[KK 4.4.2 Kernel 3.4.104][15 MAI] Dorimanx 10.5 LG G2 D801/2/3/4/5/6
  • 201 Antworten
Bellitsch89
Bellitsch89
Enthusiast
870
Original Thread: [KK 4.4.2 Kernel 3.4.104][14 NOV] Dorimanx 8.9 LG G2 800/1/2/3/5/6 F320* LS/VS980
Dorimanx LG G2 Kernel for STOCK 4.4.2 Branches!
Stable Only For:
D800/1/2/3/5/6 Models!
F320* Models!
LS/VS980 Models!
images
My PM box, is for Emergency ONLY! do not send me PM's just because you cant post! that is lame, post something useful and post in thread.
IF you need answers to QUESTIONS not belong to Development???
GO HERE! Q&A THREAD!
images
My kernel was based on LG G2 Stock Kernel v20*/21*.
Kernel Tree is 3.4.104, + LG KitKat updates + my tweaks and lots of tuning!
Global Credits!
Big thanks to g.lewarne for helping me to start!
Savoca for many kernel mods
Cyanogen (rmcc@github) for many kernel mods
Faux123 for UV/OV, Sound Gain Control, Inteli Hotplug, Fast Charge support! and more!
Alucard_24 for AlucardHotplug and mods.
LG for Stock kernel base!
MyFluxi for kernel updates and fixes.
To all my sources in GITHUB!
Linus Torvalds for Linux source!
WHAT INSIDE:
  • Default I/O Scheduling: ROW.
  • More I/O Scheduling present in kernel: DEADLINE, NOOP, CFQ, SIO, BFQ.
  • Default CPU frequency: 300-2803 MHz (MAX OC up to 2.8Ghz speed!).
  • You can set MIN/MAX CPU Freq in CPU tuning apps.
  • You can set MAX freq for screen OFF state!
  • Default CPU governor: Ondemand.
  • More CPU Govs present, conservative, performance, Intelidemand, OndemandPlus, Nightmare, Hyper, Pegasusq, IntelliActive, Alucard.
  • Support for Kernel HOTPLUG (Intelli HotPlug by @faux123)
  • Support for Kernel HOTPLUG (Alucard HotPlug by @alucard_24)
  • Support for Kernel HOTPLUG (MSM HotPlug by @myfluxi)
  • Support Inteli CPU Temp control (by @faux123)
  • Support for Touch BOOST CPU'S code (by @alucard_24)
  • Support for Async CPU, every core can have it's own min/max + cpu governor! (by @alucard_24)
  • Support 4 GPU Govs! + Tuning in STweaks. (by @myfluxi)
  • Support limit OC to 2.3Ghz / 2.5Ghz / 2.7Ghz / 2.8Ghz (by @faux123)
  • Support undervolt/overvolting via sysfs interface/apps interface (by @faux123).
  • Support using phone as keyboard and mouse for PC over USB! (by @pelya)
  • You will need APP USB Keyboard! also to enable USB keyboard in STweaks.
  • CIFS network share mounting supported.
  • Debugging is OFF by Default to save CPU cycles, and extend battery life.
  • Internal kernel function fixes (ie, memory leaks, scheduler fixes).
  • High performance, low latency kernel.
  • Compiled with -O2 flags and hardware neon-vfpv4 FPU enabled.
  • Built from official LG v20d/v20E/v20f/v20u/v21p kernel source.
  • Lokified during flash! Suport ONLY JB BootLoaders!
  • File systems support: Ext2/3/4, FAT32, CIFS, USB OTG.
  • Support F2FS filesystem! but will not auto mount it on boot for now.
  • EXFAT, NTFS supported but need USB OTG APP! it's not native!
  • WIFI Driver 1.88.60 + Many updates.
  • Sound Driver Control (Headphones Gain) use Faux Sound App.
  • Sound Driver Controls for MIC/Speaker Gain via STweaks APP.
  • Always forced fast charge! no matter what you select in ROM.
  • Sweep2Sleep! allow sweeping from right to left and backwards! on soft buttons to turn off the screen.
  • Kernel created using Linaro 2014.08 compiled by me, powerful ToolChain GCC 4.9.2 + all needed mods for it.
