[ROM-JB][N7][4.2.2][JDQ39] RasBeanJelly | 22.04.13
  • 74 Antworten
blackline2008
blackline2008
Stamm-User
166
RasBeanJelly
by rascarlo
Screens
Info:
-basierend auf AOSP
-black themed
-Power Widget
-StatusBar Tweaks
-Lockscreen Targets
-Volume Rocker Behaviours
XDA-Thread
Downlaod
Installation:
-aktuellste TWRP
-Full Wipe wenn ihr von einer anderen Rom kommt
-Cache/Dalvik Cache wipen
-Zip auf´s N7 kopieren
-Über TWRP Zip installieren
-aktuellstes GAPPS-Package von rascarlo flashen
-optional einen anderen Kernel flashen (empfohlen von rascarlo Trinity)
-Reboot
-synchronisieren mit Google
Ladet euch die GooManager im Playstore.
Ihr werdet benachrichtigt sobald es ein Update gibt.
Release / Changelog:
HTML:
***INITIAL BUILD***
- Frameworks:
    .power menu: reboot and screenshot
    .rasbeanjelly ui, black background, blue holo glow
    .package verifier enable to false
    .def install non market apps default to true
- Frameworks/Settings:
    .allow volumes to be unlinked
    .make the volume overlay more functional
    .volume rocker wake
    .volume rocker music control
    .option to control cursor in text fields using volume keys
    .volume adjust sound preference
- Settings:
    .expose build date
- Contacts:
    .fix missing December in Date Picker
***2012-11-26***
- Frameworks:
    .expanded desktop
    .expose rotation lock in quick settings
    .remove drawable for quick settings tile. black background
- Contacts:
    .T9
    .landscape option
- Phone:
    remove color overlay in incall touch ui
- Settings:
    .remove system update
- DeskClock:
    .set default alarms time
***2012-11-28***
    .build tweaks header
    .status bar clock and battery customization
    .long press back to kill app (no toast yet)
- Settings:
    .fix possible NPE in InputMethodAndLanguageSettings due to volume cursor
***2012-12-08***
- Frameworks:
    .fix notification icons not animating till ticker is updated
    .use holo alert drawables
    .remove GB alert drawable from reboot menu
    .improve tethering notification icons
    .performance increase in thumbnail handling
    .audioService: don't adjust volume when vol-downing to vibrate or silent
    .clear all button on recent apps
    .tiles
    .changed behaviour of the volume wake
***2012-12-16***
    .revert to stock tiles behaviour
    .SystemUI: Statusbar Clock and Date actions
    .customizable lock screen targets
    .Prevent scanning during DHCP process (commit to aosp)
    .GlowPadView : Re-enable magneticTargets
    .open ACTION_DATA_ROAMING_SETTINGS onClick for the RSSI tile
- Settings:
    .Changed the way that date format selector is shown (commit to aosp)
    .Settings: fix storage measurement for device without emulated sdcard (commit to aosp)
    .Format change at "Mobile network type" value (commit to aosp)
    .Makes the add button for new APNs appear in the action bar (commit to aosp)
    .Grey out settings icon when it is in disabled state (commit to aosp)
- LatinIME.
