[KERNEL][ICS] CastagnaIT Kernel v5.7 (OC/UV Governors+I/O Sched+other) [08/9/2012]
  • 249 Antworten
MrNilsson
Stamm-User
265
Der CastagnalT Kernel, ist der erste Custom Kernel für ICS Roms. Basierend auf Ivendor's Kernel (der von Arco68 stammt) sind nun mehr Governors und die Option des Overclockings gegeben.
Bitte flash diesen Kernel nicht, wenn Du eine aktuelle AOPK Rom (z. B. AOKP Eclipse v3) nutzt. Die externe SD Karte wird dann nicht mehr erkannt.
Code:
[B]Features:[/B]
[LIST]
[*]OC/UV until 1804 Mhz (selectable - default 1401 Mhz)
[*]Compiled with Linaro 4.7.2
[*]Governor SmartassV2 (default)
[*]Governor MinMax
[*]Governor InteractiveX
[*]Governor Lagfree
[*]Governor Savagedzen
[*]Governor Smoothass
[*]Governor Lionheart
[*]Governor BrazilianWax
[*]Governor Scary
[*]Governor Lazy
[*]SIO I/O scheduler (default)
[*]V(r) I/O scheduler
[*]BFQ I/O scheduler
[*]CFQ I/O scheduler
[*]Deadline I/O scheduler
[*]BLN CyanogenMod
[*]Speed up SD card read-write
[*]SLUB for now SLQB more test has need
[*]TinyRCU
[*][B][COLOR="MediumTurquoise"]BLN - Led backlight notification (see*)[/COLOR][/B]
[*][B][COLOR="MediumTurquoise"]Fast Charge support (see*)[/COLOR][/B]
[*]Memory/vm tweaks
[/LIST]
* To change easy the option it uses NSTools or similar app / widget.
Download der aktuellen Version:
CastagnaITKernel v5.9 (OC/UV)
CastagnaITKernel v5.9 Extreme Undervolt (OC/UV)
Download des aktuellen Ivendor Kernels:
Ivendor beta 5 kernel (Original no OC/UV)
Code:
Alte Versionen:
[URL="http://www.mediafire.com/download.php?s22tb4203shnmqw"]CastagnaITKernel v5.7 (OC/UV)[/URL]
[URL="http://www.mediafire.com/download.php?z8md88oy42vrzk8"]CastagnaITKernel v5.7 Extreme Undervolt (OC/UV)[/URL]
[URL="http://www.mediafire.com/download.php?w7gf8wzsnjtj0yy"]CastagnaITKernel v5.6 (OC/UV)[/URL]
[URL="http://www.mediafire.com/download.php?nvg7r1ixu6mutmy"]CastagnaITKernel v5.3 (OC/UV)[/URL]
[URL="http://www.mediafire.com/download.php?hhn6fkbvlkool1b"]CastagnaITKernel v5 (OC/UV) Fixed boot problem[/URL]
[URL="http://www.mediafire.com/?0r9le5614a4w419"]CastagnaITKernel v4.7 (OC/UV)[/URL]
[URL="http://www.mediafire.com/download.php?uznyfqb0lnaov3y"]CastagnaITKernel v4.5 (OC/UV)[/URL]
[URL="http://www.mediafire.com/download.php?b4qy96ss507rs2g"]CastagnaITKernel v4.1 (OC/UV)[/URL]
[URL="http://www.mediafire.com/download.php?u4i4jyseavy98wk"]CastagnaITKernel v2 (OC/UV)[/URL]
Installation:
  1. Kopiere die Zip auf die interne SD Karte
  2. Starte das S Plus in den Recovery Mode
  3. flash den Kernel (install .zip from SD card > choose .zip from SD card)
  4. wipe cache (wipe cache partition)
  5. wipe dalvik cache (advanced -> wipe dalvik cache)
  6. Reboot (reboot system now)
WICHTIG: Aktiviere erst die Option "Beim Booten einstellen", wenn deine Einstellungen ohne Probleme laufen.
