[KERNEL][G900F][LP] *14.03.16* CrazySuperKernel v12 [CM12.1][UBERTC 6.0/-ofast optimize]
  • 1 Antworten
j1gga84
j1gga84
Ehrenmitglied
6.259
[KERNEL][SM-G900F][CM12.1]CrazySuperKernel v11[UBERTC 6.0/-ofast optimize][11...
Zusammenfassung
Der CrazySuperKernel ist ein starker Kernel mit vielen super Eigenschaften!
Eigenschaften
- CM12.1 ramdisk (25-12-15 FINALE LP ramdisk)
- Erstellt mit UBERTC 6.0 (04-03-16)
- ofast optimize
- Full KA support with ota kernel updates
- Compiled with gcc optimization flags
- Kernel mode Neon
- Init.d support
- Franco sound control
- Logger switchable
- Frandom support
- SELinux set to permissive
- CPU governors : interactive, impulse, ondemand, smartmax, zzmoove, intellimm,ondemandplus,pegasusq,nightmare,conserva tive,lionheart,powersave,userspace,yankactive,smar tmax_eps,optimax,slim,uberdemand,intellidemand,int elliactive,abyssplugv2,abyssplug,dancedance,tripan droid,hyper,darkness,lazy
- IO schedulers :bfq-cfq-noop-deadline-tripandroid-fiops-row-sio-zen-vr-fifo
- TCP congestion controls: cubic-bic-westwood-htcp-highspeed-hybla-reno-bic-hybla-vegas-lp-yeah-illinois-scalable
- Gpu governors :msm-adreno-tz, conservative,simple_ondemand,powersave,performance ,userspace,cpubw_hwmon,msm_cpufreq
- simple gpu algorithm
- Cpu oc up to 2,84ghz
- Cpu underclock 268mhz
- Gpu oc up to 657mhz
- Gpu idle step 27mhz
- Slimbus overclock
- Kcal v2 with inverted colours
- Intelli plug hotplug
- mako hotplug
- bricked hotplug
- zen hotplug
- autosmp hotplug
- alucard hotplug
- msm sleeper (disabled by default)
- Screen wake and sleep functions
- Fast charge support (by yank555)
- LED extended control (by yank555)
- Arch power (enabled by default)
- Sched autogroup(disabled by default
- Prevent wakelock when ambiend display disabled(misc control tab)
- F2FS
- Power Efficient Workqueues
- UKSM
- Dynamic Filesystem Read-Ahead
- CPU Voltage Control
- Power Suspend Mode/State
- CRC Check Disabled
- Enabled All Suspend and Idle Modes
- QuickWakeUP
- Google's Snappy Compression/Decompression
- Dynamic FSync 2.0
- Intelli thermal v2
- A lot improvments
- A lot fixes
*some governors are disabled
Download Link
http://crazytechblog.blogspot.gr/201...perkernel.html
Bitte noch im PlayStore den KernelAdiutor zum Konfigurieren des CrazySuperKernels runterladen:
Kernel Adiutor (ROOT) – Android-Apps auf Google Play
Änderungen
Post 2 im XDA-Thread: [KERNEL][SM-G900F][CM12.1]CrazySuperKernel v11[UBERTC 6.0/-ofast optimize][11... - Post #2
Installationsanleitung
- Downloade den Kernel über den Download Link oder über KernelAdiutor downloads (funktioniert noch nicht)
- Flashe den Kernel über die Recovery
{Cache und Dalvik Cache Wipe empfohlen}
- Danach reboote
Habe Spaß mit dem Crazy Super Kernel !!!!
Danksagungen
Danke an Lord Boeffla - für seine großartige Hilfe
Danke an ShinySide - für die meisten Commits am Kernel von seinem Kernel
Danke an CrazyGamerGR - Ersteller dieses Kernels
XDADevDB Information
CrazyProject, Kernel for the Samsung Galaxy S 5
Entwickler
CrazyGamerGR
Quellcode:
FrancescoCG/CrazySuperKernel-CM · GitHub
Version Information
Status:
Stabil
Stable Release Date: 2016-03-14
Erstellt:
2015-08-26
Neustes Update: 2016-03-14
Reaktionen: Olli von G
Neue (finale) Version 12
Änderungen:
v12/04-03-16
- ubertc 6.0 update (04-03-16)
Ansonsten schaut euch mal den Thread an, CrazyGamerGR hat sein S5 zwar verkauft, allerdings entwickelt er erste Testbuilds für CM13 (Android 6.0.x) und benötigt hierfür Tester, da die Testkernel derzeit noch nicht laufen.
Wer also Lust und Zeit hat:
[KERNEL][SM-G900F][CM12.1]CrazySuperKernel v12[UBERTC 6.0/-ofast optimize] - Post #341
j1gga84
j1gga84
j1gga84
j1gga84
j1gga84
j1gga84
hanspampel
Foh
Foh