    .rbj new keyboard overlay
***2012-12-30***
- Frameworks:
    .add switch on/off action to onClick for Location tile. Keep onLongClick for default action
    .add screenOffTile
    .add ACTION_DISPLAY_SETTINGS for onLongClick behaviour of the batteryTile
    .Possible leak in android_emoji_EmojiFactory_newInstance (commit to aosp)
    .tiles. use few new icons for airplane_off, auto_rotate, bluetooth_off, brightness_auto_off/on, default_user, settings, wifi_no_network
    .add switch on/off action to onClick for rssiTile. Keep ACTION_DATA_ROAMING_SETTINGS for onLongClick
    .Don't collapse quicksettings bluetooth and wifi after change state
    .add rebootTile. onClick reboot, onLongClick reboot recovery. SU permissions needed for SystemUI
***2013-01-03***
    .NavigationBar customization
    .NavigationBar: Custom height
    .SystemUI: HSPA+ Support
    .Fixed typo in Recreating an Activity documentation (commit to aosp)
    .Fix logging typos in GpsLocationProvider (commit to aosp)
- Phone:
    .Phone: Fix NPE in PhoneUtils::toLogSafePhoneNumber (commit to aosp)
***2013-01-11***
- Frameworks:
    .enable copy/paste for google talk
    .remove duplicate cesium.ogg
    .AudioPackage5 contains duplicated bad-case filenames (media clean up)
    .ResolverActivity: don't use Holo Light
    .Use most specific attributes for distinguished name display (commit to aosp)
    .Navbar : Padding fix
    .Re-code volume rocker wake and volume rocker music control
    .TIME_TICK was not occurred at the end of DST for one hour (commit to aosp)
- Contacts:
    .If there's a contacts DB change while the dialpad is open, reload the cache instead of dropping it.
    .make contacts and people packages match the rasbean ui
***2013-01-19***
- frameworks:
    .revert "re-write of volume rocker and volume rocker music control"
- frameworks/settings:
    .add notification light cutomization
- packages/apps/contacts:
    .fix white on white for land contact_detail_fragment
- packages/apps/mms:
    .make mms match the rasbean ui
- packages/apps/settings:
    .build volume rocker only on selected devices
***2013-01-26***
- frameworks:
    .edit reboot tile to act like a powermenu tile: onClick power_menu, onLongClick power_menu_reboot
    .more black theming
    .Highlight the clear button in the recents view when clicked
    .Quick Settings: Swipe to switch
    .Quick Settings: Fix flip-to-settings animation
    .add torch tile
    .Fix for truncated sentence in "Find on Page" field (commit to aosp)
    .fix typo for symbol (commit to aosp)
    .Fix array index oob in Matrix3f.loadRotate().  commit to aosp)
    .frameworks: Display missing text on SimUnlockScreen (commit to aosp)
    .quick Settings Pulldown: Left or Right side option
    .Fix for battery temperature display (commit to aosp)
    .Fix for F/C in WifiConfigInfo (commit to aosp)
    .Force closed at settings application when delete Misc files (commit to aosp)
    .add 2 steps to navigation bar height: 20dp and 0dp (hide). 0 for those using gestures or pie
    .Option "None" replaced "Open" in Wi-Fi AP Settings of Wi-Fi Hotspot (commit to aosp)
    .Fix of Settings application sort crash (commit to aosp)
- packages/apps/deskclock:
    .Make package match the overall ui
    .Make analog clock available as a lockscreen widget.
