[KERNEL][4.4.4]F(X)TrinityUltimateKernel-V3.0 | F2FS | IntelliV2 | exFAT | OC | FSync
  • 25 Antworten
MysticEnforcer
MysticEnforcer
Dauer-User
743
F(X)TrinityUltimateK.
Info / Download
TrinityUltimateKernel_3.0.zip
[KERNEL][KK][4.4.4][Linux-3.4.4]F(X)TrinityUltimateKernel-V1.5 - OC/GPU/CC - Ultimate Kernel! | Xperia Z1 | XDA Forum
Changelog alle Versionen
V3.0Major Changes
  • Merge New Sony Source
  • sm: vidc: eliminate race condition in dynamic buffer mode
  • kernel/futex.c: Linux 3.4 compatibility fix up
  • futex: Avoid taking hb lock if nothing to wakeup
  • softirq: reduce latencies
  • futex: Larger hash table
  • AND MANY MORE!! Check Out The Git. Added Last 26Days Ago!
V2.8 and 2.9_EXT Major Patches
  • Added IntelliThermal V2 Of Faux123
  • Added Custom WLAN Driver
  • Dave Kleikamp fxTHaxxorX
  • iov_iter: iov_iter_copy_from_user() should use non-atomic copy …
  • kleikamp authored on Feb 3, 2013 fxTHaxxorX committed an hour ago
  • iov_iter: move into its own file …
  • qup_i2c: Initialize I2C resource before registering. …
  • i2c_qup: Fix for unhandled IRQ …
  • qup_i2c: export qup_i2c_init_driver …
  • page_alloc: Make watermarks tunable separately
  • 25+ Patches More.
V2.7B
  • Fix Wakeup Issue
  • cpufreq: force cpuN policy to match cpu0 when changing freq or gov
  • cpuidle: remove the power_specified field in the driver …
  • cpuidle: Fix finding state with min power_usage …
  • cpuidle: Get typical recent sleep interval …
  • cpuidle: Quickly notice prediction failure in general case …
  • cpuidle: Quickly notice prediction failure for repeat mode …
  • cpuidle: move field disable from per-driver to per-cpu
  • sched: Remove unused params of build_sched_domain() …
  • sched: Optimize build_sched_domains() for saving first SD node for a cpu …
  • sched: scale the busy and this queue's per-task load before compare …
  • sched: remove WARN_ON(!sd) from init_sched_groups_power() …
  • sched: don't call get_group() for covered cpus …
  • sched: Use cached value of span instead of calling sched_domain_span() …
  • cpufreq: Fix policy getting stuck when user & kernel min/max don't ov… …
  • cpuidle: remove unused variable dead_state
V2.6
  • Upstream Update From 3.4.0 to 3.4.9 Upstream
  • WiFi And exFAT Works! Kernel Version is Updated!
  • And Many more! - To be Added.
  • HTC AFSync
  • Added PegasusQ
  • Added Adaptive
  • Added frontswap v16
  • Added abyssplug
  • Added New CpuFreq Driver
  • Added F2FS File System Support***
  • Updated ZRAM
  • Adaption Of HR_TIMER for 3.4
  • sparc64 Misc Patches.
  • ASoC: wcd9xxx: Enable headset in high performance
  • Fully WORKING exFAT AND WiFi - You Can see the proof because 3.4.0 is changed to 3.4.X
V2.5
  • New GPU Optimization
  • DT2W With DeepSleep
V2.4AC-REFRESHED
  • Advance GPU OC V2 - 600Mhz
  • EXT4 - Speed Boost
  • Added New BootSplash
  • Added New KGSL Update
  • Added New MDP Update
  • Add SlimBus OC
V2.4AC
  • Advance GPU OC V2
  • New KGSL Update
  • SLQB Re-Added
  • New DT2W
V2.4
  • Advance GPU OC
  • New KGSL Update
  • Added Advance TCP Congestion
  • Remove Low FPS
  • Fixed 2-3 Reboots after Intallation
V2.2-3 SPECIAL
  • Galaxy Note 3 OC CPU Table
  • Updated MDP Overlay
  • KGSL Update
  • DoubleTap2Wake With Battery Drain Fix
  • New MakeFile Changes
  • New TCP Congestion
V2.1
  • exFAT Fix
V2.0
GPU Performance Legit Boost Upto 10% Now!
