Gamer-king
Stamm-User
- 67
Comatose ist gut zum Sparen.
Angelo172 schrieb:Kann ich die dann auch immer wechseln, so wie ich es gerade brauche?
Quelle/DownloadChange Log 07.12.2014
1. Linux 3.4.95.
2. Linux 3.4.96.
3. Linux 3.4.97.
4. Linux 3.4.98.
5. Modified KTMonitor to fit better with wider fonts.
6. New ktoonservativeq parameter named "cpu_load_adder_at_max_gpu"!!!!!!!!!!!! This is an awesome parameter you can use to boost your CPU while the GPU is at max level. Example: if you set cpu_load_adder_at_max_gpu = 30 and while playing a game and your GPU is at max Mhz, the CPU load is only 22%, this parameter will add the 30 thus making the CPU load a 52% which will bring up the Mhz and more cores according to your settings.
7. 4.3 kernels are now moved into ******* END OF LIFE ******* section
8. Merged in the couple of CM commits.
