[Kernel][G92xF][TW][5.1.1] *01.09.2015* Vindicator Kernel R4.1 [COGA]
  • 21 Antworten
Sven65
Gast
Vindicator Kernel
Support für F/I/S/K/L/T/W8 920 und 925 Ausführungen
Beim Flashen des Kernels springt Knox auf 0x1
Features:
-COGA Source Based
-Universal Kernel! (Thanks to G.lewarne and Ktoonsez patchset!)
-VControl Kernel Control Script(Loosely Based On lkconfig by imoseyon)
-Compiled With Graphite, Loop Nest Optimizations, Ofast And Others.
-Built With Linaro 5.2 ToolChain
-Various Other Build Optimizations
-WLAN_RX & WLAN_CTRL Wakelocks Reduced
-Dynamic Fsync
-DoubleTap2Wake
-LEDFade
-VMA Caching
-Calibrated Power Coefficients
-Smoothened GPU Throttling Curve
-Google's Snappy Compression Algorithm
-Interactive Governor Patches/Mods
-Timer/RCU System Upstreamed
-SensorHub Wakelock Toggle To Remove
-A53 UnderClockable To 200Mhz Oc To 1600Mhz
-A57 UnderClockable To 200Mhz Oc To 2500Mhz
-Slub Allocator Updated To Linux 3.18
-Synapse Support
-Memory Management Updates
-Arm Efficient Unaligned Access Enabled
-Reduced Scheduler Wakeups
-Nvidia Power Efficiency Patches
-Encrypted Performance Improvements
-Deep Sleep Fix
-Disabled IO Stats For Faster IO
-Memory Leak Patches
-Sleep/Suspend Patches
-3X Faster Integer Square Root Operations
-HRTimer Optimizations
-Avoid load Average Moire
-Scheduler Optimizations
-Power Aware Scheduling
-Sound Control
-Memcopy and String Optimizations
-Use Compile Time Constants For Jiffies Conversions When Possible(Reduces CPU Overhead)
-Workqueue Updated To Linux 3.18
-Optional Power Efficient Workqueues (Expanded to more modules than normal as well)
-Moto QuickWakeup Driver
-Frandom (Efficient Random Number Generator)
-Cruft Free
-Slimmed Down
-Tons Of Debugging and Tracers Removed
-Many Misc. Optimizations
-Optimized CFQ Scheduler For SSDs
-Tons Of IO Fixes/Performance Boosts
-Voltage Control For Numerous Things
-Entropy Optimizations/Tweaks
-Many Parts Pulled From Upstream
-Init.D Support
-Installs SU
-Installs Busybox
-Potentially Something I Forgot...
Changelog:
-Initial Release
R2:
-Updated From Linux 3.10.61 To 3.10.83
-Updated Memory Management Tweaks
-Update Interactive Tunings
-Fix App Installing
-Fix Random Reboots
-Removed Overclocking For Now(Caused reboots)
-Removed Fsync Toggle(Caused app installs to fail)
-Added Asynchronous Fsync(Faster Fsync)
-Fixed Frandom Permissions
-Additional Entropy Optimizations
-Added Interactive Patches
-Trimmed More Stuff
-Interactive No Longer Scales Up The Frequency Below 5% Load(Better Battery)
R3:
-Lag Free Interactive Tweaks (Glewarne)
-Interactive Screen Off Max Frequency = (InteractiveX)
-InputBooster Removed(Touchboost)
-BOG8 Source Update
-Better Frequency Selecting By Interactive
-Numerous Interactive Code Optimizations/Patches
-Added A Toggle To Remove SensorHub Wakelock In VControl
-Remove Task Packing
-Trimmed More Things/Debugging
-Removed Forced Full screen Updates
-Some Power Efficient Related Tweaks
-Additional Optimizations
-Many Misc Things.
-Cifs support
R4:
-COGA Based
-Compiled With Linaro 5.2 TC
-Compiled With Ofast vs Os
-Fully Tickless Kernel(faster more power efficient)
-Updated Memory Tweaks
-Added CPU OC Again!