  • * New Patches at KGSL and MDSS
  • * Reduce Voltage
  • * New I/O Scheduler ( TrinNDroid )
  • * ARCH_POWER = Enabled
  • * softirq: Use hotplug thread infrastructure
  • * [backport] Hotplug thread infrastructure
  • Increased Battery Life
  • Updated CPU Frequency Stepping
  • Partial Fix for CPU Heating - Reduce by 5%
  • Increased Performance to 15%
  • Upstream Update For CPU Frequemcy
  • Increase performance form 5MS to 2MS
  • 15+ More!
V1.9 - Special Update and Special Kernel Series
  • Updated Intelliplug
  • Tons Of Optimization
  • Updated TWRP Now Working at KK
  • Updated Futex Table x2 Performance
  • Added PowerSuspend Hooks
  • Fixed GPU OC - Now It Doesn't go Back to 450 ( Make Sure to Re-Apply the OC Every ReBoot )
  • TCP Window Size is 64K
  • Optimize Slack_Speed for Size and Speed
  • Added Frandom - Increased Speed and Performance ( Benchmark Results Improved )
  • Reduce VFS Pressure
  • PowerSuspend Updated to 1.5
  • PowerSusped Added Userspace | HYBRID | USERCONTROL - Use FauxApp To Control This.
  • SOFTIRQ : Reduce Latencies
  • slub.c: little tweak for performance improvements
ChangeLog For 1.8
  • Linux 3.4,91 || UnPushed 3.4.62-3.4.90
  • Removed Chronic Hotplug and smp
  • Fix 2.4GhzOC Table Except Voltage Table
  • 1080p Recording Optimization And Tweak
  • msm_fb: Set RR sched policy for Glupdator thread
ChangeLog For 1.7
  • CHROMIUM: BACKPORT: lib/lzo: huge LZO decompression speedup on ARM by
  • CHROMIUM: BACKPORT: lib/lzo: Update LZO compression to current upstream
  • CHROMIUM: mm: Fix calculation of dirtyable memory
  • msm8974-regulator.dtsi: further reduce CPU retention voltage
  • msm8974-regulator.dtsi: adjust GFX regulator parameters
  • char:random: Some tweaks from around github
  • futex: Make lookup_pi_state more robust
  • futex: Always cleanup owner tid in unlock_pi
  • futex: Validate atomic acquisition in futex_lock_pi_atomic()
  • mm, oom: fix and cleanup oom score calculations
  • mm, oom: fix badness score underflow
  • futex: Prevent attaching to kernel threads
  • evert "Revert "Correct R and G offsets for correct mapping""
ChangeLog For 1.6
  • Linux 3.4.0 - 3.4.62
  • Remove Early Suspend
  • Increase MDP Clock By x2
  • CpuFreq Optimization
  • XHCI Optimization
ChangeLog For 1.5
  • Linux 3.4.0 - 3.4.4
  • Re-Optimized KGSL - ( Remove Some Flickers )
  • Patch Sched.c
  • Patch Sched.h
  • Improved SSD
  • exFAT Tweak
  • Moved 2.6.X Device Tree To 3.4.X
  • Events Optimization
  • FS - AIO Optimization
  • FUSE Optimization
  • NFS Tweak
ChangeLog For 1.4
  • Optimized Square Root
  • Bit Optimization
  • mm : Read-Ahead To 512kB
  • SavaGedZen Gov
  • KGSL Tweak V2
  • R and G Offset Mappings
  • Reduce CPU Retention
  • Add Early_Suspend_Delay
  • Ramdisk : Enable Init.d Support
  • Patch The GPU
  • CPUs Patch
ChangeLog For 1.3 [/B
  • Re-Merge To Latest Sources ( Removing some cherry-picked Patches )
ChangeLog For 1.1
  • Rebased To New Kernel Source
  • Fix Pronto Wlan
ChangeLog For 1.0
  • TCP Congestion Advance:
    • TCP - Hybla
    • TCP - Cubic
    • TCP - Reno
    • TCP - Bic
    • TCP - WestWood
    • TCP - HighSpeed
    • TCP - HTCP
    • TCP - Vegas
    • TCP - Veno
    • TCP - Scalable
    • TCP - Lp
    • TCP - Yeah
    • TCP - illinois
  • MMC Tweak
  • KGSL Tweak - Optimize For Gaming
  • Linaro ToolChain
  • F2FS Enabled
  • MSM8964-Regulator
  • Sched : Optimization
  • FastCharge
  • ZRAM
  • Cherry-picked All Features From DooMLoRD using SmartGit or Merge All Features From His Source.
