hanspampel
Ehrenmitglied
- 9.865
Da es ja scheinbar hier noch keinen Custom Kernel fürs S4 gibt, stelle ich hier mal den Ersten vor. Dieser kommt vom Dev "faux123". Einige kennen ihn sicher aus N4, S3(S4 Snapdragon) oder dem HTC One.
Changelog
Download (TW4.4.2)
Download AOSP/CM etc. (4.4.4)
Android 4.3 und Google Edition
Download (TW4.3)
Changelog Google Edition
FauxClock App recommended Settings
Quelle
Achtung!! Dieser Kernel ist nur für die Snapdragon-Variante des S4 - GT-I9505!!!
Changelog
release 018 tw/CM-11 (08/02/2014)
ältere Chängelogs
- intelliplug 3.8 with profiles
- zram and KSM optimization
ältere Chängelogs
Für Android 4.3
-release 013 TW (10/27/2013)
* rebased to official JB 4.3 source (MJ5)
* intelliplug 1.8 (added dynamic load boosting function, smoother UI)
* rest are the same as AOSP/TW kernels
- release 013 (10/24/2013)
* updated to latest CM CAF patch bomb
* updated to latest CM RAMDISK
* cifs password mount fix
* epoll update from Linux 3.11+
Für Android 4.2.2
- release 012 (10/1/2013)
* slab/slub forward ported to Linux 3.8+
* fixed CIFS issues
* more efficient ZRAM
* backported 3.12+ kernel scheduler features
* fixed old cpufreq bug
* over 140+ patches!
- relesae 011 (8/26/2013)
* added LZ4 compression (faster than LZO)
* enabled LZ4 for ZRAM/ZCACHE
* added official exFAT support
* compiled with GCC 4.7
- release 009 (7/30/2013)
*** thanks to user vihru for beta testing MG1 version
*** due to mix matching libs/firmwares, you may need to try
*** several versions until you found a working version
<> MGA (for ROM BASE MGA/MFA)
<> MG1 (for ROM BASE MG1/5)
<> MF9 (for ROM BASE MF2/3/4/5/8/9)
* MEA/MDX seris are now deprecated and no longer supported!!!
- release 008 (7/28/2013)
* Compatible with ALL MF2/4/6/9 and MFD (Google Edition) ROMs
* merged to latest MFD source updates
<> note: MEX and MDX series are deprecated (all new OTA are now MFX series)
- release 007 (7/13/2013)
* added intelli-thermal kernel thermal driver
* enabled intellidemand performance lock (1 core locked @ 594 MHz)
<> MDX (for ROM BASE MDB/MDL/MDK/MDM)
* updated wireless drivers from MEA base
- release 006 (6/23/2013)
<> MDX (for ROM BASE MDB~MDM)
* added various minor kernel bug fixes from CAF/kernel.org
* more accurate load calculations (better battery/performance)
* MMC scaling (battery savings)
* 360 MHz and 600 MHz GPU frequencies added
* added simple GPU governor for better GPU controls! (battery/performance)
<> MEA (for ROM BASE MEA/MF2)
* updated to latest GT-9505 update 2 source drop
- release 005 (6/10/2013) *** (MEA base compatible)
* disabled FrontSwap
- release 004 (6/10/2013) *** (MDB~MDM base ONLY)
* added FrontSwap front Linux 3.8+ (better swap optimization)
* added CleanCache from Linux 3.8+ (better memory optimization)
* added ZRAM driver to Linux 3.8+ * added mutex optimization (better multi-tasking)
* updated drivers to ME4 source drop (except display drivers)
* added Color temperature controls
* boost voltage slightly (for better stability)
* scheduler optimization (smoother multi-tasking)
* SELinux optimization (faster SELinux!)
- release 003 (5/23/2013)
* enbled kernel AIO optimization from Linux 3.8+
* enabled touch boost for intellidemand governor
* removed kernel debugging
* enabled XZ compression (reduce kernel size)
- release 002 (5/23/2013)
* enabled ultra low CPU freqs
* ROW I/O scheduler added
* overclock to 2.1 GHz ("u"ltimate only)
* added vibration control
0* kernel freezer updated (better power savings)
* dynamic fsync safety flush added (guard against data corruptions)
* high priority queue for rpm-smd thread
* Android specific autogrouping enabled
* "random" number generator updated to Linux 3.8+
* minor power saving patches for OTG and HFPLL added
- initial release (5/10/2013)
* Dynamic Fsync
* Intelli_plug (complete replacement of mpdecision)
* intellidemand (a better ondemand governor)
* UV control
* BFQ/SIO/FIOPS I/O schedulers added
* ARM unaligned access enabled
* updated LZO algorithms (used by many including crypto, zram/zcache etc)
* updated ZRAM driver to Linux 3.8 * updated libraries with optimized kernel functions
Für Android 4.2.2
* fixed CIFS issues
* Dynamic Fsync
* UV control
Download (TW4.4.2)
M-Version*
- International LTE version (GT-I9505) "NB8"(gibt derzeit keine M-Version)
M-Version*
- International LTE version (GT-I9505)(gibt derzeit keine M-Version)
Download (TW4.3)
M-Version*
U-Version*
U-Version*
Download (GE4.4.4)- release 018 (08/02/2014)
* GPE 4.4.4 source update
* intelliplug 3.8 with profiles
* zram and KSM optimization
- release 017 (05/31/2014)
* fix CVE-2014-0196 * intelliplug 2.6
* add intelliplug screen off control
* add intelliplug touchboost control
* add intelliplug wakeup kick
* add f2fs support
* intelliactive update
* intell-thermal update (reduce overhead)
- release 016 (02/27/2014)
* add kernel mode NEON
* add futex backport from Linux 3.13+
* add intelliactive govenor!
