[Kernel] für ICS 4.0.3/4.0.4
  • 467 Antworten
Welcher Kernel läuft bei euch
  • Umfrageteilnehmer
    91
Aktualisiert, 3.0.x Custom Kernel !!
  • [KERNEL]*Matr1x* with BLN and voodoo v13.0 | ICS - 4.0.3
  • [KERNEL][22 DEC] GLaDOS V2.3
  • [KERNEL] [Testing 4.1.7] [12/22] Lucid Nexus, pre/post-2.3.3-voodoo-colors
-Voodoo Sound
-CustomVoltage mod
-Removed 65fps
because it causes colors to washout after turning off and on the screen the first time after boot. I've been trying to figure out what was causing the colors to washout for awhile, finally figured it out. If you use another kernel let the devs know about this bug.
-Pre-2.3.2(blue) voodoo colors, post-2.3.3(yellow) colors coming soon
No need for voodoo control app for pre-2.3.2 colors but if you install it wake sure to choose profile V1
-BLD
-BLN. defaults 60 mins of blinking, 650ms intervals (use NStools to enable)
-Touch wake
-Increase SDcard read ahead to 1024
-Wifi tweak
-3.0.8 linux kernel base
-1100 Mhz overclocked
-Undervolted, but not too much too cause freezes
-EXT4 mount optimization
-GPU fix, can see difference on Quadrant benchmark (planets 56fps)
-Insecure boot.img, can "adb remount"
-Init.d script support
-Disable stock recovery from flashing over CWR, may also depend on bootloader though.
All mods (bln, bld, touch wake) come disabled use NStools to enable
  • [KERNEL][24 DEC] GLaDOS V2.4
Features:
  • Based on stock Android kernel 3.0.8 IML74K
  • CPUfreq governor 'lazy'
  • Live OC version 1
  • Custom Voltage version 1
  • Battery Life eXtender (BLX) version 1
  • Power saving state DEEP IDLE version 2
  • Touch Wake version 1
  • Backlight Dimmer (BLD) version 3
  • Backlight Notification (BLN) version 9
  • Brain Fuck Scheduler (BFS) version 0.357
  • SLQB memory allocator
  • Voodoo Color version 2
  • Voodoo Sound version 10
  • CIFS
  • TUN
  • Bigmem (+20 MB more available RAM)
Aktualisiert, 3.0.x Custom Kernel !!:flapper:
  • [Kernel]Netarchy Nexus, Codename: Yerba Mate(ICS) Testing: 1.0 (27-Dec-2011)
Current Change List vs the stock 3.0.8 kernel:
- Overclocking up to 1.4ghz enabled *overclocking not active by default, use a tool such as SetCPU or CM7's cpu performance settings to overclock* (Remember kids, not all phones tolerate overclocking equally)
- Voodoo Sound driver - Courtesy of Project Voodoo
- Voodoo Color - Courtesy of Project Voodoo
- CIFS support
- TUN support
- NFS support
- Updated kernel base (Currently 3.0.14)
- Cpu policy fix to avoid crashes with SetCPU and screen off profiles (Courtesy of work by coolbho3000)
- EXT4 remount tweak
- BLN - Courtesy of work by Akent, Neldar, and Morfic
- Custom Voltage Interface - Courtesy of Ezekeel
  • [Kernel 3.x] For ICS OTA 12/26 von eugene
Features:
~ Updated Kernel Version to 3.x
~ OTA ICS Compatible
~ ro.secure=0 ( So you can push file's via adb )
~ Voodoo Sound
~ Voodoo Color
~ Added BLD
~ Added BLN
~ Overclocked to 1.3Ghz
~ default Screen Settings ( No Green flicker unless you use the voodoo app )
~ Touch-wake added, but not fully tested nor confirmed working by me just yet.
~ Added Deep Idle
~ Added BT Sleep
~ Added smartass / smartassV2 /
~ When using NSTools, min cpu police is at 200MHz, however if you use SetCPU, you can get this down to 100Mhz
~ Voltage changes... yet to confirm if it use more battery power or less.