  • Running Scripts from /system/etc/init.d/ is SUPPORTED but OFF in STweaks! if you need it, enable.
  • STweaks Kernel Control App will be installed with kernel.
  • Synapse Kernel Control/Status App will be installed with kernel.
  • Support JDI and LGD Screen types by Auto! (by @dr87)
  • Added UltraSound high performance audio hardware support.
  • Added USB SmartCard Driver.
  • Added support for MultiROM kexec-hardboot! (by patrik.KT )
  • Added support for relaxed CPU idle functions to save power.
  • Added support for USB PPP Simple modems.
  • Added support for USB to Serial adapter. (module).
  • Added Auto F2FS Mount on boot for /system /data /cache if formatted as F2FS.
Known BUGS!
*If you loose ROOT. install via recovery SuperSU 2.02 or newer.
http://download.chainfire.eu/452/SuperSU/UPDATE-SuperSU-v2.02.zip
Post reports, i will fix.
Standard disclaimer:
By installing this kernel YOU will take full responsibility for any damage to your device!
Hardware or software! no one forcing you to install it.
So please do not blame me if you read wrong! or didn't read at all the instructions that i have written for YOU.
But you can feel SAFE to use it, as I test every release on my phone!
Before I publish it for download.
Your warranty will be void by installing custom kernel as my.
This kernel will ROOT ADB Shell!
Global Info About LG Models:
D800 = AT&T Model (Support KNOCK CODE from base 20u)
D801 = US Tmobile Model (Support KNOCK CODE from base 20e)
D802 = International Model (Support KNOCK CODE from base 20b or 20d)
D803 = Canada Model (Support KNOCK CODE from base 20f)
F320* = Korean Model (Support KNOCK CODE from base 21p)
D805 + D806 (same as D802) (Support KNOCK CODE from base 20b or 20d)
LS980 = SPR Model (Sprint) (support KNOCK CODE from base ZVD)
VS980 = VZW Model (Verizon) (support KNOCK CODE by ME!)
if your ROM base is BELOW the Knock Code Base for your model!
use OLD NO KNOCK CODE kernel. or Update your ROM.
Kernel Sources:
KERNEL GITHUB
RAMDISK GITHUB
TO DOWNLOAD GO DOWN!!! YES MORE DOWN...(do i need to repeat?)
How To Install:
You will need to have ROOTED device with Recovery installed!
Refer to other threads for recovery install process.
Download kernel, upload it to your SDCARD, anywhere.
Download STOCK Kernel for your device!
so you will always have it on sdcard in case of any disaster!!!
Reboot to Recovery.
Install kernel as you installed ROM or any mod.
Reboot! :)
In case that you stuck on boot logo and want to revert to STOCK kernel.
Connect USB Push PWR + Vol Down till phone reboot and you will see LG Logo!
Release and press the buttons again! till you see screen asking if you want to WIPE your device!
if you have recovery installed, then it's will just OPEN the recovery! no WIPE will happen!!!
Just push 3 time the PWR key. and you will be moved to recovery.
Install your device STOCK kernel and wait for FIX.
Have Fun and report.
INFO FOR USER!!! READ ME FIRST:
LG has started to update all ROM + Kernels with new TOUCH SCREEN DRIVER.
that includes new feature "KNOCK CODE" see youtube!
For now only for D800/D801/D802/D803/F320/LS/VS980 ROMS that have 20B/D/E/F/U/21P/ZVD base!
In download site, you will see kernels with normal version just numbers.
And kernels with "No-Knock-Code" labels.
If your ROM do not support KNOCK CODE on screen OFF!
Then use kernel without support for it!
or you will loose the ability to wake phone with KNOCK KNOCK gesture.
If knock code on screen OFF is supported use the normal build.
Soon all ROMS will have support! all depend on LG and our great ROM Devs.
*About force fast charge. not all devices/models support that HACK.
so if it's not working for you and you are using DEFAULT profile in STweaks.
Then it's NOT WORKING FOR YOU. no need to complain. it's HACK. not LG feature.
If you cant make KNOCK ON to work! visit this site and do all steps till you get it working!
LINK TO KNOCK ON FIX GUIDE
Donation Board:
  • Meanmike (serious donation!)