* add async fsync * remove dynamic fsync (replaced by async fsync)
- release 015 (01/04/2014)
* core scheduler optimizaitons
* cortex-a15 flags added for krait cpus
* ARM LoUIS cache API added
* fastcharge driver added (working)
* updated to ML4 source drop
- release 014_r2 (11/30/2013)
* _r2 fix USB data crash issue (no code change, just a config change)
* kitkat rebase
* all features carried over form 013
* intelliplug 2.0
* Linux network, FS latency reduction patches
* epoll update from Linux 3.12+
* AIO patch for faster flash access
* fix mm memory calculations
* reduce vfat latencies
* fixed CIFS issues
- relesae 011 4.3 GE Only(8/26/2013)
- release 010 4.3 GE Only(8/6/2013)
* thanks to user Audioboxer for beta testing MH1 version
* Dynamic Fsync * Intelli_plug (complete replacement of mpdecision)
* UV control * BFQ/SIO/FIOPS I/O schedulers added
* updated LZO algorithms (used by many including crypto, zram/zcache etc) * updated ZRAM driver to Linux 3.8
M-Version*
U-Version*
Flash-Anleitung:
(Note: GT-I9505 version does not contain any checks for device ID. Use ONLY if you know you have GT-9505 variants!)
* m => mainline ohne overclocking (OC)
* u => ultimate mit OC bis hin zu 2.1GHz (vielleicht nicht für alle stabil)
- Man platziere die Zip auf den internen Speicher oder der externen SD Karte.
- boote ins Recovery
- entweder wiped vorher Cache und Dalvik Cache (mache ich persönlich immer vorher)
- gehe zu "Install zip from sd card" oder "Install zip from extern sd card", je nach Recovery-Typ (CWM)
- -> oder nur install (im TWRP)
- sucht sich den Ordner wo man die Zip rein gelegt hat
- und flasht diese nun indem man auf die Zip klickt und folgende Frage bejat (CMW) oder den Slider beim TWRP nach rechts zieht.
- nun kann man Cache und Dalvik Cache wipen wenn mans vorher nicht gemacht hat, oder macht es nochmal
CPU Control
SOC Control
Voltage Control
intellidemand gov control
GPU Control
I/O Scheduler Control
Misc Control
Vibration Control
Z-Control
Oder man nutzt Trickster MOD, ist für umme, zumindest für das Gröbste an den Einstellungen.
Above is what I use personally. MAY NOT be optimal for all
- Max clock - GHz 2.1 GHz for performance, 1.7 GHz for battery
- Min clock - MHz 162 MHz for both
- CPU Governor - Ondemand for performance, Intellidemand for battery
- mpdecision - Off
- Snake Charmer - OFF for performance, On for Battery
- Eco Mode - Off for performance, On for battery
- Set On Boot - On
SOC Control
- Set On Boot - On
- C0 - On
- C1 - On
- C2 - On
Voltage Control
- Set On Boot -
- Global CPU Voltage - Your preference
- Up Threshold - 75 for both
- Boost Frequency - 0 for both
- Two Phase Freq - 1350000 for both
- Sampling Rate - 50000 for both
- Optimal Freq - 1566000 for both
- Synchro Freq - 702000 for both
- Set On Boot - On
GPU Control
- GPU Governor - ondemand for both
- GPU Clock - 487Mhz for performance and 320 Mhz for battery
- GPU Vsync Toggle - On for both
- Set On Boot - On for both
- I/O Scheduler (eMMC) - FIOPS for both
- Readhead Size (eMMC) - 1024 for both
Misc Control
- Dynamic File Sync - On for both
- TCP Congestion Control - Westwood for both
Vibration Control
- Vibration Control - Your own Preference
Z-Control
- ZRAM Disk size - 150~200 Megabytes (or 50 MB when disabled)
- ZRAM Enable/Disable - Enable if you mult-task often
- Clear VFS Cache After Boot - On
- Auto FS Writeback Delay Mode - On
- Swappiness - 100% if ZRAM enabled, 0% if disabled
- VFS Cache Pressure - 100% if ZRAM enabled, 150% if disabled
- Dirty Ratio - 20% for both
- Dirty Background Ratio - 5% for both
Quelle
