[KERNEL][GB/ICS/JB]broodKernel - v4.5 (3.4.49)
  • 6 Antworten
flasher78
flasher78
Dauer-User
309
Da der Brood Kernel ein Super Kernel ist und dieser hier noch fehlt,erstelle ich diesen einfach mal ;)
broodKernel v4.3 OC for JB Roms
XDA Link zum Broodkernel
Source code: github
Credits to ivendor for original fork.
v4.5
Changes:
- Squashed update from 3.4.48 (fixed version) to 3.4.49
- Squashed update from 3.4.47 to 3.4.48 (fixed version)
- Compiled with -O3, on latest Christopher83 toolchain
- Added Dynamic management of dirty writeback (Christopher83)
- Lowered Vibetonz voltage
- Added governors: Intellidemand, Adaptive
- Added Schedulers: SIO
- Allow IPv6 in WiFi and remove wakelock
- Interactive governor fixes
- Merged several more patches
Download for JB v4.1.x: My Files
Download for JB v4.2.x: http://www.mediafire.com/folder/us1j27w44lz51/4.5
v4.4.5:
Changes:
- Update from 3.4.46 to 3.4.47
- Added Brazilianwax governor
Tiny update.
Download JB v4.1.2: My Files
Download JB v4.2.2: My Files
Code:
v4.4:
Changes:
- Added lulzactivew and conservativeX (less agressive conservative) governors
- Merged Christopher83 patches (fix display regulator fix)
- Merged CastagnaIT patches (lcd regulator fixes & fix)
- Lowered swapiness to 45
Not much this time but an update is an update.
All changes: https://github.com/broodplank/samsung-kernel-msm7x30/commits/cm-10.1
Download JB v4.1.2: http://www.mediafire.com/folder/c7cvo99d9farv/v4.4
Download JB v4.2.2: http://www.mediafire.com/folder/6siwdg0fziz1v/4.4
CHANGES:v4.3
- Added frandom (by Christopher83)
- Added support for voltage changing (VDD)
- Added Performance Ram Tweak (by biago7xD)
- Merged Cyanogen vsync fix
- Optimized SLUB performance
- Asynchronous I/O latency to a SSD (internal sd) greatly increased, 34% gain (Creds: kleikamp)
Download JB v4.1.2(img):boot-jb41x.img
Download JB v4.1.2(zip):broodKernel_v4.3-4.1.2.zip
Download JB v4.2.2(img):boot-jb42x.img
Download JB v4.2.2(zip):broodKernel_v4.3-4.2.2.zip
broodKernel v3.0 OC for JB Roms
Source code: github
Features till now:
Code:
Everything is working, including VSync
- Tiny RCU
- Compiled with Linaro Toolchain
- SLUB Allocator
- 1.4GHz / 1.8GHz
- Governors: performance / powersave / convervative / ondemand / smartassV2 / interactive / lulzactive
- Schedulers: noop / deadline / sio / cfq / bfq / row
- Virtual RAM (SWAP) possible
- init.d support
Download
Linaro:
Download OC for JB: http://forum.xda-developers.com/attachment.php?attachmentid=1749676&stc=1&d=1361481339
Download NonOC for JB: http://forum.xda-developers.com/attachment.php?attachmentid=1749924&stc=1&d=1361487425
GCC:
Download OC for JB: http://forum.xda-developers.com/attachment.php?attachmentid=1749874&stc=1&d=1361486208
Download NonOC for JB:http://forum.xda-developers.com/attachment.php?attachmentid=1749918&stc=1&d=1361487092
broodKernel v1.4 OC & NonOC for ICS & JB Roms
Code:
- Tiny RCU
- SLUB Allocator
- OpenVPN Support (insmod tun.ko)
- 1.4GHz / 1.8GHz
- Forced "No JPEG compression" (HQ photo's)
- EGL Tweaks
- init.d support
Downloads
WARNING: The updated EGL Libs are for ICS Only!
Download NonOC for ICS: http://forum.xda-developers.com/attachment.php?attachmentid=1525742&d=1354323823
Download OC for ICS:http://forum.xda-developers.com/attachment.php?attachmentid=1525741&d=1354323823
Download NonOC for JB: http://forum.xda-developers.com/attachment.php?attachmentid=1526752&d=1354363552
Download OC for JB: http://forum.xda-developers.com/attachment.php?attachmentid=1526750&d=1354363552
Version 1.5 (Not compiled with Linaro, these are raw boot.img files, use my quick flasher to flash)
Download OC for ICS: http://forum.xda-developers.com/attachment.php?attachmentid=1586543&d=1356287288
Download OC for JB:http://forum.xda-developers.com/attachment.php?attachmentid=1586544&d=1356287288
GINGERBREAD KERNEL BELOW!
v1.3 ist nur für Gingerbread !!!​
Latest v1.3 build:
Additions including:
- 1.8GHz
- Governors: smartassV2 / minmax / interactiveX
- Schedulers:deadline / sio
- No JPEG compression (HQ photo's)
Download:
broodKernel-v1.3-Alpha.zip
Github:
https://github.com/broodplank/broodKernel-zImage
Installation: CWM!
broodKernel v1.3 Alpha, built from Samsung sources!
