[Kernel] für ICS 4.0.3/4.0.4
  • 467 Antworten
Welcher Kernel läuft bei euch
  • Umfrageteilnehmer
    91
Es sind neue Kernel von TRINITY verfügbar auf "DERKERNEL.COM" - Crespo - Test Kernel - 50HZ und 56HZ (Sparen an Batterie, weil weniger Frames erzeugt werden)
[KERNEL] [26 APR] v1.7.2 and GamerEdition RcrdBrt's INK kernel
v 1.7.2 --------> merged 9020 and 9023 configs to have a single kernel that works on both again. removed DEEP IDLE due to instabilities with my tweaks, added code optimizations and applied a thought to KSM (DaXmax's comments were postive in my test build so I kept it). removed ondemand for the moment and added the famous steve.garon's tweaked conservative gov as default
v 1.7.1 --------> test build
v 1.7.0 --------> test build
[KERNEL] [27 APR] v1.8.7 and GamerEdition RcrdBrt's INK kernel
v 1.8.7 --------> added tweaked lazy as default gov, patched physical to virt translations at runtime, removed some other debug shit, updated linaro toolchains to this month build for better performance (released today), various other improvements
v 1.8___1.8.6 ----> test builds
Aktualisiert, 3.x.x Custom Kernel !!:flapper: :thumbup:
  • [KERNEL] [27 APR] v1.8.7 and GamerEditionV2 RcrdBrt's INK kernel
Changelog
v 1.8.7 -------->
GamerEdition -----> do not expect battery life from this, it's a special verison meant to gamers, 72 Hz screen and tweaked lazy governor (default gov)
Changelog/features for v0.8 "Matt´s Kernel" (29/04/2012):
Stock Display Freq
Added BLD & BLN
block: limit default readahead size for small devices
BLD Enabled (3000ms)
BLN Enabled (I need test)
KSM tweaked
Added modified liblights for BLN
  • >>NEU<< [KERNEL][3.0.30] Matt's kernel v0.8 - 29/04/2012 >>NEU<<
Changelog/features for v0.8 (29/04/2012):
  • Stock Display Freq
  • Added BLD & BLN
  • block: limit default readahead size for small devices
  • BLD Enabled (3000ms)
  • BLN Enabled (I need test)
  • KSM tweaked
  • Added modified liblights for BLN
Der ursprüngliche Beitrag von 13:25 Uhr wurde um 13:45 Uhr ergänzt:
  • CM9 v7.0 default kernel by KalimochoAz
[ICS] AIR Kernel Weekly Version for NexusS 3G and 4G
Air Kernel Weekly Version
※05032012 (GMT +9:00 / KST)
Aktualisiere heute abend !!! Da bin ich wieder daheim.:thumbsup:
Probiere gerade mal den Kernel aus :D
  • [KERNEL] Air Kernel v4.0 Stable and Weekly Builds for ICS
Change Log :
Weekly Builds05032012 (GMT +9:00 / KST)
-Updated to Linux Kernel 3.0.30
-Changed Linaro GCC 4.6 (gcc version 4.6.4)
-Changed SLQB Memory Allocator
-Changed some kernel debugs
-RAM : 398MB
Reaktionen: p1312k und wiesi_at
Du kannst ja mal Rückmeldung geben. Bin schon ne ganze Weile auf 4.0 und würde mal wieder updaten wollen ;-)
Wäre wirklich mal Interessant Adi, gebe mal bitte Info
Hab nur ich das Problem, dass beim weekly Air-Kernel das BLN nicht funzt. Hab den Kernel sauber installiert und BLN mit NSTools aktiviert.
Welchr Kernel würde sonst gut zu Miui v4 passen. Er sollte eine gute Akkulaufzeit haben und er soll auch noch Voodoo können.
Gesendet von meinem Nexus S mit der Android-Hilfe.de App
[KERNEL][04 APR] GLaDOS V2.11
oder
Trinity NS kernel TEUV-ICS -CM9-230312+CM9
t11 http://goo.gl/1y0YC
t12 http://goo.gl/zxg4T
Reaktionen: amo66
Info :D
Also Bugs bisher kaum feststellbar (Beim Overclock auf 1200mhz bekomme ich mit dem AIR Kernel immer! reboots, aber das hat wahrscheinlich was mit den Spannungen zu tun. Seitdem immer auf 1000mhz)
BLN funktioniert und seit dem dem Kernel gestern online war hab ich nur 23% Akku verloren mit 2g immer an ;)
Also ganz okay soweit :D
Neuer INK und Matr1x sind online :)
  • [KERNEL]*Matr1x* with BLN and voodoo v19.5 | ICS - 4.0.3/4.0.4
Change Log :
v19.5
-Updated kernel base to 3.0.30
-fixed the ondemand sampling rate issue
-added CM9 wifi support
-and added some performance tweaks
  • [KERNEL] [05 MAY] v2.2 and GamerEditionV2 RcrdBrt's INK kernel
Change Log :
v 2.2
removed noop, added tweaked deadline. Ondemand is now the default gov. Added something missed in the previous config versions to solve stability issues. Added CM9 modules (wifi) support. Updated cleaner.sh with new paths too. Other code tweaks.
Deep idle still out from my mainline.
Reaktionen: Adinoid
emoved noop
Ich würde eher sagen removed. ;)
  • [KERNEL] [05 MAY] v2.2 and GamerEditionV3 RcrdBrt's INK kernel
Change Log :
GamerEdition