  • P_Toti X4
  • Wimmme X2
  • Androloid X2
  • Pitsgraft X2
  • Praveen6585
  • Flintoast
  • Iall5tar
  • Slebit
  • Osmosizzz
  • Joschi 744
  • Diechel
  • Citytrader
  • Asalvi0
  • Europizza
  • Desireaftergod
  • Tanoxxx
  • Blackline2008
  • 60nine
  • Maxq1
  • Zone23
  • Sqlpro
  • Emil_b
  • Detzero
  • Mehmet184
  • Cortex69
  • Ygrec
  • Pendroz
  • Garfield3333
  • Ati75
  • Madmax916sps
  • Titchener17
  • Yoyo117
  • Maxximo88
  • Steephig
  • Bender_007
  • Fire3d
  • TheFerhatKing
  • ForeverYoung_ru
  • Dick Gordon
  • Iko11
  • South956
  • Tarkil
  • RoboMr.Burns
  • Ghoulie
  • Alex1690
  • Xpiatio
  • Naomi G. (guest) X2
  • Luiz S. (guest)
  • Ben P. (guest)
  • Arkadiy Y. (guest)
  • Josue S. (guest)
  • Aloys G. (guest)
  • Bjorn S. (guest)
  • BIANCHI A. (guest)
  • Brian E. (guest)
  • Andrea M. (guest)
  • Krzysztof B.(guest)
  • German H. (guest)
  • Alejandro V. (guest)
  • Anton P. (guest)
  • Christian S. (guest)
  • Jessica F. (guest)
  • Sascha B. (guest)
First banners (user/Contributor) made by @coowkeee
Contributor banner is for people that feel they really made a contribution to any of my kernels! :)
You can use Power USER banner if you wish :)
Mirror #1 by Bmbm
Mirror #2 by willflint
Info for Web Hackers,
in my mirrors, there is nothing to take!
My work is public and for the people!
Please let my mirrors work in peace.
Thanks.
Before you Install
Check WHAT model you have downloaded!!!.
Best to use OTA APP by @Diechel
Get it in Google Play
Mirror #1
Mirror #2
Change logs:
07/05/15
Kernel 10.5
*Merged NET fixes from aurora
*Merged Selinux updates and fixed broken sysfs perms, seems like long time was broken!
*Merged MDSS and NET mods from LP source.
*Fixed old mess in sound driver, and merged mods from LP kernel.
*Merged updates to all Alucards CPU govs (alucard,nightmare,darkness) optimizations.
*Restored USB SOUND drivers, and merged LP source updates for USB SOUND.
need to check USB headphones and digital DECK sound stream.
*Merged MEM patches from LP source.
*Fixed all hotplug drivers to set all cores to sleep when entering suspend.
before there was BUG and all cores where ONLINE!
*Merged updates to SHA256/EAS ARm NEON crypto code.
Enabled all ARM NEON optimization drivers! (SHA1/AES 256/512)
*Enabled missing crypto drivers for encryption. need to test!
Older Changelogs:
02/05/15
Kernel 10.4
*Merged updates to Selinux code.
*Fixed BT HD Voice for BT headsets.
*Merged fix for lowmemkill that allow to load more apps to RAM before low mem reached.
*Fixed USB core code, now OTG mouse will work, and many other devices.
*Merged updates to Nightmare, Alucard, Darkness CPU govs, and alucard hotplug from DEV.
many code optimizations and cleanups.
*Merged driver updates from aurora to DIAG,WIFI,QCEDEV,MMC,ARM,USB
*Fixed Force Fast driver code error.
*Merged updates to GPU ION code, and merged GPU fixes from LP kernel source!
*Set ZEN as sleep I/O gov.
*Set nightmare cpu gov on 2 last cores in performance profile.
*Fixed few bugs in boot scripts.
*Fixed busybox install on boot, now it's will clean USER/ROM mistakes.
no more problems about STweaks not running.
24/04/15
Kernel 10.3
*Merged patch 3.4.107 huge update to many drivers and major code. see GIT.
*Merged updates and fixes to SELINUX code.
*When i was updating LP kernel, i have found some errors i made in KK! and fixed that!
in LP branch and KK. also ported few good fixes from LP source made by LG!
*Enabled USB3 support. to allow faster file transfer, and faster charge from USB3.
