kampfbestie
Main Features:
-Overclocked Cpu To 1.2 Ghz Upto To 1.4 Ghz With Modules (Credits to bedwa)
-Overclock Module Support (Credits to tekahuna)
-Overclocked Gpu To 384 Mhz**
-Init.d Support (Credits to Thaiz)
-Cifs, Slow-Work & Tun Complied In (Could Someone Test For Me Cause I Dont Use These)
-Lots Of I/O & Governor Choices
-Carrier IQ disabled (Credits to Accura Team)
-Now compatible with most Gingerbread Roms*
-Stock Voltages
Changelog 01/04/2012:
-GPU Overclock TO 384Mhz**
-Cifs, Slow-Work & Tun Complied In Both Kernels
-Added Vr IO Scheduler & Tweaked (Set As Default)
-Added Sio IO Scheduler & Tweaked
-Added Aggressive Governor & Tweaked
-Added Gallimaufry Governor & Tweaked
-Added SmartAssV2 Governor & Tweaked
-Tweaked Hotplug For Better Response
-More Vm And General Memory Tweaks
-Modified Deadline Scheduler
-Modified Cpu Sleep Response
Changelog 27/03/2012:
-Big Overhaul Of Memory Management
-Noop I/O Scheduler Set As Default
-Raise Hz To 500
To Add:
-Battery Opimizations
-More Memory Tweaks
-Under Volting/Over Volting Interface
-USB OTG
-HID Support (Started Work On It)
-Modify DSP Frequencies For People Having Audio Skips (Mr.Bandwidth
-More Kernel Tweaks!!
v21D
http://depositfiles.com/files/zzbn8kdp9
v21D(bt wlan gefixed)
http://depositfiles.com/files/y0a6acumg
v21a
http://depositfiles.com/files/o08prubsg
-Stock Voltages
-Raise Hz To 500
To Add:
-More Memory Tweaks
-USB OTG
v21D
v21a
