[KERNEL][I9505][LP][TW/GPE/CM12.1] *07.05.15* Hulk-Kernel V1.3.1 [STweaks]
  • 255 Antworten
Jetzt habe ich gelesen, wenn ich den Strommesser dazwischen habe, welches ja bei ein USB Messgerät ist, dann denkt das Handy es ist am PC dran.
Ich habe den Kernel jetzt wieder runtergeschmissen. Mein Handy ging immer aus damit.
Hulk-Kernel V1.3.1 (07.05.2015):
- Updated to latest Ramdisk OD7 (thanks to all who sended me one!)
- fixed CM12.1 screen green bug
- fixed CM12.1 slow booting
- CM12 removed gamma control
- OC version for CM are BETAS
- msm: clock: Fix list rate to handle rate > LONG_MAX
- msm: footswitch-8x60: Update 8064 footswitch_enable() sequence for GFX3D
- msm: clock-8960: Add 1.8MHz rate to 8064's gfx3d_clk plan
- msm: a lot more optimisations
- msm: kgsl: Wake up GPU only for touch events
- msm: kgsl: Add an input handler to power up the GPU on a touch event
- msm: scm: Add scm_call_atomic3
- msm: kgsl: support busy stats based policy in tz
- msm: kgsl: Add intermediate power levels
- kgsl: switch back to allocating from highmem
- msm: kgsl: Don't set VM_IO on mmap()ed GPU memory objects
- cpufreq: add smartass2
- cpufreq: add alucard governor (thanks alucard :))
- update nightmare and darkness
- jf: set proper compass calibration point for vzw model
- block: add REQ_URGENT to request flags
- Enable ROW scheduler and all updates for it, it is now DEFAULT sched
- msm_vidc: Frame height is not updating for low resolution clip
- mm: Fix NULL pointer dereference in madvise(MADV_WILLNEED) support
- add a driver for touchboost
- gpu: ion: Refactor locking
- gpu: ion: fix locking issues in debug code
- A note for GPU: the clock speed stuff is still not fixed, but I update all stuff and I think, I can fix that soon, I don't know what samsung did here :(
- enable Underclocking to 81MHz!
- Intelli-plug: a new tab in stweaks
- Much much more... :good:
Reaktionen: Bronco77
yes! gleich den cm12.1 testen.....
Jetzt noch ein für AOSP und der Kernel Sortiment ist komplett.
CM12.1 ist AOSP, mehr oder weniger, also RR und so weiter laufen mit CM12.1 kernel, aber nicht 100% alle. Da musst du testen, wenn du Glück hast geht es sogar.
Welche Rom hast du?
Cm12.1 ist kein richtiges aosp und die aosp kernel laufen nicht immer mit cm12.1 ...
Also auf Team UB Rom läuft alles gut!
yepp, team ub und der neue 1.3.1er harmonieren (mit etwas tuning) sehr gut miteinander.....
Nutzt einer 1.3.1 mit dem alten CM12? Wenn ja, wie läufts?
Welche Rom hast du?
Ich habe die Team UB Rom 5.1.1 drauf.:D
unwissend er noop
Mir geht es in erste lienie das er läuft.
In erst tunen zu müssen das er dann überhaubt läuft na ja :D
@Gene S:
du hast mich wohl missverstanden. ich meinte nicht, dass man den kernel tunen braucht, damit er läuft, sondern dass ich ihn meinen persönlichen bedürfnissen angepasst habe.
resümee bis jetzt: ein sehr guter cm12.1-kernel, läuft sehr smooth und hat sehr gute deep-sleep-zeiten. nutze den alucard-governor.
für alle, die sich in die materie (governors und schedulers) einlesen wollen, um evtl. den kernel optimal zu konfigurieren, ist folgende seite evtl. interessant: klick
Gibt auch eine Version für CM12, also android 5.0.2
Nutzt einer den Kernel mit der CM 12.1 optimized?
Warum sollte man wenn man einen optimierten Alucard Kernel mit der Optimized mitgeliefert bekommt?
Genau das würde mich ja mal interessieren.
OK .danke für die infos:D
Läuft genauso gut auf der Version von Alucard und Anters, wie auf der offiziellen CM12.1. Fragt sich nur, wen du lieber hast. Alu oder mich ;)
Und bei diesem Build ist nicht nur der Kernel anderst, sondern auch die Rom ein wenig, glaube ich zumindest.
Reaktionen: Gene S, arjen robben und tefracky
Kurze Frage: Laut letztem Changelog hast du die Gamma Einstellung wieder entfernt? Warum? Für mich wäre das Ausschlaggebend gewesen.
  • Gesperrt
  • Exodusnick79
hagex
hagex
Holomen
Holomen
Cloud
tilo140380
tilo140380