*Merged fixes to touch boost driver by @Alucard_24.
*Merged code changes for L01F to allow to use KNOCK CODE ROM for L01F.
added full build for L01F and to official NO Knock code.
*Merged fix for mem leak, and qseccom driver and NET LLC fix.
*Corrected ZEN as default I/O on boot.
*Set NET congestion protocol to BIC for F320,L01F,VS980 as with LG stock config.
for others its CUBIC.
have fun testing this build.
it's stable and very battery saving in suspend, it's idling on -10~-5ma thats impossible with any smart phone! :)
without my kernel! :)
14/4/15
Kernel 10.2
BETAS 10.1.1 --> 10.1.5
*Replaced sepolicy for f2fs, now we using the LG original with mod for f2fs only. was CM11 binary.
*Set boot scripts to use fstab to mount data or system or both as f2fs in case they formatted as f2fs.
*Fixed bug in boot script that was braking STweaks load in case user set not to load settings on boot.
*Merged fixes and optimizations to Alucard cpu gov and hotplug. and to Nightmare Cpu gov.
*Tuned Alucard and Nightmare CPU govs for response and idle low drain.
*Merged few fixes for SPS driver in MSM code. (Smart-Peripheral-Switch)
*Fixed System not RO when not needed and not RW when needed... was mess there.
*Fixed installing kernel when your system/data is F2FS.
*Updated busybox 1.24.1 from source + Android NDK patches and fixes.
*Added new STweaks sound control: INCALL Speaker gain! now we can boost the incall volume. not depending on headphones gain.
READ the control description before asking!
*Fixed hotplugs switch function, now works as should. in some cases cores where STUCK ONLINE when switching hotplugs.
*Merged new I/O sched. "ZEN" it's fast and tuned for Android SSD storage.
*Disabled hidden bricked hotplug driver, it's needs to be fixed before use. no point to leave it in RAM.
*Alucard optimized all his CPU govs and his Hotplug driver + tuning by me.
*Reverted one change in GPU driver that seems was the scrolling delay bug. we have more gpu steps than default driver.
*Boosted GPU 100Mhz step with higher bus freq. to reduce small lags when min gpu freq is 100mhz.
*Fixed bug with stuck cores when switching hotplugs. added small delay from one to other and cores off function.
Now works as should. very old bug.
*Changed vol to gain descriptions in STweaks XML for sound control.
*Added new Advanced Color interface + App (color control) by @savoca great stuff!
when i have set saturation to 50 inside app, i have finally seen true awesomeness of my screen!
*Updated Intelligent Thermal driver, to use global freq control functions, and clean old deprecated code!
*Fixed LOAD ALL button in STweaks.
*Merged new STweaks app compiled by @krija now it's called DORIMANX simple as that.
*Set ZEN I/O driver as default in all profiles and on boot.
*Merged updates to SPI, SOUND, NET, BAM_DMUX, RQ-STATS drivers.
*Merged updates to Interactive CPU GOV.
*Merged updates to MSM CPUFREQ code including better Power Management code.
reduced deepsleep power use to -5ma!!!
*Merged updates to Alucard Hotplug by DEV.
*Fixed code bugs and disable 2 useless debug logs that no one need.
*Added more checks to charger driver for releasing charger wakelock when no power connected!
*Added boost to I/O using less merge checks and allowed to use different CPUs to finish I/O tasks.
*Fixed small bugs in boot scripts.
NEW changes!
*Merged updates to EXFAT driver.
*Merged better idle dynticks code for fast CPU idling when system is not loaded.
Should save more power.
*Disabled some encrypt custom ARM drivers to be able to use STOCK encryption.
*Merged update to Touch Boost Driver by Alucard.
24/3/15
Kernel 10.1
*Fixed sound gain controls for faux sound app if used.
*Merged code fixes found by arm-eabi-5.0 compiler by google.
*Merged MMC code update.
*Merged MDSS code update.
*Merged fix for input code.
*Merged fix for modem driver packet sync loss.
*Fixed mounting all partitions with F2FS. Final solution that works 100%
We are using CM11 Sepolicy for Selinux modded by me for LG G2 needs.
*Set System Partition to RO when no one need it to be RW. this give as small read speed boost.
