[KERNEL][GPL][3.4.91+][SM4.10]Blaze Kernel -15
  • 10 Antworten
r0b
r0b
Ehrenmitglied
4.348
Key Features
  • SELinux Permissive, with init.d support
  • init.d support + other ramdisk tweaks
  • -O3 , Cortex A15 , Graphite , neon , vfpv4 Optimizations
  • Compiled from Latest SaberMOD GCC 4.10 Toolchain which is latest Toolchain with best optimizations
  • Suuport for intelliplug 2.3 hotplug driver (Removed from ver5 onwards)
  • Support for Auto_hotlug driver
  • Faux Sound Support
  • LCD Color Control
  • Support undervolt/overvolting via sysfs interface/apps interface @Gnome
  • Adaptive Voltage Scaling Support :winki:
  • More CPU Governors ( intelliactive , performance , conservative(updated) , powersave , Wheatley , ondemand , ondemandplus , abyssplug , abyssplugv2 , userspace , interactive , smartassH3 , Lionheart )
  • More I/O Schdedulers ( FIOPS , Deadline , CFQ , ROW , BFQ(v6) , SIO , No-op , V(R) , ZEN )
  • added new power management mode "PowerSuspend" (Hello Battery)
  • add official f2fs kernel support + f2s optimization
  • exFAT AIO Optimization
  • added LZ4 compression (faster than LZO)
  • Frandom -Fast Kernel Number Generator driver added
  • Support for CPU BOOST code.
  • File systems support: Ext2/3/4, FAT32, NTFS, CIFS, USB OTG , exFAT :winki:
  • Debugging is OFF by Default to save CPU cycles, and extend battery life.
  • KSM for Page Merging
  • Added cdrom option to UMS-lun-devices (Now you can mount internal memory as CD-ROM)
  • Enabled 5 new TCP Congestion controls viz. ( Westwood, Veno,Vegas , BIC, Reno, HTCP )
Changelog:
https://www.dropbox.com/s/s4casl5m7l0xik0/changelog.txt
Downloads:
(XDA-Devdb):Blaze™ Kernel for 8974pro chips - xda-developers DevDB
(Mirror to Dev-Host):Dev-Host - Blaze.Kernel_ver6.zip - The Ultimate Free File Hosting / File Sharing Service
Installation:
Place the zip in the SDCard
and Flash it in recovery
Sources:
https://github.com/GuneetAtwal/kernel_g900f
Quelle: [KERNEL][GPL][3.4.90+][SM4.10]Blaze™ Kernel -6 - xda-developers
neu : [KERNEL][GPL][3.4.90+][SM4.10]Blaze™ Kernel -8
Update auf -14
Guten Abend ,
ist der Kernel auf die X Note Rom flashbar?
Danke
Lg
Kernel gibts wohl nicht mehr ... Keine einzige Version ist mehr erhältlich ... Warum das ? Wurde der eingestellt ? Gibts einen alternativ Link oder kann ihn jemand hochladen ?
LG
Ich habe ihn jetzt bei der X Note Rom und bei der BobCatRom versucht und das war richtig mies!
Ich habe die letzte Version wenn du sie willst?
Edit: Wo schaust du denn ?
Ich War gerade auf XDA und konnte sofort Downloaden??
Ja gerne... Na von hier aus, keiner hatte Seeders.. Also über torrent ..
Der ursprüngliche Beitrag von 16:23 Uhr wurde um 16:24 Uhr ergänzt:
EDIT: NUn hab ich ihn... v15 lettzte woche ging gar nichts ... aber dieser link geht nun danke
Mit Welcher Rom und läuft er gut?
Mit BobCatRom v1.0 läuft solala... Also bei mir stockt es ein bisschen beim scrollen im internet oder facebook...
Daher bin ich zurück zum Hacker Kernel, der ist sehr gut für jede Rom, laut A-H Users ..
Bei mir ist der auf der BobCatRom nicht gelaufen das System War nicht zu bedienen
j1gga84
j1gga84
j1gga84
j1gga84
j1gga84
j1gga84
RomBeast
RomBeast
RomBeast