  • Other Features Merge Faux123 using SmartGit
  • Kernel:Workque Optimization
  • Correct R and G offsets for correct mapping
  • kernel:sched: LOAD_FREQ (4*HZ+61) avoids loadavg Moire
  • smp: patches from mainline 3.5 to hopefully help with hotplug efficiency
  • LMK Optimization
  • Slub Tweak
teste gleich mal die neuste version,
bis jetzt ist der kernel ganz gut &
die akkulaufzeit ist top :thumbup:
Reaktionen: Hen Ry
Stockkernel ist klar, aber für die neue FW...118 auch, oder bis 108???
ich hab die .108 am laufen
der ersteller sag nur, dass er für 4.4.4 ist
Reaktionen: Hen Ry
Geht, FW.108 :):):)
Paar Einstellungen wären nicht schlecht. Leistung, Ausgleichen, Akkuschonend.
Reaktionen: MysticEnforcer
TWRP ist älter (v.2.6.3.0) oder nicht an das XZ1 angepasst, deshalb funktioniert es nicht!!!
von mir angepasst: TrinityUltimateKernel mit aktuellen TWRP v2.7.1
Was wird denn mit dem TWRP gemeint? wenn die Version nicht fuers Z1 "angepasst" ist wieso wird die Version dort eingebaut?.
Was ich festgestellt habe, ist der Zugriff auf die SD-Karte (v2.6.3.0), sonst funktioniert alles.
Nachdem ich TWRP v2.7.1 eingefügt habe ist das Problem beseitigt.
Wie bekomme ich denn des reine TWRP 2.7.1 "geflasht"?
es gibt kein reines für das XZ1 nur für das XZ
da müsste ich mal eins zusamen basteln
entweder gleich in die boot.img oder oder als reines Recovery
fastboot flash boot boot.img
fastboot flash recovery twrp.img
so in etwa
in der boot.img ist das CWM drin das tausche ich einfach gegen das neue TWRP aus,
ansonsten muss ich das vom XZ anpassen
# mount point fstype device [device2] fstype2 XZ
/boot emmc /dev/block/platform/msm_sdcc.1/by-name/boot
/system ext4 /dev/block/platform/msm_sdcc.1/by-name/system
/cache ext4 /dev/block/platform/msm_sdcc.1/by-name/cache
/data ext4 /dev/block/platform/msm_sdcc.1/by-name/userdata length=-16384
/external_sd vfat /dev/block/mmcblk1p1 /dev/block/mmcblk1 flags=display="Micro SDcard";storage;wipeingui;removable
/usb-otg vfat /dev/block/sda1 /dev/block/sda flags=display="USB OTG";storage;wipeingui;removable
# mount point fstype device [device2] fstype2 XZ1
/sdcard datamedia /dev/null
/external_sd auto /dev/block/mmcblk1p1 /dev/block/mmcblk1
Also kann ich ein "Paket" (.zip) File basteln, was ich nach dem flashen eines neuen Kernels/ROM einspiele, damit ich immer auf der gleichen Recovery Version bleibe?.