*Corrected mirror scripts to fix OTA App version order. thanks to @Computoncio
18/3/15
Kernel 10.0
*Fixed GPU freq steps. now will save more power by working on lower step when no high gpu load.
*Fixed GPU freq stuck after long high load usage and high heat. freq was stuck on 0 freq. and device will reboot
soon or later. not any more!
*Merged big update to GPU driver that allow to reduce RAM use by GPU without any effect, now we can beat any LG G2 average GPU score.
and that not just a score. it's real noticeable performance boost with lower heat from chip.
*Merged many sound driver updates including critical memory corruption fixes.
*Merged new cpu hotplug driver. that needs to be improved and adapted to my kernel. for now it's OFF and cant be selected.
*Merged update to Rmutex code that speedup the code execution.
*Merged FS updates and crypto driver fix.
*Merged latest updates to F2FS driver.
*Merged update to netfilter code.
*Merged new STweaks with great look modded by @krija great work! thanks!
*Created with new LINARO 2015.03 kernel builder GCC.
*Cleaned Synapse controls. now we have MONITOR + basic options in ONE tab. + highlights for titles.
*Merged ARM fixes from Aurora 3.5.y kernel updates.
*Merged power usage reduce code for diagnostic driver.
*Merged fix for CORE power usage in suspend. now less power used in suspend.
*Moved all Sound Gain controls to STweaks! + fixes to PA Gain Control.
Now we can select what app we want to use for sound control.
STweaks (by default) OR Faux Sound. WIN/WIN
*Merged NET updates from Aurora.
*Merged fixes for in kernel Modem driver.
*Merged big update to power charger code from Aurora 3.5.y kernel.
This allow more control of charge by kernel, so battery not get any more power than 100%. so it's prolong battery life.
Also many code fixes and optimizations that may fix wakelocks and other strange stuff that we see in thread sometimes.
*Allowed to kill CROND service.
*Merged updates to MEM code and to lowmemkiller debug code.
*Added 499Mhz CPU freq to enabled freqs. seems to work just fine.
*Fixed LGE Charging scenario wakelock stuck sometimes and preventing deepsleep. now released.
*Fixed MIN CPU Freq reset to 300mhz in some conditions. now will stick to user select.
*Updated all hotplugs drivers and cpu freq limiter with bug fixes.
*Merged updates to Alucard CPU gov and Hotplug from DEV.
*Merged Updated Synapse App by @krija no more popups at start.
*Merged RAM code updates.
*Fixed bugs in boot scripts.
*Fixed F2FS mounting on boot. we must use SeLinux Permissive to boot.
Now it's will auto set to permissive in case we have F2FS partition.
10/2/15
Kernel 9.9
*Major update to kernel locking and mutex code. from 3.14.y stable.
every driver in kernel using this code to work, so it's effect every thing!
*Updates to WIFI to reduce power usage when device in suspend and WIFI ON.
*Updates to RAM code and FS.
*Fixed YankActive CPU Gov. now stable.
*Merged updates to Interactive and Intelliactive CPU Govs.
*Merged updates to USB code and to charger code.
*Merged updates to sound driver code.
*Merged updates to KGSL (GPU) driver code.
*Merged code that allow mounting ISO images as CDROM using app.
*Merged new STweaks app with color mods.
*Rebuild Busybox 1.24.0 + new patches compiled with Android SDK R10D
Now all commands works as expected.
*Fixed bugs on boot with broken STweaks config. Now all load as should.
*Fixed broken min core online set after boot.
*Fixed crond get killed on boot. now works and as root service.
*Small mods to STweaks XML.
*Fixed F2FS partition mounting scripts. (need more work! not booting!)
*Merged sound driver update. for all music lovers! get ready to say WOW!!!
Powerful volume and clearance. Free in ear massage on me!
*Merged Patch 3.4.106 that include TONS of good stuff across many drivers see GIT!
*Fixed warning on suspend with unbalanced IRQ.
*Fixed FM Radio for LS980 model.
*Fixed Nightmare GOV. + tuning.
*Merged updates to SELinux, USB, Regulator, CPUFREQ, WIFI, NET
*Merged IMPULSE CPU Gov. It's based on Interactive but tuned differently.