-Fixed Big Cpu Settings Not Sticking
-More Interactive Tweaks
-Reverted Enforced Mode
-Async Fsync Replaced With Dynamic Fsync
-Power Aware Scheduling Option
-Updated To Linux 3.10.87
-Added DT2W
-Misc Patches
-Added Synapse Support
-Updated Nvidia Power Efficiency Patches
-Various Upstream Timer/RCU Updates
-Add LED Fade Patch
-Add Audio Control
-Add Various Voltage Controls
-Optimize ART
-Update VControl Options
-CFQ Optimizations
-GPU Throttling Smoothing
-Task Packing Toggle Fixed
-Task Packing Threshold Adjusted
-Added PowerSuspend Driver
-Updated Unification Patches
-Disabled Gentle Fair Sleepers(Ui Smoothness)
-Numerous Interactive Patches
-Removed InteractiveX
-Re-Added TouchBoost
-Enable Efficient Unaligned Access
R4.1
-Reverted Back To Dynamic Ticks Kernel
-Enabled Fast No Hz(Power Efficiency)
Installation
1.Download
2. Kernel auf dem Smartphone speichern
3. Download ins Recovery (TWRP oder Philz)
4.Kernel flashen
5. Cache und Delvik-Cache leeren
6. Neustart
Zur Sicherheit vor dem Flashen ein Backup machen
[Downloads]
[XDA-Thread]
Läuft bei mir recht gut. Kein Ruckeln o.Ä.
Dreimal Antutu laufen lassen, - immer um die 70000. (ohne OC)
LG
Lieber @Sven65,
wir hatten doch genau >>hier<< schon mal eine kleine Diskussion was genau in Kernel Vorstellungen gehört. Ich wäre dir sehr zu Dank verpflichtet, wenn du meiner damaligen Ansage hier wie auch im anderen Thread nachkommen könntest. Du kennst das Spiel hier und bist lange genug auf AH, um zu wissen, wie man ROMs oder Kernels vorstellt. Das hat sich auch beim S6 nicht geändert.
Danke
Changelog, Features, Link zu XDA, Titel und Download - wo ist der Fehler?
LG
Anleitung zum Flashen fehlt (auch wenn es immer gleich ist) und Hinweis das Knox getriggert wird laut dem Link von hanspampel.
Wäre nicht schlecht, wenn Du auf die dunkle Schriftfarbe verzichtest.
So nimmst Du der Software die Möglichkeit das automatisch bestmöglich zu regeln.
S/w wie immer.
LG
Du hast den Text kopiert und inkl. Formatierungen eingefügt. Daher hat der Hauptteil jetzt eine festgesetzte Schriftfarbe. Nutzt man den standardmäßigen hellen Hintergrund, fällt das nicht auf. Nutzt man aber einen dunklen Hintergrund, sieht das so aus wie auf meinem Screenshot.
Die Forensoftware regelt das normalerweise selbstständig. Bei hellem Hintergrund eine dunkle Schriftfarbe, bei dunklem Hintergrund helle Schriftfarbe.
Wenn Du dir mal die BBCodes in deinem Post anzeigen lässt, wirst Du das sehen.
Habs etwas angepasst, schau mal ob jetzt besser ist ?
Ich kann am PC sowie am Smartphone alles deutlich lesen - auch mit gethemtem Tapatalk.
LG
Sieht schick aus
Reaktionen: Wicki
@Darktrooper
Leider nein, siehe Screenshot von @mrfloppy1502
Der komplette OP ist gelinde gesagt "überthemed". Ich habe mal die kompletten unnötigen Color-codes rausgenommen.
Code:
[CENTER][SIZE=6][COLOR=#ff0000][B][U]Vindicator Kernel[/U][/B][/COLOR][/SIZE]
Beim Flashen des Kernels springt Knox auf 0x1[/SIZE]
[SIZE=5][B]Features:[/B][/SIZE]
-COGA Source Based
-Dynamic Fsync
-DoubleTap2Wake
-LEDFade
-VMA Caching
-Synapse Support
