[KERNEL][G900F][CM13.0][MM][ANYKERNEL] *09.12.16* CrazySuperKernel v16.0 [SYNAPSE]
  • 7 Antworten
j1gga84
j1gga84
Ehrenmitglied
6.259
Code:
DISCLAIMER!!
I am not responsible in any way for anything that can be happen to your device when you flashing my kernels.You do so at your own risk!
Zusammenfassung:
Der CrazySuperKernel ist ein kraftvoller Kernel mit vielen super Features!
Features:
- OTA Updates from Kernel Adiutor app
- Anykernel2 zip For maximum compatibility with all ROMs, CrazySuperKernel uses your existing ramdisk (Do NOT flash this over other custom kernels! You should only flash CrazySuperKernel over the kernel that came with your ROM!!)
- Synapse Support - Complete Kernel Control!! (need download the app from Play Store)
- Compiled with DF 4.9 [latest update]
- Faux sound control
- Frandom support
- CPU governors : interactive, impulse, ondemand, smartmax, zzmoove, intellimm,ondemandplus,pegasusq,nightmare,conserva tive,lionheart,powersave,userspace,yankactive,smar tmax_eps,optimax,slim,uberdemand,intellidemand,int elliactive,abyssplugv2,abyssplug,dancedance,tripan droid,hyper,darkness,lazy
- IO schedulers :bfq-tripndroid-cfq-noop-deadline-fiops-row-sio-zen-vr-fifo
- TCP congestion controls: cubic-bic-westwood-htcp-highspeed-hybla-reno-bic-hybla-vegas-lp-yeah-illinois-scalable
- Gpu governors :msm-adreno-tz, conservative,simple_ondemand,powersave,performance ,userspace,cpubw_hwmon,msm_cpufreq
- Kcal v2 with inverted colours
- Intelli thermal v2
- Intelli plug hotplug
- MSM-Sleeper Hotplug
- MSM-Zen Hotplug
- Bricked Hotplug
- Alucard Hotplug
- AutoSMP Hotplug
- Adreno idler
- Fast charge support (by yank555)
- LED extended control (by yank555)
- Prevent wakelock when ambiend display disabled(misc control tab)
- Wake And Sleep Functions
- CPU Voltage Control
- Slimbus overclock
- UKSM
- Enabled Arch Power
- CRC Check Disabled
- Gentle Fair Sleepers (Disabled by default)
- Android Logging switcher
- Enabled All Suspend and Idle Modes
- Power Suspend Mode/State
- Dynamic filesystem read-ahead
- QuickWakeUP
- Dynamic FSync 2.0
- A lot improvments
- A lot fixes
Changelog:
v16.0/9-12-16
- anykernel big updates
- upstream updates from cyanogenmod
- disabled completly mpdecision
- enabled updated bricked hotplug
- script with many set up for kernel features included in anykernel zip
- added led tab in synapse
- fixed many synapse bugs
- faux sound updated
- deleted unstable hotplugs
- fixed many bugs
- battery improve
- performance improve
- some feature fixed
- many improvments under the hood
Ältere Changelogs:
v15.0/18-11-16
v14.0/14-11-16
- big anykernel update
-removed uksm (battery drain fixed)
-insecure kernel (adb has root privileges)
-init.d support
-simple ondemand gpu governor update
-msm adreno tz governor update
-tap2wake update
-kcal update
-touch boost update
-cpu boost update
-touchkey control update
-conservative gpu gov removed
-some fixes
-some useless features removed
v13.0/13-11-16
- many fixes under the hood
v12.0/11-11-16
- fixed recent SafetyNet failure,you can use Android Pay again (thx Sultanxda)
- Anykernel update
- Anykernel clean up
v11.0/10-11-16
- removed many unstable governors
- clean up some files
- bug fixes
v10.0/10-11-16
- Anykernel update
- removed slim governor
- removed intellimm governor
v9.0/04-11-16
- Anykernel update
- deleted many hotplugs
v8.0/25-09-16
- Anykernel update
- changed to DF 4.9 Toolchain
v7.0/25-08-16
- Anykernel update
v6.0/19-07-16
- Anykernel update
v5.0/15-07-16
- Anykernel update
v4.0/08-07-16
- many bug fixes
- Anykernel update
v3.0/25-06-16
- bug fixes
v2.0/15-06-16
- Anykernel update
v1.0/28-05-16
- Anykernel update
- removed 268mhz cpu underclock step
v12/28-05-16
- Anykernel zip( need to instal your rom first to have the latest ramdisk!)