    .Use holo blu for circleTimer. Keep red for redDiamond alert
- frameworks/ex:
    .Use holo_blue_light for chips
    .use white for message_count_color
***2013-01-29***
- frameworks/base:
    .Re-implement magnetic targets
    .Adjust kernel data stack TCP parameters to optimize performance
    .power: Add CPU boosting interface
    .Add CPU boosting hooks
    .Use separate PreferenceScreen for volume rocker behaviors
- bionic:
    .Krait enhancements from caf
    .FORTIFY_SOURCE: remove memcpy overlap checks
    .bionic: Optimizations for gettimeofday and clock_gettime
- hardware/libhardware:
    .power: Add POWER_HINT_CPU_BOOST
- system/app:
    .update SuperSu
- system/xbin:
    .update su
***2013-02-01***
- frameworks/base:
    .improve scrolling cache
    .One more fix for incorrect indices (commit to aosp)
    .SystemUI: highlight quick settings and notification clear buttons
    .Use GPS, not location
    .Status bar brightness control
    .Fix NullPointerException on locale change
- packages/apps/Mms:
    .Send next message if current one fails (commit to aosp)
    .Mms: Show menu option to delete all messages in "Manage SIM card messages" (commit to aosp)
    .Fix NullPointerException in RecipientsEditor. (commit to aosp)
    .Continue to transact pending Mms once after boot completed (commit to aosp)
    .Wake up TransactService when MMS data is available  (commit to aosp)
- packages/apps/phone:
    .Phone: IncomingCallWidget shows indefinitely sometimes. (commit to aosp)
    .Advanced phone settings:
        - Vibrate on answer
        - Vibrate on call waiting
        - Vibrate on hang up
        - Vibrate every 45 second
        - Vibrate at the second mark of every minute during outgoing calls
- system/app:
    .update SuperSu
- system/xbin:
    .update su
***2013-02-02***
PLATFORM_VERSION=4.2.1_r1.2
BUILD_ID=JOP40G
Merge release
**2013-02-26***
- Build busy box from source
- frameworks/base:
    .Bugfix: Quick Pulldown sometimes flips when it should not
    .Remove duplicate if statement (code fix)
    .Lockscreen Targets: Dismiss on target select
    .Lockscreen Targets: icon revamp
    .Add method to PowerManager that allows querying the lowest possible brightness
    .Navbar : Fix left over glow
    .Lockscreen Targets : Make multi-user compatible
    .systemui: modify hdpi & xhdpi drawables for battery_min
    .Fix unexpected rotation change when re-enabling auto-rotate (commit to aosp)
    .Change default intent (commit to aosp)
    .Function uri.getAuthority is called twice. Minor doc corrections (commit to aosp)
    .avoid multiple-"0" to exceed the length of upper bound (commit to aosp)
    .add reply.writeNoException() for quick response (commit to aosp)
    .Fix bugs regarding IllegalStateException during moving position in cursorwindow (commit to aosp)
    .Clear loaders array after they are destroyed (commit to aosp)
    .Potential NPE in SQLiteConnection (commit to aosp)
    .Keep native callbacks when primary SQLiteConnection is recreated (commit to aosp)
    .Disable usage of WAL in DatabaseHelper (commit to aosp)
    .fix hover events consume issue (commit to aosp)
    .Fix PointerCoords Parcel incorrectly storing values as Int32 (commit to aosp)
    .DateView: Use Intent.ACTION_LOCALE_CHANGED to refresh notification bar clock (commit to aosp)
    .Services: Adding HSPAP info in Android (commit to aosp)
    .Handle hotplug events as described instead of rescanning (commit to aosp)
    .Process all display events in order (commit to aosp)
    .MediaStore.Audio.Media.getContentUriForPath() returns unexpected content (commit to aosp)
    .Fix ViewRootImpl to find missing focus using D-pad (commit to aosp)
    .Added English UK keyboard layout for physical keyboards (commit to aosp)
    -SystemUI: Make the HSPA+ drawables more consistent with the HSPA drawables
    .Enable multi-user support for volume_link_notification
    .Lockscreen Targets Icon Revamp
    .wifiSettings: Updating the networkinfo on supplicant event (commit to aosp)
    .P2PSetting:Avoid p2p_find on group removal event (commit to aosp)
    .Show formatted number in T9 result list
    .Improve T9 normalization code
- system/app:
    .updates SuperSu
- system/xbin:
    .update su
***2013-03-04***
PLATFORM_VERSION=4.2.2_r1
BUILD_ID=JDQ39
merge release
***2013-03-24***
- frameworks/base:
    .Fix NPE when pasting non-text from Clipboard (commit to aosp)
    .Reflect current state of torch in navigation ring button
    .Fix SystemUI crashing when ther user uninstalls an app previously set as a navigation ring shortcut
- packages/app/settings:
    .Move Superuser header below Developer Options
***2013-03-26
- frameworks/base:
    .Make system layout fill the window properly on expanded desktop mode.
    .Fix up expanded desktop behaviour.