-Deep Sleep Fix
-Sound Control
-Cruft Free
-Slimmed Down
-Init.D Support
-Installs SU
-Installs Busybox
[SIZE=5][B]Changelog:[/B][/SIZE][/SIZE]
[SIZE=5][SPOILER][/spoiler][/SIZE][SPOILER][/spoiler][SPOILER][/spoiler][/SIZE][SPOILER][/SPOILER][SPOILER]
[SIZE=5][B]-Initial Release[/B][/SIZE][/SIZE]
[SIZE=5][B][B]R2:[/B][/B][/SIZE][/SIZE]
[SIZE=5][B]-Updated From Linux 3.10.61 To 3.10.83[/B][/SIZE][/SIZE]
[SIZE=5][B]-Updated Memory Management Tweaks[/B][/SIZE][/SIZE]
[SIZE=5][B]-Update Interactive Tunings[/B][/SIZE][/SIZE]
[SIZE=5][B]-Fix App Installing[/B][/SIZE][/SIZE]
[SIZE=5][B]-Fix Random Reboots[/B][/SIZE][/SIZE]
[SIZE=5][B]-Removed Overclocking For Now(Caused reboots)[/B][/SIZE][/SIZE]
[SIZE=5][B]-Removed Fsync Toggle(Caused app installs to fail)[/B][/SIZE][/SIZE]
[SIZE=5][B]-Added Asynchronous Fsync(Faster Fsync)[/B][/SIZE][/SIZE]
[SIZE=5][B]-Fixed Frandom Permissions[/B][/SIZE][/SIZE]
[SIZE=5][B]-Additional Entropy Optimizations[/B][/SIZE][/SIZE]
[SIZE=5][B]-Added Interactive Patches[/B][/SIZE][/SIZE]
[SIZE=5][B]-Trimmed More Stuff[/B][/SIZE][/SIZE]
[SIZE=5][B]-Interactive No Longer Scales Up The Frequency Below 5% Load(Better Battery)[/B][/SIZE][/SIZE]
[SIZE=5][B][B]R3:[/B][/B][/SIZE][/SIZE]
[SIZE=5][B]-Lag Free Interactive Tweaks (Glewarne)[/B][/SIZE][/SIZE]
[SIZE=5][B]-Interactive Screen Off Max Frequency = (InteractiveX)[/B][/SIZE][/SIZE]
[SIZE=5][B]-InputBooster Removed(Touchboost)[/B][/SIZE][/SIZE]
[SIZE=5][B]-BOG8 Source Update[/B][/SIZE][/SIZE]
[SIZE=5][B]-Memory Management Update[/B][/SIZE][/SIZE]
[SIZE=5][B]-Better Frequency Selecting By Interactive[/B][/SIZE][/SIZE]
[SIZE=5][B]-Numerous Interactive Code Optimizations/Patches[/B][/SIZE][/SIZE]
[SIZE=5][B]-Added A Toggle To Remove SensorHub Wakelock In VControl[/B][/SIZE][/SIZE]
[SIZE=5][B]-Remove Task Packing[/B][/SIZE][/SIZE]
[SIZE=5][B]-Trimmed More Things/Debugging[/B][/SIZE][/SIZE]
[SIZE=5][B]-Removed Forced Full screen Updates[/B][/SIZE][/SIZE]
[SIZE=5][B]-Some Power Efficient Related Tweaks[/B][/SIZE][/SIZE]
[SIZE=5][B]-Additional Optimizations[/B][/SIZE][/SIZE]
[SIZE=5][B]-Many Misc Things.[/B][/SIZE][/SIZE]
[SIZE=5][B]-Cifs support[/B][/SIZE][/SIZE]
[SIZE=5][B][B]R4:[/B][/B][/SIZE][/SIZE]
[SIZE=5][B]-COGA Based[/B][/SIZE][/SIZE]
[SIZE=5][B]-Compiled With Linaro 5.2 TC[/B][/SIZE][/SIZE]
[SIZE=5][B]-Compiled With Ofast vs Os[/B][/SIZE][/SIZE]
[SIZE=5][B]-Fully Tickless Kernel(faster more power efficient)[/B][/SIZE][/SIZE]
[SIZE=5][B]-Updated Memory Tweaks[/B][/SIZE][/SIZE]
[SIZE=5][B]-Added CPU OC Again![/B][/SIZE][/SIZE]
[SIZE=5][B]-Fixed Big Cpu Settings Not Sticking[/B][/SIZE][/SIZE]
[SIZE=5][B]-More Interactive Tweaks[/B][/SIZE][/SIZE]
[SIZE=5][B]-Reverted Enforced Mode[/B][/SIZE][/SIZE]
[SIZE=5][B]-Async Fsync Replaced With Dynamic Fsync[/B][/SIZE][/SIZE]
[SIZE=5][B]-Power Aware Scheduling Option[/B][/SIZE][/SIZE]
[SIZE=5][B]-Updated To Linux 3.10.87[/B][/SIZE][/SIZE]
[SIZE=5][B]-Added DT2W[/B][/SIZE][/SIZE]
[SIZE=5][B]-Misc Patches[/B][/SIZE][/SIZE]
[SIZE=5][B]-Added Synapse Support[/B][/SIZE][/SIZE]
[SIZE=5][B]-Updated Nvidia Power Efficiency Patches[/B][/SIZE][/SIZE]