neue Version ist da - V.1.7B - Download ( Support 4.4.4 Only )
[KERNEL][KK][4.4.4][Linux-3.4.62]F(X)TrinityUltimateKernel-V1.7 - Spoofed | CPU | CC - Simple But Fast! | Fixed BootLoop | GPU 600Mhz
[ Features : ]
  • GPU OverClock
  • CPU OverClock
  • MPDecision
  • TCP Congestion
  • Many More!
[ Schedulers & Governor : ]
  • Deadline
  • Noop
  • Row
  • CFQ
  • SIO
  • FIOPS
  • BFQ
  • ZEN
  • VR
  • LagFree
  • SmartAssV2
  • PegasusQ
  • IntelliActive and Intellidemand
  • Interactive
  • Darkness(?)
  • Wheatley
  • DanceDance
  • SavagedZen
  • OndemandX (?)
  • OndemandQ (?)
  • Conservatice, Ondemand, Lionheart, LionheartX(?), Performance.
[ Future Features : ]
  • New BootImage
  • Compiled using CustomizeToolChain Via SGS4 Section
  • New Patches
  • AROMA Installer
  • New Kernel Version || ATM It's 3.4.0
Und schon im betrieb?
V.1.9 - Download ( Support 4.4.4 Only )
Download
Battery Life Saver Settings - CLOCK
  • 2.266 / 2.400Ghz - Max Clock
  • 322 / 422 - Min Clock
CPU HotPlug
  • Intelliplug
I/O Scheduler
  • eMMC - cfq
  • SDCard - bfq
V.2.3X - Download ( Support 4.4.4 Only )
Download
TrinityUltimateKernelV2.3AB_0-Special = Without DoubleTap2Wake ( However There will be Deepsleep )
TrinityUltimateKernelV2.3AB_T-Special = With DoubleTap2Wake ( However There will be no Deepsleep )
V2.2-3 SPECIAL
  • KGSL Update
irgendwie funktioniert das dt2w nicht richtig bei mir,
twrp funktioniert auch nicht richtig (sobalb ich das display berühre, sperrt twrp es)
passiert aber nur mit der dt2w version nicht richtig.
ohne dt2w funktioniert alles gut
Reaktionen: Hen Ry
Mit etwas Glück wird dieser Kernel bald auch für CM Nutzer verwendbar werden. Da es leider keine anderen aktiven Projekte für CM-based ROMs gibt ist das ein kleiner Lichtblick am Horizont.
If Ive Merge CM + Sony Source and make it work I'll Create A 2nd Branch At Original Source.
If It doesn't work, What will happen is that I'll Use CM Latest Source and Patch it with the latest kernel upstream and push it on another Resp.
2nd CM Will also Be OC To 2.7Ghz or 2.8Ghz with GPU OC if there is no lag, But in Stock Based Kernel GPU OC WIll be removed permanently.
3rd Whatever happens on the next Update if I Have time I'll Include AROMA Installer With GPS Customization ( Based 9n your Country Selection ), Governor Selection, and other more tweaks that can be enabled via Init.d
4th Kindly refrain posting bugs again and again its obv. Redundancy and its annoying at other Kernel Users that will read the Board, Kindly press the like button of the bug reporter or post it at bug tab up in the thread.
Regards,
FX
Note : No GPU OC For CM To.
[KERNEL][4.4.4]F(X)TrinityUltimateKernel-V2.… - Pg. 158 | Sony Xperia Z1 | XDA Forums
Reaktionen: Hen Ry
Bin ich blind oder gibt es für den Kernel garkeine App wo man die Einstellungen ändern kann?
mfg
Hen Ry
Hen Ry
Hen Ry
mongo07
  • mongo07
Aaskereija
Aaskereija
  • th3chos3n
Aaskereija
Aaskereija