Code:
[B]Changelog:[/B]
v5.9
Added Init.d support
Added CIFS support
Added memory/vm tweaks
Incrased boot speed
Return to SLUB memory allocator (SLQB it needs more test)
Revert back some changes
v5.7
Some corretions on governors settings
v5.6
New Extreme Undervolt kernel! (coming soon)
Added SLQB memory allocator
Updated SIO I/O scheduler
Corrected PLL problems to the frequencies
Corrected frequencies and voltages (thanks to Smeroni68 for suggestions and testing)
Removed audio volume tweaks from vitaliyy
Some bugfix/corrections
Sync kernel source with last change by Ivendor/Arco
v5.3
Added BLN v9
Fixed Fast Charge support (default is disabled)
Fixed missing close symbol in a function on audio library (this generated errors)
Modified some audio volume settings
Speed up sd card read/write
v5
Increased audio volume (thanks to vitaliyy tweaks)
Speed up sdcard readahead
Re-enabled voip fix
v4.7
Revert and modified most new undervolt values for high frequencies (some users have problems with last undervolt values, now we have returned to normality :))
Removed added frequencies (probable too many frequencies to scale)
Incrased default ramp up step for Smartassv2
Added Fast Charge support ported from Nexus/HTC sources (but at this moment does not work because having error with sysfs activation strings, i have not found a solution, perhaps they must be implemented in the rom)
v4.6
Do not use!, cause problems with performances of the database
v4.5
Modified some undervolt values for having more linear voltages and a smaller battery consumption (thanks to Smeroni68 for his suggestions)
Added some new frequency
Added TinyRCU as default
v4.1 - 23/08/2012:
[B]Updated ramdisk (sorry it was antiquated)[/B]
[B]Wi-Fi fixed[/B]
v3 - 23/08/2012:
Added lazy governor
Added cpuidle ladder/menu
Added missing governor defines
Updated lagfree governor settings
v2 - 23/08/2012:
Sync with beta 4 kernel of Ivendor
Removed OC/OV 1901 Mhz for instability
Autorotation seem to working
Compiled with linaro toolchain (gcc 4.7.2)
v1 - 23/08/2012:
First public build
Sync kernel source with beta 3 kernel of Ivendor
Added OC/OV until 1901 Mhz selectable
Added Scheduler SIO
Added Scheduler V(r)
Added Scheduler BFQ
Added Scheduler Deadline
Added Governor SmartassV2
Added Governor MinMax
Added Governor InteractiveX
Added Governor Lagfree
Added Governor Savagedzen
Added Governor Smoothass
Added Governor Lionheart
Added Governor BrazilianWax
Added Governor Scary
Wie immer: Du flasht den Kernel auf eigene Gefahr! Für mögliche Schäden wird keine Haftung übernommen!
Originalthread: [KERNEL][ICS] CastagnaIT Kernel v5.9 (OC/UV Governors+I/O Sched+other) [13/9/2012] auf forum.xda-developers.com
  • Ivendor_Beta5_Kernel_signed.zip
  • CastagnaITKernel_v5.9_signed.zip
  • CastagnaITKernel_v5.9_ExtremeUV_signed.zip
Reaktionen: uwalburg, Zeus.1965, Rawwrius und 4 andere
Funkzioniert das auch auf Paranoid Android?
Ja, bei jeder Rom die auf Arco68's Release basiert, also funktioniert es z. B. auch bei MIUI 4. The Android Open Kang Project (AOPK) Roms werden nicht unterstützt.
Reaktionen: I3_Painful_I3
MrNilsson schrieb:
Ja da bis jetzt jede ICS Rom und jeder Kernel auf Arco68's Release basiert, also funktioniert es z. B. auch bei MIUI 4.
und welchen von beiden soll ich da jetzt installieren?? welche unterschiede sind da vorhanden raff es grad net so
Im ersten post findest du den alternativen UND den originalen wenn du wieder zurück möchtest ;)
Gesendet mit der Android-Hilfe.de App
meine Frage war eigentlich, ob sich ein Mod findet, der die zusammenführt ..
Ein neuer Kernel ist draußen (v4.5). Dieser läuft jedoch nicht stabil. Beim nächsten Kernel Update das ordentlich läuft, schreibe ich einen Mod an, der den Titel ändert und die beiden Threads zusammen führt.
Sent from my Galaxy S Plus i9001 with Tapatalk
Es scheint sich eher um Konfigurationsfehler als um Bugs zu handeln......
v4.6 ist draußen :D
Seid ich den 4.1 drauf habe kann ich nicht mehr auf meine speicherkarte zugreifen :-(
nur auf die interne help me :-((((
na dann werd ich mir die 4.6 mal ziehen ..... bin mächtig gespannt, nachdem ich heute die ganze Zeit mit der 4.5 rumexperimentiert habe. Die ist wirklich nen Schuss in den Ofen ....
Gr.
B.
edit:
Link bei xda ist (noch?) down..... changelog deutet für mich darauf hin, daß man es bei der 4.5 mit dem UV/OC übertrieben hat... warum man den Fastcharge implementiert, wenn er nicht funktioniert ist mir ein Rätsel....
17:42 ...... Der Link funktioniert jetzt.... auf zum fröhlichen Testen
Wer spielt den jetzt noch mit 4.6 :lol: . Ist doch schon 4.7 da :)
uuups ..... Teppfuhler.... 4.7 natürlich; der DLlink gibt ja genau das her :)
edit
... also gefühlt ist das Ergebnis flüssiger .... das Phone spricht viel direkter an.
so hab jetzt zeit und werd mal 4.7 rauf hauen und schauen wie es funktioniert :)
Der Thread ist wieder auf dem aktuellen Stand.
Nutzt du eine AOPK Rom? Der Pfad von AOPK Roms zu der externen Karte unterscheidet sich zu dem Roms, die auf Arco68's Release basieren. Darum wird die Karte nicht mehr angezeigt.
So, hab nun mit 4.7 seit gestern keinerlei Probleme, es läuft einwandfrei.
Jep läuft bei mir auch super. Hab nun auch mal das Modem auf XXKPL geflasht und der Akkuverbrauch wurde stark gemindert.
Meins läuft jetzt auch auf 4.7. Läuft einwandfrei, und seht mal :D :love:
Cyanlux
XeLLaR
XeLLaR
XeLLaR
Rhonin
Rhonin
  • Corsaaa
Flash04
