONLY INSTALL IF YOU HAVE RECOVERY IN PARTITION
ROM
CHANGELOG
- Base ICS Korean (Thanks XBsall)
- All translated into more than 30 languages
- Rooted and Deoxed
- Zipaling
- New gobernors
- New ways reading SD
- Kernel Darkroom
- Optimized Ram
- Boot optimized
- Improved SD card reading and much ......
- Tweak screen sensitivity
- Tweak scrolling
- Enhanced data rate 3G, wifi
- Tweak in wifi, less consumption
- Tweak battery consumption
- Boot Defragment
- And more ...... Tweaks
- Visual customization of the rom
- Battery in percent 1%
- Off mode CRT screen off
- Bravia Engine
- Improved sound AC! D Sound
- Camera Original retouched by Defcomg (14Nov.iArccamaraRC2) (Thanks)
- Camera JB 4.1.2
- Official JB Gallery 4.1.2
- Keyboard LG
- JB official Keyboard 4.1.2
- Face Unlock Unlock
- Apk sms
- ES File Explorer
- Busybox
- Led Tesla
- Quick Boot (to go directly to the recovery)
- The Official Team Darkroom Apk
- Team Wallpapers Darkroom
- More than we allow ourselves safe ........
KERNEL
First thank Pesach85 of xda that has taught me to compile a signed boot and solve certain problems with compiling the kernel binary.
It's been a long hard journey, as I lost my ubuntu and data, hence the long delay. Get to the point
Ramdisk Tweaks:
- Taskiller increased for better management of the RAM
- Load modules from ramdisk
Kernel Tweaks:
- Added "Voltage Control v2" (You can play either the voltage frequencies, so you can have as fecuencia you want to increase the voltage or down if your phone supports it. Set entity 750mV to 1500 mV. Advisable not shift from 1400mV. We are not responsible for any damage to your CPU)
- Overclock to 1500MHz!
- Added a lot more often for more battery saving.
75MHz, 150MHz, 250MHz, 350MHz, 450MHz, 600MHz, 858MHz, 10 08MHz, 1108MHz, 1208MHz, 1308MHz, 1350MHz, 1400MHz, 1500 MHz
- UNDERVOLT, enough to start you all.
- Added CPU Topology
- Set hotplug system as governor and adjusted.
- Added VR and SIO schedulers, and tight deadline. SIO as Set system scheduler.
- Added Lazy governor and governor Wheatley
- Used as binary to compile the latest version
- OC GPU to 384 MHz
- Added "Fsync Control"
- Added libraries to increase copying and moving data
- Added drivers for our GPU originals (ported from GN)
- GPU OC to 460Mhz
- Added a new frequency to the GPU. Now: 157.6 Mhz-384Mhz-460Mhz
- Added a new line voltage higher than stock for added stability at very high frequencies.
- Latency of 300 to 30.
Very fast and stable, and RAM management is infallible.
Well let me explain a few things, you can use at voltages as NSTools programs for editing (recommended), Perfomance, Voltage Control, SetCPU, Rom Toolbox ... etc
Finally the last point that I want to explain is the Fsync Control, this means that you can disable that can cause data loss in a crash / freeze and can also lead to problems if two or more processes accessing the same file. Furthermore disable reduces the number of operations by reducing battery consumption and increase system performance.
It can be disabled by creating a script, paste the following into or empty file and place it in / system / etc / init.d / named XXFsync (where XX is any number):
Code:
#!/sytem/bin/sh echo 0 > /sys/class/misc/fsynccontrol/fsync_enabled
INSTALLATION
1. Put the zip in SD
2. Ask for carrying TWRP recovery:
WIPE ------ WIPE CACHE ------FACTORY RESET------SYSTEM
2a. Normal recovery for CWM:
WIPE CACHE------WIPE DAVIL CACHE------WIPE DATA------FORMAT SYSTEM------FORMAT DATA
3. Install zip
4. Reboot
It takes a little to start, patience ................... seems to stay frozen, but do not worry, it's normal, are more than 700mg of rom and takes to boot.
When configuring acabeis the first time around, restarting a few times, so that it works as it should and stabilizes. At first it costs apks open, but now see the difference when you start using it.
Download link: Dev-Host - Darkroom_Ics_International_V2.zip - The Ultimate Free File Hosting / File Sharing Service
ROM INTERNATIONAL V2 WHITOUT MOD
Download link: Dev-Host - Darkroom_Ics_International_V2_normal.zip - The Ultimate Free File Hosting / File Sharing Service
If you want to put icons for phone, contacts, sms, mail in chrome as in the images of the launcher, stay above and clicking when you solteis appears a little circle with a brush, push up and you will see a screen with all the icons available. Marcais which querais and ready.
Comments and hope you enjoy it.
To thanks cost nothing
If you like our work, you can invite a few beers
Reaktionen: Bert.Milchmann und RyaEngel
Eins der besten ICS Rooms die mein Sohn bis jetzt hatte.
Schnell und sehr viele Fehler der Version 1 ausgemerzt.
Läuft sehr stabil.
Habe vorher Factory Reset gemacht und die interne SD Karte Formatiert, danach installiert.
Nur Kamera ist noch verdreht . Haben wir mit diesem Update hin bekommen.
http://forum.xda-developers.com/attachment.php?attachmentid=1687430&d=1359494009
Und das ist der Artikel dazu :
xda-developers - View Single Post - [Mod]Cameras [ARC(ICS),P1(CM10),CM9,4.2(CM9+CM10+ICS),HDR(ICS)]
Also bis jetzt ein totales :thumbup:
Bert
Ich habe massive Probleme mit dieser Rom. Der Empfang geht und kommt. Liegt es am kernel? Kann mir jemand einen anderen kernel empfehlen, oder ein ne andere Rom, die ich einfach drüberbügeln kann. Danke
Hatte es versucht zu installieren. Die installation verlief auch super nur nach der installation ging nix mehr. Nur das silberne LG Logo.
Habe Android 4.0.4 ICS v30a drauf
MarcoJoo
MarcoJoo
  • ataur-qw
ataur-qw
  • Schimun
LGG3_32GB
LGG3_32GB
