[Kernel][GT-I9505][TW/GE][4.4.3] *18.09.2014* AEL Kernel V6.2
  • 86 Antworten
beicuxhaven
beicuxhaven
Ehrenmitglied
10.437
Nur für INTERNATIONAL GALAXY S4 (GT-I9505) für TW & GE ROMS
Build with I9505XXUFNB8 (I9505 KK OPEN SOURCE UPDATE 5) Samsung Sources
- Merged with new Android GPE 4.4.3 Sources
- CPU OC up to 2.1 ghz and UC down to 162 mhz (CREDITS faux123)[/URL])
- Faux Sound Control (CREDITS faux123)
- Voltage Control (HUGE THANKS: jamison904)
- Used and modded the ramdisk from the newest I9505XXUGNE5 Stock Kernel
- Added Intelliplug Driver
- Enabled the following additional governors:
lionheart (RECOMMENDED), asswax, smartmax, dancedance, conservative,
conservativex, intelliactive, ondemandplus, pegasusq, wheatley, alucard (CREDITS: alucard),
darkness, nightmare
- Enabled the following additional I/O Schedulers:
Simple (sio), zen (recommended), fiops, fifo, vr
You can use either trickstermod app or No Frill Cpu Control (both free for Play Store)
to control the various CPU and other Custom Settings that are enabled in the AEL Kernel
- Enabled cpu boost driver
- Enabled Fast Charge (You can enable/ disable it with tricksterMod app)
(ALL CREDITS TO THE AMAZING Faux123)
- Fixed Charging with Power Off for Old Bootloader (credits: @Fenny)
- Permissive, init.d and busybox support (huge THANKS and CREDITS to xda @wanam)
- Disabled TIMA verification and logs
- Based on Android 4.4.3 Samsung Sources (I9505GUEUCNE3)
- Voltage Control
- Many Governors: pegasusq, intelliactive, conservativex, ondemandplus, wheatley
lionheart, conservative, asswax, dancedance, smartmax
- Many I/O Schedulers: Simple (SIO), Zen, VR, fiops, fifo
- Faux Sound Control - Disabled TIMA verification and logs
19/05
- CPU OC up to 2.1 ghz and UC down to 162 mhz (THANKS: faux123 and Alucard)
- Added 3 more governors (alucard, darkness, nightmare) (THANKS: Alucard)
13/05
- Reverted back to stock LED brightness and fading for now
- Added wheatley governor for real this time
11/05
- Enabled Voltage Control (HUGE THANKS: jamison904)
- Added the following governors:
. pegasusq, intelliactive, conservativex, ondemandplus, wheatley
TW RELEASES
Contributors
friedrich420,
Kernel Special Features:
Version Information
Status: Stable
Current Stable Version: 1
Stable Release Date: 2014-04-09​
Created 2014-04-09
Last Updated 2014-04-09​
Viel Spaß beim TESTEN!!
Reaktionen: scme4 und abemann
Kann bis jetzt nur gutes berichten.
Läuft stabil, macht keine Mucken und mit den empfohlenen Gov lionheart und sched zen sehr geschmeidig.
Akkulaufzeit kann ich noch nichts genaues sagen, aber schonmal vergleichbar mit den anderen Kerneln, die ich schon getestet habe und mir gute Akkulaufzeiten beschert haben.
Von mir ne klare Empfehlung - thumbup-
Reaktionen: beicuxhaven
Ich bin auch sehr zufrieden. Und jetzt zweimal weil es hier jetzt einen thread gibt.
Mit welcher app stellt ihr den kernel ein
Fauxclock
Gibt es davon auch ne Version die for free ist oder muss ich sie kaufen
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Ich benutze No-Frill CPU geht genau so… steht ja im ersten post drinn welche Friedrich auch schreibt.. Und ist for free
Reaktionen: abemann und mbs
Gibt nur die pay Version. Aber die hatte ich eh schon, deswegen benutze ich sie.
Aber wie scme schrieb, trickstermod oder No-Frill tun es genauso gut.
Was ähnlich wie Faux Clock ist, ist Trickster Mod. Um Längen besser als das altbackene NoFrills. Davon gibts auch ne freie Version.
Aber hier gehts ja nicht um die Apps, dafür gibts auch entsprechende Threads.
Der Kernel ist wirklich klasse. Stabil und akkufreundlich. Ich bin echt begeistert.
Vielen Dank dafür!
Der Kernel läuft zwar gut,aber dafür zieht er ganz schön am Akku.Ich bleibe daher lieber beim Adam Kernel;)
Kernel 1.1 ist raus
Download auf der Echoe Seite...
Edit sagt,
1.2 ist draußen...
Edit 2 :
Ich war mal so frei und hab den Titel und download angepasst ;-)
hallo neuer Kernel ist da
S4 Custom Kernels:
v1.2.1 (13/05/2014) AEL Kernel v1.2.1
S4 (GT-I9505) KERNELS | EchoeROM EchoeROM
Reaktionen: cisco65 und abemann
Neue Version 1.2.1 vom 13/05/14
Steht doch schon über dir ;-)
Löppt soweit auch gut, keine Probleme.
Das sollte nur bedeuten, dass ich den Titel und den Startpost angepasst habe.
Reaktionen: abemann
Welche Governors und i/o Scheduler empfehlt ihr für Performance und guter Akku Ausdauer ?
Das würde ich auch gerne wissen.
Bin bis jetzt mit lionheart/zen ganz gut gefahren.
Neu...
S4 Custom Kernels:
(19/05/2014) AEL Kernel v2
Reaktionen: beicuxhaven, corona999999 und DON VITO
Ich habe auch schon auf XDA angefragt, aber bis jetzt kann mir keiner helfen. Deshalb frage ich auch hier in die Runde.
Ich nutze aktuell Echoe 20 mit dem AEL Kernel 1.21. Alles läuft prima. Nun möchte ich gerne diesen neuen Kernel probieren. Leider klappt da bei mir nicht.
Wenn ich den neuen Kernel flashe, dann startet mein S4 zwar, aber einen Augenblick später friert der Bildschirm ein, und mein Gerät startet neu. Jetzt findet es dann auch plötzlich kein Baseband mehr.
Wo kann der Fehler sein?
Ich habe Trickster Mod runtergeworfen, weil ich gelesen habe, dass es sich mit dem Kernel nicht so gut verträgt.
Ich habe den Kernel dirty nachgeflasht, denn das half mir bei der Echoe 20 Installation vorher auch immer schon sehr.
Kernel erneut runtergeladen.....bringt auch nichts.
Kann mir einer einen Tipp geben, wo ich den Fehler finden kann?
Bis jetzt scheinen ja alle begeistert von diesem Kernel zu sein.
Danke für die Hilfe.
DV
  • Gesperrt
  • Exodusnick79
hagex
hagex
Holomen
Holomen
Cloud
tilo140380
tilo140380