Features:
- Working Wifi (dhd.ko)
- Added Governor: smartassV2
- Added I/O Schedulers: sio/deadline
Installation:
Code:
1. Copy boot.img to adb.exe directory
2. Enter the following commands in cmd (in the directory of adb)
Code:
adb push boot.img /sdcard/boot.img
adb shell
su
dd if=/sdcard/boot.img of=/dev/block/mmcblk0p8
reboot
3. Or use my quick flasher!
Download:
broodKernelv1.3_fromsource.rar
or
OC/UV 1.8Ghz
broodKernel-v1.3-ocuv.rar
attachment.php
broodKernel v1.2
- Heavily tweaked KQI stock kernel -
Major changes since last release:
More management can be done trough init.d, I added a general broodKernel script and also a very extended screenstatescaling script with a lot of options (check them both out!) Also I made 3 versions of the kernel, they have different bootlogos, the other settings are identical
Info:
This kernel is based on the KQI stock kernel, and only has modifications in it's ramdisk, so the kernel will stay stock, but is heavily tweaked. I added Thunderbolt tweaks, GT-i8150 GPU Drivers, 2 init.d scripts (00broodkernel and 01screenstatescaling)
Features:
- Added Auto Mount
-- All partitions mounted in noatime / RW
-- Cache / Data & Persist mounted with barrier=0 / commit=60
- Added AOSP bootanimation library
- Added init.d Support (runs at the end of the boot process)
- Changed Kernel Security settings
-- ro.secure=0
-- ro.allow.mock.location=0
-- ro.debuggable=1
-- persist.service.adb.enable=1
- Adjusted Low Memory Killer
-- LMK 60MB Based
- Added build.prop Tweaks
-- Smoother GUI Tweak
-- Less Ringtone Delay
-- GPU Rendering
- Added IPv4 Tweaks
-- Changed Buffersizes
-- Tweaks in /sys/proc/net/core
-- Tweaks in /sys/proc/net/ipv4
- Added Touchscreen Tweaks
-- Sensitive touch
- Added Kernel Tweaks
- Added SD-Card Tweaks
- Added VM (writeout) Tweaks
- Added Zipalign
- Added Vacuum (sqlite_optimize)
- Added GT-i8150 GPU Drivers
- Added 00broodkernel in init.d:
-- Set I/O Scheduler
-- Set SDCard Readahead
-- Enable/Disable Error Reporting
-- Enable/Disable sysctl.conf file
- Added 01screenstatescaling in init.d:
-- Set Awake Governor & min/max freq
-- Set Sleep Governor & min/max freq
-- Enable/Disable Governor tweaks
-- Option to use 01screenstatescaling as the only cpu management source (disable init.qcom.post_boot.sh)
Installation:
1. Place the zip on your (internal) sdcard
2. Reboot in CWM Recovery
3. Install zip from sdcard
4. Install zip from (internal) sdcard
5. Choose broodKernel-v1.2-i9001.zip
6. Install
7. Enjoy!
Credits go to: pikachu01 and skywaker01 (Both are great devs!)
Github
Download Regular version:
This means it contains the normal i9001 bootlogo
n/a for download yet
Download "Finish" version: (Pre-Build, for testing)
Contains running android to finish bootlogo
Zippyshare.com - broodKernel-v1.2-i9001-TestBuild.zip
Download "AppleHaters" version:
Contains an android pissing on the Apple logo bootlogo
Reaktionen: GabrielS, wuppi1, SGS+_User und 2 andere
jetzt wird es langsam Zeit das der junge mal eine neue Version mit den letzten Kernel-Änderungen veröffentlicht. In sein Github tut sich seit der letzten Version bei den Kernel garnix :D
Flasher weist du vllt ob von Brood V1.8 OCUV für Gingebread auch Init.d unterstützt ?
Tut er.
Version 4.5 zum Download
v4.5
Changes:
http://forum.xda-developers.com/showpost.php?p=42560365&postcount=835
Startpost + links aktualisiert
This is the only 3.4.x kernel that works under JB 4.1.X afaik - I flashed it a few moments ago and now i load the akku to get more information about the power consumption....
Spaß beiseite - Also wie ich schon im CAF-Thread angedeutet habe, teste ich Ihn gerade. Läuft bis dato ganz fluffig - GPS fix recht fix - WLAN läuft - 2G/3G läßt sich schnell hin und her schalten -
Was bis dato nicht funzt (zumindest bei mir ;) ):
1 - Wifi - Tethering
2 - BLN
3 - PhantomKeypressFilter ist nicht implementiert
Schönen Abend noch
Rhonin
