[LP 5.0.2 Kernel 3.4.113][08 JAN] Dorimanx 12.0 LG G2 D800/1/2/5 LS/VS980
  • 216 Antworten
Ok, dann werde ich alles einleiten...
Reaktionen: smartpr1v4t3
Version 7.9 ist raus mit hauptsächlich Fixes und GPU Driver update.
So OP wurde aktualisiert, wenn wer noch was zu ergänzen hat gebt bescheid :)
Neueste Version 8.0.1
Neueste Version 8.2
Werde morgen den OP aktualisieren.
Version 8.4 ist heute erschienen.
Version 8.3 wurde als neuer Stable Release markiert.
8.3 lief bei mir nun eine Woche Fehlerfrei
8.4 läuft bei mir seit 4 Stunden auch ohne Probleme
Releases:
06/01/16
Kernel 8.4 IN TEST
*Merged updates to SIO I/O gov and its named now SIOPLUS!
*Merged updates to rbtree code.
*Merged massive update to SCHED CORE,FAIR,RT,TIME,CPUTIME,SMP
it's brings many bug fixes and performance vs battery save optimizations that hold CPU in idle when nothing to do,
with less spikes to higher freqs, and allow max performance when needed,
always considering the heat! that actually reduce performance.
*Merged updates to MMC code.
*Merged updates to power management code.
*Merged updates to Memory code.
Many ram leaks fixed in kernel drivers.
*Merged big update and bug fixes for workqueue code.
*Updated ToolChain with GCC 5.3 builder. + optimizations.
*Cleaned some junk fails and errors on boot in log. some fixed now,
some just removed as not exist in code from stock.
*Merged updates to memory group counter code. and enabled it for ROM.
*Merged updates to NET code to support new counter code and CGROUP updates.
*Merged updates to GPU sync driver and to ION CMA HEAP code, mem leaks fixed.
*Merged many updates to IRQ code that allow enable/disable IRQ's based on active cores and not just on core0,
by this improving performance of kernel tasks and drivers operations.
*Merged update to impuse cpu GOV.
*Merged updates to Suspend code to show more info about wakeup sources.
*Merged updates to RPM-SMD, and QMI drivers mostly bug fixes.
*Merged updates to ARM DMA driver and few other null pointer bug fixes.
*Updated busybox from source and build it with GCC 5.3 and optimized gcc flags.
*Cleaned some broken not existing commands from ramdisk boost scripts.
31/12/15
Kernel 8.3 STABLE
*Compressed kernel with better LZ4 compression.
*Fixed F2FS mount when Selinux enabled.
*Allowed better support for busybox functions when Selinux is enabled.
*Removed useless console drivers that never used.
*Changed kernel GCC optimization to increase performance.
*Merged updates to PROC FS code.
*Updated Busybox with latest updates and better GCC optimizations.
*Updated debug log script and Dori App XML descriptions + cleanups.
Reaktionen: Janity
Die 8.3 lief bei mir absolut fehlerfrei. Auch die 8.4 scheint bisher stabil zu laufen. Wesentlich besser als stock. Ich finde die Arbeit von dorimanx einfach super und das ach so alte g2 wird immer schneller und ausgereifter.
Da kann ich mir dir anschließen.
Unglaublich was er aus dem Teil holt. Die ersten Versionen waren etwas holprig aber nun laufen die Versionen einfach Klasse. Wenns nen Problem gibt wird es meist innerhalb von 24 Stunden gefixt. Dank ihm werd ich mir erst nen neues Gerät holen wenn er sich eines holt^^
Bearbeitet von: Janity - Grund: Direktzitat entfernt. Bitte Forenregeln beachten.
Update Auf Version 8.5
Version 8.4 Stable ;)
Keine neuen speziellen Features, hauptsächlich Optimierungen, Updates und Fixes
11/01/16
Kernel 8.5 IN TEST
*Merged many updates to workqueue code.
*Merged updates to USB and MTP code.
*Merged Memory, SLUB, PAGE ALLOC and UKSM critical updates.
*Merged ARM IRQ updates, many bugs fixed, and new optimizations added.
*Merged update to Alucard CPU gov.
*Merged updates to KGSL GPU driver.
*Merged updates to DMA and IOPOOL.
*Merged updates and optimizations to DEVRES, CMA and SLIM.
*Corrected debug log script to detect chargerlogo log, and tell user that it's useless for dev.
So, nach einiger Abstinenz teste ich mal die 8.4. Ist doch die letzte stable? Hab aber dieses Mal kein F2FS genommen. Ich hab vorhin gelesen man soll F2FS nicht zusammen mit SELinux nutzen. Das habe ich damals nicht deaktiviert. Ggf war ja dass das Problem.
Genau die 8.4 ist letzte Stable.