*Fixed HeadPhones PA Gain (Analog Sound volume booster) now can be controlled via STweaks,
has 2 mods! locked! then it's ON! cant be changed high/low
Unlocked, can be changed high/low ONLY by some ROMS/Devices!!! if you have no effect! set the LOCK back.
and leave it alone.
*Merged VS980 27A LG Source updates to kernel and to ramdisk.
*Updated Interactive + YankActive + IntelliActive from IMPULSE CPU Gov.
*Many merges for sound driver fixes and noise/mic fixes.
26/1/15
Kernel 9.8
*Created using New LINARO 2015.01 kernel builder.
*Merged new updated STweaks by @krija, @Kryten2k35 big thanks for rebuild.
*Merged new CPU GOV, YankActive it's modified interactive, good for battery save, bad for games. (low FPS)
*Merged MEM,MSM,CPUFREQ,F2FS,FS updates.
*Merged new LG LP F320K source updates for now only common good to use code for 4.4.2 ROM.
updates to: MMC, BT, SOUND, NET, SLIMBUS, STAGING, Thermal, Vibrate, Power, base, OF, USB
*Allowed to use 2000ma charge max in force fast charge code. default is 1600 as was.
*Merged GCC Optimization by the book.
19/1/15
Kernel 9.7.1
*Fix Modem/SIM detect for LS/VS980 Models. others have no effect.
18/1/15
Kernel 9.7
*Rebuild LINARO 2014.12 with latest libs and optimized for more build options. (using to build busybox)
*Updated Kernel Busybox to 1.24.0 from source, optimized for my kernel needs.
*Merged updates to sound driver.
*Merged updates to crypto driver.
*Merged updates to ARM, QsecCom
*Merged updates to Camera, LCD Panel, WIFI, Thermal, Binder from 3.10.y
*Merged updates to Memory, CPU, MMC, SCHED, SeLinux
*Added old Busybox cleanup on boot, and add Busybox version show to Synapse.
09/1/15
Kernel 9.6
*Upgraded LINARO kernel builder to 2014.12 + latest GLIBS,C++,LD,Gold addons. and more.
*Merged fix for CPU code that fix possible kernel panic.
*Merged fix for RAM code.
*Fixed stuck PA HeadPhone gain in OFF mode (-6) now speaker and headphones sound is LOUD as should be.
also this fix hissing sounds, should be clean now.
*Added HighSpeed congestion TCP protocol. by request, see GOOGLE.
*Allowed to use low max freq on suspend, min 1Ghz.
*Tuned all profiles with hotplug suspend ON. to reduce power use, see GIT for more changes.
Profile will be RESET on first boot. so change what you like after boot. (take 1min delay before changes!)
31/12/14
Kernel 9.5
*Merged sound driver updates/bug fixes
*Cleaned and fixed Intellimm CPU gov.
*Merged updates to slimbus driver.
*Merged update to BFQ I/O sched v7r7
*Merged fix for main boot code.
*Merged fix for regulator code.
*Merged fix for default LG Hotplug support code.
20/12/14
Kernel 9.4
*Restored lost updates/fixes to core/security/fs/selinux/block
When i was hunting for SOD bug, i had to revert patches to narrow the SOD to box,
and squashed it with big hammer in MMC code!
Now i can restore good stuff back.
*Fixed oldest bug ever from LG source. now all good. (MMC queue code see git)
*Merged Samsung stock patch to: WIFI, TIME, BT, AUDIT, USB, NET all good for us too.
*Cleaned not needed kernel config, and reduced kernel size by 100kb.
14/12/14
Kernel 9.3
Added support for L01F model! first BETA tester told me that it's working!!!
For now without KNOCK CODE. as there is no official KK build from LG!
*Restored WIFI PM control by powersuspend.
*Restored good MMC wake/suspend functions.
*Restored HTC ASYNC function.
*Merged fixes from Alucard to his drivers.
*Merged Sound Driver fixes.
*Merged NET fixes.
*Merged SCHED fixes.
This is the same 9.2.1 BETA for D802 and L01F just with new number :)
Any way it's working good, and now less power draining as was before 9.2 but without SOD bug.
I have purged all pre 9.2 builds from storage, they all where infected by SOD bug. so no point to hold them stored.