- removed franco sound
- added faux sound
- added dynamic filesystem read-ahead
- added tripndroid scheduler
v11/25-05-16
- update cm/rr ramdisks (24-05-06/21-05-16)
- update toolchain to UBERTC 4.9
v10/23-05-16
- update cm/rr ramdisks (22-05-06/21-05-16)
- removed cpu oc
- removed gup oc
- removed gpu idle step 27mhz
- added many features
- added many govs
- added many scheds
- added tcp controllers
- added many hotplugs
- added many under the hood tweaks
- added wake/sleep functions
- added cpu voltage control
v9/17-05-16
- update cm/rr ramdisks (16-05-06/15-05-16)
- added cpu oc
- added gup oc
- added gpu idle step 27mhz
v8/12-05-16
- removed cpu oc
- removed gup oc
v7/12-05-16
- update ramdisk (12-05-06)
- added intelli thermal
- added cpu oc
- added gup oc
v6/10-05-16
- builded from scratch and clean up my features
- updated ramdisk (10-05-16)
- added adreno idler
v5/07-05-16
- last fixes to bootup
v4/14-04-16
- fixes
v3/05-04-16
- fixes
v2/04-04-16
- initial release
v1/02-04-16
- compiling bugs and bootloops fix
Download Link:
Download Link [AnyKernel]: https://www.androidfilehost.com/?w=files&flid=53052
Download Link UKM/Synapse Support:
https://www.androidfilehost.com/?w=files&flid=63155
Download Link UKM Unistaller: UKM Unistaller.zip | by CrazyGamer for Galaxy S5
Homepage des Entwicklers:
[KERNEL][SM-G900F][CM13]CrazySuperKernel | Cr@zyTechBlog
Installationsanleitung:
- Flashe den Kernel nicht über andere Custom Kernels!
Du solltest den CrazySuperKernel nur über den Kernel flashen, der standardmäßig in deiner ROM enthalten ist.
- Lade den Kernel aus dem Downloadlink
- Flashe den Kernel über die Recovery
{Cache und Dalvik Cache Wipe empfehlenswert}
- Reboote
Viel Spaß mit dem Crazy Super Kernel !!!!
FAQ:
Empfohlene App zur Konfiguration des Kernels:
Kernel Adiutor (ROOT) – Android-Apps auf Google Play
Was tun, falls es zum Bootloop kommt:
Falls es zum Bootloop kommt halte Lautstärke runter, Powertaste und Home Taste gleichzeitig gedrückt, bis das Gerät vibriert und es zum Reboot kommt. Direkt danach, noch vor dem Samsung Logo, halte Lautstärke hoch, Powertaste und Home Taste gleichzeitig gedrückt, bis das Gerät vibriert und in die Recovery booted. Installiere deine ROM noch einmal dirty drüber, so dass der original Kernel wieder installiert wird, danach sollte das Gerät wieder normal starten, in jedem Fall wird ein Backup im Vorfeld empfohlen!
Danksagungen:
Thx the devs where created the features where included in kernel
Thx CrazyGamerGR
XDADevDB Information
CrazySuperKernel, Kernel for the Samsung Galaxy S 5
Entwickler
CrazyGamerGR
Quellcode: GitHub - FrancescoCG/CrazySuperKernel-MM-CM13
Reaktionen: Olli von G
Hi, unterstützt der Kernel auch loop device?
Hier gilt das Gleiche wie für den Boeffla Kernel.
Auch der CrazySuperKernel basiert auf dem CM Stock Kernel, der einfach noch um ein paar Funktionen erweitert wurde, somit sollte es auch hiermit funktionieren.
Allerdings bin ich mir nicht sicher ob der CrazySuperKernel derzeit noch einwandfrei läuft, zumindest auf MM, weil der Entwickler mehr oder weniger blind entwickelt, da er kein S5 mehr besitzt.
Es gibt eine neue Testversion:
New test build is up for official cm13 g900f klte builds only!
Its builded clean from the most updated official cm13 sources w/o features added only builded with gcc 4.8 . [ my new todo list is uber tc 7.0 ,sound mod,some features,a few governors (interactive is enough but anyway),some surprise features if all go well and of course my underclock step ] .
download link here: G900F_CrazySuperKernel_CM13_v5.zip | by CrazyGamer for Galaxy S5
Neue Version online:
v8.0/25-09-16
- Anykernel update
v9.0/04-11-16
- Anykernel update
Neue Versionen online:
v10.0/10-11-16
- Anykernel update
v11.0/10-11-16
- bug fixes
v12.0/11-11-16
- Anykernel update
v13.0/13-11-16
EDIT:
v14.0/14-11-16
-init.d support
-tap2wake update
-kcal update
-touch boost update
-cpu boost update
-some fixes
v15.0/18-11-16
Hat den CrazySuperKernel eigentlich mal jemand getestet bzw. mit dem Boeffla Kernel verglichen?
Früher lief der CrazySuperKernel überhaupt nicht rund, mittlerweile ist das wohl anders!?
j1gga84
j1gga84
j1gga84
j1gga84
j1gga84
j1gga84
Maki.
Rookie19
Rookie19