In der 8.4 Version wurde anscheinend die Thematik mit Selinux und F2FS behoben
Hat es aber noch nicht offiziell geschrieben da es vorher noch ein paar Leute testen sollen ;)
Ich werden F2FS seit 1 Jahr und hatte noch kein Problem, aber ohne SELinux halt
Na ich werde erst mal ein paar Tage den Dori ohne F2FS nutzen und schauen ob er stabil läuft oder die alten Probleme wieder auftreten. So kann ich ausschließen das es an F2FS liegt.
Bis jetzt (seit 1-2h) läuft er ganz gut. Hoffe es bleibt so :)
Hallo, ich bin nicht ganz unerfahren mit Modding und bla bla aber hoffe dennoch auf ein wenig Hilfe. :D
Wie flashe ich denn die Twrp von Blastagator? Ich habe gesucht aber nicht wirklich was gefunden, auch nicht in dem Thread. Oder macht es auch die Autorec vom Store wenn ich Root schon habe?
Und bringt der Kernel wirklich so viel? Ich bin eher ein gewöhnlicher Nutzer, gezockt wird damit wenig weil Konsole.
Und bevor ich den Bootloader und den Kernel flashe möchte ich das gerne backupen. Reicht das dann mit Twrp /boot zu backupen?
Wie gesagt ich bin kein dummer, musste auch vor 2 Tagen das komplette Display wechseln da kaputt. xD
Ich danke für evtl Hilfe. :)
Letzten Updates:
Derzeitig 8.7 in Verwendung und kein Problem
20/01/16
Kernel 8.7 BETA
*Merged updates to FS Proc, Memory, and cpumask.
*Merged big update to Lib Bitmaps from 4.5.y source.!
Used in every driver, for every printing info function and other common stuff.
*Merged more fixes to F2FS driver. now it's considered STABLE by Linux foundation.
*Merged updates to ZRAM from 4.5.y
*Merged HUGE updates to Network code, many optimizations in buffer driver and his friends.
*Reduced max CPU heat on boot, to allow some devices to boot safely.
*Reverted change to RMNET that seems to crash on workqueue process.
*Merged updates to RPM-SMD that allow to use much better way to communicate with modem and other drivers.
*Merged big update to IDR code that used in every driver in kernel + converted old IDR to new API
And removed old bugged IDR code as done in 4.5.y!
*Included NEW Dorimanx App made by @Krija looks great. big thanks for this update.
17/01/16
Kernel 8.6 MEGA BETA (stable 90%)
*Merged massive update to base regmap driver that used by other drivers.
full sync with 3.10.y source.
*Merged updates to ARM code, including mem leak fixes, many bug fixes, optimizations, cleanups!
*Merged many updates to FS,SHCED CORE,RCU,OOM,DMA, and other global and common functions.
*Merged updates to MMC,CRYPTO,ION, and massive update to ADSPRPC (modem driver and sound soc).
*Merged updates to SCM, and massive update to USB driver including OTG and MTP + MIDI out updates.
*Merged updates to LIB,KEYS,PRINTK,EXT4,FAT,CPUIDLE,SYS and other critical fixes for CPU core.
*Merged massive update to memory code from 3.10.y and upstream code aurora updates backported from 4.5.y
Including many optimizations, bug fixes, and new ways to speedup kernel functions that work with RAM.
*Merged update to COMPILER defines and optimizations to get more stable kernel made by GCC compiler.
*Merged many updates to NET,RPM SMD,SPI,BUSPM,MSM_BUS, and other mods belong to network and kernel to ROM API's.
*Merged updates to timekeeping,net unix, cleanups in ARM code to release lost ram regions.
*Merged update to Alucard hotplug from DEV.
*Merged latest updates to ZRAM from 4.5.y kernel that include critical bug fixes with memory and IO allocation.
*Merged MASSIVE update to F2FS driver! all from latest 4.5.y kernel branch about 97 commits! + all needed changes
in global kernel code that lead to optimizations in many functions.
*Merged latest updated from CM13 and Aurora 3.4.y kernels, including updates to RMNET(data connection), USB, and ARM updates.
*Merged update to cron script that allow to use cron tasks with user timezone! and not UTC.
[doublepost=1453555780,1453555425][/doublepost]
Also, wenn du noch gar kein TWRP drauf hast (wie ich lese hast du dies aber bereits ;)) dann am besten den Thread suchen wie man das Handy rootet und ein Recovery installiert.
Solltest du bereits das normale TWRP als Recovery haben, dann einfach das Zip vom Blastagator Recovery herunterladen und im TWRP installieren.
Nach der Installation Handy neubooten oder neu ins Recovery booten.
