Klarooo
Ehrenmitglied
- 22.978
AK.Kernel für AOSP/CM11/CM11s
Features:
Compiled with Toolchain 4.7.4 A15 Optimized
Linux 3.4.0
-O3 Optimized
Linaro Flags Optimized
Latest CM11 Bacon patches - updated to 27/08/2014
Universal Kernel Control Support
Synapse Enabled
Anykernel Ramdisk Format (Compatible with all ROMS)
F2FS Filesystem Support
Swappines Reduced to 10%
Freqs Table: 268Mhz <-> 2880Mhz
XZ Kernel Compression
Deadline, Row, Cfq, Bfqv7r5, Sio, Tripndroid, Fiops
Disabled IO Stats
Slim Governor, Interactive Pro, Smartmax, Smartmax Eps, Ondemand Eps
Conservative Gpu Governor
KCAL Control
Faux Voltage Control
Faux Sound Control
Cpuboost Enabled
Mpd Hotplug
Faux Intelli Hotplug
Aes and Sha1 Optimized
Fast Charge
Kexec Hardboot - Multirom
Ntfs Support
Sysinterface for enable/disable Gentle Fair Sleepers (Disabled by default)
CIFS Enabled
PowerSuspend Support
AUTO SMP (Simple and efficient multi-core cpu hotplug driver)
Latest Touch Firmware and Patches
File System sync on/off (Enabled by defualt)
ZRAM Support
Logcat on/off (Disabled by default)
Cpu Multicore Powersaving
Auto FS Laptop Mode on/off (Disabled by default)
SmartCover Support
KSM
Linux 3.4.0
-O3 Optimized
Synapse Enabled
Disabled IO Stats
KCAL Control
Faux Sound Control
Cpuboost Enabled
Mpd Hotplug
Fast Charge
Ntfs Support
CIFS Enabled
ZRAM Support
SmartCover Support
KSM
CM11 Kernel - getestet mit folgenden ROMs:
- pa
- slim
- slimdarkness
- madhi
- crdroid
- pac rom
- vanir
- Gummy Rom
- Mokee
- LiquidSmooth
- Slimsaber
- Miui
- cm11 Milestone
- cm11 Nightly
- DroidKang
- crDroid
CM11s Kernel - getestet mit folgenden ROMs:
- CM11s
CM12 Kernel - getestet mit folgenden ROMs:
- eigentlich alle CM12/5.0 die im Umlauf sind - keine Garantie.
Downloads:
Nightlys sind gekennzeichnet mit "_bxx" hinter Version
Klick
Installation:
- Recovery booten
- Kernel flashen
- Reboot
Bei Bedarf: UKM flashen + Synapse installieren
Download
Homepage: AK Kernel
Quelle: XDA