  • [KERNEL][27 DEC] GLaDOS V2.5
Features:
  • Live OC version 1
  • CIFS
  • TUN
Aktualisiert, 3.0.x Custom Kernel !!:smile:
  • [Kernel 3.1.6] ICS OTA 12/27 von eugene
Features:
~ Updated Kernel Version to 3.1.6
~ ro.secure=0 ( So you can push via adb )
~ Voodoo Sound
~ Voodoo Color
~ Added BLD
~ Added BLN
~ default Screen Settings ( No Green flicker unless you use the voodoo )
~ Added Deep Idle
~ Added BT Sleep
~ When using NSTools, min police is at 200MHz, however if you use SetCPU, you can get this down to 100Mhz
~ Added Bigmem
  • [Kernel]Netarchy Nexus, Codename: Yerba Mate(ICS) Testing: 1.0.1 (27-Dec-2011)
- CIFS support
- TUN support
- NFS support
- Deep Idle - Courtesy of Ezekeel
- Backlight Dimmer - Courtesy of Ezekeel
Revision 1.0:
- Initial release
Revision 1.0.1:
- Adjust voltage cap to correctly max out at 1600mV, not 1350mV
- Add Ezekeel's BLD and Deep Idle patches
- Initiate construction of a new mecha-rabid naked bunny in the interests of eventual world domination
Aktualisiert, 3.x.x Custom Kernel !!
  • [Kernel 3.1.6-ICUP] For ICS OTA 12/28 von eugene
Features:
**** ->>> Ice Cream Universal Product <<<-->>> ICUP Kernel Edition <<<- ****
~ Updated Kernel Version to 3.1.6-ICUP
~ Voodoo Sound
~ Voodoo Color
~ Added BLD
~ Added BLN
~ Added Deep Idle
~ Added BT Sleep
~ Added Bigmem patch
~ BLD is on by default now
~ BLN is on by Default now & Blinking is built into kernel ( Missed calls still not work, unknown if working on neldar's paid app or not? )
~ TUN is now built-in
~ CIFS is now built-in
~ Battery 100% charging fixed ( Stopped at 97% or 98% before )
~ NSTools is only primarily needed if you wish to turn things off, or wish to use Live OC
~ added dm-cache
~ kernel:sched: LOAD_FREQ (4*HZ+61) avoids loadavg
~ BFQ I/O Added, NOT DEFAULT!
~ CFQ I/O Default for stability
~ readahead edits
~ block: limit default readahead size for small devices
  • [Kernel 3.1.6-ICPU] ICS OTA 12/30
Features:
~ Voodoo Sound
~ Voodoo Color
~ Added BLD
~ Added BLN
~ Added Deep Idle
~ Added BT Sleep
~ added dm-cache
~ readahead edits
~ Fixede BLN for i9023 phone's ( Turns out I screwed up Ezekeel bln patch )
~ Added option for dev's to replace the ramdisk ( For those working on MIUI Roms )
~ ext4 edits for smoother rom
~ Changed Voltage on 1.2Ghz & 1.3GHz to stop reboots on some phones
~ increase bus side for smoother I/O
~ init.d Supported
Typical Questions Asked:
~ Switch you Mobile browser to desktop mode to download the link..
~ No I won't be adding Lazy Gov.
~ BLX patch is not needed, the charging is fixed via the battery.c file in the kernel source
~ Deep Idle stats will never show! It's not the same!!!!
~ Yes, Battery life is awesome
~ Yes, Benchmarks will be lower than the last builds.... However what little hit we took we gained in battery.
  • [Kernel 3.1.6-ICUP] For ICS OTA 12/30 ( Speedy-1 Update )
Features:
~ Voodoo Sound
~ Voodoo Color
~ Added BLD
~ Added BLN
~ Added Deep Idle
~ Added BT Sleep
~ added dm-cache
~ readahead edits
~ init.d Supported
~ Fixed a few issue causing FC for some
~ Removed Deep Idle, as it's a conflict with the didle I use.
