tobiasth
Philosoph
- 2.559
- Themenstarter
- #41
Siehe Post01
MrTheFredman schrieb:[/COLOR]Hat ja fast keine bugs mehr, nur die Leistung bei spielen ist nicht mehr so gut
Gesendet von meinem Nexus 7 mit der Android-Hilfe.de App
bmwpowerf11 schrieb:Gibt ja jetzt schon keine richtigen mehr für 4.3
- massive surfaceflinger and hwcomposer updates
- fixed googles bad patch on last update which broke backupservice
- added quiet hours
- added lockscreen targets and shorcuts which is much improved to the 4.3 version and has finally as well the small glitches fixed. A lot recoded work went into this
- added quick unlock feature
- added rotation settings
- again a lot fixes on google code and some on our code
- fix navring works now without google now as well
- fix navring stays now till really a target is selected
- gallery2 received 30 patches of fix google stuff
- mako kernel got a huge update
- hammerhead kernel minor updates
- maguro kernel lean got sorted out and is working now flaweless
- a lot small stuff
And here you go:
- Fully customizable quick settings the new way with new included music tiles and features
- Notification drawer and quicksettings background as well with tablet support now
- Notification transparency
- Notification drawer shortcuts
- Hide carrier label on notification drawer
- Wifi access point is shown in notification drawer
- Easy full swipe access between notification drawer and quicksettings
- Quick pulldown for quick settings
- Quick settings style options
- Battery icon the new slim way reflected on quicksettings as well
- Fully Clock and date customization on status bar
- Statusbar brightness controll
- Fully revamped navigation bar and navigation ring customizations much more ehanced to 4.3
- Fully global menu customization the new way
- SlimCenter
- Mute Volume adjust sound
- Ascending ringtone
- Quiet hours new extended version
- Mute Camera shutter sound
- Control safe headset warning
- Volume rocker music control
- Less frequent notification sounds
- Power connectivity alert
- Fully customizable volume panel
- Display rotation options
- Fully customizable auto brigthness hysterese
- CRT animation the new way with new animation as well
- Notification light options
- Battery light options if device supports it
- Volume rocker wake
- Wake up on charge
- Slims full customizable low battery warning
- Enable/disable camera widget on lockscreen
- Enable carusell animation on lockscreen
- disable initial page hints on lockscreen
- start widgets maximized on lockscreen
- Fully revamped lockscreen target options
- Lockscreen shortcuts
- Lock before unlock the new way
- Pattern size customizing
- Systemwide blacklist support for calls and sms/mms
- Slims Privacy Guard the new way
- Auto keyboard rotation feature
- Disable fullscreen keyboard
- IME selector notification
- Show permanent enter key on keyboard
- Volume key cursor control
- SuperUser
- Mediascanner behaviour on boot
- Wifi country code
- Camera smart capture
- Camera picture quality
- Camera gps indicator
- Camera color filter options
- Camera completly menu revamp the new way
- Gallery video smart controll
- SMS/MMS has completly all feature back from 4.3
- None intrusive incall UI
- Dialer has all features back from 4.3
- Torch app
- System wide immersive mode aka expanded desktop
- and tons tons of fixes on google code, revamps on old code, new features and polishing of old features and for sure a lot we still forgot to list here
Known bugs:
- Navigation bar recents button sometimes need to be presses twice
- SMS sending sms with private codes results in a crash
- Lockscreen when carusell animation is enabled dragging the camera icon messes the animation
- Icons on global menu are sometimes a bit distored....not much
- Battery tile icon/icon percentage/percentage test below the icon is misalligned. Other batterys icons are ok.
Device specific:
- crespo: slight battery drain
- maguro/toro/toroplus: sometimes random reboots....does not effect all
- t0lte rare camera bugs but mostly stable
- t0lte if you experience data drops please use latest CWM to flash
- jf devices: autorotate is broken
