[A700][ROM] iconiaN 2.6 (Jelly Bean 4.1.1) Fully rooted
  • 132 Antworten
trayzor
Dauer-User
338
Na dann, auf in die nächste Runde.
aktuelle Version: 2.6
--> [A700][ROM][BETA] iconiaN 1.0 (Jelly Bean 4.1.1) Fully rooted - xda-developers A700 "choose zip from sdcard" -> zip auswählen
[*]freuen
[/LIST]
DIESE ROM IST NUR FÜR DAS A700.
Für das A701, möge man hier reinblicken : A701 4.1.1 [JB] OTA Firmware. UPDATE: FULL 4.1.1 and ROOT - xda-developers
Original-Text:
*** CAUTION ***
ROM HAS ONLY BEEN TESTED ON A EMEA_GB DEVICE
*** FLASH AT YOUR OWN RISK ***
iconiaN is a project I am starting to bring a unified stock rom to the A700 that will work on devices from all regions.
I will soon be making iconiaN a project on github in the next few weeks and will welcome contributions from you all.
About the rom:
  • Android 4.1.1 (Jelly Bean) - Based on latest RV10RC01.EMEA.GB
  • Fully working ROOT
  • Unsecured boot.img
  • Newest BusyBox
  • Zipaligned
  • Fully de-odexed
  • init.d scripts (BusyBox run-parts) support (Not Tested)
  • All /system applications updated to latest available
  • Aroma installer - Choose what bloatware to remove (Can not remove Polaris Office or Solitaire)
You need:
  • Acer Iconia Tab A700 with unlocked bootloader
  • ClockworkMod Recovery
  • Jelly Bean Firmware (can be installed with rom)
How to flash:
  • Download ROM and place it on your virtual SD card
  • Boot your phone into ClockworkMod Recovery (via adb or with a key combo)
  • In main menu, select "install zip from sdcard"
  • Select "choose zip from sdcard" and browse to the location of iconiaN rom
  • After flashing process is complete, reboot the device (device will auto reboot if updating firmware)
Download:
Thanks to:
  • Moscow Desire
  • pawitp
  • chainfire
  • Bluewall for initial work on the logo
  • plus all those who helped to crack open the A700
Hier sollten vielleicht noch ein paar Anmerkungen gemacht werden.
- Das Rom eignet sich sehr gut für User die noch bei ICS 4.0.4 stecken, den es bringt den JB 4.1.1 Bootloader mit.
- Es kann mit allen Versionen geflasht werden, da es keine Regionabfrage hat.
Bei der Installation ist zu beachten was ihr für eine Version habt!
Bei der ersten Abfrage:
- User mit JB 4.1.1 nehmen den ersten Eintrag.
- User mit ICS 4.0.4 den zweiten.
Bei der zweiten, Full Wipe, kommt es darauf an, wie mutig ihr seid. Ich habe den ersten Eintrag gewählt. Ich vertraue den Factory/ Daten Rest noch nicht.
Wenn der Roboter am Schluss der Installation umfällt, keine Angst, es läuft.
Ansonsten, gutes Rom. So was sollte von Acer kommen.
Hatte bei meinem ICS->JB Sprung sicherheitshalber nen Full Wipe hingelegt..der Kleine lebt nocht ;) Ich zieh das grade rüber, werde dann berichten.
Full Wipe hingelegt
Ok, gut zu wissen. Ist insgesamt ein sehr gutes Stock Rom, ohne die kleinen Mängel, der nachbehandelten Stock Roms.
Installation verlief problemlos, Tablet rennt. Am Ende kam dann zwar das tote Android-Zeichen, aber das kann man wohl ignorieren.
Edit : Wollte grade mit nem Font Changer die Font ändern.. Boot Loop :D Also Finger weg davon :D
Ja, ist da sehr anfällig. Geht nicht jede Schrift.
schon etliche Factory Resets und CWM Wipe´s hinter mir, bisher keine Probs!
Und da ich sehe das auch "mein" Chainfire mit an Board war kann das nur gut sein!
Eig Schade das ich es grad nicht brauche, wird aber natürlich in CWM/ROM Ordner gelegt, zu den anderen ;)
Der ursprüngliche Beitrag von 19:02 Uhr wurde um 19:14 Uhr ergänzt:
hm, wollte das grad in POST3 meines TuT Threads übernehmen aber ich kann außer Post1 nichts editieren :(
mal daheim am rechner dann schauen....
Frage zum ROM, startet in English oder? so wie das FR in Französisch. Kann aber auf DE umgestellt werden. zeigt aber als Version EMEA_GB an?
Und der Aroma-Installer ist wohl auch auf Englisch!?
Aroma ist auf Englisch, gibt wohl keine Übersetzung.
Da ich weder Daten gewipet habe noch JB-Rom installiert habe, kann ich dir zu deiner anderen Frage nichts mit Sicherheit sagen.
Aber von der Logik her : Wenn das FR in FR startet, dann wird das GB in E starten. Ich vermute aber wirklich, dass da gewipet wurde.
Ansonsten - wenn du die JB per Aroma NICHT flashst, hast du natürlich noch das Deutsche EMEA_DE ;-)
löschbar, hat sich erledigt
wäre nett wenn es ein paar optimierungen hätte bezüglich dem fullhd display wie z.B animationen abschalten oder per hardware rendern lassen, + auflösung ändern usw weil das originale Acer JB ist LAAAHM
Zum einen is es fast pur Stock, zum anderen läuft jb ziemlich gut;)
Aus einer fernen Galaxie getappt
Gibs Doch endlich zurück und Kauf dir was anderes!
:screwy:
Sorry für manche Schreibfehler, aber mit Slide It ist zwar schnell aber nit schön geschrieben! ;-)
Gesendet vom Note OTA
Bitte nicht auf Nexxxus herumhacken!
Er ist der Held, weil wir durch seine Recherche nun wissen, woher der JB-USB-Unplug-Bug kommt!
Da hat er jetzt ein paar Quatschred-Freispiele! :thumbup:
Mag ja sein aber das dauergemecker nervt ebend. :rolleyes:
Vor allem bringts hier nix wenn dann bei acer, die könntens ändern .
Wir sollten hier auf fachlich/sachlicher Basis kommunizieren :D
Gesendet von meinem A700 mit Tapatalk 2
Was genau ist an diesem Rom besser als das original von acer ? läuft das ganze flüssiger ? Ist es nicht so voll gestopft mit unnötiger Software ?
Post 1 LESEN und selbst entscheiden
Es hat Fullroot. Bei der hier angebotenen Methode, ist das nicht der Fall, beim original DE, gleich gar nicht. Um ein Gerät richtig nutzen zu können, ist das eine wichtige Entscheidung. Es scheint auch einen Tick neuer zu sein.
Jein. Nein, wenn man es so lässt. Ja, da man ja überflüssiges entfernen(root) kann.
Ist im Urzustand ist es gleich.
Reaktionen: sedai
Während der Installation kannst du per Aroma auswählen, was nicht installiert werden soll. Insofern schon ein bisschen weniger aufgebläht :)
Gesendet von meinem A700 mit der Android-Hilfe.de App
Reaktionen: sedai
das ROM wäre perfekt wenn es exfat support hätte.
weis einer zufällig ob exfat geht bzw noch irgendwie nachgerüstet werden kann?
Mir geht es darum große dateien auf die SD zu schreiben z.B FullHD Filme.
NTFS funktioniert zwar aber es ist langsam wegen dem journaling und nutzt die MicroSD schneller ab als exfat.
  • Gabberlein
Gabberlein
D3ltoroxp
Andi2017