[SIZE=5][B]-Various Upstream Timer/RCU Updates[/B][/SIZE][/SIZE]
[SIZE=5][B]-Add LED Fade Patch[/B][/SIZE][/SIZE]
[SIZE=5][B]-Add Audio Control[/B][/SIZE][/SIZE]
[SIZE=5][B]-Add Various Voltage Controls[/B][/SIZE][/SIZE]
[SIZE=5][B]-Optimize ART[/B][/SIZE][/SIZE]
[SIZE=5][B]-Update VControl Options[/B][/SIZE][/SIZE]
[SIZE=5][B]-CFQ Optimizations[/B][/SIZE][/SIZE]
[SIZE=5][B]-GPU Throttling Smoothing[/B][/SIZE][/SIZE]
[SIZE=5][B]-Task Packing Toggle Fixed[/B][/SIZE][/SIZE]
[SIZE=5][B]-Task Packing Threshold Adjusted[/B][/SIZE][/SIZE]
[SIZE=5][B]-Added PowerSuspend Driver[/B][/SIZE][/SIZE]
[SIZE=5][B]-Updated Unification Patches[/B][/SIZE][/SIZE]
[SIZE=5][B]-Disabled Gentle Fair Sleepers(Ui Smoothness)[/B][/SIZE][/SIZE]
[SIZE=5][B]-Numerous Interactive Patches[/B][/SIZE][/SIZE]
[SIZE=5][B]-Removed InteractiveX[/B][/SIZE][/SIZE]
[SIZE=5][B]-Re-Added TouchBoost[/B][/SIZE][/SIZE]
[SIZE=5][B]-Enable Efficient Unaligned Access[/B][/SIZE][/SIZE]
[SIZE=5][B][B]R4.1[/B][/B][/SIZE][/SIZE]
[SIZE=5][B]-Reverted Back To Dynamic Ticks Kernel[/B][/SIZE][/SIZE]
[SIZE=5][B]-Enabled Fast No Hz(Power Efficiency)[/B][/SIZE][/SIZE][/SPOILER]
[SIZE=5][B]Installation[/B][/SIZE][/SIZE]
[SIZE=5][B]1.Download[/B][/SIZE][B][/B][/SIZE]
[SIZE=5][B]2. Kernel auf dem Smartphone speichern[/B][/SIZE][B][/B][/SIZE]
[SIZE=5][B]3. Download ins Recovery (TWRP oder Philz)[/B][/SIZE][B][/B][/SIZE]
[SIZE=5][B]4.Kernel flashen[/B][/SIZE][B][/B][/SIZE]
[SIZE=5][B]5. Cache und Delvik-Cache leeren[/B][/SIZE][B][/B][/SIZE]
[SIZE=5][B]6. Neustart[/B][/SIZE][B][/B][/SIZE]
[SIZE=5][B][U]Zur Sicherheit vor dem Flashen ein Backup machen[/U][/B][/SIZE][B][U][/U][/B][/SIZE]
[SIZE=5][[B]Downloads[/B][/SIZE][/SIZE]
[URL='http://forum.xda-developers.com/galaxy-s6/samsung-galaxy-s-6--s-6-edge-unified-development/kernel-vindicator-t3156281'][SIZE=5][[B]XDA-Thread[/B][/SIZE][/URL][/SIZE]
[/CENTER][/QUOTE]
Hab ich das?
Hab ich nicht, aber jetzt....
Du weisst schon wieder alles was ich mache.
Sven65 schrieb:
Hab ich nicht....
Ah, okay. Ich hatte angenommen, die doppelt und dreifachen Farb- und Größenformatierungen waren Copy&Paste geschuldet. Dann hast Du die selber formatiert? Respekt. :D
Und jetzt wieder
Sonst muss ich löschen ;)
Hallo an alle,hat jemand bei euch mit dem Kernel schon ein Freeze gehabt? Egal ob bei Youtube oder anderen Anwendungen friert der Bildschirm ein und man bekommt das Smartphone kaum zum arbeiten.
Hatte ihn mal zwei Tage problemlos drauf.
LG
Okay, bei mir läuft der Kernel nicht rund, mal schauen was in nächster Zeit die Version 5 zu bieten hat.
Hier steht ja noch nicht viel. ich nutze den Aktuellsten Hacker kernel und frage mich ob es nicht bessere gibt oder ob es der beste ist. Nun schrieb mein vorredner von freezes. gibt es andere erfahrungen mit diesem kernel?
Habs mal ausprobiert. Gefällt mir NICHT
Nur 2 Governor, Interactive und Performance
Scheduler lässt sich nicht einstellen
WLAN bricht irgendwie öfter ab.
Das nenn ich mal ein gutes Ergebnis.
Wicki
FlashMaster Android
Sven65
Thomasmueller85
Nobby1960
Nobby1960
