Riggo
Stamm-User
- 114
@submain
Bei mir läuft Beta 1 bis jetzt sauber.
Was? Es sind keine Berichte über Instabilitäten in den letzten Wochen bekannt.submain schrieb:schon jemand mít RR getestet? Läuft der neue Kernel immer noch instabiler als der Standard-Kernel?
Hi all,
maintenance update is out:
Version 3.3-beta3
17.10.2016
Enjoy
- Note: This kernel is only for CM based roms which are newer or of 07.10.2016, for older rom take latest stable version !!
If you use custom roms like Resurrection Remix, Blisspop etc. you have to carefully check if you need still version 3.2 stable as custom roms are usually updated with slower pace- Update: Updated with latest official CM kernel commits as of 17.10.16, 8am CET
- Fix: Add forgotten functionality to overwrite CPU frequencies when not using Boeffla-Config (not recommended)
- Change: Removed compiler flag not required anymore
Andi
Ok, maintenance update again.
This is including also the latest 3 patches of official CM branch
Version 3.3-beta4
18.10.2016
Enjoy
If you use custom roms like Resurrection Remix, Blisspop etc. you have to carefully check if you need still version 3.2 stable as custom roms are usually updated with slower pace- Update: Updated with latest official CM kernel commits as of 18.10.16, 8am CET
Andi
Hi all,
major overhaul of the Samsung stock MM kernel, I built it from scratch with cleaned commits based on latest Samsung sources.
Version 2.2-beta1
14.10.2016
Enjoy
- Kernel completely built from scratch on latest Samsung sources G900FXXU1CPHV_SM-G900F_EUR_MM_Opensource, eliminating lots of obsolete commits and code
- Change: Internal kernel busybox updated to latest version 1.25.1 (self-compiled from sources, www.busybox.net)
- Change: KCAL initialization changed (if switched to off, it should never do anything during bootup)
- Change: Removed ramconsole again as last_kmsg on S5 was never of any help in the past
- Change: Improvements to anykernel script (credits to Osm0sis)
- Change: Build script improvements
Andi
New kernel version for CM13 is out.
Version 3.3-beta5
25.10.2016
* Note: This kernel is only for CM based roms which are newer or of 07.10.2016, for older rom take latest stable version !!
* If you use custom roms like Resurrection Remix, Blisspop etc. you have to carefully check if you need still version 3.2 stable as custom roms are usually updated with slower pace
* - Update: Updated with latest official CM kernel commits as of 25.10.16, 8am CET
(this includes upstreaming of Linux version to 3.4.12)
* - New: Remove verifiedbootstage flag to avoid triggering safetynet (this means improved compatibility to certain apps like Android Pay etc.)
Enjoy
Andi
Hi all,
small maintenance update for the CM13 kernel:
Version 3.3-beta6
31.10.2016
- - Note: This kernel is only for CM based roms which are newer or of 07.10.2016, for older rom take latest stable version !!
If you use custom roms like Resurrection Remix, Blisspop etc. you have to carefully check if you need still version 3.2 stable as custom roms are usually updated with slower pace- - Update: Updated with latest official CM kernel commits as of 31.10.16, 8am CET
- - Change: Build script improvements (credits to ZaneZam)
Enjoy
Andi
Version 3.3-beta8
09.11.2016
- Update: Updated with latest official CM kernel commits as of 09.11.16, 6am CET
Version 3.3-beta7
07.11.2016
- Update: Updated with latest official CM kernel commits as of 07.11.16, 8am CET
(this fixes USB-OTG again)
- Fix: Busybox 1.25.1 recompiled with missing sync command
Hi all,
the most probably last CM13 kernel is out now.
So finally we have a stable and final version for CM13. This means - the kernel is now officially end-of-life, out of support etc.
I might only update it to a new stable again if some important security patch is required one day.
Version 3.3 stable -- Final
15.11.2016
Enjoy
- Note: This kernel is only for CM based roms which are newer or of 07.10.2016 (latest CM snapshot has older code !!!), for older rom take 3.2 stable version !!
If you use custom roms like Resurrection Remix, Blisspop etc. you have to carefully check if you need still version 3.2 stable as custom roms are usually updated with slower pace- Update: Updated with latest official CM kernel commits as of 15.11.16, 6am CET
Andi
Hi all,
decision taken, as already announced on Twitter - I will support one more CM generation for the S5.
So here we go for a very first beta of the CM14.1 S5 Boeffla-Kernel:
CM14.1 -- Version 4.0-beta1
16.11.2016
This kernel will NOT work on CM13.x, CM12.x, CM11 or Samsung stock roms !!!
- First official beta version - expect bugs from both kernel and also rom, CM14.1 is still very fresh and as a normal consequence full of issues
- Note: This kernel only runs on official CM14.1 for the international Galaxy S5 g900f - nothing else !!!
- Note: You need at least version 2.4.16 of Boeffla-Config V2 to allow all functionalities to be available
- All functionalities included as in latest CM13.0 Boeffla-Kernel 3.3
- Based on official CM kernel source repo as of 16.11.2016, 8am CET
It will work only on CM14.x based roms.
Note: This kernel will not receive new features anymore (see road map on www.boeffla.de), but I will keep it compatible to CM14.1 development.
Enjoy
Andi
quick update for CM14.1 kernel.
Version 4.0-beta2
21.11.2016
Enjoy
- Update: Updated with latest official CM kernel commits as of 21.11.16, 9am CET
- Change: Internal cleanup and improvements
Andi
