[epic wip]cm12 5.0.2 a500/a501 - v0
  • 20 Antworten
Holli
Holli
A500/A501
Features:
  • 5.x CM12 based
  • WIFI/Bluetooth
  • Audio
  • Storage
  • 2D/3D acceleration
  • Cameras
  • GPS
  • can boot from data/system/cache btrfs/f2fs/ext4 fstypes
  • exfat/ntfs/btrfs/f2fs storage mounting
  • custom dpi without affecting google apps
  • usb huawei 3g support
  • a501 3g/gps support
  • sound boost
  • usb audio sound card support
  • btrfs mounting
  • ntfs mounting
  • HDMI
  • gpu oc
  • do something about the bottom buttons they are hard to get to(buttons to the left option)
  • hardware rotation lock
  • kernel t68
To do:
  • dock not supported
  • listview animations
  • usb ethernet menu
  • full hw video codecs
  • handle usb modem zerocd(usb modem mode switch)
  • tell me more?
stuff to know:
  • wipe from any rom
  • tablet ui is gone and buried from now on phablet ui only
Screenshots: second post
Installing/updating:
  • wipe data comming from any rom except this one...
  • install rom zip
  • install gapps
  • reboot
  • let it settle for a couple of minutes
Changelog:
v0 - init release
- cm sync 15.02.15
- has some of the omnirom changes
- GUI works fast and good
- GPS works but slow lock... usual
- left buttons works
- camera works
- codecs work most of the time :)
- hardware rotation switch should work
a501 3g/gps not working yet
- 3g huawei not working from usb yet
- power hal not working
- vpn has some issues
- use gapps posted here not the ones from omnirom
- rom doesn't need supersu... it uses a build in implementation
- TO REMEMBER THIS IS NOT EVEN CLOSE TO OmniROM compleation level
- tell me more issues in the forum!!!!
Link/Download: Forum TegraOwners • View topic - [EPIC WIP]CM12 5.0.2 A500/A501 - V0
Thanks thor2002ro
Reaktionen: Fiedl, Rob J. Cole, yasindas und eine weitere Person
Bei der Installation stehen ja verschiedene Kernel zur Auswahl.... welcher is da eigentlich der Richtige?
Oder welcher der Bessere?
mfg
@de-Ravin Hab den letzten Kernel beim Flashen ausgewählt. Glaube das war 4.9
Keinerlei Probleme damit. :biggrin:
Vielen Dank für die tolle CM 12 ROM. Läuft richtig rund und fast ohne Ruckeln. So weit es die alte Hardware noch her gibt:winki:
Ist die ROM auch so "laggy" wie die OMNI ROM?
Bei mir ist auf alle Fälle nichts laggy. Läuft alles sehr flüssig.
Hätte nicht gedacht, dass ich das A500 noch mal so viel nutzen werde.
Macht wieder richtig Spass mit dieser ROM.
Die Omni lief bei mir vorher auch laggy.:smile:
Reaktionen: Pharao373 und r998877
Gibt ja jetzt die v1 :smile:
Reaktionen: r998877 und Pharao373
Läuft die besser als 4.4.4?
Rein subjektiv würde ich sagen: nein. Die 4.4.4 OMNI ROM lief etwas flüssiger. Sie läuft aber auf jeden Fall besser als die Lollipop OMNI ROM. Bei mir funktionieren endlich wieder Youtube-Videos in 720p.
Hallo
ich versuche nun schon lange das cm12 zu flashen.
Nach dem flashen bekomme ich immer einen schwarzes Display und ein weißes Dreieck unten links?
Auch eine kompl.wipe bringt nichts.
Der ursprüngliche Beitrag von 10:20 Uhr wurde um 11:20 Uhr ergänzt:
So kurze Info,ich habe es geschafft,habe das update-recovery-TWRP-rev2.0-beta4 geflasht und danach das Rom geflasht mit den gapps.
Super :thumbsup:
Aber über USB kann das Tab nicht geladen werden?
Der ursprüngliche Beitrag von 11:20 Uhr wurde um 11:40 Uhr ergänzt:
Hat das einer von euch schon gerootet?
Wenn ja wie wirt das gemacht.
So rooten ging auch mit Update-SuperSU-v2.40:thumbup:
Und wieso kann ich keinen anderen Browser (boat-browser)installieren?
v2 - cm12 sync 29.03.15
- changes from omnirom v6
- adapted hwcodecs
- updated power hal
- update automatic brightness should work a lot better
- possible fix for
a501 modem data
- increase zram size
- trebuchet update
- sqlite optimizations
- bootanimation triggers a cpu boost
- includes kernel t70 scratch rework kernel(theres 1 kernel flavor)
:winki:
Omni v7 mit dem neuen Kernel ist auch jetzt da!!
Der sollte auch mit v23 der finalen kitkat laufen.
Hi,muß ich das ROM nach dem downoad erst entpacken bevor ich es flashen kann,denn in der Zip ist ja noch eine Zip?
Gruß Fiedl
Hi,wo finde ich denn Designs für das ROM? Für`s Tablet geeignet!
Gruß Fiedl
HALLO!!! Ist hier keiner mehr aktiv???
Gruß Fiedl
Nein, die Zip kannst du in der Recovery flashen.
Gruß Fiedl
Welches Design?
Nein, das Tablet ist ja auch schon ziemlich alt ;)
Naja,das Tablet vielleicht,aber das ROM doch nicht. Die Zip ging so nicht zu flashen.Mußte doch erst nochmal entpackt werden.Dann gings.
Welches Design!? Ist doch eine Theme Engine vorhanden. Die Designs meinte ich.
Gruß Fiedl
hallochen
habe das rom auf 2 A501 installiert aber bei beiden wird die Simkarte nicht angenommen
Hat wer auch dieses problem ud vielleicht eine Lösung
Mfg Sepp
Dein supersu ist 2.46?
Reaktionen: sepp1307
Hallo Eurodroid
Danke für deine Hilfe
Hat geholfen bei dem Rom hier und auch beim Omnirom
...so einfach :) Super!
Hollapolla
Rob J. Cole
acer
Aaskereija
Aaskereija