It's Crismas soon, and my piggy saving box is dry empty long time now :(
Show some love for dev :)
Have fun with new build. it's marked as STABLE same as 9.2
Reaktionen: schmedie, Spaulding89, smartpr1v4t3 und 3 andere
V2.0 läuft bei mir absolut flüssig und schnell!!!
Abgesehen davon habe ich heute einen (für meine Verhältnisse) überdurchschnittlich guten Akkuverbrauch festgestellt.
Musste die letzten Besorgungen und Vorbereitungen für meinen anstehenden Ski-Urlaub vom PC auf das LG verlegen, dementsprechend viel Tapatalk und Browser, gelegentlich GMail und Whatsapp, Sync an, Helligkeit mit YAAB geregelt, H/LTE im Vodafone-Netz.
Für mich ist der aktuelle Dorimanx-Kernel eine sehr gute Mischung aus Performance und Akkuleistung. Hoffe ihr habt an diesem Kernel genau soviel Freude wie ich...
Kernel 2.1:
*Updated from 3.4.0 --> 3.4.78 from main line updates.
Many fixes to CORE,NET,USB,PWR,ARM,SOUND,RAM
*Removed WIFI wakelocks! wifi is less responsive at deepsleep but save x10 power.
*Updated LOKI patch to support new bootloaders.
*Cleaned STweaks descriptions and fixed kernel update check.
*Improved Default ondemand GOV tuning, now no more lags or stuck freq when needed so much...
*Updated Miracast driver from LG KK Source, i hope it's will work now.
*Fixed critical permissions on boot.
*Fixed unknown kernel ver for some ROMS. (i didnt see that with rayglobe 4 rom!)
Need to test:
*Miracast when WIFI is not connected to network! and do connected.
*Wifi wakelocks and connection response on deepsleep
*Battery usage
*Performance
*all sensors. (all works for me!)
*Kernel version show
*any other checks
Have Fun
http://www.dorimanx.com/LG/D802/Kernel-Dorimanx-V2.1-[00-25]-[02-02]-LG-D802-PWR-CORE.zip
Läuft absolut perfekt auf Flex ROM 1.2.0 von Letschky.
Danke für den Thread
Ich bin froh dass es Dorimax gibt ;)
Als Hell seinen Support für seinen Kernel eingestellt war ich schon traurig, aber bin hier sehr zufrieden.
Reaktionen: vietnam und stöbener
Folgendes vlt kann mir jemand helfen ;)
Erstmal das Problem, auf meiner Arbeit darf ich KEIN Handy haben also ab in das Handy im Spinnt da habe ich ein sehr sehr sehr schlechten empfang.
So Ich habe immer den hell kernel benutzt troz schlechtem empfang hatt ich immer ein wunderschöne battery life Max 1% verbrauch in 2:30 Std ( dann ist pause )
Seid gestern benutzte ich diesen Kernel HIER Dorimanx 2.1 und schon gehen die probleme los....
Battery Drain in 2:30 Std 20%
Wie kommt das ???, muss ich bzw kann ich vieleicht irgendwas noch im Kernel einstellen das ich NICHT so ein Drain habe. da es ja 100% am kernel liegt.
Jetzt fragen sich wieso benutzt du nicht weiter den Hell Kernel : Antwort wird LEIDER nicht weiter dran gearbeitet. Also hat jemand nen Tip für mich ???
Kurz noch ne Info :
Hell Kernel Arbeitstag max 5% Drain
Dorimanx 2.1 Kernel ganze 50% Drain
Probiere mal bitte V2.0
Irgendwie wird mein Handy bei V2.1 ziemlich heiß. Kanns aber noch nicht bestätigen bin gerade wieder auf Version 2.0 zurück und teste.
Keine Probleme mit 2.1.
Dürfte mit der 2.1 wirkliche Probleme geben mit dem Batterie Verbrauch und dann wird das Handy auch ziemlich warm bei einigen. Link XDA
Mit 2.0 wurde es nicht mehr ganz so heiß aber noch immer ziemlich warm.
Bin jetzt mal zurück auf Stock und die Cloudy Flex läuft trotzdem flüssig ;)
Von dem her warte ich erstmal ab.
2.2 ist online...
