[KERNEL][ICS] CastagnaIT Kernel v5.7 (OC/UV Governors+I/O Sched+other) [08/9/2012]
  • 249 Antworten
Quote:
Originally Posted by prescott66
V5.7 is very laggy for me. V4.7 works like a charm for me.with latest ehndroix rom.thanks for your discussion guys
Quote:
Originally Posted by davidrome
I dont know what are you doing, but 5.4 without is smoother than 5.7
Quote:
Originally Posted by Invicta
back tgo 5.4 without, 5.7 is draining the battery like a b***
Quote:
Originally Posted by TwinHeadedEagle
I installed 4.7 and it's working best...
Hi to all, a user on Italian forum, had lags with v5.7 and he was back to v5.4... finally he decided to start from scratch form a Factory Reset and SD format (please procede to backup all the needed datas somewhere outside the internal SD... if not it will destroy all!!!)
Wipe ALL, DATA/CACHE/DALVIK/FORMAT INTERNAL SD (not microSD!!)... after first reboot, he reported that the installation give a perfect running system... he proceded the installation of some app from market... all still perfect... he complete the installation of the 200 apps he is using daily (still from market) and the system run like a charm...
Based on this report (thanks to user "iLpirLa" ): for people who encountered strange behaviour and lags just with kernel update, this user has absolutely tested what means to reinstall all (PLEASE: DO NOT RESTORE ANYTHING with TB... this is causing strange problems...). It will take time, so do not do this operation during the day... do in the evening/night... and DO A NANDROID BACKUP of your current system BEFORE proceding...
This the procedure he follow:
- from recovery -> data wipe (this will destroy all your data!!)
- format sd card (copy all needed data on microSD before doing this)
- wipe cache /dalvik
- flash kernel v5.7 (extreme or standard depending on your hardware)
- reboot
Set language and system settings (as the first time you installed CM9-Ics)
- reboot in recovery -> fix permission -> reboot
- reinstall from MARKET all your app's
REPORT here if all it's OK.
IMPORTANT: I'm not responsable for any data lost or damage to your phone... all is in your hand!!
Der ursprüngliche Beitrag von 08:14 Uhr wurde um 08:15 Uhr ergänzt:
Kleine Info von smeroni68 aus XDA
Funst der kernel auch auf ICS basierend MIUI Roms
Nein. Wahrscheinlich nicht. Bin mir zwar nicht sicher, würde aber auch mein Handy nicht auf's Spiel setzen.
Jo funzt.
Sent from my Galaxy S Plus i9001 with Tapatalk
Da oben steht das es ICS-Kernel sind, gehen diese trotzdem für GingerBread?
Nein
Reaktionen: eTexx
MrNilsson schrieb:
Nein
Welchen Kernel sollte man dann am besten nehmen?
Grüße.
Ich hatte glaube ich den Feacore Phoenix oder so...
Reaktionen: eTexx
Das steht doch in den jeweiligen Threads?
Reaktionen: eTexx
Ja, aber ich weiß nicht wie ich dadurch herausfinde welcher der beste ist.
Ausprobieren :)
Ich habe mit Cm7 den FeaCore, wie isaak.lee schon gesagt hat
Reaktionen: eTexx
Jonasx schrieb:
Ausprobieren :)
Den FeaCore kernel kann man doch auch ohne FeaMod flashen oder? habe nämlich CWM 5.5 drauf.
Nö, ich denke nicht.
Reaktionen: eTexx
Welcher GB-Rom hast du den benutzt? Ich denke daran die von NitroX zu flashen.
Bin gestern von ICS mit Cm9 auf GIGABREAD umgestiegen, der Akkuverbrauch war mir zu groß mit ICS. Mit GIGABREAD hatte ich dann auch nur Probleme, die Bootanimation hängte sich ständig auf, alle Möglichen Prozesse sind die ganze Zeit abgestürzt und es gab plötzliche reboots:eek:
Na ja jetz hab ich grad Cm7 drauf, gefällt mir sehr gut und besser wie Cm9 :)
Sonst hatte ich bisher nur ICS Custom Roms drauf ;)
Ja ich steige auch von Cm9 um auf Gingerbread Roms wieder. Cm7 hat doch noch zu viele bugs? z.B funktioniert Kamera Zoom und so nicht.
Cm9 SMS fenster, Vibration etc hat einfach nicht gefallen an mir gefunden :D
Ja der Zoom ist der einzige Bug der mir bisher aufgefallen ist, stört mich aber nicht so sehr, mit Zoom ist bei mir immer alles so verpixelt.
Ausserdem finde ich das CM Blau einfach Klasse :)
Am Anfang wurde auch meine sdkarte nicht erkannt aber nach einem wipe cache jetzt doch.
So nun mal FeaCore drauf geflasht. FeaMod wird automatisch mitgeflasht.. hoffe das macht mir später keine Probleme wenn ich wieder ICS will :D
Cyanlux
XeLLaR
XeLLaR
XeLLaR
Rhonin
Rhonin
  • Corsaaa
Flash04