    .Added support for multiple navigation key bars
    .Add pie control optimizations for Phone UI.
    .Option to show/hide status bar in expanded desktop mode.
    .Pie control
***2013-04-04***
    .Whether power menu expanded desktop is enabled
    .Make Navigation Bar and Pie Controls share the same button layout
***2013-o4-08***
- frameworks/base:
    .Power Menu: Update the Expanded Desktop drawable
    .LockscreenTargets : Dismiss on target select
    .Fix pie controls being disabled by launcher gestures
    .FlingTracker can divide by zero and hang StatusBar in an infinite loop
    .Fix divisions by zero on boo
    .Toggle expanded desktop for navigation bar
    .Enable Ethernet tab in data usage (commit to AOSP)
    .Expose system settings for all users.
    .Hide non multi-user compatible settings for secondary user
    .Move status bar behavior while in expanded mode into pie control
- frameworks/base:
    .Improving pie control's user interaction
    .Fix potential deadlock between LockScreen and WindowManagerService (commit to aosp)
    .Fix DateUtils.formatElapsedTime (commit to aosp)
    .use Calendar in DateUtils format method (commit to aosp)
- dalvik:
    .Zygote: Restrict slave mountspace so Dalvik apps can mount system-wide volumes
    .dalvik: remove duplicated call to dvmJitCalleeSave()
    .Change NewDirectByteBuffer to allow NULL if capacity == 0
    .Optimize dvmHash Loops
    .Remove possilbe leaks in dalvik
    .Reclaiming attribute obj after pthread_create
    .Fix handling of annotations whose classes are missing at runtime
    .Possible leak in dvmAllocRegion
    .Optimize opcodes to avoid bubble in pipeline
    .ExceptionInInitializerError should wrap only non Error exceptions
    .Remove dvmFindInterfaceMethodInCache2
    .Use ALOGE rather than SLOGE for mountEmulatedStorage failures
- frameworks/base - packages/apps/settings:
    .User Interface: Multi pane preference settings User Interface
***2013-04-14***
- frameworks/base:
    .Quick launch shortcuts: update search panel on userSwitch to recreate targets
    .keyguard: enable magnetic target if no custom targets defined
    .Adapt navigation bar's long press behaviour for pie controls
    .SystemUI: fix memory leaks
    .Improve dual pane preferences summary
    .Move quick lunch shortcuts to build tweaks
    .Expose User interface only on selected devices
    .It is a Nexus, not simply a phone/tablet
    .Update kill_app_longpress_back_summary
- dalvik:
    .Remove dead instruction in common_exceptionThrown (commit to aosp)
    .Fix a tracked reference leak in dvmGenerateProxyClass (commit to aosp)
    .Remove stray references to non-existent opcodes (commit to aosp)
    .Fix a Field.isAnnotationPresent crash (commit to aosp)
    .Dump native stacks for all threads in native code (commit to aosp)
    .Fix a minor leak in handleVM_CreateString (commit to aosp)
    .Fix a minor leaks caused by failed initializations.(typo) (commit to aosp)
    .Fix a leak in Dalvik_dalvik_system_DexFile_openDexFile (commit to aosp)
    .Tiny optimization for complier templates for arm (commit to aosp)
***2013-04-22
- frameworks/base:
    .Don't start keyguard in an attempt to exit it.
    .PowerMenu : Improve keyguard filtered actions
    .Led Settings : Hex input for colorpicker
- packages/inputmethods/LatinIME:
    SummerTime: restore some white icons and textviews
Reaktionen: cptechnik, arashi, Tetsujin und eine weitere Person
So, Screenshots hinzugefügt.
Ich hab's nur kurz getestet, aber ich finde es nicht so performant wie CM10...
Aber ich hatte auch noch nicht den TrinityKernel drauf (dieses ROM hat den StockKernel an Bord).
Neues Update ist draußen!
Startpost angepasst!