~ Removed Live OC as you can just Overclock using SetCPU or NSTools
~ Few more ext4 edits
[Kernel 3.1.6-ICUP] For ICS OTA 12/30 ( Speedy ohne Update )
Wieder mit zum Download hinzu gefügt !!!!
Wegen der Möglichkeit LiveOC- und DeepIdle- Einstellungen in NSTools.
(Wurde aber von eugene373 bewusst rausgenommen.)
  • [Kernel] SimpleKernel 1.0 (stock kernel + backlight mods)For Nexus S i9020T/i9023 Stock ICS 4.0.3
Changes from stock:
BLN (Backlight Notifications)
BLD (Backlight Dimmer)
CIFS module
Init.d (requires busybox to work; use busybox installer from market)
Insecure (ro.secure=0)
  • [Kernel] SimpleKernel 1.0 (stock kernel + backlight mods + voodoo*)
Changes from stock:
BLD (Backlight Dimmer; default delay=30s)
CIFS module
Voodoo (*optional)
  • [Kernel 3.1.6-ICUP] { NS & NS4G } For ICS OTA 12/31 ( Speedy-2 )
Features:
~ Voodoo Sound
~ Voodoo Color
~ Added BLD
~ Added BLN
~ Added Deep Idle
~ Added BT Sleep
~ added dm-cache
~ readahead edits
~ init.d Supported
~ GPS Issue Fixed on NS4G
~ Cleaned up codec a bit
~ Dropped bus side back down, due to causing lag in some apps
~ Built for stability & Battery life across the board
Ich hoffe, dass Fragen erlaubt ist?!
Gibt es hier schon einen Kernel, mit dem man gleich rooten kann (ähnlich dem CF-Root-Kernel oder dem Semaphore-Kernel für's SGS)?
Diese Kernel (.tar-Dateien) kann man bequem über Odin flashen und hat dann ein gerootetes Phone.
Nein so einen Kernel gibt es hier nicht, kannst maximal dein ROM rooten! Kernel flashen mit Odin ist glaube nicht die beste Lösung für`s NEXUS S !!!!! Für root gibt genug Anleitungen hier im Forum !;)
Reaktionen: Elting
  • [KERNEL][01 JAN] GLaDOS V2.6
Features:
Live OC version 1
CIFS
TUN
  • [KERNEL]*Matr1x* with BLN and voodoo v13.5 *Removed due to issues* | ICS - 4.0.3
v13.5 Added the 100% "battery tweak", patched up to 3.0.14, added the LagFree and InteractiveX governors, BLN app support, INIT.D support, and any Ezekeel bug fixes.
Code:
- Based on Linux kernel version 3.0.14- OC to 1.46 Ghz- Voodoo sound and color (Thanks to supercurio)- BLN (Thanks to neldar)- BFS (Thanks to Con Kolivas) + -ck tweaks- SLQB memory allocator- Deadline I/O Scheduler- additional governors (Smartassv2, Lazy, Minmax, Lagfree, InteractiveX)- Stochastic Fair Blue (internet packet queue management algorithm)- CIFS, TUN, NFS- INIT.D
  • [Kernel]Netarchy Nexus, Codename: Yerba Mate(ICS) Testing: 1.0.2 (2-Jan-2011)
- CIFS support
- TUN support
- NFS support
- Backlight Dimmer - Courtesy of Ezekeel​
die v13.5 steht nun wieder zum Download zur Verfügung.
Ich gehörte leider zu denen, die sich eine blutige Nase geholt hatten,
bevor mathkid, die defekte zip vom Netz genommen hatte.
Bisher läuft die 13.5 fehlerfrei.
upps und schon ist die zip wieder wech.
Das geht seit Stunden so, er lädt ne zip hoch, es wird eifrig geflasht,
es kommen Feedbacks zu Fehlern und er nimmt die zip wieder vom Netz.
Sehr aufregend das Ganze
:razz:
Ist wieder da ! hatte zum Glück noch mal probiert :thumbup:
74819
Firetime
Firetime
Müllstein
  • Müllstein
5 6 7
Firetime
Firetime
