[KERNEL] STOCK Lollipop - Xceed™
  • 6 Antworten
reflex
reflex
Stamm-User
202
Wie immer gilt: Flashen auf eigene Gefahr!, vorher Backup machen.
Wer wieder zurück zum Stock kernel möchte der findet hier die entsprechenden Kernel
Stock-Kernel-LP 5.0.2-D802 für 30a,30b,30d,30e (flashen über recovery)
Xceed™ Custom Kernel, Kernel for the LG G2
[KERNEL] Xceed™ [Synapse][BUMPED][D802][KK|… | LG G2 | XDA Forums
Short Feature list:
(Full feature list including Developmental Goals are on Github)
Basic Governors(I won't add Ripoffs, Ondemand is in continuous development to give you a balance between savings and performance)
Built using my own GCC 4.8.x Toolchain(yeah its not 4.9.x blah blah, I have a GCC 4.9.x build and so far testing the outputs of both Toolchains 4.8.5 yielded better performance and results..the toolchain build also has "some" of my magic..and toolchain is maintained regularly with all parts being updated constantly) built across the standards of Google's own Toolchain..
Simple and no fancy stuff..(more does not guarantee it's better)
Uses a simple free and user friendly application called Synapse by @AndreiLux for configuration purposes(slightly adding more functionality)
A few Notes:
Be advised that this kernel is best used "As is" i do want to prohibit the use of scripts that they say "enhances performance and battery" just use the kernel as it is..everything is managed automatically by the kernel and rest assured continuous innovations are en-route.
Compatibility list:
According to testers/users feedback the Kernel works on the FOLLOWING ROMS(tested)
Stock Kitkat ROMs
Stock Kitkat ported ROMS
Download:
Changelog:
05.05.2015 D802-LP-prod-bld2
- Housekeeping
- Rework OC to be more battery and performance friendly
Download D802-LP-prod-bld2.zip XceedXcelerate from SourceForge.net
Reaktionen: chika
Hast ihn probiert?Ich hatte den Vorgänger einen Tag drauf.Hatte ständig Reboots.
hab ihn seit 2 Stunden drauf, bis jetzt alles ok. In der jetzigen Version sollen die reboots gefixt sein.
so kleines Fazit.
Läuft bis jetzt schön smooth und Akkuschonend. Kein Absturz. Auch springt die CPU nicht mehr bei jeder Aktion auf 100% hoch, wie beim Stock Kernel.
P.s. Inzwischen gibts ja wieder einen neuen Kernel namens RevKernel :laugh:
Hab das neueste build 4 drauf von gestern. Läuft stabil, alles weich und smooth -super! Und VPN geht auch endlich.
Ist dieser Kernel mit der Cloudy G2 3.3 kompatibel? Also hat jemand diese Kombination bereits getestet und kann was berichten?
Leider schmiert der Dorimanx-Kernel in Verbindung mit der Cloudy G2 in regelmäßigen Abständen ab, aus welchem Grund auch immer.
@Julix3:
Deine Frage ist zwar schon relativ lange her, aber mit der Cloudy G2 3.3 ist der Kernel NICHT kompatibel!
Nach dem Flashen erscheint während des Bootvorgangs die Meldung "Security Error" und das Gerät schaltet sich aus.
Julian
Reaktionen: TheCritter
reflex
reflex
reflex
DaBeat0
Fritz Brause
barracuda79
barracuda79