Wieder neues Update am 26.09.!
Also bevor der Thread hier einschläft (was eine Schande vor dem Herrn wäre!!!), will ich mal loswerden, dass egal welche Nexus 7 Hybrid schnick schnack rom ich auch teste (AOKP, PA, SmoothROM, BuglessBeast usw.), ich jedes mal auf die RasBeanJelly zurück komme (beim Nexus habe ich das schon vor längerer Zeit eingesehen:love:).
Die Rom ist genau so wie beim Galaxy Nexus (Prime :D) absolut Bugfree, schnell, nie ein FC und vor allem Black!:love:
(ist halt kein TabletUI etc. aber ich finde das PhabletUI nicht schlimm oder störend. Zumal damit alles "störfrei" läuft!)
Meine Kernel- Empfehlung für die ROM ist der neuste Franco (Ich weiß RasBean + Trinity etc. pp.). Aber auf dem Nexus7 macht der Franco Kernel einen Bomben Job! Hatte schon Trinity, Elite, Motley usw. getestet.... entweder kein merkbarer Leistungsunterschied obwohl die viel stärker OC (CPU bis zu 1,6Ghz, teilweise sogar 1,8Ghz und bis zu 650 Mhz GPU) waren oder das Nexus 7 wurde heiß.....
Beim Franco garnichts! der läuft richtig sauber und stabil.
Wer also was richtig schönes und leichtes sucht, das nie zickt und einfach sauber und schnell läuft, dem kann ich diese Rom mit Franco nur empfehlen.
Reaktionen: pe7er und Elting
Neue Version ist draußen!
Ich hab nun viel ausprobiert (CM10, AOKP, PA, EOS, SmoothROM) aber dieses Stück Software in Verbindung mit dem neuesten Faux-Kernel rockt die Hütte bei mir! ;)
Flüssiger und performanter kann es fast gar nicht mehr sein... :thumbup:
Neue Version ist seit gestern online!
Startpost angepasst! :)
Hallo. Erstmal Danke an den Threadersteller.
Bin von PA gewechselt und bisher sehr zufrieden. Sehr schlank, schnörkellos und performant. So mag ich es am liebsten.
Reaktionen: Elting
wenn man in die Build Tweaks geht dann kann man ja die Lockscreen shortcuts einstellen.
hier werden aber bei mir kaum apps angezeigt. hätte zum beispiel gerne den browser und facebook drin, aber die stehen nicht zur auswahl.
hat jemand eine idee?
Normal sollten unter Aplications alle installierten Apps aufgelistet sein....
Kleines HowTo meiner Seite.
Grüße
Danke
Ich war zu blöd und hab das untermenü `applikationen' übersehen
Du redest mir wie immer von der Seele, alter, wir verstehen uns :) Meine Frau hat sich zur Weihnachten einen Kindle gewünscht ( ja,ja, Frauen und Technik ;)) fürs lesen und so. Da sagte ich " Schatz, da habe ich was viel besseres für dich, lass dich überraschen ;) " Also, bin bald sicherlich auch hier unterwegs, denn für mich gibt es mittlerweile nur ein Rom... RasBeanJelly = BlackBeauty :love: :drool: Bis bald...
Reaktionen: Elting und Tetsujin
Jetzt hätte ich in dem ganzen Trouble doch glatt die neue Version übersehen...
Reaktionen: arashi
So, bin jetzt mal hier gelandet! Es läuft phantastisch! Dieses Rom kann ich sehr empfehlen!
vomited by N7
is die navigationbar so weit einstellbar das man die Höhe verstellen kann?
sent from s2
der downloadmirror lädt sich tot bei mir.. hat jmd ne alternative bitte?
sent from my Nexus 7
Neues Build ist draußen!
Reaktionen: arashi
RasBeanJelly gibt's nun auch in der 4.2er Version! :)
Beachtet unbedingt den Hinweis auf die aktuellen Recoveries!
