[ROM][2012-10-01] Meldrak A510 Custom Light Stock ROM
  • 0 Antworten
M1cha84
M1cha84
Es gibt eine neue Custom Rom für unser geliebtes A510:
A510 Custom Light Stock ROM Odexed
built on Acer_AV041_A510_1.099.00 and
NoThrills WorldWide optimized Stock ROM
I made this rom for my personal use but I want to share it with you
First of all, I'd like to thank you NoThrills for his roms and recovery
This rom is very close up to his, so take a look at main features on his topic
Here's what's changed:
  • rom is fully ODEXED (speed up boot and default applications)
  • default launcher replaced by HoloLauncherHD (JellyBean like launcher)
  • screen sensitivity bug "removed" (tablet will always start with sensitivity set to high)
  • olympic stuff removed (wallpaper removed and bootanimation set to iconia tab)
  • all Acer applications removed exept Ring, Print, DolbyMobile and DRMVideoPlayer
  • AmazonApps, FileManagerHD, FlashPlayer and TitaniumBackup added to flexrom
  • all apps up to date on 2012-09-30 (exept AcerRing that I wasn't able to integrate update)
  • Phone services removed to save more battery
  • original Acer kernel
Installation:
  • If you don't have it already, install the CWM-Based Recovery.
  • Download the ROM from this post and put the .ZIP file on your internal or external SD Card.
  • Start Recovery by powering down your device, holding the Volume down (**) button and turning it on again.
  • Make a Nandroid Backup. Select backup and restore and choose one of the backup options.
  • Select wipe data/factory reset. Select format /flexrom in mount menu.
  • Install this ROM by choosing install zip from sdcard and then choose zip from sdcard or choose zip from external sdcard.
  • Wait for the installation to finish and select reboot system now.
DOWNLOAD
Viel Spass beim Ausprobieren!
Hier der Link zum XDA-Thread
DenisKamylin
DenisKamylin
DenisKamylin
HM56
HM56
  • Rohwi62
Rohwi62