Reaktionen: andi2398
Oh Mann. Kannte die Kernels vom Galaxy2. War trotzdem bei den ersten D802 Versionen noch dabei. Fand den Kernel auch ganz nett, bis ich testhalber wieder zurück zum StockMOD Kernel bin, der mir im Vergleich eine deutlich längere Laufzeit beschert hat.
Jetzt habe ich die 2.2 Version von dorimanx getestet, was mir meine SU Konfig total zerschossen hat. Sehr ärgerlich. Und imho macht dorimanx hier auch wieder die selben Fehler wie früher: scheinbar wahllos irgendwelchen Code einbauen. Und mehr, und mehr. Der Kernel ist in den letzten Wochen um 2MB dicker geworden. Was zur Hölle? Schlank ist anders.
Bleibe jetzt definitiv beim StockMOD. Laufzeit, Konfiguration und Performance sind in meinen Augen perfekt.
Reaktionen: stöbener
Gut zu wissen, hab da noch gar nicht wirklich drauf geachtet. Hab 2.2 noch nicht getestet... Welche stock-mod Version benutzt du denn? 3.0 oder einen von den test-kerneln?
Ich glaube Dori geht es nicht so sehr um die Laufzeit. Er probiert einfach das meiste aus dem Handy heraus zu holen. Das es da auch Fehler gibt ist normal. Wird sich schon einarbeiten. Aber das kann ja zum Glück jeder für sich entscheiden worauf er Wert legt, Leistung oder Batterie. Mit der Zeit wahrscheinlich beides. Und es gibt ja auch noch die "flashsüchtigen" die alles ausprobieren müssen.
Vorallem was Dorimanx teilweise von sich gibt, ist mehr als lächerlich...
Die Versionen 1.7-1.9 waren doch alle irgendwie broken.
Random screen wakeups ohne was zu machen
Wifi ging bei einigen nicht oder nur schwerwiegend
Warum in aller Welt wird SuperSU nachgeflasht und somit die config zestört? Sinn?
Keine ahnung was noch alles
Aber warum sucht er sich nicht einfach Tester für die einzelenen Modelle? Er sagt immer, er testet die builds ja vorher, aber er besitzt ja nur das D802, was ist mit den anderen Modellen? Ich würde mir da doch im Thread nen paar tester suchen, durch nen kleinen aufruf und dann die builds ausgiebig testern. Nur was da im moment los ist, ist es für mich eher ein "nightly kernel", er bringt jeden Tag nen update und wir user dürfen HOFFEN, dass alles funktioniert.
Ich mein OK, die features sind nett, aber...naja.
Ich als Dev würde mir da nen paar tage zeit nehmen und gescheit testen (mit testern) und dann nach nen paar Tagen ein richtiges release machen anstatt diese "nightly" variante.
Ich respektiere seine Arbeit, da ich von Android development null ahnung habe, aber ich finde man sollte schon gewähren können, dass der Kernel auch läuft, immerhin ist das so der einzige Kernel für stock :D
3.0. Keine Lust auf Beta. ;)
Ich hatte auch schon Hells Kernel getestet. Aber, wie gesagt, der StockMOD funzt bei mir am besten. Und das ohne Updates seit Monaten.
Zitiere mich mal selbst ;)
Lag glaube ich an meinen kompletten System am Handy.
Habe die Rom neu geflasht nun ist alles normal mit Dori 2.0
Diese wakelocks...
@kewkie
Könntest du bitte auch einen SS mit den wakelocks und stock kernel posten?
Ich hab mich die letzen Tage fleißig eingelesen in Sachen Custom Kernels und würde den Dorimanx sehr gerne ausprobrieren.
Das einzige was ich noch nicht rausgefunden habe: sollte ich probleme haben, oder doch stock bevorzugen, wie komme ich wieder auf den Stock Kernel zurück?
Reicht ein Nandroid Backup einzuspielen?
Die Custom Rom (Cloudy Flex) neu flashen?
Wäre sehr über eine hilfreiche antwort dankbar, denn vorher trau ich mich an den Prozess lieber mal nicht ran :scared:
Das kannst du beides machen. Aud der Kernel downloadseite ist ganz unten der default kernel aus der 10f rom. Den kannst du auch flashen.
Reaktionen: findnix007
