damachine
@submain die boeffla system optimierungs einstellung ist doch kontra produktiv. Ich glaube das diese einstellung vom entwickler auch nicht empfohlen wird, da zu alt. gpu rendering funktioniert doch eh nicht? Gruß
Wichtig:Hi all,
it is time for the first CM13 kernel with the new anykernel concept.
Before you start, make sure you have read and understood the following:
http://boeffla-kernel.de/index.php/7...new-anykernels
If you ask questions which are addressed in this article, or you have issues which are a consequence of not reading the article, I will not answer. It is your responsibility to understand what you do BEFORE you do it.
(and also read this for more background: http://boeffla-kernel.de/index.php/6...ernels-new-app)
Side note:
Although the kernel is now likely to be much more compatible with custom roms using CM basis, I will not change my support conditions at all. If you report an issue on a non-original CM rom, do not expect me to react (Support - Boeffla-Kernel)
Ensure you update to latest Boeffla-Config App 2.3.1 BEFORE you flash the new kernel !!!
Enough threatening now, here we go:
Version 3.1-beta1
12.07.2016
Enjoy
- Note: This is the first Boeffla-Kernel with the new anykernel concept.
Make sure you read and understand the basics: Boeffla-Anykernel Know-How and New concept kernels/New app
- Note: You have to use Boeffla-Config version 2.3.1 or newer in order to use all functionality !!
- This kernel as exactly the same functionalities as the last stable kernel release
- Update: Updated with latest official CM kernel commits as of 12.07.16, 8am CET
Andi
j1gga84 schrieb:Nachteil: nach jedem ROM Update muss der Boeffla hinterher geflasht werden aber ich denke, dass man das überleben kann. Dafür sollte der Boeffla nun kompatibler zu mehreren ROMs sein
Hi all,
update is out:
Version 3.1-beta2
14.07.2016
Enjoy
- Change: Not not display warning "kernel is not seandroid enforcing" during boot anymore (thanks to xda user tamirda)
Andi
Hi all,
it is time for the first Samsung stock kernel with the new anykernel concept.
Side note:
Although the kernel is now likely to be much more compatible with custom roms using Samsung stock basis, I will not change my support conditions at all. If you report an issue on a non-original Samsung rom, do not expect me to react (Support - Boeffla-Kernel)
Ensure you update to latest Boeffla-Config App 2.3.3 BEFORE you flash the new kernel !!!
Version 2.1-beta1
13.07.2016
Enjoy
- Note: You have to use Boeffla-Config version 2.3.3 or newer in order to use all functionality !!
Andi