Ich empfehle dir ein komplettes Backup vom Handy zu machen (nicht nur boot) und am PC zu sichern bevor du überhaupt etwas anderes machst ;)
Wo genau der Bootloader drinnen ist kann ich dir nicht 100% sagen müsste aber Boot sein.
Zum Kernel, ich würde Lollipop selbst nicht verwenden ohne den Kernel.
Dorimanx Kernel hat nichts mehr mit dem Originalen zu tuhen und ist ziemlich stark modifiziert und optimiert worden.
Reaktionen: Janity
Nein habe noch gar kein Rec drauf deswegen frage ich ja. :D
Ob das Ding aus dem Store völlig zureicht oder wie ich gleich die Blastagator flashen kann. Bei dem Huawei Y300 (ja nothandy xD) ging es mit fastboot flash gedöns im Cmd. Das finde ich nur nirgends. Nur was gefunden mit Loki.
Ps: Deathnote ist gut, aber die letzen Folgen haben sich gezogen ^^
Ich nochmal. Habe root, rec und den Kernel installiert bekommen.
Was mir nur auffällt das die Option "Cron" nicht funktioniert bei mir. Der Service ist online und wird auch supported wenn ich Test drücke aber machen tut er dennoch nichts. Wenn ich ganz unten auf "Test Cron Task Jobs" klicke kommt 5x "no data". Und ja Internet ist aktiv auch wenn das nicht mit allem zu tun hat.
Habe auch bis heute gewartet ob er wie erwartet Nachts den Cache löscht, tut er aber nicht.
Hat jemand eine Idee? Danke.
Stock LP 30d und Kernel 8.5
MMh ist komisch, also ich habe nun den letzten Kernel drauf 8.8 und da läuft alles ohne Probleme.
Wenn ich auf Test Cron Jobs gehe kommen die Zeiten wann diese das letzte mal ausgelöst wurden.
Ich würde empfehlen mit der Dorimanx OTA App den 8.8 Kernel einmal zu flashen und sehen ob es dann klappt.
Weiters kannst du alles zurücksetzen, vielleicht hilft das.
Das machst du am besten mit der OTA App. Gehst in Einstellungen und unter andere Optionen oben die 2 Häckchen setzen.
Reset Config und Delete .dori folder
Wichtig ist auch nach dem Handy start die Dorimanx App nicht direkt öffnen, erst 1-2 Minuten warten. In dieser Zeit werden die Einstellungen des Kernels
geladen und wenn man die App öffnet kann es sein das er die Einstellungen falsch setzt.
8.7 ist neuer Stable Kernel
Update Kernel:
24/01/16
Kernel 8.8 BETA!
*Merged Selinux updates and fixes.
*Merged updates to Memory process reclaim, now less aggressive and less CPU power used.
this lead to less heat and more battery save. ram is still managed as should.
*Merged updates to FS and MM to improve global kernel performance.
*Merged updates to KEYS code including vulnerability fix that can crash kernel by using loop
script to drain all RAM. and many other fixes added from 3.10.y source.
*Merged updates to Camera driver, only few critical memory leaks and buffers crash fixes.
camera driver should be much more stable now. no quality changes!
*Merged new update to Dorimanx APP by @krija big thanks for fast corrections!
*Merged updates to EXT4 and USB drivers from 3.10.95 kernel patch!
*Merged log cleanup for NET IPV6 code.
*Updated Busybox with latest source code updates. compiled with GCC 5.3 by me.
*Merged spelling and grammar updates to Dorimanx APP config XML. came from users that wish to help!
PS: DeathNote ist Top :D müsste eigentlich meiner Erinnerungen wieder mal aufrischen :)
Ja gut dann flashe ich mir später mal die 8.7
PS: Ist's auch keine Frage, aber meiner Meinung sind halt die letzten Folgen nicht die Krönung. Ist aber auch schon eine ganze Weile her wo ich des geschaut habe. xD
Letztes Update Release Version 9
Hab ich selbst nun seit 8. Feb drauf und noch kein einziges Problem festgestellt
9.1 soll demnächst folgen
08/02/16
Kernel 9.0 BETA!
*Merged updates to NET code.
*Merged updates to Alucard HotPlug by DEV.
*Merged updates to Alucard,Nightmare CPU govs by DEV.
*Merged updates to sound,usb,hid from patch 3.10.96
*Merged updates to LIB drivers, many changes that change the way code is made and operate.
*Merged updates to Crypto drivers, many new crypto features and performance boost.
*Merged updates to random32,radix-tree and genalloc.
*Merged updates to LZ4 compression driver.
*Merged updates to QSEECOM,Android-Alarm and camera VIDC.
*Merged many changes to ARM LIB code. this boost performance and correct memory distribution.
*Merged fix for Selinux driver.
*Updated GCC 5.3 toolchain with latest binutils and other libs, and used to compile kernel.
