XeLLaR
Dauer-User
- 621
Da der Alte thread nichtmehr geupdated wird, hier der neue.
Dieser Kernel basiert auf dem Kernel von Ivendor ( dessen kernel auf Arco´s kernel basiert)
Mit diesem Kernel wird euer gerät, wieder zu neuem Leben erweckt.
Den Originalthread findet ihr hier:
[KERNEL][✔ICS✔JB] CastagnaIT v10.9 (OC/UV, Governors, I/O, More feature) [05/04/2013] - xda-developers
VERSIONS
JB-CM10.1 Kernel version 3.4.60
JB-CM10 Kernel version 3.0.94
ICS Kernel version 3.0.94
CIT FEATURES (the features in gray are completely realized by myself)
✔ Overclock until 1804 Mhz (default 1401 Mhz) [VIEW TABLE OF FREQUENCIES]
✔ Extreme undervolted kernel version available
✔ Standard kernel have 355MB of free memory
✔ Bigmem kernel have 377MB of free memory (720P video recorder does not work, but you can record with 480P)
✔ Governors: Lulzactive(v.2) (default), Ondemand, OndemandX, Interactive, InteractiveX, Powersave, Performance, SmartAssV2, MinMax, Lagfree, Savagedzen, Smoothass, Lionheart, BrazilianWax, Scary, Lazy, Intellidemand, Fantasy, Hyper
✔ I/O scheduler: SIO (Default) , ROW, V(r), BFQ, CFQ, Deadline, Noop, FIOPS (JB ONLY), ZEN (ICS ONLY)
✔ Con Kolivas performance improvements (CK3 for JB, CK1 for ICS)
✔ Init.d support
✔ Custom AriesPart for customize kernel settings
✔ FAT and NTFS filesystem support
✔ CIFS support
✔ TUN support
✔ BLNv9 - Led backlight notification (see**1)
✔ Increased boot speed
✔ Increased audio loudness
⋅⋅⋅⋅⋅⋅ more power for your speaker
✔ Do Not Kill process (see**2)
⋅⋅⋅⋅⋅⋅ this feature protect apps/launcher/system process from being killed by the internal Low Memory Killer
✔ Improved Low Memory Killer
✔ USB Forced Fast Charge support (see**2) (info)
✔ HQ Photo - without compression (see**2) (default enabled)
⋅⋅⋅⋅⋅⋅ save camera pictures without compression
✔ FULL Touch Screen customization (see**2)
⋅⋅⋅⋅⋅⋅ you can customize your touchscreen as you like, sensitivity, movement, response time, number of touches and more...
✔ Battery Life eXtender (BLX) (see**2)
⋅⋅⋅⋅⋅⋅ extend the life of your battery by limiting the maximum charge
✔ Brightness of display tweaked
⋅⋅⋅⋅⋅⋅ now you can lower the brightness of two points more than the stock, there are no changes to be done is automatically managed
✔ Speed up SD card read-write (see**2)
✔ Default readahead based on the size of the connected disk
✔ VDD level sysfs interface
✔ Timer Slack Controller
✔ Dynamic manegement of Timer Slack Controller
✔ Dynamic sync control (see**2)
✔ Writeback optimized for slight best smooth performace
✔ Frandom fast random generator (with hacked random and urandom linked to frandom)
✔ Stochastic Fair Blue (SFB) network scheduler
✔ Cleancache & QCache
✔ Lowered display voltage
✔ Lowered wi-fi voltage
✔ Lowered touchscreen voltage
✔ Zram swap ready (default disabled)
✔ Google snappy compression for zram
✔ SLUB memory allocator
✔ UI speed up tweaks
✔ Memory/vm tweaks
✔ ...and much more!! For detailed information read the changelog below
CIT FEATURE ONLY FOR ICS/JB-CM10 KERNEL
✔ Ported from google Proportional Rate Reduction for TCP
✔ Ported from kernel 3.1 Dynamic writeback and I/O-less dirty throttling
✔ Updated Zram
Kernel für ICS
Kernel für Jellybean 4.1
Kernel für Jellybean 4.2
CastagnaIT AriesParts V2.0
Eventuell unbekannte begriffe:
BFS - Brian F#ck Scheduler
CFS - Completely Fair Scheduler
BIGMEM - Version mit mehr Ram
OC - CPU Übertaktbar, mit ein wenig Undervolt
ExUV - CPU Übertaktbar, mit viel Undervolt um die bestmögliche Akkulaufzeit zu erzielen!
HQ Photo ausschalten - ohne Kompression (CWM flashbare zip)
Zram einschalten (CWM flashbare zip) NICHT MIT DEM 3.X KOMBINIEREN
1) Kopiere die datei auf die Interne SD-Karte
2) Starte in das Recovery menü flashe den Kernel
3) Wipe cache
4) Wipe dalvik cache
5) Neustart
6) Neustart ins recovery (wieder)
7) Fix permissions
8) Neustart
v12.4
Kompiliert mit Linaro 4.7.4 2013.07 optimiert von Christopher
Alle Kernels CM9/CM10/CM10.1 mit den AriesVE-DevConnection-Team Sources Gesyncht.
Credits
CyanogenMod Team
Arco68 for his kernel
Ivendor for his kernel updates
Smeroni68 for his help to testing and support to adjust frequencies/voltage
To all the developers mentioned in the changelog that have contributed with patches, and updates
And to all SGW and SGS+ users that helped with testing and donations
VERSIONS
✔ Init.d support
✔ CIFS support
✔ TUN support
✔ Memory/vm tweaks
✔ Updated Zram
Kernel für ICS
3) Wipe cache
5) Neustart
7) Fix permissions
8) Neustart
v12.4
Credits
CyanogenMod Team
