d407974
Stamm-User
- 431
neue Version ist raus.
Change Log 6.23.2013
1. Linux 3.4.49 and 3.4.50
2. MF4 Samsung Source update
3. [PATCH] Squash of two EHCI: HSIC commits from caf
4. More dmesg log spam removal
5. Made fast charge completely ignore PC no (no more unrecognized device thing)
6. Fixed OTG issue co-existing with Fast Charge
7. Change GPU step 544 to 545
8. Added 627 GPU step in conjuction with Team-Hydra
9. Completely synced with CM as of right now
10. Fixed KTweaker issue with saying Fast Charge was disabled when it really was
11. Fixed message saying "CPU Max Mhz" does not match when user set no "Screen OFF Profile Mhz"
12. Ktoonservative: New tunable: touch_boost_cpu_all_cores. This item allows you to enable/disable the setting of 2nd, 3rd and 4th cores to the same speed as CPU0 on boost operations, default is 1 (on) and this is the way it has behaved sense day 1, just giving people the option to disable it and maybe what is causing issue with reboots on AOSP, but doubt it.
13. More attempts to help stop AOSP reboots that occurs on some phones
KT-SGS4-TW-JB-INTL-06-23-2013.zip