*Enabled encryptfs and set all needed to allow DATA encryption when using EXT4! will not work for F2FS!!!
*Merged updates to SCHED CORE,FAIR and NOOP I/O Sched.
*Merged fix for serial tty used for BT connections.
*Merged fixes for ratelimit and llist code. some are critical!
*Added new tuning in Dorimanx App for HotPlug sample rate.
it's best to sync with CPU gov sample rate! but if you feel performance drop,
feel free to set it to 10 samples. this was the default.
*Disabled UKSM by default, this driver is helping to save 25MB or little more, but drain power.
so it's should be used only if you think you need that 25mb for one small app in ram.
*Added FSTRIM crontab option, disabled by default. will run FSTRIM on system/data/cache at 22:00 every day.
*Fixed CRON service OFF/ON and other scripts belong to CRON, there was some mess
now all good.
*Updated BUSYBOX with latest changes from busybox source!
*Fixed AD UPDATE script that run every SAT, now it's will work as should. it's was missing connection and fail.
Now it's will try to connect to internet longer...
*Changed OOM profile to STOCK, it's work good for me for 2 weeks now. and i have free RAM for my needs.
*Updated DEBUG script to include also live dmesg log that written to /data/logging/ all the time by ROM.
So i will have more bigger picture what happened before device crashed.
*Profiles will be RESET on first boot!!!
26/01/16
Kernel 8.9 STABLE!
*Merged critical fixes for ZMALLOC for ZRAM.
*Fixed Process Reclaim code, now releasing RAM as should.
*Merged fix for FUSE driver.
*Added new sysfs for checking ram pressure for LMK and Process Reclaim
And added them to SYNAPSE status page. now you can see your RAM pressure
*Added new CRON task to clear RAM cache from apps only! every 2 hours.
This will help to get smooth and stable device for longer time.
The option will not kill any apps from RAM, it's just strip cached RAM
by them. so other apps that running for you right now, will run faster.
*Fixed CRON timezone script, and fixed few small bugs in scripts.
*Merged updates to ramdisk and init from D802H stock kernel for D802 build only.
Hab die 9 auch seit 8. Feb drauf und mich erstaunt immer wieder was das Telefon noch für kleine Sprünge schafft. :D
Bugs habe ich dennoch:
*Dorimanx Tweaks hat selten ein FC wenn ich öffne.
*Cron Task will immer noch nicht wie ich es will.
*Ich habe Verzögerung bei Push Notification, generell nur WhatsApp. Das lief mit 8.5 noch smooth. Manchmal kommt die Notification nur wenn Display aktiv. Ist zwar eher selten dennoch manchmal nervig da ich viel schreibe. Auch mit der neuen WA Version hatte ich das schon. Habe schon 3x Wipe Dalvik und Cache ausprobiert im TWRP. Max Screen Off ist auf 1,7 Ghz.
Betrifft das nur mich? xD
Schön wenn sich auch wer anders in dem Thread zu Wort meldet. Mir kommt oft vor ich mach das nur noch für mich xD
Den FC habe ich auch ab und zu direkt beim Öffnen erscheint der, ist aber eher selten.
Hast du zufällig auch Busybox installiert? Sollte man aufjedenfall deinstallieren mit dem Kernel vlt liegt es daran?
Bei mir funktionieren die ohne Probleme.
Das mit WhatsApp dürfte nur bei dir sein, kann das Problem nicht feststellen hast du Greenify oder irgendwelche Task Manager installiert?
An den ScreenOff einstellungen sollte es nicht liegen.
Ich selbst habe gestern mal mein System neu installiert wegen Viper4Android bereinigung.
Kannst ansonsten ja mal machen sollte ja nichts verloren gehen solange du Data nicht wipest.
Habe ich wie folgt gemacht:
Backup ;)
Wipe System, cache, dalvik
cloudy 3.3 (oder rom) installieren
install bootloader
install kernel
install xposed
Das wars und es lief wieder alles wie gewünscht.
Bzgl. Settings, habe jetzt seit 2 tagen die Einstellunge immer 2 Cores Online aktiviert und alle 4 Kerne auf 1,7Ghz begrent.
Hotplug Alucard und Govenor Alucard. Touchboost disabled.
Smartphone läuft noch immer total flüssig und der Akku hält etwas länger. Muss ich aber noch länger testen um es sicher sagen zu können.
ich bin auch begeistern von dem Smartphone, für mich die beste Investition in ein Gerät.
Muss aber auch sagen dank Dorimanx, ohne dem kernel und LP 5.0.2 wärs ne andere Geschichte.
Er hat eh schon angekündigt er wird sich das LG G5 vermutlich holen, denke da werde ich dann gleichziehen ;)
