[KERNEL][4.4.2][TW-ROMs only][05.08][2.4] Adam Kernel
  • 364 Antworten
myreality
myreality
Enthusiast
3.898
Wanam hat nun, nachdem er einen Kernel für das I9500 gebaut hat, auch einen für die Snapdragon Variante veröffentlicht.
Ab Version 2.0 für Android 4.4.2 geeignet.
Nur für Touchwiz basierende Firmwares geeignet.
Features:
*Built from Samsung sources Update5 (NB8 - Kitkat)
*Init.d support
*Busybox (/sbin)
*Built with Stock ARM Toolchain 4.7
*SELinux set to Permissive
*AutoRoot with SuperSU
*CISF andd NTFS File System support built as modules (Stored on "system/lib/modules")
*Built-in exFAT sdcard support
*Built-in NFS support
*Tweaked Ondemand CPU Governor for better performance/power balance
*Disabled Android Logger (can be enabled through Stweaks)
*Disabled TIMA verifications and logs
*Disabled some useless tracers
*Tweaked Ondemand CPU Governor for faster response
Changelog 2.4:
*Merge with Samsung sources update 8
*Update Ramfs to GNG8
*Update Root files
Changelogs vorheriger Versionen:
Changelog 2.3:
*Built-in CIFS support and enable Clean cache
*Update Root
*Power off charging support for old Bootloader (Thanks to @Fenny)
Changelog 2.2:
*Enable Front swap
*Update Busybox to 1.22.1
*Set Kernel compression to Gzip
*Few other permissions fixes
Changelog 2.1:
*Remove Knox Apps
*Minor config changes
Changelog 2.0:
*Merge with Samsung sources NB8 (Kitkat)
*Updated SuperSU to 1.93
Changelog 1.6:
*Disabled some useless debuggers
*Update Root files
*Added a Knox security removal
Changelog 1.5:
* Updated Root to 1.41
* Updated InitRamfs/exFAT to MGA
* Many Battery life tweaks (MC Sched and Ondemand CPU Gov)
Changelog 1.4:
* Patched with Samsung kernel sources update 2
* Updated Root to 1.34
* NFS Built-in kernel
* Updated InitRamfs to MF4
* Some Battery life tweaks
Changelog 1.3.3:
*Patched with ME4 Samsung kernel sources (Thanks to Faux)
*Updated Root to 1.32
*Updated InitRamfs to MF2
*Some Battery life tweaks
This update fixes Wifi, Smart scrolling, Dual Camera on the newest FW MEA and MF2…
Changelog 1.3.2:
* Lower Ondemand CPU up_threshold
* Auto Wipe cache and dalvik_cache (CWM version)
* Few other fixes
Changelog 1.3.1:
* Update Root files V1.30 (Thanks to Chainfire)
* exFAT support
* Disabled Android Logger
* Android Logger switch trough Stweaks App (No Reboot required) (Thanks to AndiP)
* CIFS/NFS/NTFS built as modules (located on /system/lib/modules)
* Disabled some useless tracers
* Increased timeout for some bad sdcards (Thanks to AndreiLux and AndiP)
* improved Ondemand CPU Governor tweaks for faster response
* Enable Sdcard encryption
Download:
Version 2.4: https://mega.co.nz/#!wxRj3YRJ!zI8mnlXK5P5QyljJ69WcH40vvP5gGHyxQwQHhQ7iLGg
Mirror#1: http://romcook.com/?d=53E10BA68
Sources
https://github.com/wanam/Adam-Kernel-GS4-LTE
Thread @ XDA
Reaktionen: predatorone, wolfsstolz, katzmann und 25 andere
- Enabled available stock CPU governors (conservative, powersave,interactive)
Kam noch dazu.
CU
Reaktionen: Snake89, abemann, Adrioid83 und 2 andere
Auto Root heißt soviel wie auf jeder Firmware die man hat hat man Root?! YES!
Habt ihr nen alternativen Downloadlink, kann ihn grad nicht runterladen.
(oder wie üblich GEDULD?)
LG
kann ich den kernel auch mit der Stock MDM nutzen, also einfach per recovery flashen?
Ja.
Gesendet von meinem GT-I9505 mit der Android-Hilfe.de App
Hat schon jemand sein Handy mit dem Kernel gerootet? Gibt es Probleme?
Würde mich auch mal interessieren, was passiert wenn ich den Kernel auf meine prerooted ME2 flashe. Ist root dann weg oder wie?
Also ich habe ihn drauf und habe root behalten!!
Ich auch und alles bestens.
Hm. jetzt ist der Gerätestatus auf Benutzerdefiniert, wie krieg ich den wieder auf Offiziell?
Da lies doch mal im Root-Thread nach. Ist dort beschrieben. Bei Fragen gibt es zu dem Thread auch ein FAQ-Thema.
https://www.android-hilfe.de/forum/anleitungen-fuer-samsung-galaxy-s4-i9505.1123/anleitung-i9505-aktivierung-des-root-accounts.413326.html oder https://www.android-hilfe.de/forum/root-custom-roms-modding-fuer-samsung-galaxy-s4.1093/fragen-diskussion-betreffend-der-aktivierung-des-root-accounts.413695.html für evtl. Fragen.
Das S4 besitzt einen Flashcounter, der zählt, wie oft geflasht wurde.
Er zählt nur inoffizielle Sachen (Kernel, OS etc.), die nicht von Samsung signiert wurden.
Den Counter hat Samsung nun versteckt, er befindet sich nicht mehr im Download Modus. Dort steht nur noch ob ihr eine offizielle unveränderte Firmware besitzt.
Der versteckte Counter lässt sich glücklicherweise zurücksetzen, dank der App TriangleAway.
CU
Gibts davon auch ne Version die ich mit Odin flashen kann?
Nope...
Gesendet vom GT-9505 tuned by Binford... more power!
CIFS and EFS built as modules (Stored on “/system/lib/modules”)
Heißt das es wird IMEI/EFS automatisch gesichert. Oder muß ich es
nach Anleitung selbst machen?
man sollte vielleicht erwähnen das der Kernel (noch) keine 64 Gb Karten unterstützt !
was für mich persönlich zwingend notwendig ist !
Reaktionen: BBF-Android und TAT1980
Lohnt sich der Kernel gegen über Stock??
ZZ.b bei Akku und m.ruckler??
Läuft soweit gut. Hab keine Ruckler, hatte ich aber vorher auch noch nicht. Akku kann ich noch nicht sagen, erst der erste Durchlauf. Hab aber das Gefühl, dass er weniger hoch taktet. Hab schon jede Menge rumgespielt heut, hab noch 70%Akku,2 Stunden Display on und auf cpu spy dümpelt das phone die meiste Zeit auf 300 bis 400. Governor ondemand
Reaktionen: TAT1980, ->TopAZ<- und d407974
  • Gesperrt
  • Exodusnick79
hagex
hagex
Cloud
tilo140380
tilo140380
Holomen
Holomen
